Optical Encoders
SERIES 63K
High Resolution, Ball Bearing,
4-Pin
FEATURES
• 25, 32, 50, 64, 100, 128 and 256
Cycles per Revolution Available
• Sealed Version Available
• Rugged Construction
• Cable or Pin Version
• 300 Million Life Cycles
• 5,000 RPM Shaft Rotation
DIMENSIONS In inches (and millimeters)
TOP VIEW
.250
(6.35)
.215
(5.46)
KEYWAY DEPTH
1.250 DIA
(31.75)
.025 X 45˚
(.64)
CHAMFER
.249/.250 DIA
(6.32/6.34)
.066
(1.68)
1/2 - 32
UN-2A
THREADS
.725±.025
(18.41±.64)
GRAYHILL XXXX X-X
63KXXX
XXXX X-X
XX
.776±.025
(19.71±.64)
.650 DIA
(16.51)
MOUNTING
SURFACE
.219
(5.57)
.501
(12.73)
PIN #1
.100
(2.54)
.225
(5.71)
.150
(3.81)
.300
(7.62)
TOP VIEW
1.250 DIA
(31.75)
.250
(6.35)
.215
(5.46)
KEYWAY DEPTH
.025 X 45˚
(.64)
CHAMFER
.350
(8.89)
.033
(.84)
.066
(1.68)
1/2 - 32
UN-2A
THREADS
.725±.025
(18.42±.64)
GRAYHILL XXXX X-X
63KXXX-XXX
.219
(5.57)
.249/.250 DIA
(6.32/6.34)
.650 DIA
(16.51)
MOUNTING
SURFACE
XXXX X-X
XX-XXX
.501
(12.73)
PIN #1
CONNECTOR IS
MOLEX P/N
14-56-3046
OR EQUIVALENT
CABLE LENGTH
XXX±.25
(XXX±.7)
UNLESS OTHERWISE SPECIFIED, DIMENSION TOLERANCES ARE AS FOLLOWS:
LINEAR ±.010 (.25), DIAMETERS ±.010 (.025), ANGULAR ±5˚
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
I-44
Optical and Mechanical
Encoders
.350
(8.89)
.033
(.84)
Optical Encoders
CIRCUITRY AND WAVEFORM: Standard Quadrature 2-Bit Code
PIN #
GROUND
1
OUTPUT B
2
1 CYCLE
OUTPUT
A
10 KΩ
OUTPUT A
OUTPUT
B
3
4.7 KΩ
10 KΩ
POWER 5V
4
CHANNEL A LEADS CHANNEL B BY
90˚ ± 45˚ IN ALL ROTATIONS FOR
CLOCKWISE ROTATION OF SHAFT.
SPECIFICATIONS
Encoders
Electrical Ratings
Environmental Ratings
Materials and Finishes
Operating Voltage: 5.0 ±.25 Vdc
Supply Current: 30 mA maximum at 5 Vdc
Logic Output Characteristics:
Output Type: Open collector with integrated
Schmitt Trigger and 10 KΩ pull-up resistor
Maximum Sink Current: 16 mA at .40 volts
Power Consumption: 150 mW maximum
Optical Rise Time: 500 nS typical
Optical Fall Time: 14 nS typical
Operating Temperature Range: -40°C to 85°C
Storage Temperature Range: -55°C to 100°C
Relative Humidity: 90-95% at 40°C for 96
hours
Vibration Resistance: Harmonic motion with
amplitude of 15g, within a varied 10 to 2000
Hz frequency for 12 hours per MIL-STD-202,
Method 204
Shock Resistance: Test 1: 100g for 6 mS,
half-sine wave with velocity change of 12.3 ft/s.
Test 2: 100g for 6 mS, sawtooth wave with
velocity change of 9.7 ft/s.
Bushing: 6262-T9 aluminum alloy or
zinc diecast
Housing: Hiloy 610B
Code Rotor and Aperture: Chemically etched
stainless steel/electroformed nickel
Printed Circuit Board: NEMA Grade FR-4.
Five microinches minimum gold over 100
microinches minimum nickel over copper
Optical Barrier: Polyphenylene sulfide, 94 V-0
Backplate: Polyester
Header: Phosphor bronze, 200 microinches
tin over 50 microinches nickel (pin version
only)
Infrared Emitter: Gallium aluminum arsenide
Photo IC: Planar silicon
Retaining Ring: Stainless steel
Cable: 26 AWG, stranded/tinned wire, PVC
coated on .100 (2,54) centers (cable version
only)
Connector: Glass-filled PCT, UL94V-0
Mechanical Ratings
Mechanical Life: 300 million revolutions
Time Life: Guaranteed for 10 years of
continuous operation (calculated from emitter
degradation data)
Mounting Torque: 20 in-lbs maximum
Terminal Strength: 5 lbs terminal pull-out
force minimum
Solderability: 95% free of pin holes and voids
Operating Torque: 0.5 in-oz maximum (no
detents) for unsealed versions
Externally Applied Shaft Force: Axial: 15 lbs
maximum; Radial: 15 lbs maximum
ORDERING INFORMATION
Bearing Subassembly
Bearing: NSK ABEC 5 (stainless steel)
Preload Collar: 303 (stainless steel)
Spacer: 303 (stainless steel)
Bellville Spring: spring steel (stainless steel)
Series
Style: K = Standard, 4-pin, high resolution
KS = Sealed, 4-pin, high resolution
Cycles: per channel per revolution = 25, 32, 50, 64, 100, 128, 256
63KS256–020
Termination:
Blank (no dash or numbers): pins as described in drawing.
Cable Termination: 020 = 2.0 inches minimum to 250 = 25 inches maximum. Provided in increments of 1/2
inch. (Example 035 = 3.5", 060 = 6".) Cable is terminated with standard Molex part no. 14-56-3046. Use any
standard .100 center 4-pin header to interface with cable. Recommended to be mounted with Molex
header part no. 70543-0003 or 70553-0003.
Control knobs available, see page I-57.
Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill.
I-45
很抱歉,暂时无法提供与“63K64”相匹配的价格&库存,您可以联系我们找货
