Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product.
Joysticks
SERIES 67C
Hall Effect Joystick with Integrated
Pushbutton & Optical Encoder
FEATURES
• Proportional joystick, pushbutton & optical
encoder functions from a single shaft
• Analog joystick outputs are proportional to
angle of shaft deflection
• Long life, high reliability
• Choices of cable length and termination
• Customized solutions available
APPLICATIONS
• Global positioning / Driver
information systems
• Entertainment equipment
• Medical equipment controls
• Radio control belly boxes
• Robotics
• Aerospace
• Avionics
• Security camera controls
DIMENSIONS in inches
Joysticks
87654321
MATING CONNECTOR AMP P/N 188275-8 OR EQUIVALENT
JOYSTICK OUTPUT WAVEFORM
Y+
X-
CODE REPEATS EVERY 4 POSITIONS
20 POSITIONS PER REVOLUTION
X+
Y-
OUTPUT SHOWN IS TYPCIAL FOR VDD = 5.00V AND NOT NECESSARILY TO SCALE
BEHAVIOR IS SHOWN FOR X-AXIS AS EXAMPLE
BEHAVIOR OF Y-AXIS IS SAME AS X-AXIS
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
Joysticks
SPECIFICATIONS
General Electrical Specifications
Operating Voltage on Pin 6 (VDD): 5.0 ±
0.25V
Absolute Maximum Voltage* on Pin 6
(VDD): -0.3 V min, 6.5 V max.
Operating Current: 8 mA typ., 12 mA, max.
Joystick Electrical and Mechanical
Ratings
Sensing Method: Hall effect, proportional
to angle of deflection
Output Voltage (Pins 7 & 8): Analog (Ratiometric to Operating Voltage)
Output at Center Position: 50% VDD
Output at Full Travel:
10% VDD (for X-, Y- directions)
90% VDD (for X+, Y+ directions)
Output Tolerance: ± 2% VDD (at Center
and at Full Travel)
Output Current: 200 µA, max.
Angle of Throw: 6.5° + 2° / -1° in main
directions; 9.0° ± 0.1° in diagonals
Life: 500,000 actuations in each of the four
main directions
Pushbutton Electrical and
Mechanical Ratings
Joysticks
Rating: 10 mA at 5 Vdc resistive
Absolute Maximum Voltage* on Pins 2 &
3: 6.0 V
Contact Resistance: less than 10 ohms
Life: 1 million actuations minimum
Contact Bounce: < 4 mS make,
很抱歉,暂时无法提供与“67C00-8-M-P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+953.3400225+123.69508
- 国内价格
- 1+1736.88840
- 200+693.03600
- 500+669.87000
