D
SERIES 04J
Joystick with Center Pushbutton
FEATURES
• Sealed against contamination when properly mounted (IP67)
Ø.925 ±.002 ID
.56 ±.03
• TwoOF
styles
available:
O-RING
GROOVE behind-panel mount or front-panel mount
• RoHS compliant
• Short behind panel
4X .030
TERMINAL
THICKNESS
5X .079
TERMINAL
.093
CENTER TERMINAL
DESCRIPTION
Series 04J is a single
Y pole, 4-way toggle switch with a pushbutton in the
center position. 4-way contact is made in the opposite direction of travel.
EPOXY REAR SEAL
3
DIMENSIONS in inches (and millimeters)
.775 ±.005
TO FLAT
Ø.925 ±.002 ID
Ø1.176 ±.005
2
.56 ±.03
OF O-RING GROOVE
4X .030
TERMINAL
THICKNESS
5X .079
TERMINAL
45.0°
Y
Y
EPOXY REAR SEAL
3
.775 ±.005
TO FLAT
2
1
Ø.700 REF
BUTTON
.114
Ø.700 REF
BUTTON
.210
.210
BEHIND PANEL MOUNT
.674
2X .283
CENTER TO
CENTER
.223
TO
OF
TERMINAL
2X .283
CENTER TO
CENTER
.051 ±.001
O-RING GROOVE
DEPTH
.015
[ 0,38 ]
.659
[ 16,73 ]
.410
[ 10,41 ]
.015
COMMON
THICKNESS
2X .141
CENTER TO
CENTER
2X .141
CENTER TO
CENTER
.674
.601
[ 15,25 ]
Ø.700
[ 17,78 ]
Ø.080
5 CENTER
4
TERMINAL
Ø.080
CENTER
TERMINAL
.114
4X .055
TERMINAL
C
.055
[ 1,4 ]
2X .283
[ 7,19 ]
4X .055
[ 1,4 ]
.705
[ 17,91 ]
Ø1.000
[ 25,4 ]
FRONT PANEL MOUNT
.096 +.002/-.003
.350
O-RING GROOVE
[ 8,89 ]
WIDTH
ELECTRIC & MECHANICAL RATINGS
Rating: 2 amp resistive; 0.5 amp inductive at
28VDC or 115VAC
Contact Resistance: .05 ohms (max)
Operating Temperature: -55°C to +85°C
Operational Life: 100,000 cycles (min)
Pushbutton Travel: .020 minimum overall
Pushbutton Operating Force: 5 lbs. (max)
Insulation Resistance: 10,000M ohms
ORDERING INFORMATION
Available from your local Grayhill
Distributor.
For prices and discounts, contact
a local sales office, an authorized
local distributor or Grayhill.
.160
.079
[ 2,01 ]
3/4-32 UNF 2A THREADS
SECTION Y-Y
Ø1.063
O-RING
GROOVE
DETAIL
Vibration: per MIL-DTL-9419F, Method 3.5.9
Toggle Lever Travel: 15° from center (max)
Toggle Operating Force: 16 oz + 6 oz initial
Toggle Pivot & Stop Strength: 25 lbs. (max)
Mechanical Shock: per MIL-STD-810,
procedure I, method 516.4
Immersion: per MIL-PRF-8805
Moisture Resistance: per MIL-DTL-9419
.125
Grayhill Series Number
Version:
B = behind panel; A = front panel
Connection:
P = PCB mount; S = solder lugs
MOUNTING NUT
Ø.625
[ 15,88 ]
.223
[ 5,66 ]
4X .030
[ 0,76 ]
MATERIALS & FINISHES
Switch Body & Concave Cap: Thermoplastic
(black, cone-shaped cap is gray)
Bushing: Aluminum alloy (black chrome)
Contact Terminals: 1/2 hard brass (gold over
silver over nickel plating)
Spanner Nut: Stainless steel (black chrome)
O-Ring: 50 durometer fluorosilicone
CIRCUITRY
POS 4
C
POS. 3
POS. 1
04J-BP-T 0 1
Current: 1 = high; 2 = low
Keycap
SCALE 1.000 Color: 0 = black; 1 = gray
Keycap Shape:
T = stadium cap; C = cone-shaped cap
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
POS. 5
(PSHBTN MODE)
POS. 2
*Contact made opposite the direction of travel
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
C
5
1
.055
COMMON
TERMINAL
.093
CENTER TERMINAL
Joysticks
FF.
Joysticks
4
很抱歉,暂时无法提供与“04J-BS-T02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2354.89680
- 200+939.62160
- 500+908.22600
