607702/607703
607702/607703
    GRAYHILLINC.
    GRAYHILL - 607702/607703 - Knob, Round Shaft, Round, 34 mm
607702/607703 数据手册
Optical Encoders Series 60C Multi-Function Joystick FEATURES • Three-in-One Joystick, Optical Encoder and Pushbutton • Compact Packaging • Choices of Cable Length and Termination • Customized Solutions Available APPLICATIONS • Avionics • Medical Equipment • Automotive Navigation, Information & Entertainment Equipment DIMENSIONS in inches (and millimeters) JOYSTICK OPERATION ENCODER WAVEFORM Unless otherwise specified, standard tolerance are: Linear ± .025 Diameter ± .010 Angle ± 2.0° Optical and Mechanical Encoders TRUTH TABLE Standard Quadrature 2-Bit Code JOYSTICK ENCODER FRONT MOUNTING REAR MOUNTING SWITCH SCHEMATIC Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders CONTROL KNOBS Ø1.150 P/N 607702 .487 ±.002 Ø.505 .695 Inner Knob Ø1.344 Outter Knob P/N 607703 .585 .080 SPECIFICATIONS Rotary Electrical and Mechanical Ratings Joystick Electrical and Mechanical Ratings Operating Voltage: 5.00 ± 0.25 Vdc Supply Current: 35mA at TYP at 5 Vdc Power Consumption: 175mW TYP at 5Vdc Output: Direct output from inverting Schmitt trigger Logic Output Characteristics: High: No less than 3.5 Vdc Low: No greater than 1.0 Vdc Mechanical Life: 500K cycles (through all positions and a full return) Angle of Throw: 8° max. in all directions Rating: 10 mA at 5 Vdc resistive Contact Resistance: less than 10 ohms Contact Bounce: < 4ms make, 10 ms break Mechanical Life: 500K actuations minimum Actuation Force: option 7 = 485 ± 115grams Pushbutton Travel: 0.033 ± 0.015 inches to contact; 0.075 inches maximum Environmental Ratings Operating Temperature Range: -40°C to 85°C Storage Temperature Range: -55°C to 100°C Relative Humidity: 96 hours at 90-95% humidity at 40°C Vibration: Harmonic motion with amplitude of 15g, within a varied 10 to 2000 Hz Mechanical Shock: Test 1: 100g for 6ms half-sine wave with a velocity change of 12.3 ft/s Test 2: 100g for 6ms sawtooth wave with a velocity change of 9.7 ft/s Thermocycle: 4 hours cycling between -40°C to 85°C Materials and Finishes Bushing: Thermoplastic Shaft Outer: Thermoplastic Upper Housing: Thermoplastic Pushbutton Rocker: Thermoplastic Pushbutton Actuator: Thermoplastic Inner Shaft Slide: Thermoplastic Slider Plate: Thermoplastic Backplate: Thermplastic Lightpipe, Joystick: Thermoplastic Lightpipe, 16 pos: Thermoplastic Centering Profile: Thermoplastic Shaft Inner: Aluminum Pins: Stainless steel Barbed Rivet: Stainless steel Detent Balls: Carbon steel 100 with nickel finish Centering Balls: Carbon steel 100 with nickel finish Detent Springs: Tinned music wire Centering Springs: Tinned music wire Cable ASM: .050 round conductor flat cable, PVC coated. Conductors are stranded, topcoated wire Solder: 95.5% SN, 4% AG, 0.5% CU Dome: Stainless steel PCB 16 Pos: NEMA grade FR-4. Plating is gold or palladium over nickel Infrared Emitter: Gallium aluminum arsenide Phototransistor: Planar silicon Resistor: Carbon film Schmitt Trigger: RoHS Compliant TSSOP, 14 pin Lubricating Grease: Nyogel 774L Label: TT406 Thermal transfer cast film OPTIONS Contact Grayhill for custom terminations, rotational torque, number of positions, shaft configurations, and resolutions. Control knobs are also available. Ordering Information Series Angle of Throw: 22= 22.5° or 16 positions Rotation Torque: M= Medium torque Pushbutton: 7= 485 grams Joystick: 4= Four directions 60C22-M7-4-060S Termination: 0.050" center ribbon cable with; C= Connector; S= 0.1" stripped end Cable Length: 025 thru 250 in 1/2 inch increments, 060= 6.0 inch cable Available from your local Grayhill Distributor. For prices and discounts, contact a local sales office, an authorized distributor, or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical and Mechanical Encoders Operating Voltage: 5.00 ± 0.25 Vdc Supply Current: 35mA TYP at 5 Vdc Power Consumption: 175mW TYP at 5Vdc Output: Direct output from inverting Schmitt trigger Output Code: 2-Bit quadrature, channel A leads channel B by 90° in cw rotation Logic Output Characteristics: High: No less than 3.5 Vdc Low: No greater than 1.0 Vdc Mechanical Life: 500K rotational cycles (through all positions and a full return) Rotational Torque: medium torque option 3.00+2.00 in-oz, torque shall be within 50% of initial value throughout life Mounting Torque: 15 in-lbs. maximum Shaft Push/Pull Out Force: 25 lbs minimum Terminal Strength: 15 lbs terminal minimum Pushbutton Electrical and Mechanical Ratings
607702/607703 价格&库存
很抱歉,暂时无法提供与“607702/607703”相匹配的价格&库存,您可以联系我们找货
