30-32 RED
30-32 RED
    GRAYHILLINC.
    SWITCH PUSH SPST-NC 1A 115V 40°C ~ 85°C
30-32 RED 数据手册
Butt Contact Pushbutton Switches SERIES 30 SPST, 1 and 5 Amp FEATURES • Reliable • Economical • Large Selection • UL Recognized • CSA Certified • Sealed Bushing and Pushbutton Option DIMENSIONS in inches (and millimeters) 30-1 30-1UL 30-3 30-3UL 30-601* Pushbutton Switches Normally Open–SPST Standard, Economy and UL Recognized .162 ± .005 (4,11 ± 0,13) A 1/4-32 UNEF-2A THREAD B .992 (25,20) REF. HEX MOUNTING NUT .375 (9,53) ACROSS FLATS .109 (2,77) THICK C LABEL* D *PART NUMBER AND E.I.A. DATE CODE LABEL CL .186 (4,72) REF. CL .375 ± .005 (9,53 ± 0,13) A = .150 ± .015 (3,81 ± 0,38) B = .250 ± .010 (6,35 ± 0,25) C = .370 ±.015 (9,40 ± 0,38) D = .222 ± .020 (5,64 ± 0,51) Action 1,000,000 Total Travel *Complete Part Number Button Color 30-601 RED Red 30-601 BLK Black Actuating Force (oz.) Momentary .062 ± .010 10 ±4 (1,57 ± 0,25) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Operations at Rated Load 1 Amp 0.5 Amp 1,000,000 Total Travel Action Part Number 30-1 30-3 Actuating Force (oz.) .062 ± .010 10 ± 4 (1,57 ± 0,25) Button Color Red Black Mtg. Hole 17/64" (6,75) UL Recognized Operations at Rated Load At 5 Vdc At 20 Vdc 150 mA 20 mA Rating at 115 Vac Resistive Momentary Economy Version Electrical Ratings Standard Mtg. Hole 17/64" (6,75) Rating at 120 Vac Resistive Rating at 220 Vac Resistive Operations at Rated Load Part Number Button Color —– 6,000 30-1UL 30-3UL Red Black Actuating Force (oz.) Mtg. Hole 5 Amp Action Momentary Total Travel .062 ± .010 10 ± 4 (1,57 ± 0,25) 17/64" (6,75) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Butt Contact Pushbutton Switches DIMENSIONS in inches (and millimeters) Normally Closed–SPST and UL Recognized Normally Closed–SPST 30-2 30-2UL 30-6 30-6UL Rating at 115 Vac Resistive .162 ± .005 (4,11 ± 0,13) DIA. 1.005 (25,53) REF. C LABEL* *PART NUMBER AND E.I.A. DATE CODE LABEL .375 ± .005 (9,53 ± 0,13) Momentary Part Number 1,000,000 30-2 30-6 Actuating Force (oz.) .065 + .010/ - .015 8 ± 4 (1,65 + 0,25/ - 0,38) Rating at 220 Vac Resistive 5 Amp Pushbutton Switches 30-251* A = .209 ± .015 (5,31 ± 0,38) B = .250 ± .010 (6,35 ± 0,25) C = .410 ±.015 (10,41 ± 0,38) D = .222 ± .020 (5,64 ± 0,51) E = .187 ±.010 (4,75 ± 0,25) F = .100 ± .010 (2.54 ± 0,25) E A = .209 ± .015 (5,31 ± 0,38) B = .250 ± .010 (6,35 ± 0,25) C = .415 ± .015 (10,54 ± 0,38) D = .230 ± .015 (5,84 ± 0,38) E = .187 ±.010 (4,75 ± 0,25) F = .100 ± .010 (2.54 ± 0,25) .437 ± .010 (11,10 ± 0,25) ACROSS FLATS OF HEX .505 (12,83) REF. ACROSS CORNERS .375 ± .010 DIA. (9,53 ± 0,25) Button Color 6,000 30-2UL 30-6UL Black Red Total Travel Actuating Force (oz.) Rating at 115 Vac Resistive 1 Amp Rating at 220 Vac Resistive 1 T = 1/4-32 UNEF-2A THREAD O = O RING Operations at Rated Load /2 Amp 250,000 Total Travel Action *Complete Part Number 17/64" (6,75) Button Color 30-251 RED Red 30-251 BLK Black Actuating Force (oz.) .062 ± .020 ±8 (1,57 ± 30 0,51) Momentary Rating at 115 Vac Resistive A O LABEL* B C Mtg. Hole 17/64" (6,75) 1.104 (28,04) REF. 1 Amp Rating at 220 Vac Resistive Operations at Rated Load *Complete Part Number /2 Amp 250,000 30-252 RED 30-252 BLK Red Black Actuating Force (oz.) Mtg. Hole 12 ± 4 17/64" (6,75) 1 Action D .230 REF. (5.8) *PART NUMBER AND E.I.A. DATE CODE LABEL Mtg. Hole SNAP ON CAP F T HEX MTG NUT .312 (7,92) ACROSS FLATS .062 (1,57) THICK 1.091 (27,71) REF. D .186 REF. (4.7) E B C .015 (0,38) Normally Closed–SPST With Sealed Bushing and Button 30-252* A O HEX MTG NUT .312 (7,92) ACROSS FLATS .062 (1,57) THICK LABEL* *PART NUMBER AND E.I.A. DATE CODE LABEL 17/64" (6,75) SNAP ON CAP F T Mtg. Hole Part Number —– Action .375± .010 DIA. (9,53 ± 0,25) Black Red Operations at Rated Load .065 + .010/ - .015 Momentary (1,65 + 0,25/ - 8 ±4 0,38) Normally Open–SPST With Sealed Bushing and Button Button Color UL Recognized Rating at 120 Vac Resistive D .230 REF. (5.8) Operations at Rated Load Total Travel Action B HEX MOUNTING NUT .375 (9,53) ACROSS FLATS .109 (2,77) THICK A = .150 ± .015 (3,81 ± 0,38) B = .250 ± .010 (6,35 ± 0,25) C = .375 ±.015 (9,53 ± 0,38) D = .230± .020 (5,84 ± 0,51) 1 Amp 1/2 Amp A 1/4-32 UNEF-2A THREAD Rating at 220 Vac Resistive .437 ± .010 (11,10 ± 0,25) ACROSS FLATS OF HEX. .505 (12,83) REF. ACROSS CORNERS Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Momentary Total Travel .065 ± .010 (1,65 ± 0,25) Button Color T = 1/4-32 UNEF-2A THREAD O = O RING 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Butt Contact Pushbutton Switches DIMENSIONS in inches (and millimeters) Normally Open–SPST With Overtravel 30-15 30-37 .162 ± .005 (4,11 ± 0,13) 1/4-32 UNEF-2A THREAD A 1.077 (27,36) REF. B HEX NUT (SEE H) C A = .150 ± .015 (3,81 ± 0,38) B = .250 ± .010 (6,35 ± 0,25) C = .455 ±.015 .186 REF. (11,56 ± 0,38) (4.7) D = .222 ± .020 (5,64 ± 0,51) Rating at 115 Vac Resistive 1 Amp Rating at 220 Vac Resistive Operations at Rated Load Part Number /2 Amp 500,000 30-15 30-37 1 Total Travel Action LABEL* D .375 ± .005 (9,53 ± 0,13) Normally Open–SPST With Positive Feel Momentary .125 + .020/ - .010 .020" Overtravel (3,18 + 0,51/ - 0,25) 8±4 Red Black Mtg. Hole 17/64" (6,75) *PART NUMBER AND E.I.A. DATE CODE LABEL Pushbutton Switches H = HEX NUT 3/8 ± .010 (9,53 ± 0,25) ACROSS FLATS 3/32 ± .010 (2,38 ± 0,25) THICK Actuating Force (oz.) Button Color .390 ± .010 (9,91 ± 0,25) 30-17* A 1.35 (34,3) REF. E B 15/32-32 UNS-2A THREAD HEX NUT (2) (SEE H) C LABEL* D .186 REF (4.7) H = HEX NUT 9/16 ± .010 (14,29 ± 0,25) ACROSS FLATS 3/32 ± .010 (2,38 ± 0,25) THICK A = .392 ± .015 (9,96 ± 0,38) B = .421 ± .015 (10,69 ± 0,38) C = .315 ±.015 (8,00 ± 0,38) D = .222 ± .020 (5,64 ± 0,51) E = .205 (5,21) REF. Rating at 115 Vac Resistive 1 Amp Action Rating at 220 Vac Resistive 1 Operations at Rated Load /2 Amp 200,000 Total Travel Over Travel Momentary .156 ± .015 .046 (1,17) Pos. Feel (3,96 ± 0,38) Min. *Complete Part Number Button Color 30-17 RED Red 30-17 BLK Black Actuating Force (oz.) Mtg. Hole 18 ± 4 31/64" (12,30) *Complete Part Number Button Color *PART NUMBER AND E.I.A. DATE CODE LABEL Normally Open–SPST With Push-Pull .187 ± .005 (4,75 ± 0,13) 30-16* 15/32-32 UNS-2A THREAD A 1.45 (36,8) REF. HEX NUT (2) (SEE H) B C D LABEL* .186 REF (4.7) H = HEX NUT 9/16 ± .010 (14,29 ± 0,25) ACROSS FLATS 3/32 ± .010 (2,38 ± 0,25) THICK Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois A = .493 ± .015 (12,52 ± 0,38) B = .421 ± .015 (10,69 ± 0,38) C = .315 ±.015 (8,00 ± 0,38) D = .222 ± .020 (5,64 ± 0,51) Rating at 115 Vac Resistive Rating at 220 Vac Resistive Operations at Rated Load 1 Amp 1/2 Amp 100,000 Action Push-to-Make Total Travel .145 ± .015 (3,68 ± 0,38) 30-16 RED Red 30-16 BLK Black Actuating Force (oz.) Mtg. Hole 56 ± 16 31/64" (12,30) *PART NUMBER AND E.I.A. DATE CODE LABEL 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Butt Contact Pushbutton Switches DIMENSIONS in inches (and millimeters) Normally Closed–SPST With Push-Pull 1.87 – .005 (4,75 – 0,13) 30-32 15/32-32 UNS-2A THREAD A 1.36 (34.5) REF. HEX NUT (2) (SEE H) B C LABEL* D H = HEX NUT 9/16 – .010 (14,29 – 0,25) ACROSS FLATS 3/32 – .010 (2,38 – 0,25) THICK Rating at 115 Vac Resistive Operations at Rated Load 1 Amp 1/2 Amp 100,000 A = .493 – .015 (12,52 – 0,38) B = .421 – .015 Total (10,69 – 0,38) Action C = .225 –.015 Travel (5,72 – 0,38) .145 ± .015 D = .222 – .020 Pull-to-Make (3,68 ± 0,38) (5,64 – 0,51) Part Number Button Color 30-32 RED Red 30-32 BLK Black Actuating Force (oz.) Mtg. Hole 56 ± 16 31/64" (12,30) *PART NUMBER AND E.I.A. DATE CODE LABEL Specifications CIRCUITRY Pushbutton Switches Rating Criteria For UL recognized switches, see individual switch chart. File number is E35289. Contact Resistance: 25 milliohms maximum on a new switch Voltage Breakdown: 1,000 Vac between mutually insulated parts Insulation Resistance: 1,000 megohms minimum Operating Temperature: -40° to +85°C Mounting Torque: 2 inch-pounds Switch Materials and Finishes Mounting Nut and Cover Bushing: Brass, tin zinc ACCESSORIES Accessory Cap 30B1012-5 30B1012-8 30B1012-9 Rating at 220 Vac Resistive Base: Thermoset plastic Button: Polyester for 30-16 and 30-32; Phenolic for 30-17, 30-1UL, 30-2, 30-2UL, 30-3UL, 30-6 and 30-6UL; Polycarbonate for all others. Shorting Bar: Brass with gold over nickel plating for 30-601; brass with fine silver contact surface for all others. Terminals: Brass with gold over nickel plating for 30-601; commercial brass with fine silver contact surface and silver-plated for all others. Spring: Tinned music wire Button Cap: Nylon for 30-17; Polyethylene for 30-251 and 30-252. Detent Balls: Carbon steel, nickel-plated Terminal Type: Solder lug O-Ring Seal: (30-251, 30-252) Nitrile per MIL-P-5516 30C1023-1 Button Guard 10C1015-1 07C1040-1 Decorative Mounting Nuts Decorative Mounting Nuts Button Cap and Guard Part Number 30C1023-1 is made for switches with 1/4" (6,35) inch diameter bushings. It may be used with the following Series 30 switches: 30-1, 30-1 UL, 30-2, 30-2 UL, 30-3, 30-6, 30-15, 30-37, 30-251 BLK, 30-251 RED, 30-252 BLK, 30-252 RED, 30-601 BLK and 30-601 RED. The button cap is available in 3 colors: part number 30B1012-5 is red; part number 30B1012-8 is white; and part number 30B1012-9 is black. It may be fastened to the button with adhesive. It may be used with the following Series 30 switches: 30-1, 30-1UL, 30-2, 30-2UL, 30-3, 30-3UL, 30-15, 30-37, 30-601 BLK, and 30-601 RED. Part Number 07C1040-1 is made for switches with 15/32" (11,91) inch diameter bushings. It may be used with the following Series 30 switches: 30-16 BLK, 30-16 RED, 30-17 BLK, 30-17 RED, 30-32 BLK and 30-32 RED. The button guard, part number 10C1015-1 is made to be used with 15/32" (11,91) inch diameter switches to prevent unintentional actuation. It may be used with the following Series 30 switches: 30-16 BLK, 30-16 RED, 30-17 BLK, 30-17 RED, 30-32 BLK, and 30-32 RED Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois SPSt n.O. SPSt n.C. ORDERING INFORMATION Part Number Description and Button Color 30-1* 30-2* 30-3* 30-6* 30-15 30-16 BLK 30-16 RED 30-17 BLK 30-17 RED 30-32 BLK 30-32 RED 30-37 BLK 30-251 BLK 30-251 RED 30-252 BLK 30-252 RED 30-601 BLK 30-601 RED N.O., Standard, Red N.C., Standard, Black N.O., Black N.C., Red N.O., Overtravel, Red Push to Make, Black Push to Make, Red N.O., Positive Feel, Black N.O., Positive Feel, Red Pull to Make, Black Pull to Make, Red N.O., Overtravel, Black N.O., Sealed, Black N.O., Sealed, Red N.C., Sealed, Black N.C., Sealed, Red N.O., Economy, Black N.O., Economy, Red Accessory Part Number 30B1012-5 30B1012-8 30B1012-9 30C1023-1 07C1040-1 10C1015-1 Description Accessory Cap, Red Accessory Cap, White Accessory Cap, Black Accessory Nut Accessory Nut Button Guard *Add “UL” suffix to part number for UL recognized switches. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton Options and Accessories SEALED TERMINAL AND WIRE LEAD OPTIONS OPTION -E AND -EW FEATURES • 1/4, 1/2, and 1 Amp • Limit, Overtravel, or Panel Seal • Butt or Wiping Contact • Normally Open or Normally Closed • Momentary or Push/Pull • Series 23, 30, 39 and 46 Option -EW, Potted Base & 6" Wire Leads Option -E Epoxy-Sealed Terminals SPECIFICATIONS Rating Criteria Pushbutton Switches Make and Break Current Rating: See page for standard part number Contact Resistance: 25 milliohms maximum on a new switch. Less than 4 milliohms per inch of wire for wire lead option styles. Insulation Resistance: 1,000 megohms minimum between mutually insulated parts Voltage Breakdown: 1,000 Vac minimum between mutually insulated parts Materials and Finishes Potting Sleeve (Series 39): Thermoset Plastic Wire Leads: #26AWG, (.99mm diameter) insulated Teflon, Copper stranded wire, per MlL-W-16878,Type E. Ends are stripped 0.250" (6.35) and solder dipped. For other specifications, see Page References. Standard Part Number Red Button Standard Part Number Black Button 23-1 30-1 30-15 30-17 RED 30-16 RED 30-251 RED 30-252 RED 30-32 RED 30-6 30-601 RED 39-1* –––– 39-12* 39-101 39-351 RED 39-352 RED* 39-601 RED 39-701*** 39-702*** 46-101 RED 46-102 RED 46-110 RED 46-111 RED 46-150 RED 46-151 RED 46-200 RED 46-201 RED 46-270 RED 46-271 RED 23-4 30-3 30-37 30-17 BLK 30-16 BLK 30-251 BLK 30-252 BLK 30-32 BLK 30-2 30-601 BLK 39-3* 39-2 39-24* –––– 39-351 BLK 39-352 BLK* 39-601 BLK –––– –––– 46-101 BLK 46-102 BLK 46-110 BLK 46-111 BLK 46-150 BLK 46-151 BLK 46-200 BLK 46-201 BLK 46-270 BLK 46-271 BLK Choices of Suffix -E -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -EW** -E,- EW -EW** -EW** -EW** -E, -EW -EW* -EW** -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E, -EW -E -E -E -E Length Behind Panel In inches (and millimeters) -EW Style Standard Switch Body & Terminals 0.665 0.592 0.679 0.958 0.958 0.632 0.645 0.867 0.605 0.592 0.315 0.490 0.455 0.650 0.350 0.529 0.315 0.800 0.510 0.890 0.890 0.890 0.890 0.957 0.957 0.921 0.921 0.957 0.957 (16,89) (15,04) (17,25) (24,33) (24,33) (16,05) (16,38) (22,02) (15,37) (15,04) (8,00) (12,45) (11,56) (16,51) (8,89) (13,44) (8,00) (20,32) (12,95) (22,61) (22,61) (22,61) (22,61) (24,31) (24,31) (23,39) (23,39) (24,31) (24,31) –––– 0.645 0.728 1.007 1.007 0.685 0.700 0.896 0.640 0.645 0.440 0.575 0.575 0.775 0.450 0.630 0.440 0.925 0.750 0.957 0.957 0.957 0.957 1.024 1.024 –––– –––– –––– –––– (16,38) (18,49) (25,58) (25,58) (17,40) (17,78) (22,76) (16,26) (16,38) (11,18) (14,61) (14,61) (19,69) (11,43) (16,00) (11,18) (23,50) (19,05) (24,31) (24,31) (24,31) (24,31) (26,01) (26,01) *Epoxy potting sleeve enlarges the diameter of the -EW style to 0.300 (7,62). **Sealed terminal (-E) option is not necessary; terminals have sealed construction. ***Natural Color Button †Adjustable from 1.214 (30,84) to 1.334 (33,88) dependent on button height, see switch pages. Pushbutton 60 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton Options and Accessories ORDERING INFORMATION Use the Selector Charts at the beginning of the section to select a series. Use the pages listed there or referenced here to select a switch. Standard Part Number Choice of Button Color (see switch pages) (see switch pages) –––– –––– –––– –––– 30-01-01-500-XX 30-01-04-500-XX 30-05-01-502-XX 30-05-04-502-XX –––– 46-01-05-500-XX 46-01-07-500-XX 46-01-08-500-XX 46-01-09-500-XX 46-05-05-502-XX 46-05-07-502-XX 46-05-08-502-XX 46-05-09-502-XX –––– –––– –––– –––– 30-001-A-XX 30-002-A-XX 30-015-A-XX 30-017-A-XX 30-1-1-50-XX 30-1-4-50-XX 30-5-1-52-XX 30-5-4-52-XX 30-601-A-XX 46-1-5-50-XX 46-1-7-50-XX 46-1-8-50-XX 46-1-9-50-XX 46-5-5-52-XX 46-5-7-52-XX 46-5-8-52-XX 46-5-9-52-XX 46-102-A-XX 46-111-A-XX 46-200-A-XX 46-201-A-XX To order epoxy sealed terminals, add the suffix E to the selected part number as allowed in the chart. Example: 30-1-E. To order the epoxy-potted version with 6-inch wire leads, use the suffix -EW as allowed in the chart. Example: 39-1-EW Available From Your Local Grayhill Distributors. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Choices of Options -E, -E, -E, -E, -E, -E, -E, -E, -E, -E, -E, -E -E -E, -E, -E -E -E, -E, -E -E -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW -EW Length Behind Panel In inches (and millimeters) Standard Switch & Terminals 1.119 (28,42) 1.132 (28,75) 1.204 (30,58) Adjustable† 1.100 (27,94) 1.257 (31,93) 0.930 (23,62) 1.130 (28,70) 1.119 (28,42) 1.361 (34,57) 1.451 (36,86) 1.381 (35,08) 1.381 (35,08) 1.179 (29,95) 1.465 (37,21) 1.188 (30,18) 1.317 (33,45) 1.417 (35,99) 1.417 (35,99) 1.448 (36,78) 1.448 (36,78) -EW Style Body 1.172 (29,77) 1.167 (29,64) 1.253 (31,83) Adjustable† 1.153 (29,29) 1.310 (33,27) 0.983 (24,97) 1.183 (30,05) 1.172 (29,77) 1.428 (36,27) 1.518 (38,56) –––– –––– 1.246 (31,65) 1.532 (38,91) –––– –––– 1.484 (37,69) 1.484 (37,69) –––– –––– CIRCUITRY: Series 46 N.C. (YELLOW) C1 (RED) N.O. (GREEN) *Epoxy potting sleeve enlarges the diameter of the -EW style to 0.300 (7,62). **Sealed terminal (-E) option is not necessary; terminals have sealed construction. ***Natural Color Button †Adjustable from 1.214 (30,84) to 1.334 (33,88) dependent on button height, see switch pages. SPDT WIPING CONTACTS Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton 61 Pushbutton Switches Standard Part Number Without Options Choice of Button Color Pushbutton Options and Accessories ACCESSORIES For Pushbutton Switches Button Caps Decorative Mounting Nuts Pendant Housing Button Guard DIMENSIONS In Inches (and millimeters) .75 (19,1) ACROSS FLATS Decorative Mounting Nuts .44 (11,2) ACROSS FLATS .50 (12,7) ACROSS FLATS 30C1023-1 Pushbutton Switches .46 (11,7) DIA. .52 (13,2) DIA. Brass, nickel-plated for 1/4" (6,35) bushing. .09 (2,3) 07C1040-1 23C1024-1 .77 (19,6) DIA. Brass, nickel-plated for 5/16" (7,93) bushing. Brass, nickel-plated for 15/32" (11,9) bushing. .12 (3,1) .09 (2,3) Button Caps and Guard .89 (22,6) DIA. 30B1012 07Z1047 Thermosetting plastic (Fasten to button with cyanoacrylate adhesive) black, red or white. .19 (4,8) .09 (2,3) .34 (8,6) For use with all Series 30 and 39 switches except part number 39-101. See switch pages. .25 (6,4) DIA. 07Z4950 07Z5051 .33 (8,4) REF. Flat Cap .89 (22,6) 1.19 1.03 (30,2) (26,16) .27 (6,86) DIA. Brass, zinc trivalent chromate-plated for 15/ 32" (11,9) bushing. .41 (10,4) .59 (15,0) .08 (2,0) Housing 2.45 (62,23) .42 (10,67) Thermoplastic, black or red color. For use with Series 2000 and Series 7 switches. See switch pages. 1.00 (25,4) DIA. Remote Switching Accessories Pendant Housing and Caps 10C1015-1 1.19 (30,2) .08 (2,03) .25 (6,4) .89 (22,6) Recessed Cap 1.04 1.19 (30,2) (26,4) .48 (12,2) .48 (12,2) Application: All grayhill pushbutton switches with 15/32-32 bushings: catalog numbers 2201, 2202, 07-7, 07-8, 07-21, 07-22, 07-26, 4001, 4002, 10-9, 10-10, 10-100, 10-101, 30-16, 30-17 and 30-32. any other switch with 15/32-32 bushing if it fits housing. Material: Thermoplastic Specials: other colors available on special order. ORDERING INFORMATION: Mounting Nuts, Button Caps, and Guards Part Number Color 07C1040-1 23C1024 30C1023-1 07Z1047-1 BLK 07Z1047-2 RED 10C1015-1 30B1012-5 30B1012-8 30B1012-9 Decorative Nut Decorative Nut Decorative Nut Black Button Cap Red Button Cap Button Guard Red Cap White Cap Black Cap Pendant Housing and Caps Part Number 07Z4950 07Z4950 07Z5051 07Z5051 RED BLK RED BLK Description Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Red Flat Cap & Housing Black Flat Cap & Housing Red Rcssd Cap & Housing Black Rcssd Cap & Housing Sold only as sets of one housing and one cap. Pushbutton 62 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
30-32 RED 价格&库存
很抱歉,暂时无法提供与“30-32 RED”相匹配的价格&库存,您可以联系我们找货
30-32 RED
  • 2+376.548502+48.77620
  • 5+341.741845+44.26752
  • 10+242.4042710+31.39983
库存:24
30-32 RED
30-32 RED
  • 1+348.926831+45.19823
  • 11+229.7217511+29.75700
  • 21+224.0476021+29.02200
库存:21
