58J8A90-01B02N
58J8A90-01B02N
    GRAYHILLINC.
58J8A90-01B02N 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Keylock Rotary Switches Series 58 Single Deck, Antistatic Lock features • Minimum Space Behind Panel • 15,000 Vdc Static Protection • 5 Tumbler-Plate Security • In-Panel Key Recoding Dimensions Switch Features • Economical • Solder Lug or PC Mount • 36°, 45°, 60°, or 90° Throws • 1 or 2 Poles Per Switch • Up to 10 Positions for 1 Pole • 200 mA for 25,000 Cycles in inches (and millimeters) Standard Style Ø .900 (Ø 22,86) MOUNTING NUT .875 (22,23) ACROSS FLATS .125 (3,18) THICK SHOWN IN THIS VIEW ONLY A TERMINAL FOR POSITION 1 COMMON TERMINAL 4 3 2 1 POSITION INDICATOR ARROW 36°, 45°, 60°, or 90° Angle of Throw LOCKWASHER Ø 1.062 ± .020 (Ø 26,97 ± 0,51) SHOWN IN THIS VIEW ONLY .268 ± .015 (6,81 ± 0,38) .792 ± .020 (20,12 ± 0,51) .625 ± .010 (15,88 ± 0,25) .187 ± .015 (4,75 ± 0,38) All terminals are provided regardless of the number of active switch positions. 1.957 ± .062 (49,71 ± 1,57) PC Mount Style 36°, 45°, 60, or 90° Angle of Throw 2 1 Dimensions not shown are the same as above. 4 3 Rotary Switches .260 ± .020 Keyslot is shown in (6,60 ± 0,51) switch position 1. Key removal position A. Key is inserted cut edge down. .125 ± .015 (3,18 ± 0,38) 1.875 ± .062 (47,63 ± 1,57) Grayhill part number and date code marked on label. Customer part number marked on request. terminal DETAIL RECOMMENDED PANEL CUT Solder Lug A Solder Lug Common E G B PC Mount H A = .064 ± .005 (1,63±0,13) B = .032 ± .004 (0,81±0,10) C D C = .050 ± .010 (1,27±0,25) D = .062 Ø ± .002 (1,57 Ø ±0,05) G = .020 ± .003 (0,51 ±0,08) H = .062 ± .004 (1,57 ±0,10) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois G F E = .125 ± .015 (3,18 ±0,38) F = .020 ± .003 (0,51 ±0,08) .629 + .010 –.000 (15,98 + 0,25) H .750 + .015 –.000 (19,05 + 0,38) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Keylock Rotary Switches circuitry 36° Angle of Throw 45° Angle of Throw REAR VIEW REAR VIEW COMMON TERMINAL (1 POLE) .320 ± .015 (8,13 ± 0,38) DIAMETER CIRCLE OF TERMINAL CENTERS COMMON TERMINAL (1 POLE) .320 ± .015 (8,13 ± 0,38) DIAMETER CIRCLE OF TERMINAL CENTERS .125 ± .015 (3,18 ± 0,38) 18˚ POS. 1 LOCATION OF COMMONS 2 POLES 36˚ 8 VIEWED FROM FRONT END; SHOWN IN POSITION 1. 1 8 1 8 6 6 4 TWO POLE ONE POLE 90° Angle of Throw REAR VIEW 60° Angle of Throw COMMON TERMINAL (1 POLE) COMMON TERMINAL (1 POLE) .320 ± .015 (8,13 ± 0,38) DIAMETER CIRCLE OF TERMINAL CENTERS .125 ± .015 (3,18 ± 0,38) 30˚ 5 4 5 5 TWO POLE 3 6 3 6 4 5 REAR VIEW 3 C1 ONE POLE C1 C2 7 4 2 7 2 7 C2 3 7 LOCATION OF COMMONS 2 POLES 45˚ VIEWED FROM FRONT END; SHOWN IN POSITION 1. 10 1 10 1 9 9 2 2 8 .125 ± .015 (3,18 ± 0,38) 22.5˚ POS. 1 LOCATION OF COMMONS 2 POLES .320 ± .015 (8,13 ± 0,38) DIAMETER CIRCLE OF TERMINAL CENTERS .125 ± .015 (3,18 ± 0,38) 45˚ POS. 1 LOCATION OF COMMONS 2 POLES 90˚ VIEWED FROM FRONT END; SHOWN IN POSITION 1. 6 6 1 1 2 5 4 POS. 1 Rotary Switches 60˚ 5 C2 3 ONE POLE C1 2 3 TWO POLE 3 ONE POLE 1 C1 2 TWO POLE switch Specifications Materials & Finishes Keys: Brass; 2 supplied Lock Barrel & Plug: Zinc, clear chromate Lockwasher: Steel, tin zinc plated Mounting Nut: Steel, nickel-plated Tumbler Plates: Brass Electrical Characteristics Chart is shown for non-shorting contacts and resistive load and for the life limiting criteria indicated below. The data for the curve was measured at sea level, 25°C and 68% relative humidity. Contact Grayhill for more information if any of the following is true: life limiting criteria are more critical than those listed; more cycles of operation are required; a larger make and break current is required; the operating environment includes elevated temperatures or reduced pressures. 300 CURRENT MILLIAMPS Mounting: By bushing, nut and lockwasher Keying: All locks keyed alike except by special order Orientation of Keylock Switch: Lock flats on both sides with key upright (cut side down) in position 1. Key Removals: 36° Throw Switch At every position or At 0° & 180° 45° Throw Switch At every position or At 0°, 90°, 180°, 270° 60° Throw Switch At every position or At 0°, 180° 90° Throw Switch At every position or At 0°, 180° Optional pulls Contact Grayhill 4 C2 Lock Specifications General Characteristics 1 4 2 3 4 VIEWED FROM FRONT END; SHOWN IN POSITION 1. A 200 B Curve A: 220 Vac all angles of throw. Curve B: 115 Vac and 30 Vdc for all angles of throw. 100 0 0 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 10 20 CYCLES x 1000 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 30 Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Keylock Rotary Switches switch Specifications Continued Contact Resistance: Initially: less than 10 mΩ End of life: less than 50 mΩ Insulation Resistance: (Between mutually insulated parts) Initially: 50,000 MΩ Minimum: 10,000 MΩ Breakdown Voltage: (Between mutually insulated parts) more than 600 Vac Life Expectancy: Per chart; cycle is 1 rotation thru all active positions plus a full return. Carry Current: 6A; maximum temperature rise 20°C Anti-Static Voltage: Anti-static types tested to withstand 15,000 Vdc Mechanical Characteristics Switching Mode: Shorting (make before break) or non-shorting (break before make) as limited by the Choices chart Type of Contact: Wiping Number of Terminals: All switches are provided with the full circle of terminals regardless of the number of active positions Stop Strength: 1.70 Nm maximum (15.0 inlbs) Switching Torque: 8 to 16 in-ozs Materials and Finishes Switch Base: Thermoset plastic Switch Housing: Nylon Detent Rotor: Nylon Detent Balls: Steel, nickel-plated Detent Springs, and Contact Springs: Stainless steel Common Ring: Brass, gold plate over silver plate Terminals: Brass, gold over silver and nickel plate Rotor Contact: Precious metal, gold alloy Choices and limitations Lock Style and Description* Switch Style and Angle of No. Of Poles/ Description Throw Decks Deck Positions Per Pole** Shorting or Non-Shrtg. Series 58J Switches J4: Standard–Key pulls at Position 1 and at 90 Degree Increments J8: Standard–Key Pulls at Each Position A = Standard, Solder Lugs P = Standard, PC Mount A = Standard, Solder Lugs P = Standard, PC Mount Rotary Switches J9: Standard–Key Pulls at Position 1 and at 180 Degrees A = Standard, Solder Lugs P = Standard, PC Mount 45° 1 1 2 02 to 08 02 to 04 N or S N or S 36° 1 1 2 02 to 10 02 to 05 N or S N or S 45° 1 1 2 02 to 08 02 to 04 N or S N or S 90° 1 1 2 02 to 04 02 N N 36° 1 1 2 02 to 10 02 to 05 N or S N or S 45° 1 1 2 02 to 08 02 to 04 N or S N or S 60° 1 1 2 02 to 06 02 to 03 N N 90° 1 1 02 to 04 N 2 02 N *Standard Keylock has anti-static protection. All keylock versions available without anti-static protection, with a reduced overall body length. Contact Grayhill for more information. **For single pole switches with maximum positions, specify continuous rotation or fixed stop when ordering. Ordering Information Series Lock Style: per Choices Chart J4, J8, J9 Switch Style: per Choices Chart A or P Angle of Throw: 36, 45, 60 or 90 (per Choices chart) Number of Decks: 01 Poles per Deck: = 1 or 2 (per Choices chart) Positions per Pole: 02 thru 10 (per Choices chart) Type of Contacts: (per Choices chart) N = Non-shorting S = Shorting Stop Arrangement Suffix: (needed only for 1-pole switches with maximum positions) F = Fixed stop between last and first positions *Leave blank for continuous rotation Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. 58J8A36-01-1-10N-F Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
58J8A90-01B02N 价格&库存
很抱歉,暂时无法提供与“58J8A90-01B02N”相匹配的价格&库存,您可以联系我们找货
58J8A90-01B02N
