39-351 BLK
39-351 BLK
    GRAYHILLINC.
    插件
    按动开关 直插 单刀单掷-常开 500mA -40℃~+85℃
39-351 BLK 数据手册
Butt Contact Pushbutton Switches SERIES 39 SPST, 150 mA to 1/2 Amp FEATURES • Requires an Absolute Minimum of Space • Molded-In Terminals in SPST–N.O. • Solder Lug Terminals DIMENSIONS in inches (and millimeters) Economy Version Normally Open–SPST Economy and Standard Version 39-1 39-3 39-601* At 5 Vdc At 20 Vdc 1,000,000 150 mA 20 mA .110 ± .005 (2,79 ± 0,13) DIA. H .036 ±.005 (0,91 ± 0,13) H = HEX MTG NUT .063 ± .010 (1,59 ± 0,25) THICK .219 ± .010 (5,56 ± 0,25) ACROSS FLATS .068 ±.005 (1,73 ± 0,13) B E.I.A. DATE CODE LABEL* Momentary .615 (15,62) REF. C 39-601 RED 39-601 BLK Red Black Actuating Mtg. Total Force (oz.) Hole Travel .035 ± .015 +4 11/64" 4 -2 (0,89 ± 0,38) (4,37) DIA. Action A Button Color Standard D Operations at Rated Load Electrical Ratings .250 + .010/ –.005 (6,35 + 0,25/ – 0,13) DIAMETER A = .175 + .025/ –.020 (4,45 + 0,64/ – 0,51) *Label increases B = .125 ± . 010 (3,18 ± 0,25) nominal diameter C = .215 ± .015 (5,46 ± 0,38) to .255 (6,48) D = .100 ± .020 (2,54 ± 0,51) Complete Part Number At 115 Vac At 220 Vac 1,000,000 1 /2 Amp Res. 1/4 Amp Res. Action Momentary Button Color 39-1 Red 39-3 Black Actuating Total Force (oz.) Travel +4 .035 ± .015 4 –2 (0,89 ± 0,38) Mtg. Hole 11/64" (4,37) DIA. Normally Open–SPST with Sealed Bushing and Button 39-351* .110– .005 DIA. (2,79 – 0,13) A = .175 +.025/ .020 (4,45 +0,64/ 0,51) B = .125 – .010 (3,18 – 0,25) C = .250 –.015 (6,35 – 0,38) D = .100 – .020 (1,54 – 0,51) E.I.A. DATE CODE #8-40 UNS-2A THREAD C HEX MTG. NUT .0625 (1,59) TYP. THICK AND .218 (5,54) TYP. ACROSS FLATS O B .650 (16,51) REF. E.I.A. DATE CODE LABEL* Rating at 115 Vac Resistive A H B C .755 (19,18) REF. D .250 + .010/ – .005 (6,35 + 0,25/ – 0,13) DIAMETER A = .175 + .025/ –.020 (4,45 + 0,64/ – 0,51) *Label increases B = .125 .010 (3,18 0,25) nominal diameter C = .355 .015 (9,02 0,38) to .255 (6,48) D = .100 .020 (2,54 0,51) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 39-351 RED 39-351 BLK Red Black Actuating Force (oz.) .035 ± .015 16 ± 8 (0,89 ± 0,38) .110 .005 (2,79 0,13) DIA. 8-40 UNS-2A THREAD .068 .005 (1,73 0,13) Button Color Total Travel Action Momentary *Complete Part Number .072 – .005 (1,83 – 0,13) Normally Open–SPST with Overtravel .036 .005 (0,91 0,13) Operations at Rated Load .036 – .005 (0,91 – 0,13) Button is O-Ring sealed internally. H = HEX MTG NUT .063 .010 (1,60 0,25) THICK .219 .010 (5,56 0,25) ACROSS FLATS Rating at 220 Vac Resistive /2 Amp 1/4 Amp 250,000 .068 – .005 (1,73 – 0,13) D 39-12 39-24 1 O = O RING XXXX .312 –.005 (7,92 –0,13) ACROSS FLATS .072 .005 (1.83 0,13) Rating at 115 Vac Resistive A 1 Rating at 220 Vac Resistive Operations at Rated Load /2 Amp 1/4 Amp 100,000 Action Total Travel Over Travel Complete Part Number Button Color Red Black 39-12 39-24 Actuating Force (oz.) Mtg. Hole 11/64" .130 ± .025 .015 (0,38) Momentary 5 ± 3 (4,37) (3,30 ± 0,64) Min. DIA. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton Switches 8-40 UNS-2A THREAD .072 ±.005 (1.83± 0,13) Operations *Complete at Rated Part Load Number Electrical Ratings Butt Contact Pushbutton Switches DIMENSIONS in inches (and millimeters) Normally Closed–SPST 39-2 .105 – .005 (2,67 – 0,13) DIA. 8-40 UNS-2A THREAD H = HEX MTG NUT .063 – .010 (1,60 – 0,25) THICK .219 – .010 (5,56 – 0,25) ACROSS FLATS .100 ±.010 (2,54 ± 0,25) .060 ± .010 (1,52 ± 0,25) Rating at 115 Vac Resistive A H B E.I.A. DATE CODE LABEL* .780 (19,81) REF. 1 Rating at 220 Vac Resistive Operations at Rated Load /4 Amp 1/8 Amp 250,000 C Total Travel Action D .250 +.010/ .005 (6,35 +0,25/ 0,13) DIAMETER A = .175 – .025 (4,45 –0,64) *Label increases B = .125 – . 010 (3,18 – 0,25) nominal diameter C = .390 – .010 (9,91 – 0,25) to .255 (6,48) D = .100 (2,54) MAX. Momentary Part Number Cap Color 39-2 Black Actuating Force (oz.) +4 .042 ± .010 4 – 2 (1,07 ± 0,25) Mtg. Hole .172 (4,37) DIA. Normally Closed–SPST with Sealed Bushing and Button Pushbutton Switches 39-352* .110– .005 DIA. (2,79 – 0,13) #8-40 UNS-2A THREAD A A = .165 +.035/ .015 (4,19 +0,89/ 0,38) B = .125 – .007 (3,18 – 0,18) C = .429 –.015 (10,90 – 0,38) D = .100 (2,54) MAX. E = 10 TO 40 APPROX. H B C O-RING .819 (20,80) REF. E.I.A. DATE CODE LABEL* H = HEX MTG. NUT .0625 (1,59) TYP. THICK AND .218 (5,56) TYP. ACROSS FLATS D Rating at 115 Vac Resistive 1 .100 (2,54) MAX. CIRCUITRY SPSt n.O. SPSt n.C. SPECIFICATIONS Rating Criteria Contact Resistance: 25 milliohms maximum on a new switch Voltage Breakdown: 1,000 Vac between mutually insulated parts Insulation Resistance: 1,000 megohms minimum Operating Temperature: -40°C to +85°C Mounting Torque: 2 inch-pounds Momentary Button Color 39-352 RED 39-352 BLK Red Black Actuating Total Force (oz.) Travel .042 ± .010 8 ± 4 (0,17 ± 0,25) .060 – .010 (1,52 – 0,25) *Label increases nominal diameter to .255 (6,48) Materials and Finishes SPST–N.O. WITH OVERTRAVEL Action *Complete Part Number .100 – .010 (2,54 – 0,25) .250 +.010/ .005 (6,35 + 0,25/ 0,13) Button is o-ring sealed internally. Operations at Rated Load /4 Amp 1/8 Amp 100,000 E .312 –.005 (7,92 –0,13) ACROSS FLATS Rating at 220 Vac Resistive Mounting Nut: Brass, tin zinc Housing: Aluminum, clear anodized for 39-351 and 39-352; Brass, zinc trivalent chromate-plated for others Button: Thermoset plastic Base: Thermoset plastic Shorting Bar: Fine silver for 39-2 and 39-352; brass, gold-plated over nickel plate for 39-601; fine silver, gold-plated for others Terminals: Fine silver for 39-2 and 39-352; commercial bronze with gold-plated fine silver contact surface for others Spring: Tinned music wire O-Rings: (39-351 and 39-352) Internal ring is silicone; external ring is buna ‘N’ Accessory Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Button Cap Part No. 30B1012 For use with part numbers 39-351 and 39-352. (Fasten to button with Cyanoacrylate Adhesive) ORDERING INFORMATION Part Number Description 39-1 N.O., Red Button 39-2 N.C., Black Button 39-3 N.O., Black Button 39-12 N.O., Overtravel Red Button 39-24 N.O., Overtravel Black Button 39-351 RED N.O., Sealed, Red Button 39-351 BLK N.O., Sealed, Black Button 39-352 RED N.C., Sealed, Red Button 39-352 BLK N.C., Sealed, Black Button 39-601 RED N.O., Economy, Red Button 39-601 BLK N.O., Economy, Black Button Accessory cap may be used with all switches shown except 39-2. Accessory Part Number Description 30B1012-5 Red Button Cap 30B1012-9 Black Button Cap 30B1012-8 White Button Cap 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton Options and Accessories SEALED TERMINAL AND WIRE LEAD OPTIONS OPTION -E AND -EW FEATURES • 1/4, 1/2, and 1 Amp • Limit, Overtravel, or Panel Seal • Butt or Wiping Contact • Normally Open or Normally Closed • Momentary or Push/Pull • Series 23, 30, 39 and 46 Option -EW, Potted Base & 6" Wire Leads Option -E Epoxy-Sealed Terminals SPECIFICATIONS Rating Criteria Pushbutton Switches Make and Break Current Rating: See page for standard part number Contact Resistance: 25 milliohms maximum on a new switch. Less than 4 milliohms per inch of wire for wire lead option styles. Insulation Resistance: 1,000 megohms minimum between mutually insulated parts Voltage Breakdown: 1,000 Vac minimum between mutually insulated parts Materials and Finishes Potting Sleeve (Series 39): Thermoset Plastic Wire Leads: #26AWG, (.99mm diameter) insulated Teflon, Copper stranded wire, per MlL-W-16878,Type E. Ends are stripped 0.250" (6.35) and solder dipped. For other specifications, see Page References. Standard Part Number Red Button Standard Part Number Black Button 23-1 30-1 30-15 30-17 RED 30-16 RED 30-251 RED 30-252 RED 30-32 RED 30-6 30-601 RED 39-1* –––– 39-12* 39-101 39-351 RED 39-352 RED* 39-601 RED 39-701*** 39-702*** 46-101 RED 46-102 RED 46-110 RED 46-111 RED 46-150 RED 46-151 RED 46-200 RED 46-201 RED 46-270 RED 46-271 RED 23-4 30-3 30-37 30-17 BLK 30-16 BLK 30-251 BLK 30-252 BLK 30-32 BLK 30-2 30-601 BLK 39-3* 39-2 39-24* –––– 39-351 BLK 39-352 BLK* 39-601 BLK –––– –––– 46-101 BLK 46-102 BLK 46-110 BLK 46-111 BLK 46-150 BLK 46-151 BLK 46-200 BLK 46-201 BLK 46-270 BLK 46-271 BLK Choices of Suffix -E -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -EW** -E,- EW -EW** -EW** -EW** -E, -EW -EW* -EW** -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E -E -E -E Length Behind Panel In inches (and millimeters) -EW Style Standard Switch Body & Terminals 0.665 0.592 0.679 0.958 0.958 0.632 0.645 0.867 0.605 0.592 0.315 0.490 0.455 0.650 0.350 0.529 0.315 0.800 0.510 0.890 0.890 0.890 0.890 0.957 0.957 0.921 0.921 0.957 0.957 (16,89) (15,04) (17,25) (24,33) (24,33) (16,05) (16,38) (22,02) (15,37) (15,04) (8,00) (12,45) (11,56) (16,51) (8,89) (13,44) (8,00) (20,32) (12,95) (22,61) (22,61) (22,61) (22,61) (24,31) (24,31) (23,39) (23,39) (24,31) (24,31) –––– 0.645 0.728 1.007 1.007 0.685 0.700 0.896 0.640 0.645 0.440 0.575 0.575 0.775 0.450 0.630 0.440 0.925 0.750 0.957 0.957 0.957 0.957 1.024 1.024 –––– –––– –––– –––– (16,38) (18,49) (25,58) (25,58) (17,40) (17,78) (22,76) (16,26) (16,38) (11,18) (14,61) (14,61) (19,69) (11,43) (16,00) (11,18) (23,50) (19,05) (24,31) (24,31) (24,31) (24,31) (26,01) (26,01) *Epoxy potting sleeve enlarges the diameter of the -EW style to 0.300 (7,62). **Sealed terminal (-E) option is not necessary; terminals have sealed construction. ***Natural Color Button †Adjustable from 1.214 (30,84) to 1.334 (33,88) dependent on button height, see switch pages. Pushbutton 60 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton Options and Accessories ORDERING INFORMATION Use the Selector Charts at the beginning of the section to select a series. Use the pages listed there or referenced here to select a switch. Standard Part Number Choice of Button Color (see switch pages) (see switch pages) –––– –––– –––– –––– 30-01-01-500-XX 30-01-04-500-XX 30-05-01-502-XX 30-05-04-502-XX –––– 46-01-05-500-XX 46-01-07-500-XX 46-01-08-500-XX 46-01-09-500-XX 46-05-05-502-XX 46-05-07-502-XX 46-05-08-502-XX 46-05-09-502-XX –––– –––– –––– –––– 30-001-A-XX 30-002-A-XX 30-015-A-XX 30-017-A-XX 30-1-1-50-XX 30-1-4-50-XX 30-5-1-52-XX 30-5-4-52-XX 30-601-A-XX 46-1-5-50-XX 46-1-7-50-XX 46-1-8-50-XX 46-1-9-50-XX 46-5-5-52-XX 46-5-7-52-XX 46-5-8-52-XX 46-5-9-52-XX 46-102-A-XX 46-111-A-XX 46-200-A-XX 46-201-A-XX To order epoxy sealed terminals, add the suffix E to the selected part number as allowed in the chart. Example: 30-1-E. To order the epoxy-potted version with 6-inch wire leads, use the suffix -EW as allowed in the chart. Example: 39-1-EW Available From Your Local Grayhill Distributors. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Choices of Options -E, -E, -E, -E, -E, -E, -E, -E, -E, -E, -E, -E -E -E, -E, -E -E -E, -E, -E -E -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW Length Behind Panel In inches (and millimeters) Standard Switch & Terminals 1.119 (28,42) 1.132 (28,75) 1.204 (30,58) Adjustable† 1.100 (27,94) 1.257 (31,93) 0.930 (23,62) 1.130 (28,70) 1.119 (28,42) 1.361 (34,57) 1.451 (36,86) 1.381 (35,08) 1.381 (35,08) 1.179 (29,95) 1.465 (37,21) 1.188 (30,18) 1.317 (33,45) 1.417 (35,99) 1.417 (35,99) 1.448 (36,78) 1.448 (36,78) -EW Style Body 1.172 (29,77) 1.167 (29,64) 1.253 (31,83) Adjustable† 1.153 (29,29) 1.310 (33,27) 0.983 (24,97) 1.183 (30,05) 1.172 (29,77) 1.428 (36,27) 1.518 (38,56) –––– –––– 1.246 (31,65) 1.532 (38,91) –––– –––– 1.484 (37,69) 1.484 (37,69) –––– –––– CIRCUITRY: Series 46 N.C. (YELLOW) C1 (RED) N.O. (GREEN) *Epoxy potting sleeve enlarges the diameter of the -EW style to 0.300 (7,62). **Sealed terminal (-E) option is not necessary; terminals have sealed construction. ***Natural Color Button †Adjustable from 1.214 (30,84) to 1.334 (33,88) dependent on button height, see switch pages. SPDT WIPING CONTACTS Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton 61 Pushbutton Switches Standard Part Number Without Options Choice of Button Color Pushbutton Options and Accessories ACCESSORIES For Pushbutton Switches Button Caps Decorative Mounting Nuts Pendant Housing Button Guard DIMENSIONS In Inches (and millimeters) .75 (19,1) ACROSS FLATS Decorative Mounting Nuts .44 (11,2) ACROSS FLATS .50 (12,7) ACROSS FLATS 30C1023-1 Pushbutton Switches .46 (11,7) DIA. .52 (13,2) DIA. Brass, nickel-plated for 1/4" (6,35) bushing. .09 (2,3) 07C1040-1 23C1024-1 .77 (19,6) DIA. Brass, nickel-plated for 5/16" (7,93) bushing. Brass, nickel-plated for 15/32" (11,9) bushing. .12 (3,1) .09 (2,3) Button Caps and Guard .89 (22,6) DIA. 30B1012 07Z1047 Thermosetting plastic (Fasten to button with cyanoacrylate adhesive) black, red or white. .19 (4,8) .09 (2,3) .34 (8,6) For use with all Series 30 and 39 switches except part number 39-101. See switch pages. .25 (6,4) DIA. 07Z4950 07Z5051 .33 (8,4) REF. Flat Cap .89 (22,6) 1.19 1.03 (30,2) (26,16) .27 (6,86) DIA. Brass, zinc trivalent chromate-plated for 15/ 32" (11,9) bushing. .41 (10,4) .59 (15,0) .08 (2,0) Housing 2.45 (62,23) .42 (10,67) Thermoplastic, black or red color. For use with Series 2000 and Series 7 switches. See switch pages. 1.00 (25,4) DIA. Remote Switching Accessories Pendant Housing and Caps 10C1015-1 1.19 (30,2) .08 (2,03) .25 (6,4) .89 (22,6) Recessed Cap 1.04 1.19 (30,2) (26,4) .48 (12,2) .48 (12,2) Application: All grayhill pushbutton switches with 15/32-32 bushings: catalog numbers 2201, 2202, 07-7, 07-8, 07-21, 07-22, 07-26, 4001, 4002, 10-9, 10-10, 10-100, 10-101, 30-16, 30-17 and 30-32. any other switch with 15/32-32 bushing if it fits housing. Material: Thermoplastic Specials: other colors available on special order. ORDERING INFORMATION: Mounting Nuts, Button Caps, and Guards Part Number Color 07C1040-1 23C1024 30C1023-1 07Z1047-1 BLK 07Z1047-2 RED 10C1015-1 30B1012-5 30B1012-8 30B1012-9 Decorative Nut Decorative Nut Decorative Nut Black Button Cap Red Button Cap Button Guard Red Cap White Cap Black Cap Pendant Housing and Caps Part Number 07Z4950 07Z4950 07Z5051 07Z5051 RED BLK RED BLK Description Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Red Flat Cap & Housing Black Flat Cap & Housing Red Rcssd Cap & Housing Black Rcssd Cap & Housing Sold only as sets of one housing and one cap. Pushbutton 62 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
39-351 BLK 价格&库存
很抱歉,暂时无法提供与“39-351 BLK”相匹配的价格&库存,您可以联系我们找货
39-351 BLK
    39-351 BLK
      • 1+145.63800
      • 200+58.11480
      • 500+56.17080
      • 1000+55.20960
