39-351 RED
39-351 RED
    GRAYHILLINC.
39-351 RED 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Butt Contact Pushbutton Switches SERIES 39 SPST, 150 mA to 1/2 Amp FEATURES • Requires an Absolute Minimum of Space • Molded-In Terminals in SPST–N.O. • Solder Lug Terminals DIMENSIONS in inches (and millimeters) Economy Version Normally Open–SPST Economy and Standard Version 39-1 39-3 39-601* .110 ± .005 (2,79 ± 0,13) DIA. .036 ±.005 (0,91 ± 0,13) .068 ±.005 (1,73 ± 0,13) B E.I.A. DATE CODE LABEL* .615 (15,62) REF. C D .250 + .010/ –.005 (6,35 + 0,25/ – 0,13) DIAMETER A = .175 + .025/ –.020 (4,45 + 0,64/ – 0,51) *Label increases B = .125 ± . 010 (3,18 ± 0,25) nominal diameter C = .215 ± .015 (5,46 ± 0,38) to .255 (6,48) D = .100 ± .020 (2,54 ± 0,51) 39-601 RED 39-601 BLK Actuating Total Force (oz.) Travel .035 ± .015 4 +4 -2 (0,89 ± 0,38) Action A H H = HEX MTG NUT .063 ± .010 (1,59 ± 0,25) THICK .219 ± .010 (5,56 ± 0,25) ACROSS FLATS At 5 Vdc At 20 Vdc 1,000,000 150 mA 20 mA Momentary Button Color Red Black Mtg. Hole 11/64" (4,37) DIA. Standard Operations at Rated Load Electrical Ratings At 115 Vac At 220 Vac 1,000,000 1 /2 Amp Res. 1/4 Amp Res. Momentary Button Color 39-1 39-3 Red Black Actuating Force (oz.) Total Travel .035 ± .015 (0,89 ± 0,38) Action Complete Part Number Mtg. Hole 4 +4 –2 11/64" (4,37) DIA. Normally Open–SPST with Sealed Bushing and Button 39-351* .110– .005 DIA. (2,79 – 0,13) A = .175 +.025/ .020 (4,45 +0,64/ 0,51) B = .125 – .010 (3,18 – 0,25) C = .250 –.015 (6,35 – 0,38) D = .100 – .020 (1,54 – 0,51) E.I.A. DATE CODE #8-40 UNS-2A THREAD A O B C HEX MTG. NUT .0625 (1,59) TYP. THICK AND .218 (5,54) TYP. ACROSS FLATS .650 (16,51) REF. .068 .005 (1,73 0,13) Button Color 250,000 39-351 RED 39-351 BLK Red Black /4 Amp 1 Action Total Travel Actuating Force (oz.) Momentary .035 ± .015 (0,89 ± 0,38) 16 ± 8 E.I.A. DATE CODE LABEL* Rating at 115 Vac Resistive A B C .755 (19,18) REF. D .250 + .010/ – .005 (6,35 + 0,25/ – 0,13) DIAMETER A = .175 + .025/ –.020 (4,45 + 0,64/ – 0,51) *Label increases B = .125 .010 (3,18 0,25) nominal diameter C = .355 .015 (9,02 0,38) to .255 (6,48) D = .100 .020 (2,54 0,51) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois *Complete Part Number .110 .005 (2,79 0,13) DIA. H .036 .005 (0,91 0,13) Operations at Rated Load .072 – .005 (1,83 – 0,13) 8-40 UNS-2A THREAD H = HEX MTG NUT .063 .010 (1,60 0,25) THICK .219 .010 (5,56 0,25) ACROSS FLATS Rating at 220 Vac Resistive .036 – .005 (0,91 – 0,13) Button is O-Ring sealed internally. Normally Open–SPST with Overtravel .072 .005 (1.83 0,13) /2 Amp .068 – .005 (1,73 – 0,13) D 39-12 39-24 1 O = O RING XXXX .312 –.005 (7,92 –0,13) ACROSS FLATS Rating at 115 Vac Resistive 1 /2 Amp Action Rating at 220 Vac Resistive /4 Amp 1 Total Travel Operations at Rated Load Complete Part Number 100,000 39-12 39-24 Over Travel .130 ± .025 .015 (0,38) Momentary (3,30 ± 0,64) Min. Button Color Red Black Actuating Force (oz.) Mtg. Hole 5±3 11/64" (4,37) DIA. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton Switches 8-40 UNS-2A THREAD .072 ±.005 (1.83± 0,13) Operations *Complete at Rated Part Load Number Electrical Ratings Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Butt Contact Pushbutton Switches DIMENSIONS in inches (and millimeters) Normally Closed–SPST 39-2 .105 – .005 (2,67 – 0,13) DIA. 8-40 UNS-2A THREAD H = HEX MTG NUT .063 – .010 (1,60 – 0,25) THICK .219 – .010 (5,56 – 0,25) ACROSS FLATS .100 ±.010 (2,54 ± 0,25) .060 ± .010 (1,52 ± 0,25) Rating at 115 Vac Resistive A H B E.I.A. DATE CODE LABEL* .780 (19,81) REF. 1 Rating at 220 Vac Resistive /4 Amp Operations at Rated Load Part Number 250,000 39-2 /8 Amp 1 C D .250 +.010/ .005 (6,35 +0,25/ 0,13) DIAMETER A = .175 – .025 (4,45 –0,64) *Label increases B = .125 – . 010 (3,18 – 0,25) nominal diameter C = .390 – .010 (9,91 – 0,25) to .255 (6,48) D = .100 (2,54) MAX. Action Total Travel Actuating Force (oz.) Momentary .042 ± .010 (1,07 ± 0,25) +4 4 –2 Cap Color Black Mtg. Hole .172 (4,37) DIA. Normally Closed–SPST with Sealed Bushing and Button Pushbutton Switches 39-352* .110– .005 DIA. (2,79 – 0,13) #8-40 UNS-2A THREAD A A = .165 +.035/ .015 (4,19 +0,89/ 0,38) B = .125 – .007 (3,18 – 0,18) C = .429 –.015 (10,90 – 0,38) D = .100 (2,54) MAX. E = 10 TO 40 APPROX. H B C O-RING .819 (20,80) REF. E.I.A. DATE CODE LABEL* H = HEX MTG. NUT .0625 (1,59) TYP. THICK AND .218 (5,56) TYP. ACROSS FLATS D Rating at 115 Vac Resistive 1 /4 Amp .100 (2,54) MAX. E .312 –.005 (7,92 –0,13) ACROSS FLATS CIRCUITRY SPST N.O. SPST N.C. SPECIFICATIONS Rating Criteria Contact Resistance: 25 milliohms maximum on a new switch Voltage Breakdown: 1,000 Vac between mutually insulated parts Insulation Resistance: 1,000 megohms minimum Operating Temperature: -40°C to +85°C Mounting Torque: 2 inch-pounds *Complete Part Number Button Color 100,000 39-352 RED 39-352 BLK Red Black /8 Amp 1 Action Momentary Total Travel .042 ± .010 (0,17 ± 0,25) Actuating Force (oz.) 8 ± 4 .060 – .010 (1,52 – 0,25) *Label increases nominal diameter to .255 (6,48) Materials and Finishes SPST–N.O. WITH OVERTRAVEL Operations at Rated Load .100 – .010 (2,54 – 0,25) .250 +.010/ .005 (6,35 + 0,25/ 0,13) Button is o-ring sealed internally. Rating at 220 Vac Resistive Mounting Nut: Brass, tin zinc Housing: Aluminum, clear anodized for 39-351 and 39-352; Brass, zinc trivalent chromate-plated for others Button: Thermoset plastic Base: Thermoset plastic Shorting Bar: Fine silver for 39-2 and 39-352; brass, gold-plated over nickel plate for 39-601; fine silver, gold-plated for others Terminals: Fine silver for 39-2 and 39-352; commercial bronze with gold-plated fine silver contact surface for others Spring: Tinned music wire O-Rings: (39-351 and 39-352) Internal ring is silicone; external ring is buna ‘N’ ORDERING INFORMATION Part Number 39-1 39-2 39-3 39-12 39-24 39-351 RED 39-351 BLK 39-352 RED 39-352 BLK 39-601 RED 39-601 BLK Description N.O., Red Button N.C., Black Button N.O., Black Button N.O., Overtravel Red Button N.O., Overtravel Black Button N.O., Sealed, Red Button N.O., Sealed, Black Button N.C., Sealed, Red Button N.C., Sealed, Black Button N.O., Economy, Red Button N.O., Economy, Black Button Accessory cap may be used with all switches shown except 39-2. RECOMMENDED PANEL CUTOUT ACCESSORY Button Cap Part No. 30B1012 For use with part numbers 39-351 and 39-352. (Fasten to button with Cyanoacrylate Adhesive) Accessory Part Number Description 30B1012-5 Red Button Cap 30B1012-9 Black Button Cap 30B1012-8 White Button Cap Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Pushbutton Engineering Information Pushbutton switches are selected not only by their ratings, but also by their contact type. While nearly all rotary switches and DIP switches have wiping contacts, pushbutton switches may have either wiping or butt contacts (see internal views below). Wiping Contacts are self-cleaning and usually provide a low resistance in circuits where contact resistance is critical. However, the wiping action creates mechanical wear and conductive wear products. Butt Contacts have less wear than wiping contacts and therefore, have a longer life. They are also smaller. Butt contacts are not self-cleaning, so their contact resistance can vary from operation to operation. Snap Action switches are basically butt contact switches with a spring mechanism which provides the make and break. The mechanism controls both the operating point and the rate of operation, but adds to the wear of the switch. The rapid rate of make and break means that these switches are appropriate for high current loads. They usually have a slight wiping action and contact surfaces made of precious metals to minimize their disadvantages. Internal Views of Pushbutton Switches Wiping Contact ACTUATOR BUSHING Butt Contact Snap Action ACTUATOR ACTUATOR BUSHING BUSHING OVERSPRING INTERNAL BUTTON SHORTING BAR FIXED CONTACTS SHORTING BAR RETURN SPRING MOVABLE CONTACT RETURN SPRING FIXED CONTACTS FIXED CONTACTS Switch Terminology Actuator: The part of the switch to which an external force is applied to operate the switch. Alternate Action (Push-Push) Switch: A switch in which the operable position is maintained after the first actuation, and then disengaged with the second operation. Break-Before-Make Switch (BBM): A double throw switch in which the moving contact breaks the connection with the first circuit before making contact with the second; also called non-shorting switch. Double Throw Switch: A switch which has a normally open as well as a normally closed circuit per pole. Joystick Action Switch: (From Joystick, the control for an airplane). A lever switch which operates with momentary action in 4 directions, and is disengaged in the upright position. www.grayhill.com Make-Before-Break Switch (MBB): A double throw switch in which the contacts makes connection with the second circuit before breaking contact with the first; also called shorting switch. Maintained Contact Switch: A switch in which the actuator remains in a position until it is actuated to another position where it also remains until actuated. Example: Push-Pull Switch. Momentary Contact Switch: A switch in which the shorting bar returns from its operated position to its normal or free position when the actuating force is removed. N.O., Normally Open: Switch in which the circuit is open without actuation (with actuator in the "normal" position). Overtravel: The distance or angle between the operating position and the extreme position to which the actuator may be moved. Pole: An electrically isolated circuit within a switch; a common terminal and all the selected terminals to which it connects. Pretravel: The distance or angle through which the actuator moves from its free position to its electrical operating position. Operating Position or Point: The position of the actuator when the desired electrical action (make or break of contact) occurs. Single Throw Switch: A switch which has only one normally open or one normally closed circuit per pole. N.C., Normally Closed: Switch in which the circuit is closed without actuation (with actuator in the "normal" position). Throw: See Single Throw and Double Throw. Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Pushbutton Switch Selection Chart Circuitry* Rating (Amps at Operations 115 Vac Res.) At Rating Maximum Width*** inch (mm) Features Series Butt Contact N.O. or N.C. 5 6,000 N.O. or N.C. 1 1,000,000 N.O. 1 500,000 N.O. 1 200,000 On or Off 1 100,000 N.O. or N.C. 1 250,000 N.O. 1 1,000,000 N.O. or N.C 1 1,000,000 N.O. 1 200,000 N.O. 1 200,000 N.O. .020** 80,000 N.O. .020** 80,000 N.O. .020** 80,000 N.O. or N.C. .250 100,000 N.O. .500 1,000,000 N.O. .500 500,000 SPST N.O. .500 100,000 N.O. .500 250,000 N.C. .250 250,000 N.C. .250 100,000 N.C. .250 100,000 N.O. .150** 1,000,000 N.O. .150** 1,000,000 N.O. .150** 100,000 N.O. .020, .150** 1,000,000 N.O. .020, .150** 1,000,000 N.O. .020, .150** 1,000,000 N.O. .020, .150** 100,000 3/8 (9,53) 3/8 (9,53) 3/8 (9,53) 11/16 (17,46) 11/16 (17,46) 1/2 (12,7) 11/16 (17,46) 1+ (25,4) 11/16 (17,46) 11/16 (17,46) 5/16+ (8,13) 5/16+ (8,13) 5/16+ (8,13) 1/4 (6,35) 1/4 (6,35) 1/2 (12,7) 1/2 (12,7) 5/16 (7,94) 1/4 (6,35) 5/16 (7,94) 1/2 (12,7) 1/4 (6,35) 1/4 (6,35) 1/4 (6,35) 3/8 (9,53) 3/8 (9,53) 1/4 (6,35) 1/2 (12,7) UL Listed Momentary, Terminal Seal, (Wire Leads Optnl.) Overtravel, Terminal Seal, (Wire Leads Optnl.) Positive Feel, Overtravel, Terminal Seal, (Wire Leads Optional) Push/Pull Action (Maintained) Watertight, Terminal Seal, (Wire Leads Optnl.) Square & Round Bezels Square Bezel Panel Mount Pos. Feel, Overtravel, Square & Round Bezels Pos. Feel, Overtravel, Sq. Bezel Panel Mount Miniature, Surface Mount Miniature, Horizontal PC Mount Miniature, Vertical to PC Mount Sealed Plunger, Stackable with LEDs Miniature Overtravel, Miniature Limit Switch, (Wire Leads Optional) Overtravel, Miniature, (Wire Leads Optional) Watertight Seal, Miniature, (Wire Leads Optional) Miniature (Wire Leads Optional) Watertight Seal, Miniature, (Wire Leads Optnl.) Actuator Seal, Miniature Limit Switch (Wire Leads Optional) PC Mount, Miniature, Sealed PC Mount, Miniature, Right Angle, Cap Seal PC Mount, Miniature, Overtravel Economical Contact Plating Econ. Plating, Square Bezel Panel Mount Economical Contact Plating Actuator Seal, Overtravel, Miniature Limit Switch, (Wire Leads Optional) BBM SPDT BBM .250 .250 100,000 500,000 1/4 (6,35) 1/2 (12,7) SPST AND SPDT, Stackable w/LEDs PC Mount, 2 Circuits, Right Angle, Total Seal 32 39 .020** 80,000 5/16 (8,13) Miniature, Surface Mount 38 BBM 30 30 30 30 30 30 30 30 30 30 38 38 38 32 39 39 39 39 39 39 39 39 39 39 30 30 39 39 Wiping Contact SPST N.O. or N.C. N.O. or N.C. N.O. N.O. 3 1 .250 .4VA 6,000 100,000 100,000 40,000 13/16 (20,6) 13/16 (20,6) 1/2 (12,7) .177 (4,5) Decorator Line Momentary Action & Positive Feel Types Momentary Action & Terminal Seal Types Process Sealed, Subminiture 4000/10 4000/10 23 49 SPDT BBM or MBB BBM or MBB BBM or MBB BBM BBM BBM N.O. .250 .250 .250 .250 .250 .250 .4VA 250,000 250,000 100,000 250,000 250,000 250,000 40,000 7/16 (11,11) 1+ (25,4+) 1/2 (12,7) 11/16 (17,46) 11/16 (17,46) 1+ (25,4+) .177 (4,5) Momentary Action Square Bezel Panel Mount Watertight Seal Square & Round Bezels Alternate Action, Square & Round Bezels Alternate Action, Square Bezel Panel Mount Process Sealed, Subminiature 46 46 46 46 46 46 49 DPDT BBM or MBB BBM BBM or MBB BBM BBM BBM or MBB .250 .250 .250 .250 .250 .250 100,000 250,000 100,000 250,000 250,000 250,000 5/8 (15,88) 13/16 (20,6) 11/16 (17,46) 11/16 (17,46) 11/16 (17,46) 1+ (25,4+) Momentary Action Environmental Seal/Wire Leads Watertight Seal Square & Round Bezel & Positive Feel Types Alternate Action, Square & Round Bezels Alternate Action, Square Bezel Panel Mount 46 46 46 46 46 46 1, 3 25,000 7/8 (22,23) SPST, 1 and 3 Amp 4000/10 5, 10 25,000 7/8 (22,23) Audible Click Snap Action Contact SPST N.O. or N.C. SPDT BBM 2000/7 * BBM is Break-Before-Make (Non-Shorting). MBB is Make-Before-Break (Shorting). ** Rated for 28 Vdc and/or 5 Vdc (.150 A) and 20 Vdc (.020 A). *** Maximum width behind panel or above PC board rounded to next highest 1/16" (1,59 mm). www.grayhill.com Bulletin 1224 Rev 04/14 Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Pushbutton Options and Accessories SEALED TERMINAL AND WIRE LEAD OPTIONS OPTION -E AND -EW FEATURES • 1/4, 1/2, and 1 Amp • Limit, Overtravel, or Panel Seal • Butt or Wiping Contact • Normally Open or Normally Closed • Momentary or Push/Pull • Series 23, 30, 39 and 46 Option -EW, Potted Base & 6" Wire Leads Option -E Epoxy-Sealed Terminals SPECIFICATIONS Rating Criteria Pushbutton Switches Make and Break Current Rating: See page for standard part number Contact Resistance: 25 milliohms maximum on a new switch. Less than 4 milliohms per inch of wire for wire lead option styles. Insulation Resistance: 1,000 megohms minimum between mutually insulated parts Voltage Breakdown: 1,000 Vac minimum between mutually insulated parts Materials and Finishes Potting Sleeve (Series 39): Thermoset Plastic Wire Leads: #26AWG, (.99mm diameter) insulated Teflon, Copper stranded wire, per MlL-W-16878,Type E. Ends are stripped 0.250" (6.35) and solder dipped. For other specifications, see Page References. Standard Part Number Red Button Standard Part Number Black Button 23-1 30-1 30-15 30-17 RED 30-16 RED 30-251 RED 30-252 RED 30-32 RED 30-6 30-601 RED 39-1* –––– 39-12* 39-101 39-351 RED 39-352 RED* 39-601 RED 39-701*** 39-702*** 46-101 RED 46-102 RED 46-110 RED 46-111 RED 46-150 RED 46-151 RED 46-200 RED 46-201 RED 46-270 RED 46-271 RED 23-4 30-3 30-37 30-17 BLK 30-16 BLK 30-251 BLK 30-252 BLK 30-32 BLK 30-2 30-601 BLK 39-3* 39-2 39-24* –––– 39-351 BLK 39-352 BLK* 39-601 BLK –––– –––– 46-101 BLK 46-102 BLK 46-110 BLK 46-111 BLK 46-150 BLK 46-151 BLK 46-200 BLK 46-201 BLK 46-270 BLK 46-271 BLK Choices of Suffix -E -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -EW** -E,- EW -EW** -EW** -EW** -E, -EW -EW* -EW** -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E -E -E -E Length Behind Panel In inches (and millimeters) -EW Style Standard Switch Body & Terminals 0.665 0.592 0.679 0.958 0.958 0.632 0.645 0.867 0.605 0.592 0.315 0.490 0.455 0.650 0.350 0.529 0.315 0.800 0.510 0.890 0.890 0.890 0.890 0.957 0.957 0.921 0.921 0.957 0.957 (16,89) (15,04) (17,25) (24,33) (24,33) (16,05) (16,38) (22,02) (15,37) (15,04) (8,00) (12,45) (11,56) (16,51) (8,89) (13,44) (8,00) (20,32) (12,95) (22,61) (22,61) (22,61) (22,61) (24,31) (24,31) (23,39) (23,39) (24,31) (24,31) –––– 0.645 0.728 1.007 1.007 0.685 0.700 0.896 0.640 0.645 0.440 0.575 0.575 0.775 0.450 0.630 0.440 0.925 0.750 0.957 0.957 0.957 0.957 1.024 1.024 –––– –––– –––– –––– (16,38) (18,49) (25,58) (25,58) (17,40) (17,78) (22,76) (16,26) (16,38) (11,18) (14,61) (14,61) (19,69) (11,43) (16,00) (11,18) (23,50) (19,05) (24,31) (24,31) (24,31) (24,31) (26,01) (26,01) *Epoxy potting sleeve enlarges the diameter of the -EW style to 0.300 (7,62). **Sealed terminal (-E) option is not necessary; terminals have sealed construction. ***Natural Color Button †Adjustable from 1.214 (30,84) to 1.334 (33,88) dependent on button height, see switch pages. Pushbutton 60 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Pushbutton Options and Accessories ORDERING INFORMATION Use the Selector Charts at the beginning of the section to select a series. Use the pages listed there or referenced here to select a switch. Standard Part Number Choice of Button Color (see switch pages) (see switch pages) –––– –––– –––– –––– 30-01-01-500-XX 30-01-04-500-XX 30-05-01-502-XX 30-05-04-502-XX –––– 46-01-07-500-XX 46-01-08-500-XX 46-01-09-500-XX 46-05-05-502-XX 46-05-07-502-XX 46-05-08-502-XX 46-05-09-502-XX –––– –––– –––– –––– 30-001-A-XX 30-002-A-XX 30-015-A-XX 30-017-A-XX 30-1-1-50-XX 30-1-4-50-XX 30-5-1-52-XX 30-5-4-52-XX 30-601-A-XX 46-1-7-50-XX 46-1-8-50-XX 46-1-9-50-XX 46-5-5-52-XX 46-5-7-52-XX 46-5-8-52-XX 46-5-9-52-XX 46-102-A-XX 46-111-A-XX 46-200-A-XX 46-201-A-XX To order epoxy sealed terminals, add the suffix E to the selected part number as allowed in the chart. Example: 30-1-E. To order the epoxy-potted version with 6-inch wire leads, use the suffix -EW as allowed in the chart. Example: 39-1-EW Available From Your Local Grayhill Distributors. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Choices of Options -E, -E, -E, -E, -E, -E, -E, -E, -E, -E, -E -E -E, -E, -E -E -E, -E, -E -E -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW Length Behind Panel In inches (and millimeters) Standard Switch & Terminals 1.119 (28,42) 1.132 (28,75) 1.204 (30,58) Adjustable† 1.100 (27,94) 1.257 (31,93) 0.930 (23,62) 1.130 (28,70) 1.119 (28,42) 1.451 (36,86) 1.381 (35,08) 1.381 (35,08) 1.179 (29,95) 1.465 (37,21) 1.188 (30,18) 1.317 (33,45) 1.417 (35,99) 1.417 (35,99) 1.448 (36,78) 1.448 (36,78) -EW Style Body 1.172 (29,77) 1.167 (29,64) 1.253 (31,83) Adjustable† 1.153 (29,29) 1.310 (33,27) 0.983 (24,97) 1.183 (30,05) 1.172 (29,77) 1.518 (38,56) –––– –––– 1.246 (31,65) 1.532 (38,91) –––– –––– 1.484 (37,69) 1.484 (37,69) –––– –––– CIRCUITRY: Series 46 N.C. (YELLOW) C1 (RED) N.O. (GREEN) *Epoxy potting sleeve enlarges the diameter of the -EW style to 0.300 (7,62). **Sealed terminal (-E) option is not necessary; terminals have sealed construction. ***Natural Color Button †Adjustable from 1.214 (30,84) to 1.334 (33,88) dependent on button height, see switch pages. SPDT WIPING CONTACTS Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton 61 Pushbutton Switches Standard Part Number Without Options Choice of Button Color Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Pushbutton Options and Accessories ACCESSORIES For Pushbutton Switches Button Caps Decorative Mounting Nuts Pendant Housing Button Guard DIMENSIONS In Inches (and millimeters) .75 (19,1) ACROSS FLATS Decorative Mounting Nuts .44 (11,2) ACROSS FLATS .50 (12,7) ACROSS FLATS 30C1023-1 Pushbutton Switches .46 (11,7) DIA. .52 (13,2) DIA. Brass, nickel-plated for 1/4" (6,35) bushing. .09 (2,3) 07C1040-1 23C1024-1 .77 (19,6) DIA. Brass, nickel-plated for 5/16" (7,93) bushing. Brass, nickel-plated for 15/32" (11,9) bushing. .12 (3,1) .09 (2,3) Button Caps and Guard .89 (22,6) DIA. 30B1012 07Z1047 Thermosetting plastic (Fasten to button with cyanoacrylate adhesive) black, red or white. .19 (4,8) .09 (2,3) .34 (8,6) For use with all Series 30 and 39 switches except part number 39-101. See switch pages. .25 (6,4) DIA. 07Z4950 07Z5051 .33 (8,4) REF. Flat Cap .89 (22,6) 1.19 1.03 (30,2) (26,16) .27 (6,86) DIA. Brass, zinc trivalent chromate-plated for 15/ 32" (11,9) bushing. .41 (10,4) .59 (15,0) .08 (2,0) Housing 2.45 (62,23) .42 (10,67) Thermoplastic, black or red color. For use with Series 2000 and Series 7 switches. See switch pages. 1.00 (25,4) DIA. Remote Switching Accessories Pendant Housing and Caps 10C1015-1 1.19 (30,2) .08 (2,03) .25 (6,4) .89 (22,6) Recessed Cap 1.04 1.19 (30,2) (26,4) .48 (12,2) .48 (12,2) Application: All grayhill pushbutton switches with 15/32-32 bushings: catalog numbers 2201, 2202, 07-7, 07-8, 07-21, 07-22, 07-26, 4001, 4002, 10-9, 10-10, 10-100, 10-101, 30-16, 30-17 and 30-32. any other switch with 15/32-32 bushing if it fits housing. Material: Thermoplastic Specials: other colors available on special order. ORDERING INFORMATION: Mounting Nuts, Button Caps, and Guards Part Number Color 07C1040-1 23C1024 30C1023-1 07Z1047-1 BLK 07Z1047-2 RED 10C1015-1 30B1012-5 30B1012-8 30B1012-9 Decorative Nut Decorative Nut Decorative Nut Black Button Cap Red Button Cap Button Guard Red Cap White Cap Black Cap Pendant Housing and Caps Part Number 07Z4950 07Z4950 07Z5051 07Z5051 RED BLK RED BLK Description Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Red Flat Cap & Housing Black Flat Cap & Housing Red Rcssd Cap & Housing Black Rcssd Cap & Housing Sold only as sets of one housing and one cap. Pushbutton 62 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
39-351 RED 价格&库存
很抱歉,暂时无法提供与“39-351 RED”相匹配的价格&库存,您可以联系我们找货
39-351 RED
    39-351 RED
      • 5+199.275015+25.56103
      • 25+129.5386525+16.61594
      • 50+123.6849450+15.86508
      库存:735
      39-351 RED
