77P36-01-1-05N
77P36-01-1-05N
    GRAYHILLINC.
77P36-01-1-05N 数据手册
Single Deck Rotary Switches SERIES 77 0.5" Diameter, 200 mA 0.18" Behind Panel Features • Small Size - Minimal Space Required Behind Panel • Available with Continuous Rotation or a Fixed Stop • High Stop Strength • Shaft and Panel Seal • Process Seal available • Single Deck with 1 or 2 Poles APPLICATIONS • Handheld Radios • Handheld Medical Devices • Night Vision Products • Laser Aiming Devices DIMENSIONS in inches [and millimeters] .625 [ 15,88 ] Ø.500 [ 12,7 ] TERMINAL VIEW 1 POLE Rotary Switches .314 ±.008 [ 7,98 ±0,2 ] .340 ±.005 [ 8,64 ±0,12 ] .250 ±.005 [ 6,35 ±0,12 ] Ø.326 [ 8,28 ] Ø.200 ±.010 [ 5,08 ±0,25 ] CIRCLE OF TERMINAL CENTERS .250 ±.005 [ 6,35 ±0,12 ] Ø.125 ±.001 [ 3,18 ±0,02 ] Ø.200 ±.004 [ 5,08 ±0,1 ] 18° TERMINAL 1 HOUSING FLAT 18° SHAFT FLAT POS.1 .109 ±.010 [ 2,77 ±0,25 ] .375 [ 9,53 ] REF .094 ±.005 [ 2,39 ±0,12 ] Unless otherwise specified, tolerances are ± .015 inch and ± 3 degrees RECOMMENDED PANEL CUT-OUT .066 ±.010 [ 1,68 ±0,25 ] .180 [ 4,57 ] 3/8-32 UNEF-2A THREAD [ +.005 -.000 +0,12 -0,00 9,53 ] .072 [ 1,83 ] Ø.200 [ 5,08 ] 36° POSITI0N 1 +.003 -.000 +0,07 8,76 -0,00 .345 [ COMMON 2 TERMINAL 1 TERMINAL 1 TERMINAL 1 Recommended Mounting Torque: Tighten mounting hex nut to 12 in-lb (15 in-lb max). Before applying torque, rotation of the switch housing must be constrained by the housing flat via the "Recommended Panel Cut-Out" or similar method. Constraining by PCB or anything soldered to the terminals will result in damage to the switch ] 36° 11X Ø .024 ±.004 [ 0,61 ±0,1 ] Ø.008 [0,2] * ] [ TERMINAL VIEW 2 POLE 2 POLE LAYOUT Ø.200 [ 5,08 ] +.003 -.002 +0,07 0,38 -0,05 11X Ø .015 COMMON TERMINAL RECOMMENDED PCB LAYOUT (VIEWED FROM SWITCH SIDE OF PCB) 1 POLE LAYOUT Ø.375 10X 36° 12X Ø .024 ±.004 [ 0,61 ±0,1 ] Ø.008 [0,2] * .072 ±.005 [ 1,83 ±0,12 ] COMMON 1 12X Ø .015 [ *CUSTOMER TO ESTABLISH PCB DATUMS FOR HOLE PATTERN PLACEMENT +.003 -.002 +0,07 -0,05 0,38 ] Grayhill part number and date code marked on label. Customer part number marked on request. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Series 50 Series 75 Series 77 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Single Deck Rotary Switches Rated Loads Switches are rated to make and break the following loads: Environment Condition Lamp Load Inductive Load (140mH) Resistive Load Cycles Milliamp Volts Milliamp Volts Milliamps Volts 50 28 VDC 30 28 VDC 50 12 VDC 25,000 10 28 VDC 25,000 50 28 VDC 10,000 100 28 VDC 7,500 Atmospheric Pressure Reduced Pressure (70,000 feet) 200 28 VDC 5,000 50 115 Vrms 10,000 100 28 VDC 7,500 One cycle is 360-degree rotation and a return through all switch positions to the starting position. Electrical Specifications Mechanical / Environmental Ratings Operating Temperature: -40°C to +85°C Storage Temperature: -65°C to +100°C Altitude: 70,000 feet Rotational Torque: 3 in-oz min. to 7 in-oz max Stop Strength: 7.5 inch pounds min Withstanding Shaft Push Force: 100 pounds Weight: 4.7 grams with hardware 3.9 grams without hardware Vibration: MIL-DTL-3786, MIL-STD-202, method 204, condition "B" Shock: MIL-DTL-3786, Medium impact per MIL-STD-202, Method 213. Moisture Resistance: MIL-DTL-3786, MILSTD-202, Method 106 Salt Spray: MIL-DTL-3786, MIL-STD-202, method 101, condition "B" Explosion Proof: MIL-DTL-3786, MIL-STD 202, method 109 Immersion: With shaft operation – Shaft and panel seal withstands water pressure of 15 psi minimum per MIL-DTL-3786 (Equivalent to 33ft [10m] immersion for 30 minutes). Without shaft operation - Shaft and panel sealed to withstand 74ft [22m] immersion for 2 hours, MIL-DTL-810G Method 512.5. Sand and Dust: MIL-DTL-3786, MIL-STD202 Method 110 Flux Seal (Process Sealed Versions): Level 1 & 2 per MIL-DTL-3786. Materials and Finishes Switch Base: Diallyl Phthalate per MIL-M-14 Bushing: Zinc alloy, tin zinc plating Detent Rotor: Nylon Detent Balls: Steel, nickel-plated Contact Spring: Tinned music wire Detent Spring: Stainless steel Shaft: Stainless steel Shaft Seal: Ethylene Propylene Panel Seal: Silicone Rotor Contact: Silver cad-oxide, gold-plated Terminals and Common: Brass, gold plate .00002" minimum thickness over silver plate .0003" minimum. Mounting Hardware: One mounting nut .089" thick by .433" across flats and one external tooth lockwasher supplied with each switch. Mounting nut is brass, nickel plated and lockwasher is stainless steel. Additional Characteristics Contact Type: Non-shorting, wiping contacts Terminals: Switches are provided with the full circle of terminals regardless of the number of active positions. Contact Grayhill if the life limiting criteria is more critical than those listed, if the required cycles of operation are greater than those listed, if a larger make and break current is required than the one listed for the desired number of cycles, or if elevated temperatures or reduced pressures are part of the operating environment. ORDERING INFORMATION 77SPT36-01-1-10N-F Series 77 S = Shaft & Panel Sealed, leave blank for no shaft & panel seal P = PC Terminals T = Process Seal, Leave blank for no process seal Angle of throw: 36 = 36° Number of Decks: 01 Only Stop arrangement: Needed only with 1 pole switches with maximum positions. Leave blank for continuous rotation; add F for fixed stop. Contacts: N = Non-shorting Positions per pole: 02 up to 10 positions (1 pole), 02 up to 05 positions (2 poles) Poles per deck: 1 or 2 For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Rotary Switches Low Level Circuit Rating: 10 milliamperes, 30 millivolts DC or Peak AC open-circuit voltage, 25,000 cycles Contact Resistance: 50 milliohms max (15 milliohms initially). 100 milliohms max low level. Insulation Resistance: 50,000 Mohms initially (10,000 Mohms after life) at 100 VDC Voltage Breakdown: 600 Vac initially, 250 Vac after life
77P36-01-1-05N 价格&库存
很抱歉,暂时无法提供与“77P36-01-1-05N”相匹配的价格&库存,您可以联系我们找货
