19101-10UL
19101-10UL
    GRAYHILLINC.
    SWITCH ROTARY 10POS 15A 120V
19101-10UL 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Single Deck Rotary Switches SERIES 24 Features • Positive Detent Provides Operator Feedback • Stainless Steel or Plastic Shaft Option • Unsurpassed Performance in Numerous Applications 1" Diameter, 1 Amp, .580" Behind Panel DIMENSIONS in inches (and millimeters) Solder Lug PC Mountable .312 ± .020 (7,93 ± 0,51) .250 ± .020 (6,35 ± 0,51) .109 ± .015 (2,77 ± 0,38) .578 ± .030 (14,68 ± 0,76) TERMINAL 9 IN LINE WITH KEYWAY .250 ± .020 (6,35 ± 0,51) .250 + .001/ – .002 (6,35 + 0,03/ – 0,05) DIA. BUSHING KEYWAY .066 ± .002 (1,68 ± 0,05) WIDE .036 ± .005 (0,91 ± 0,13) DEEP FROM THE .375 (9,53) DIAMETER 7 1.015 ± .015 (25,78 ± 0,38) DIA. APPROX. .750 (19,05) DIA. OVER TERMINAL ENDS AT INSERTION END .531 ± .020 (13,49 ± 0,51) CL OF BUSHING KEYWAY 8 9 6 5 10 4 C1 1 3 2 ONE POLE 3/8-32UNEF-2A THREAD Typical Terminal Detail (PC Mount) BASE TERMINAL .564 ± .020 (14,33 ± 0,51) .020 ± .002 (0,51 ± 0,05) COMMON TERMINAL .016 ± .002 (0,41 ± 0,05) .187 ± .005 (4,75 ± 0,13) .937 ± .020 (23,80 ± 0,51) DIA. COMMON .050 ± .002 (1,27 ± 0,05) .096 ± .003 (2,44 ± 0,08) 36° ± 5° Rotary Switches .219 ± .005 (5,56 ± 0,13) Terminal Location (PC Mount) .525 (13,34) TYP. 36° TYP. REF. .363 (9,22) TYP. .294 (7,47) TYP. .347 (8,81) TYP. .213 (5,41) TYP. .113 (2,87) TYP. Grayhill part number and date code marked on label. Customer part number marked on request. Specifications Electrical Rating Circuit Diagram Solder Lug and PC Mount (Switch is viewed from shaft end.) Note: Common Terminal is located above Base Terminal 10. Rated: To make and break the following loads: 1 amp at 115 Vac, resistive; 0.5 amp at 220 Vac resistive; 1/4 amp, 115 Vac inductive; 1/50 amp, 115 Vdc inductive; 1/10 amp, 6 to 28 Vdc inductive; 1/10 amp, 115 Vdc resistive; 1 amp, 6 to 28 Vdc resistive; to carry 10 amps continuously. Contact Resistance: 10 milliohms initial. After 25,000 cycles of operation 20 milliohms maximum. Insulation Resistance: 50,000 Mohms minimum initially Voltage Breakdown: 1,000 Vac, (500 Vac, or better after most environmental tests). Life Expectancy: 100,000 mechanical cycles of operation normally. NOTE: Actual life is determined by a number of factors, including electrical loading, rate of rotation, and environment, as well as maximum contact resistance, minimum insulation resistance, and minimum voltage breakdown required at the end of life. Detent Balls: Steel, nickel-plated Shafts: Stainless steel, or plastic Detent: Opposing spring and ball in a hill and valley raceway. Detent Springs: Tinned music wire terminals (except common): Brass, tin plated. Rotor Contact: Steel shaft version—phosphor bronze, silver-plated .0003" minimum. Plastic shaft version—silver alloy. Stator (Base) Contact: Brass, silverplated .0003" minimum Common Plate, including Solder Lug or PC tab: Brass, silver-plated .0003" minimum Rotor Mounting Plate: Nylon fabric-based laminated phenolic per MIL-T-15047 Mounting Nut:Brass, tin/zinc-platedor stainless steel. Additional Characteristics Stop Strength: 12 in-lbs Rotational torque:12 in-ozs Shaft Flat Orientation: Opposite point of contact (See circuit diagram.) Environmental: These switches have passed Materials and Finishes Switch Base: Melamine per (MIL-M-14) the following environmental testing: Altitude and temperature, 100 hour salt spray; Vibration 10 to ASTM-D-5948 Cover, Stop Washers, Bushing: Brass, tin/ 500 cps; Shock 30-G; Humidity; Fungus. Operating Temperature Range: -40 °C to +85 °C zinc-plated PC Mount: PC Switches are furnished with 10 Contacts: Both shorting and non-shorting base terminals for mounting purposes. wiping contacts have over 300 grams contact force. Retaining Rings, Stop Arms, and Thrust STANDARD OPTIONS Special Terminals & RFI Grounding Washers: Stainless steel Not available through distributors. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois ORDERINg INFORMAtION Switches are single deck, one pole switches of 2 to 10 positions. They have plastic or steel shaft, with solder lug or PC terminals, with either shorting or non-shorting contacts (plastic shaft PC mount in nonshorting only). Ten position switches have continuous rotation; fixed stop switch with a metal shaft is available by special order. Base part numbers are as follows: Lug style, steel shaft: 24001-X* Lug style, plastic shaft: 24B36-01-1-X* PC style, steel shaft: 24878-X* PC style, plastic shaft: 24P36-01-1-X* The X is replaced with the number of positions required (02, 03, etc.) Complete the part number by adding N for non-shorting contacts or S for shorting contacts. RECOMMENDED PANEL CUTOUT 005 .375 +. -.000 DIA. 060 -+ . 002 0 003 . 1545 +. -.000 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Multi-Deck Rotary Switches ACCESSORIES Internal Tooth Lockwasher–Figure A For a 3/8" bushing. Approximately 0.500" (12,7) outside diameter, .022" (0,56) thickness. Material is cadmium-plated steel. Part No. 12Q1272-1 For a 1/4" bushing. Approximately 0.400" (10,16) outside diameter, .018" (0,46) thickness. Material is steel, tin/ zinc plated. FIGURE A Non-Turn Washer–Figure B Can be ordered as extra hardware for the Series 5000, 24, 42, 43, 44, 54, 71B, 53, 57 and 59 rotary switches. The internal key of the washer slides into the bushing keyway. The right angle tab locks into a predrilled hole on the back side of the mounting panel. Material is brass, tin/zinc plated. Part No. 12C1087-1 bushing to the panel. The kit consists of four items: a grooved hex nut, a keyed washer, a keyed seal and a non-turn washer. Assembly is described on Page J-53. Dimensions of panel seal kit items are shown in Figure C. This kit seals the bushing to the panel; it does not seal the shaft to the bushing. Not usable with adjustable stop switches. Part No. 42-24 .625 ± .010 (15,88 ± 0,25) DIA. .375 + .004 – .000 (9,53 + 0,10) DIA. .375 ± .005 (9,53 ± 0,13) C L Panel Seal Kit–Figure C Sold as a separate item to seal the switch .125 ± .003 (3,18 ± 0,08) Non-Turn Washer .060 ± .002 (1,52 ± 0,05) .154 + .004 –.000 (3,91 + 0,10 –0,00) DIA. .625 ± .010 (15,88 ± 0,25) DIA. .376 + .003 –.000 (9,55 + 0,08 –0,00) DIA. .437 ± .010 (11,10 ± 0,25) .032 ± .002 (0,81 ± 0,05) .125 ± .010 (3,18 ± 0,25) .120 ± .003 (3,18 ± 0,08) FIGURE B .032 ± .002 (0,81 ± 0,05) .045 ± .003 (1,14 ± 0,08) .562 (14,27) ACROSS FLATS .010 ± .002 (0,25 ± 0,05) .187 ± .010 (4,75 ± 0,25) .088 (2,24)/ .093 (2,36) Seal FIGURE C Keyed Washer Hex Nut Rotary Switches Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Rotary Switch Engineering Information Catalog Ratings Are catalog ratings misleading? In most cases, yes. Load and life ratings shown in most catalogs are usually invalid for most applications. This results from the complex interplay of such factors as environment, duty cycle, life limiting or failure criteria, actual load, etc. Circuit designers should be aware of these factors, and the effect they have on the useful life of the switch in their applications. The problem of switch rating arises from the wide variety of requirements placed on the switch. This includes various applications, and the sensitivity of the switch to a change in requirements. If we attempted to establish life ratings for all possible applications, we would have an almost infinite variety of ratings. To simplify the problem, switch manufacturers, switch users, and the military, have established certain references for ratings. These include loads, life requirements, environments, duty cycles, and failure criteria. These references are arbitrarily established. But, they allow you to compare different switch designs. They do not, however, match the actual requirements for most applications. The curves shown here are an example of some of the life load curves. These curves are life load characteristics of the Grayhill 42M and 44M switches. Note that the curves consider only two voltage sources and two types of loads. These voltages and loads are, however, considered as standards for testing procedures by the industry. Curve data is based on tests conducted at sea level, 25°C and 68% relative humidity. Cycle = 360° rotation and return. Cycling rate is 10 cycles per minute. Switch rating is for non-shorting contacts. CURRENT (AMPS) 7 6 5 VOLTAGE 115 VAC RESISTIVE 4 3 2 1 0 0 10 25 50 CYCLES x 1,000 CURRENT (AMPS) 1.7 1.5 VOLTAGE 30 VDC RESISTIVE 1.2 1.0 .75 INDUCTIVE (2.8 HENRIES) .50 .20 0 0 10 25 50 CYCLES x 1,000 www.grayhill.com These curves allow you to predict the expected life of the switch once you know the voltage, current and type of load. Also note that each cycle is approximately a 360° rotation and a return. For a ten position switch this would be a rotation from position 1 to position 10 and back to 1. This cycle runs approximately ten times a minute. Thus testing causes more electrical and mechanical wear than what the switch incurs in actual use. Summary The life and load ratings in this and other catalogs are probably not totally valid for your application. The bright side of the picture is that in most applications the switch will perform better than its ratings. This is because the standard industry test conditions are more stringent than those found in most applications. This difference can be very dramatic. For example, Grayhill’s 42A and 44A Series Rotary Switches, are rated at 1 ampere (115 Vac resistive). However, they will operate at 5 amperes in many applications. To see how some major factors influence switch performance, read on. USEFUL LIFE CRITERIA The “useful” life of a switch in your application depends on what you demand of it. This includes parameters such as contact resistance, insulation resistance, torque, detent feel, dielectric strength, and many other factors. For example, a contact resistance of 50 milliohms may be totally unusable in certain applications such as a range switch in a micro-ohm meter. In other applications a contact resistance of 5 ohms may be perfectly satisfactory. In establishing “useful” life for a switch in your application, you must first determine “failure criteria,” or “end of life” parameters. At what level of contact resistance, dielectric strength, etc., is the switch no longer acceptable for your application? Most switches are acceptable on all parameters when new. There is a gradual deterioration in performance with life. The rate of deterioration varies greatly with basic switch design. Often, circuit designers select a switch on the basis of its performance when new. This is a mistake. The performance of the switch after several years of equipment use is more significant. To estimate this, first determine the life limiting or failure criteria for your application. In most uses, important life-limiting (failure) criteria include the following parameters: Contact Resistance Insulation Resistance Dielectric Strength Actuating Force Contact Resistance This is the resistance of a pair of closed contacts. This resistance effectively appears in series with the load. Typical values are in the range of a few milliohms for new switches. These values usually increase during life. The rate of increase is greatly affected by the voltage, current, power factor, frequency, and environment of the load being switched. Typical industry standard “end of life” criteria for this parameter are: MIL-DTL-3786: MIL-S-6807: MIL-S-8805: MIL-S-83504: 20 milliohms (Rotary Switches) 20 milliohms (Snap Pushbuttons) 40 milliohms (Pushbuttons) 100 milliohms (DIP Switches) Contact resistance can be measured by a number of different methods. All of them are valid depending upon the switch application and the circuit. Grayhill uses the method in applicable military specifications. This method specifies an open circuit test voltage and a test current. The voltage drop across the closed contacts is measured. The contact resistance is determined by Ohm’s Law from the test current and the measure voltage drop. MIL-DTL-3786, MIL-S-6807 and MIL-S-8805 require a maximum open circuit test voltage of 2 Vdc; they require a test current of 100 milliamperes. MIL-S-83504 requires a maximum test voltage of 50 millivolts and a test current of 10 milliamperes. When a switch is rated to make and break 5 or more amperes, there is a difference. Contact resistance is determined by measuring the voltage drop while the switch is carrying the maximum rated current. The voltage drop that occurs across the contacts determines, in part, the contact temperature. If the temperature rise of the contacts is sufficient, it affects contact material. A chemical reaction will take place that can cause an insulating film to appear on the contacts. This film is present between the contacts during the next switching operation. This film formation can cause failure due to increasing contact resistance. For switching of very low voltages and currents, this resistance may be the failure criteria. Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Insulation Resistance This is the resistance between two normally insulated metal parts, such as a pair of terminals. It is measured at a specific high DC potential, usually 100 Vdc or 500 Vdc. Typical values for new switches are in the range of thousands of megohms. These values usually decrease during switch life. This is a result of build-up of surface contaminants. Typical industry standard “end of life” criteria for the parameter are: MIL-DTL-3786: MIL-S-6807: MIL-S-8805: MIL-S-83504: 1000 megohms (for plastic insulation) Not specified 2000 megohms 1000 megohms Another special test condition is commonly specified. It measures insulation resistance for switches in a high humidity atmosphere (90%-98% R.H.). In this condition, condensation of moisture commonly occurs on the surface of the insulating material. Some types of insulation will absorb varying amounts of moisture. This will normally lower the insulation resistance. Typical industry values for this condition are: MIL-DTL-3786: MIL-S-6807: MIL-S-8805: MIL-S-83504: 10 megohms (for plastic insulation) 3 megohms after drying 10 megohms (for plastic material) 10 megohms Dielectric Strength This is the ability of the insulation to withstand high voltage without breaking down. Typical values for new switches in this test are in excess of 1500 Vac RMS. During switch life, contaminants and wear products deposit on the surface of the insulation. This tends to reduce the dielectric withstanding voltage. In testing for this condition, a voltage considerably above rated voltage is applied. Then, the leakage current is measured at the end of life. Typical industry standard test voltages and maximum allowable leakage currents are as follows: MIL-DTL-3786: 1000 Vac and 1 mA maximum leakage MIL-S-6807: 600 Vac RMS after life 10 microamperes maximum leakage MIL-S-8805: 1000 or 1000 plus twice working voltage (AC) RMS and 1mA maximum leakage MIL-S-83504: 500 Vac and 1 mA maximum leakage UL Standard: 900 Vac without breakdown (UL Standard (dependent on test) Voltage breakdown is another method for www.grayhill.com describing the ability of the insulating material to withstand a high voltage. Voltage breakdown describes the point at which an arc is struck and maintained across the insulating surface with the voltage applied between the conducting members. ADDITIONAL LIFE FACTORS Effect of Loads On any switch, an arc is drawn while breaking a circuit. This causes electrical erosion of the contacts. This erosion normally increases contact resistance and generates wear products. These wear products contaminate insulating surfaces. This reduces dielectric strength and insulation resistance. The amount of this erosion is a function of current, voltage, power factor, frequency and speed of operation. The higher the current is, the hotter the arc and the greater the erosion. The higher the voltage is, the longer the arc duration and the greater the erosion. Inductance acts as an energy storage device. This returns its energy to the circuit when the circuit is broken. The amount of erosion in an inductive circuit is proportionate to the amount of inductance. Industry standard test inductance as described in MIL-I-81023 is 140 millihenries. Other test loads include 250 millihenries and 2.8 henries. Effect of Ambient Temperature Temperature extremes may affect switch performance and life. Very high temperatures may reduce the viscosity of lubricants. This allows them to flow out of bearing areas. This can hasten mechanical wear of shafts, detents, plungers, and cause early mechanical failure. Contact lubricants are sometimes used. Too little lubrication can result in a high rate of mechanical wear. Too much lubrication flowing from other bearing areas can adversely affect dielectric strength and insulation resistance. Through careful design and selection of lubricants most manufacturers attempt to minimize these affects. Nevertheless, continual operation in high ambient temperatures will shorten the life of a switch regardless of design. Extremely low ambient temperatures may also create problems. Low temperatures may cause an increase in the viscosity of the contact lubricant. Higher viscosity can delay or prevent the closing of contacts, causing high operating contact resistance. Under certain atmospheric conditions, ice may form on the contact surfaces. This also causes high and erratic contact resistance. Frequency can also affect erosion. The arcing ends when the voltage passes through zero. To a certain extent, the following is true. The higher the frequency, the sooner arcing ends, the lower the erosion. Neither of these conditions may materially reduce the life of the switch. However, it may cause unsatisfactory operation. If the voltage of the circuit is high enough, it can break down the insulating layer. Some current will flow through the high resistance contacts. A local heating action is created, which tends to correct the condition in a short period of time. The speed of operation affects the duration of the arc. Fast operation can extinguish the arc sooner. This reduces the erosion, unless the air within the switch is completely ionized. Switches with high contact pressures may minimize the low ambient temperature effect. This is particularly true if the application calls for switching signal level voltages and currents. Actuating Force Effects of Altitude Rotational torque is the actuating force required to turn a rotary switch through the various positions. The actual torque or force required depends on the design of the switch. It varies widely from one design to another. See appropriate MIL Specs or manufacturers literature for typical industry values for specific designs. When torque or force values are specified, it is customary to give a minimum and maximum value. During life, two offsetting factors may occur to change the initial value. Relaxation of spring members will tend to lower torque or force values. Wear or “galling” of mating surfaces, however, may tend to increase these values. Typical end of life specifications may require the switch to fall within the original range. Or, they may specify a maximum percentage change from original value. For example, “the rotational torque shall not change more than 50% from its initial value. In high altitudes, barometric pressure is lower. Low pressure reduces the dielectric strength of the air. The arc strikes at a lower voltage and remains longer. This increases contact erosion. Switches for use in high altitudes will therefore require derating in terms of loads and/or life. Effects of Duty Cycle Mechanical life testers cause accelerated life testing. Testers operate switches at a rate of approximately 10 cycles per minute. This rate is greatly in excess of normal manual operation in equipment. It constitutes a severe test of the switch. Lubricants do not have an opportunity to redistribute themselves over the bearing surfaces at this duty cycle. The contact heating caused by arcing does not have a chance to dissipate. Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Thus, the switch runs “hot”, increased mechanical wear and contact erosion result. Your application probably requires manual operation of the switch with an attendant low duty cycle. If so, you can usually expect much longer switch life than is shown by the accelerated life laboratory life tests. Conclusion Remember, load and life ratings are based on manufacturers’ selected references. They include accelerated life tests and an arbitrary set of application parameters and failure criteria. These parameters and criteria may not always fit your application. Then how do you know if a switch will give reliable performance in your application? How do you know if it will last the life of your equipment? Ask the switch manufacturer. Grayhill, and most other reputable manufacturers have compiled vast quantities of test data. We are in a position to give a good estimate of a switch’s performance in many nonstandard applications. You should provide the following data: Expected Life: Load: Operation: Application: Environment: Failure Criteria: in number of cycles voltage, current, power factor, and frequency manual or mechanical, duty cycle type of equipment altitude, ambient temperature range relative humidity, corrosive atmosphere, shock, vibration, etc. end of life contact resistance, dielectric strength, insulation resistance, etc. With this information, we can usually estimate if a given switch is suitable for your application. www.grayhill.com Soldering What causes failure in a new switch after it has been installed? The principle failure is high contact resistance caused by solder flux on the contact surfaces. To avoid this, be sure to follow good soldering practices. Use the proper solder with the proper flux core, maintain the proper soldering temperature, use the proper soldering iron tip for the work, and never use liquid flux when soldering a switch. initially and 10.0 ohm maximum dc resistance following environmental and mechanical tests. Many equipment manufacturers feel they are satisfying their needs with a measurement of .025 to 10 ohms for the expected life of the switch. Under most circumstances, standard non-sealed switches pass the larger value easily. The lower value (.025 ohms) requires special attention and parts for compliance over the life of the switch. Do not use solvent baths or washes with any unsealed electromechanical parts. Switches, unless they have been especially protected suffer badly. Solvents readily dissolve fluxes and carry them into the contact area of switches. A thin, hard flux coats the contact surface after the solvent evaporates. Additionally, solvents may dissolve and wash away lubricants in switches. Lubricant loss may prevent proper mechanical action. Switch Selection Exercise similar precautions when you mount a switch to a printed circuit board. Maintain proper solder temperatures and follow proper cleaning techniques. Avoid subjecting these switches to lengthy solder baths. The excessive heat can deform the plastics. RFI/EMI Shielding Some applications require shielding against Radio Frequency Interference and/or Electro-Magnetic Interference. Experts feel that the most effective way to achieve shielding is to provide a conductive bridge across the component mounting hole. They also generally agree that there is no good method for testing shielding. So, the equipment manufacturers themselves must identify and solve specific problems. Component manufacturers can generally assist in the solution of shielding problems. RFI/EMI testing is incorporated into MILDTL-3786 for rotary switches. Requirements are 1.0 ohm maximum dc resistance between the mounting bushing and operating shaft Whenever possible, use standard switches and contact configurations. Standards provide the greatest economy and the best delivery. When you need a deviation, it pays to consult with your suppliers as soon as possible. At the early stages of the design, there are many low cost options for achieving the results. At the late stages of design, some of the options may no longer be open. For example, size may be restricted. This might result in a more costly redesign. Typical standard rotary options are as follows: coded contacts, homing rotor effect, progressively shorting contacts, PC mountable terminals, rotary switch spring return positions, and push-to-turn or pull-to-turn mechanisms. Limited panel space may be solved by a concentric shaft rotary switch. It is two rotary switches, located one behind the other. There are other concentric shaft possibilities. A rotary switch can be combined with another component. These include a potentiometer, a pushbutton switch, and a mechanical element. The most cost effective design may be one of these concentric options. But, selection must be made at the outset of equipment design. Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. 1. SELECT A FACTOR FACTOR: Current Life Rating All switches are rated to make and break at least 100 milliamperes for 10,000 cycles of operation. Rating becomes a matter of interpretation. Carefully review the Engineering Information on the previous pages. Ratings which assure a different life are possible; contact Grayhill. 25,000 Cycles At Load (Amps) 10,000 Cycles At Load (Amps)   6,000 Cycles At Load (Amps, UL) 19 Single Deck Switch Series Multi-Deck Switch Series 24 50/51 56 75 77 5000 08/09 42/44 43/54 53,57,59 71 — — 15 1 — — .050 .200 — — .200 — — .100 — .050 — — 1 — — .250 .500 — 1,3,5* 1,3,5* — 1,3,5* 1,3,5* — — .250 .150, .250* — — — * Varies with angle of throw and style. FACTOR: Size Maximum Dimension Single Deck Switch Series Multi-Deck Switch Series In Inches (& Millimeters) 19 24 50 51 56 75 77 5000 08 09 42 44 53 57 59 71 Diameter, Behind Panel 2.280 1.015 .500 .561 .500 .298 1.015 .687 .750 1.015 1.170 1.350 1.190 1.190 .750 Length Behind Panel, 1 Deck .950 .580 .698 .698 .355 .500 .470 .960 .960 1.025 1.025 .916 .916 .916 .760 Behind Panel, Add'l Deck — — — — — — — — .268 .268 .346 .346 .329 .326 .326 .218 Diameter, Behind Panel (57,9) (25,8) (12,7) (14,2) (12,7) (7,6) Length Behind Panel, 1 Deck (24,1) (14,7) (17,7) (17,7) (9,0) (12,7) Behind Panel, Add'l Deck — — — — — — () (25,8) (17,4) (19,0) (25,8) (29,7) (34,3) (30,2) (30,2) (19,0) () (11,9) (24,4) (24,4) (26,0) (26,0) (23,3) (23,3) (23,3) (19,3) — — (6,8) (6,8) (8,8) (8,8) (8,4) (8,3) (8,3) (5,5) * If multi-deck switch is needed, contact Grayhill. FACTOR: Circuitry Max. Positions 1 Deck (1Pole)* Angle Of Throw Maximum Decks** Maximum Poles Per Deck*** Shorting Or Non-Shorting 15° 18° 22°30' 22°30' 12 12 12 1 12 10 8 2 N or S N or S N or S N or S Solder Solder Solder Both 53 59 57 51 12 12 12 12 12 11 30° 30° 30° 30° 30° 30° 12 12 12 1 1 1 6 6 6 4 4 1 N or S N or S N or S N or S N or S N Both Both Solder Both Both **** 71 9 44 51 56 19 10 10 10 10 10 10 10 10 36° 36° 36° 36° 36° 36° 36° 36° 12 12 12 1 1 1 1 1 2 2 2 2 2 2 1 1 N or S N or S N or S N N or S N or S N or S N or S Both Both Both PC Both Both Both Solder 8 71 42 75/77 50 56 24 5000 8 8 8 6 6 6 4 4 4 45° 45° 45° 60° 60° 60° 90° 90° 90° 12 12 1 6 12 1 12 6 1 4 4 2 3 3 2 2 2 2 N or S N or S N N N N N N N Both Solder Both Both Solder Both Solder Both Both 9 44 50 9 44 50 44 9 50 24 20 16 16 * Maximum positions per pole depends on number of poles per deck. www.grayhill.com ** Based on 1 pole per deck. Number of decks is also limited by the total number of poles. Solder Lug Or PC Series Number *** Limited by total number of poles per switch. ****Choice of Faston or Solder Lug terminals. Bulletin 1220 Rev 04/14 Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Rotary Switch Standard Options • Custom Switches With No Tooling Required • Easily Ordered Specials 1. Dummy Terminal Used as tie point, it is not an active switch position. Can be located at any specified position outside of active switch terminals. Priced as active position. Example, a three position switch with 2 dummy terminals would be priced as a five position switch. .072 +.000 –.002 (1,83 –0,05) .034 ± .003 (0,86 ± 0,07) .045 .047 (1,19) (1,14) .096 ± .001 (2,44 ± 0,03) 2. Enlarged Wire Holes .032 ± .001 (0,81 ± 0,03) R (2) 5. Notched Terminals Used in place of the conventional solder lug terminals. 6. External Shorting Links .068 ± .005 (1,73 ± 0,13) .045 (1,14) Series 08A, 09A, 42H, 42M, 44H, and 44M: Lug terminals for several wires; standard in Series 08M, 09M, 53, 57, and 59 switches. 3. High Density Wiring Terminal .096 ± .001 (2,44 ± 0,03) .0635 + .002 –.001 (1,61 + 0,05 – 0,02) DIAMETER The gold-plated terminal features a slot to accept wires in addition to the conventional wire hole. 4. Taper Tab Terminals .095 (2,41) .280 (7,11) 45° .062 ± .003 (1,57 ± 0,08) DIAMETER External shorting links, as shown in the drawing, can be used in place of conventional solder lug terminals in the Series 5000, 24, 42 or 43 rotary switches. Shorted terminals can also be accomplished internally in the Series 71 rotary switches. Solder lug terminals can be intermixed on the same deck. 7. Non-Standard, Non-Turn Devices Switches without tabs Series 08, 09, 42 and 44: There is no additional charge for a front support plate without a nonturn tab. Non-turn tab of non-standard projection Series 08: All tabs located at .260 inch radius from centerline of switch. The following projections (inches) are available: .121; .094; .045; .032 Series 44: From Centerline Projection .375" (9,53 mm) .062" (1,57 mm) .531" (13,49 mm) .121" or .049" (3,07 or 1,24 mm) 8. RFI Grounding A silver-plated shaft and wave washer improve DC grounding of shaft to mounting bushing, thus minimizing possible radio frequency interference. Example: static and dynamic DC resistance after 25,000 cycle life test is maximum 100 milliohms. For concentric shaft switches, discuss grounding with factory. Special handling charges apply to small lots. 9. Electrostatic, Electromagnetic Shielding A metallic shield can be added between decks. Grounding of the shield provides additional RFV /EMI protection, Size and shape of the shield depends on the equipment configuration and the amount of protection required Price is dependant onthe number and type of shields required. 10. Unidirectional Rotation The detenting system permits rotation in only one direction. Usable only with continuous rotation switches. Specify direction of rotation. Applicable to 30° and 36° throw switches only. Switch Options For Styles A and S Options For All Styles Series# 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 .079 (2,01) Used in place of conventional solder lug terminals. Taper tab terminals are gold plated. 08 x x x x x x 09 x x x x x x 24 x x x x x x 42 x x* x x x x x x x x x x 43 x x x x x x* x x x 44 x x* x x x x x x x x x 50/51 x x 56 x x 53/57/59 x 54 x x x x x* x x x x x 71 x* x x 5000 x x x x x x * See description below for limitations. www.grayhill.com Patent Pending ©2013 Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. 11. Intermixing of Shorting and NonShorting Contacts In some switches, non-shorting and shorting contacts can be intermixed between decks. A 2-deck switch, for example could have shorting contacts on deck 1 and non-shorting contacts on deck 2. In a few switches, non-shorting and shorting contacts can also be intermixed between poles. A 2-pole per deck switch, for example, could have non-shorting on pole #1, and shorting on pole #2. Series 08 and 09: An 09M30 or 08M36 rotary switch can have shorting and non-shorting contacts intermixed between decks. Shorting and non-shorting contacts can be intermixed between poles as well as decks in styles A, S, P, and SP. Example: an 08P36, 1-pole, 10 position switch with terminals on one side of the switch would be priced as a 2 deck, five position, one pole per deck switch. 13. Homing Rotor (Bridging and Shorting Deck) and Progressively Shorting Deck A homing rotor (bridging and shorting) switch deck connects all terminals to the common except the terminal in the selected switch position. For example, in position 1, terminals 2 thru 12 are CIRCUIT DIAGRAM Series 50, 51, and 56: Non-shorting and shorting contacts can be intermixed between poles. Priced the same as standard switches. The type of contacts on each pole must be precisely indicated. 12. PC Mount Switches With Terminals From One Side of Switch Series 71 PC mount switch has all terminals on one side. Series 08P, 09P, and 42P with non-shorting contacts are also available with terminals limited to one side. Contact Grayhill for a special part number. This is accomplished by using 2 decks per pole and placing the rotating contacts 180° out of phase on each deck. The first deck picks up the first half of the positions; the second deck picks up the last half of the positions. Common terminals are tied together by the PC board circuitry. A total of 12 decks (6 usable poles) is the maximum per switch. Switches with the maximum number of positions (12 for 30°, or 10 for 36°) will have continuous rotation. Rotation can be limited to less than the maximum positions. For example, an 8 position Series 8P36 switch with terminals on one side, would pick up 5 positions on the first deck and 3 positions on the second deck. Price is the same as standard switches with comparable number of decks and positions. www.grayhill.com C 12 HOMING ROTOR DECK 1 2 11 Series 42, 43, 44, and 54, in 30° or 36°: Non-shorting and shorting contacts can be intermixed between poles or decks. Series 71: Non-shorting and shorting contacts can be intermixed between poles in fixed stop switches only. decks are used in combination with conventional decks, it is important to remember that the stop system limits the rotation of both types of decks. For example, when a homing rotor deck Is used in combination with a 6-position conventional deck, the homing rotor is likewise limited to six positions. O-RINGS 10 3 9 4 5 8 6 7 connected to the common, and terminal 1 is open. In position 2, terminal 3 thru 12 and 1 are connected to the common, and terminal 2 is open. A homing rotor deck will function for 25,000 mechanical cycles of operation. The progressively shorting switch deck connects consecutive switch positions to the common. For example, in position 1, terminal 1 is connected to the common; in position 2, terminals 1 and 2 are connected to the common; in position CIRCUIT DIAGRAM C PROGRESSIVELY SHORTING DECK 1 2 14. Shaft and Panel Seal on Concentric Shaft Switches The following diagram shows the location of the O-rings required to seal the shafts to the bushings. When the concentric shaft switches are sealed in this manner, the .125 inch diameter shaft is supplied full round. Bushing-to-panel sealing is accomplished by the panel seal kit. 15. Fixed Stop, Add-A-Pot Switches The rotary switch section of the Add-A-Pot rotary switches can be built with a fixed mechanism rather than the standard adjustable stop mechanism. The front end of a switch of this type is similar to the Series 43A or Series 54A style concentric rotary switches. The total number of decks is limited to three. The Series 43 is limited to 1 pole per deck. Series 54 to 2 poles per deck. 3 4 5 6 3, terminals 1,2, and 3 are connected to the common. A progressively shorting deck is limited to a maximum of 6 positions. A progressively shorting deck will function for 25,000 mechanical cycles of operation. 16. Series 54 Concentric Shaft Switch in 45°, 60°, and 90° Throws The Series 54A switch is available with these angles of throw in Section A of the concentric rotary switch. Section B is available in 30° angle of throw only. Section A is limited to 1 to 3 decks, non-shorting contacts, and 1 or 2 poles per deck. Homing Rotor or Progressively Shorting decks can be ordered as a deck of a 44A or 44M style switch, or their sealed equivalents. Order up to 11 conventional decks and 1 special circuitry deck. For a good detent feel, the switch is limited to a total of 12 poles plus the homing rotor or progressively shorting deck. Example: 6 2-pole decks and a homing rotor. When these special Bulletin 1222 Rev 04/14
19101-10UL 价格&库存
很抱歉,暂时无法提供与“19101-10UL”相匹配的价格&库存,您可以联系我们找货
19101-10UL
  • 1+1207.590431+156.22026
库存:2
19101-10UL
