68B-425-4
68B-425-4
    GRAYHILLINC.
    YELLOW PROPORTIONAL PADDLE SWITC
68B-425-4 数据手册
Joysticks SERIES 68B Hall Effect Rocker Switch FEATURES • Ratiometric analog output • Sealed to IP67 dynamic - even during actuation • Rugged industrial design suited for outdoor use • Provides positive tactile feedback in any environment • Long operational life • Redundant output for safety • Available with 26°detent and 36° latching, friction hold, or spring return (no detent) • Choices of cable length • Choices of accent color APPLICATIONS • Dash-panel and armrest controls • Hydraulic fluid flow control • Engine speed control • Heavy duty industrial equipment • Remote control belly boxes DIMENSIONS in inches, [mm] TOP VIEW Joysticks THIS VIEW APPLIES TO 68B-XXX-0 PART NUMBERS ONLY MOUNTING PANEL OPTIONS .130 [3.30] x4 .660 [16.76] .455 [11.56] R.050 [R1.27] x8 MOUNTING PANEL RECOMMENDATIONS: R.100 [R2.54] x4 1.000 [25.4] 1.410 [35.81] 1.190 [30.23] 1. FASTENERS SHOULD BE #4 THREAD FORMING SCREWS FOR PLASTIC. 2. MOUNTING TORQUE TO BE 3-5 IN.LBS, 8 IN.LBS MAXIMUM. 3. DIAMETER OF MOUNTING HOLES IN CUSTOMER PANEL TO BE 0.130" [3.30mm]. DIAMETER OF MOUNTING HOLES IN SWITCH ARE 0.100" [2.54mm]. 4. LENGTH OF MOUNTING SCREWS TO BE: (PANEL THICKNESS) + 0.140" [3.56mm] OR LESS. 5. MINIMUM SPACING BETWEEN TWO UNITS IS 1.080" [27.43 mm] FROM CENTERLINE TO CENTERLINE. .840 [21.34] Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Joysticks BLOCK DIAGRAM & JOYSTICK OUTPUT WAVEFORM SPECIFICATIONS Electrical Specifications Joysticks Operating Voltage on Pin 1 (VDD): 5.0V ± 0.5V Absolute Maximum Voltage* on Pin 1 (VDD): -18 V min, +18 V max (t < 1 h) Operating Current: 15 mA typ., 20 mA, max. Output Voltage is Analog (Ratiometric to Operating Voltage) Output at Center Position: 50% VDD Output at Full Travel: 10% VDD or 90% VDD depending on configuration Output Voltage Tolerance: ± 3% VDD at full travel ± 5% VDD at center position Output Current: 1 mA, max. Recommended Load: 10 K Ohm pull-down resistor. Sensor Error: When a sensor error occurs, the output goes to < 4% of operating voltage (VDD ) *Exceeding the Absolute Maximum Voltage may result in permanent damage to the device. This is a stress rating only and functional operation of the device at those or any other conditions above those indicated in the operation listings of this specification is not implied. Physical & Mechanical Ratings Vibration: Random, meets MIL-STD-810G, Method 514.6, Procedure I Mechanical Shock: Meets MIL-STD 202, Method 213B Test Condition A Transit Drop: Meets MIL-STD-810G, Method 516.6, Procedure II Terminal Strength: 10 lbs. minimum, tested per MIL-STD-202, Method 211A Push-Out Force: 45 lbs. minimum Pull-Out Force: 45 lbs. minimum Paddle Impact: 0.5 lbs. weight dropped 3x ORDERING INFORMATION ACCENT COLOR 1 = Black 2 = Blue 3 = Purple 4 = Yellow 5 = Green 6 = Red from height of 0.3m Paddle Side-Load: 45 lbs. minimum Mounting Torque: 3-5 in-lbs recommended, 8 in-lbs maximum Return to Center Life: 2 million cycles minimum** Detent Life: 200,000 cycles minimum Latching Life: 200,000 cycles minimum Friction Hold Life: 200,000 cycles minimum ** One cycle is defined as full travel from the center to the +40° direction, then full travel to the -40° direction, then return to the center Environmental Ratings Seal: IP67 as mounted Altitude: Meets MIL-STD-810G, Method 500.4, Procedure I Thermal Shock: Meets MIL-STD-810G, Method 503.4, Procedure I Operating High Temperature: +85°C, Meets IEC 68-2-2, Test Aa Operating Low Temperature: -40°C, Meets IEC 68-2-1, Test Aa Storage High Temperature: +100°C, Meets IEC 68-2-2, Method Aa Storage Low Temperature: -55°C, Meets IEC 68-2-1, Method Aa Damp Heat Cycle: Meets IEC/EN 60068-2-38 Z/AD Humidity, 85/85: Meets MIL-STD 202, Method 103B, 500 hours Solar Radiation: Meets ISO 4892-2, Method A, Cycle 1, 1000 hours Chemical Resistance: Meets IEC 600682-74 Salt Fog: Meets MIL STD 810G Dielectric: Meets MIL-STD-202G, Method 301 Insulation Resistance: Meets MIL-STD202G, Method 302 Materials and Finishes Paddle: Thermoplastic with elastomer finger grip Cable Assembly: 22AWG stranded, tincoated copper wires in PVC insulation Connector Body: Thermoplastic Terminals: Nickel RoHS Compliant EMC Ratings Radiated Immunity: At 3 orientations, meets ISO11452-5 (140 V/M, 10KHz-2MHz), ANSI/ ASAE EP455 5.16 (100 V/M, 2-200MHz), ISO 11452-2 (140 V/M, 200MHz-1GHz), and ISO 11452-2 (50 V/M, 1GHz-2.7GHz). Conducted Immunity: Bulk Current Injection Meets ISO11452-4, SAE J1113-4 (120 mA, 1MHz-400MHz) Radiated Emissions: Meets CISPR25, Class 3 (150kHz - 54MHz), CISPR 16.2.3, Class B (30-1000 MHz) and ISO13766, level 6db (30MHz - 1GHz ) Conducted Emissions: Meets CISPR 25, Class 5 Electrostatic Discharge: Meets ANSI/ASAE EP455 5.12, Level 1 Power Frequency Magnetic Field: Meets IEC 61000-4-8, 30 A/m PADDLE FUNCTION 0 = No detent or latching 1 = 26° detent + 36° latching 2 = Friction hold (Custom options available, contact Grayhill) 68B-XXX-X SUPPLY VOLTAGE* 5 = 5.0V *Output is proportional to VDD PINOUT AND WIRE COLOR CHART TERMINATION 0 = No Connector; 8” wires with stripped ends 4 = 4.00” Cable with Deutsch Connector 6 = 6.00” Cable with Deutsch Connector 8 = 8.00” Cable with Deutsch Connector For prices and custom configurations, contact a local sales office, an authorized distributor, or Grayhill's sales department. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
68B-425-4 价格&库存
很抱歉,暂时无法提供与“68B-425-4”相匹配的价格&库存,您可以联系我们找货
68B-425-4
    • 1+1826.03160
    • 200+728.60040
    • 500+704.25720
