47A3P1J1M7QT
47A3P1J1M7QT
    GRAYHILLINC.
    插件
    船型开关 3PDT 5A 28VAC 125VDC
47A3P1J1M7QT 数据手册
Series 47A: Miniature Rocker and Paddle Switches Series 47A Miniature Rocker and Paddle Switches FEATURES • Save Space and Weight • SPDT, DPDT, 3PDT and 4PDT Circuitry • Choice of Actuators and Terminations • UL Recoginized Models in inches (and millimeters) MODEL NO. ON ON ON (ON) ON 2-3 SP1 SP2 SP3 SP4 SP5 TERM. COMM. NONE NONE OFF OFF OFF OPEN .185 (4.70) Ø.094 (Ø2.39) SPDT SWITCH POSITION .937 (23.80) 1.156 (29.36) 3 25˚ Rocker and Paddle Switches DP1 DP2 DP3 DP4 DP5 TERM. COMM. ON ON ON (ON) ON 2-3,5-6 .275 (6.99) 3 DPDT SWITCH POSITION NONE ON NONE (ON) OFF ON OFF (ON) OFF (ON) OPEN 2-1,5-4 .185 (4.70) .500 (12.70) 25˚ .155 (3.96) 3P1 3P2 3P3 3P4 3P5 .275 (6.99) 6 TERM. COMM. 3PDT SWITCH POSITION ON ON ON (ON) ON 2-3,5-6 .147 (3.70) .020 (0.50) .185 (4.70) NONE ON NONE (ON) OFF ON OFF (ON) OFF (ON) OPEN 2-1,5-4 1 05COMM. 3 4 .937 (23.80) 3 2 1 1.156 (29.36) 7 5 2 4 1 .080 (2.03) 25˚ .155 (3.96) .080 (2.03) .190 (4.83) 9 .500 8 (12.70) 7 6 5 3 2 4 1 .441 (11.21) 08COMM. 6 3 .450 (11.43) .030 (0.76) Ø.094 (Ø2.39) ()=MOMENTARY 02COMM. 6 .376 (9.56) SCHEMATIC MODEL NO. .190 (4.83) 3 2 1 1.156 (29.36) .937 (23.80) .270 (6.86) .030 (0.76) Ø.094 (Ø2.39) 05COMM. 3 4 1 1 .020 (0.50) .147 (3.70) ()=MOMENTARY 02COMM. 2 .376 (9.56) 02COMM. MODEL NO. .500 (12.70) .155 (3.96) ()=MOMENTARY 1 .080 (2.03) 3 2 1 ON (ON) ON (ON) (ON) 2-1 SCHEMATIC .030 (0.76) 9 .275 (6.99) .147 (3.70) .020 (0.50) .650 (11.43) SCHEMATIC Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 47A: Miniature Rocker and Paddle Switches Models in inches (and millimeters) 4PDT MODEL NO. TERM. COMM. ON ON ON (ON) ON 2-3,5-6 NONE NONE OFF OFF OFF OPEN ON (ON) ON (ON) (ON) 2-1,5-4 .937 (23.80) .185 (4.70) 1.156 (29.36) 3 2 1 25˚ ()=MOMENTARY 02COMM. 1 05COMM. 3 4 08COMM. 6 .275 (6.99) 9 7 ActuatoR OPTIONS: For Panel Mount Only R1 .275 (6.99) 1.156 (29.36) .937 (23.80) 12 .500 (12.70) 11 10 9 8 7 6 5 3 2 4 1 .850 (11.43) .531 (13.49) .310 (7.87) .365 (9.27) .138 (3.50) .375 (9.52) .020 (0.50) Rocker and Paddle Switches .275 (6.99) 1.156 (29.36) .937 (23.80) .441 (11.21) .155 (3.96) .190 (4.83) in inches (and millimeters) Ø.094 (Ø2.39) R2 .020 (0.50) .147 (3.70) SCHEMATIC .080 (2.03) DIP Switches 4P1 4P2 4P3 4P4 4P5 .030 (0.76) Ø.094 (Ø2.39) SWITCH POSITION .084 (2.13) .365 (9.27) .875 (22.22) .332 R. (8.43 R.) .740 (18.8) .138 (3.50) Ø.094 (Ø2.39) .020 (0.50) 1.625 (41.27) 1.375 (34.92) .595 (15.11) ROCKER WIDTH .906 (23.01) .320 (8.13) .576 NOM. (14.63) .383 (9.73) Ø.125 2 PLCS. (Ø3.17) .505 (12.83) BRACKET WIDTH .138 (3.50) .024 (0.61) R4 .093 (2.36) 1.625 (41.27) 1.375 (34.92) Ø.125 2 PLCS. (Ø3.17) .888 (22.56) .595 (15.11) ROCKER WIDTH .505 (12.83) BRACKET WIDTH .024 (0.61) 1.174 (29.82) 1.312 (33.32) .138 (3.50) .437 (11.10) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Slide DIP Switches R3 Series 47A: Miniature Rocker and Paddle Switches ActuatoR OPTIONS: For Panel Rear Mount Only in inches (and millimeters) R5 .595 (15.11) ROCKER WIDTH 1.875 (41.27) 1.625 (34.92) .478 (12.14) 1.318 (33.4) .024 .505 (0.61) (12.83) BRACKET WIDTH R6 .765 (19.43) PANEL THICKNESS .047 TO .125 (1.19 TO 3.18) .138 (3.50) .128 (3.25) PANEL MOUNTING .600 (15.24) .615 (15.62) .280 (7.11) .450 (11.43) R7 .093 (2.36) .090 (2.29) .500 (12.70) .005 R.(4) (0.13 R.) MAX. TYP. .456 (11.58) PANEL MOUNTING Rocker and Paddle Switches .765 (19.43) .600 (15.24) .615 (15.62) .450 (11.43) PANEL THICKNESS .047 TO .125 (1.19 TO 3.18) ActuatoR OPTIONS: For P.C. Mount Only .090 (2.29) .280 (7.11) .005 R.(4) (0.13 R.) MAX. TYP. .500 (12.70) in inches (and millimeters) J1 .365 (9.27) .531 (13.49) .310 (7.87) .299 (7.59) J2 .084 (2.13) .365 (9.27) .156 (3.96) .332 R. (8.43 R.) .740 (18.80) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 47A: Miniature Rocker and Paddle Switches ActuatoR OPTIONS: For P.C. Mount Only in inches (and millimeters) J3 J4 .093 (2.36) .351 (8.92) .906 (23.01) .888 (22.55) 1.174 (29.82) .595 (15.11) .320 (8.13) DIP Switches .595 (15.11) 1.055 (26.80) 1.055 (26.80) J5 J6 .432 (10,97) .362 (9,19) .306 (7,77) .450 (11,43) .260 (7,11) .125 (3,18) .093 (2,36) .644 (16,36) .230 R. (5,84 R.) .460 (11,68) J8 J7 .125 (3,18) .432 (10,97) .093 (2,36) .230 R. (5,84 R.) .644 (16,36) .230 R. (5,84 R.) in inches (and millimeters) Solder Lug M2 .156 (3.96) .189 (4.80) P.C. Mount (Std) .250 (6.35) M3 P.C. Mount, Quick Connect .075 (1.91) WX DIM."A" EPOXY SEAL .150 (1.91) .080 (2.03) .050 (1.27) .047 (1.19) THK. .030 (0.76) THK. .030 (0.76) Note: Solder lug terminals supplied with mounting tabs standard. PC Mount terminals supplied without mounting tabs standard. .062 (1.57) .100 (1.27) .250 (6.35) OPTION CODE DIM."A" .750(19.05) W1 .964(24.48) W2 W3 .425(10.80) W4 1.062(26.97) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Slide DIP Switches .450 (11,43) Termination OPTIONS .078 (1.98) .093 (2,36) .894 (22,71) .450 (11,43) M1 .125 (3,18) .432 (10,97) Rocker and Paddle Switches .450 (11,43) Series 47A: Miniature Rocker and Paddle Switches Termination OPTIONS M6 in inches (and millimeters) Right Angle P.C. Mount, Horizontal Actuation PIVOT .062 (1.57) EPOXY SEAL .500 (12.70) .125 (3.18) SPDT .016 (0.41) .048 (1.22) 2 .185 (4.69) 3 .500 (12.70) .030 (0.76) .169 (4.29) .500 (12.70) .200 (5.08) 1 .270 (6.86) .200 (5.08) Ø.073 (Ø1.85) .185 (4.70) .050 (1.27) .230 (5.84) .500 (12.70) EPOXY SEAL PIVOT .125 (3.18) DPDT .016 (0.41) .048 (1.22) .150 (3.81) 6 1 2 3 .150 (3.81) .030 (0.76) .500 (12.70) M7 5 .500 (12.70) .050 (1.27) .169 (4.29) .200 (5.08) .450 (11.45) 4 .185 (4.69) .200 (5.08) Ø.073 (Ø1.85) .185 (4.70) Right Angle P.C. Mount, Vertical Actuation Rocker and Paddle Switches .150 (3.81) 3 .100 (2.54) .125 (3.18) SPDT Ø.073 (Ø1.85) .270 (6.86) EPOXY SEAL .500 (12.70) 2 1 2 1 .050 (1.27) .500 (12.70) 3 .050 (1.27) .235 (5.97) .500 (12.70) .200 (5.08) .030 (0.76) .016 (0.40) .150 (3.81) .450 (6.86) EPOXY SEAL .100 (2.54) .125 (3.18) DPDT 5 4 .190 (4.83) .050 (1.27) .235 (5.97) .500 (12.70) 6 3 5 2 4 1 .050 (1.27) .150 (3.81) .190 (4.83) .500 (12.70) .500 (12.70) 6 .200 (5.08) .030 (0.76) .016 (0.40) .150 Ø.073 (Ø1.85) .200 (5.08) (3.81) .125 (3.18) 3PDT 7 8 9 6 3 8 5 2 7 4 1 .190 (4.83) .500 (12.70) .565 (14.35) 9 .050 (1.27) .565 (14.35) .650 (16.50) .100 (2.54) EPOXY SEAL .050 (1.27) .235 (5.97) .190 (4.83) .200 (5.08) .016 (0.40) .030 (0.76) .150 (3.81) .200 (5.08) .150 (3.81) .200 (5.08) Ø.073 (Ø1.85) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 47A: Miniature Rocker and Paddle Switches Termination OPTIONS in inches (and millimeters) .100 (2.54) EPOXY SEAL .125 (3.18) 4PDT 10 V2-V3 Vertical Bracket P.C. Mount 3 5 2 10 7 4 1 .500 (12.70) .016 (0.40) .030 (0.76) .150 (3.81) .565 (14.35) .200 (5.08) .150 (3.81) .565 (14.35) .200 (5.08) Ø.073 (Ø1.85) .162 (4.11) .125 (3.18) DIM. "A" OPTION DIM."A" CODE 1 .125 (3.18) 6 8 12 SPDT .048 (1.22) 9 11 .050 (1.27) .235 (5.97) .190 (4.83) 12 DIP Switches .050 (1.27) 11 .190 (4.83) .850 (21.59) .185 (4.70) 2 3 .020 (0.51) EPOXY SEAL V2 .460 (11,68) V3 .630 (16,00) .620 (15.75) .030 (0.76) Ø.073 (Ø1.85) .185 (4.70) .620 (15.75) .320 (8.13) .162 (4.11) DPDT 4 .048 (1.22) .125 (3.18) .185 (4.70) .320 (8.13) Specifications Ratings Contact Rating: Q option - 5A with resistive load @ 125 VAC or 28 VDC; 2A with resistive load @ 250 VAC. R option - 0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 40,000 make-and-break cycles at full load 5 6 .020 (0.51) EPOXY SEAL V2 .460 (11,68) V3 .630 (16,00) .030 (0.76) .620 (15.75) .190 (4.83) .185 (4.70) Ø.073 (1.85) .620 (15.75) Contact Resistance: 10 milliohms max. initial @ 2-4 VDC, 100 mA Insulation Resistance: 1,000 megaohms minimum Dielectic Strength: 1,000 V RMS @ sea level Operating Temperature: -30°C to 85°C UL Recognition: File number is E35289 .370 (9.40) MATERIALS Case: Diallyl phthalate (DAP) (UL 94V-0) Rockers: Nylon (UL 94V-0) Bushing: Stainless steel Switch Support: Brass, tin-plated Terminal/Contacts: Brass with silver or gold plate Terminal Seal: Epoxy Ordering Information 47ASP1J2M6RT Series 47A Minature Rocker and Paddle Switches Model: SPDT: SP1, SP2, SP3, SP4, SP5 DPDT: DP1, DP2, DP3, DP4, DP5 3PDT: 3P1, 3P2, 3P3, 3P4, 3P5 4PDT: 4P1, 4P2, 4P3, 4P4, 4P5 (See Model options.) Actuator: R1, R2, R3, R4, R5, R6, R7 J1, J2, J3, J4, J5, J6, J7, J8 (See actuator options.) Termination Options: M1, M2, M3, M6, M7, S6, V2, V3, W1, W2, W3, W4 (See Termination options.) RoHS Compliant Contact: R = Brass alloy, gold plate over nickel plate Q = Brass alloy, silver plated Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Slide DIP Switches OPTION DIM."A" CODE Rocker and Paddle Switches .125 (3.18) DIM. "A"
47A3P1J1M7QT 价格&库存
很抱歉,暂时无法提供与“47A3P1J1M7QT”相匹配的价格&库存,您可以联系我们找货
