Joysticks
SERIES 67C
Hall Effect Joystick with Integrated
Pushbutton & Optical Encoder
FEATURES
• Proportional joystick, pushbutton & optical
encoder functions from a single shaft
• Analog joystick outputs are proportional to
angle of shaft deflection
• Long life, high reliability
• Choices of cable length and termination
• Customized solutions available
APPLICATIONS
• Global positioning / Driver
information systems
• Entertainment equipment
• Medical equipment controls
• Radio control belly boxes
• Robotics
• Aerospace
• Avionics
• Security camera controls
DIMENSIONS in inches
Joysticks
87654321
MATING CONNECTOR AMP P/N 188275-8 OR EQUIVALENT
JOYSTICK OUTPUT WAVEFORM
Y+
X-
CODE REPEATS EVERY 4 POSITIONS
20 POSITIONS PER REVOLUTION
X+
Y-
OUTPUT SHOWN IS TYPCIAL FOR VDD = 5.00V AND NOT NECESSARILY TO SCALE
BEHAVIOR IS SHOWN FOR X-AXIS AS EXAMPLE
BEHAVIOR OF Y-AXIS IS SAME AS X-AXIS
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
Joysticks
SPECIFICATIONS
General Electrical Specifications
Operating Voltage on Pin 6 (VDD): 5.0 ±
0.25V
Absolute Maximum Voltage* on Pin 6
(VDD): -0.3 V min, 6.5 V max.
Operating Current: 8 mA typ., 12 mA, max.
Joystick Electrical and Mechanical
Ratings
Sensing Method: Hall effect, proportional
to angle of deflection
Output Voltage (Pins 7 & 8): Analog (Ratiometric to Operating Voltage)
Output at Center Position: 50% VDD
Output at Full Travel:
10% VDD (for X-, Y- directions)
90% VDD (for X+, Y+ directions)
Output Tolerance: ± 2% VDD (at Center
and at Full Travel)
Output Current: 200 µA, max.
Angle of Throw: 6.5° + 2° / -1° in main
directions; 9.0° ± 0.1° in diagonals
Life: 500,000 actuations in each of the four
main directions
Pushbutton Electrical and
Mechanical Ratings
Joysticks
Rating: 10 mA at 5 Vdc resistive
Absolute Maximum Voltage* on Pins 2 &
3: 6.0 V
Contact Resistance: less than 10 ohms
Life: 1 million actuations minimum
Contact Bounce: < 4 mS make,
很抱歉,暂时无法提供与“67C00-8-M-040C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+974.5357225+126.64341
