62SG11-M0-040C
62SG11-M0-040C
    GRAYHILLINC.
    ENCODER OPT 12 POS PB 10" CBL CO
62SG11-M0-040C 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders SERIES 62SG Compact / Cost Effective FEATURES • Just 0.3-inch behind panel depth • Over 1 million rotational cycles • 2-bit gray code output • Quadrature coding • Available in 16, 24 and 32 detent positions • Optional integrated pushbutton • Light pipe technology • Cost competitive with mechanical encoders at higher volumes APPLICATIONS • Automotive - audio systems - navigation systems • Medical - patient monitoring systems • Test & Measurement - analyzers - oscilloscopes • Audio & Video - consumer electronics - professional editing equipment DIMENSIONS in inches (and millimeters) SUGGESTED MOUNTING PANEL CUTOUT Optical and Mechanical Encoders .161 ± .002 [ 4,09 ± 0,05 ] Ø .380 ± .003 [ 9,65 ± 0,07 ] .057 ± .002 [ 1,45 ± 0,05 ] Unless otherwise specified, standard tolerances are: Linear ± .025 Diameter ± .010 Angle ± 2.0 0 OTHER TERMINATION OPTIONS P/N JST SHROUDED HEADER SM08B-GHS-TB MATING CONNECTOR P/N JST HOUSING GHR-08V-S RAC Right Angle AngleConnector Connector RAC -- Right Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .050” .050”Stripped Stripped Cable Cable .050” .050”Pin Pin Header Header 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Optical Encoders WAVEFORM AND TRUTH TABLE SPECIFICATIONS Environmental Specifications Rotary Electrical and Mechanical Specifications Operating Voltage: 5.00 ± 0.25 Vdc Supply Current: 30 mA maximum Logic Output Characteristics: Logic High: VOH = 3.0 Vdc MIN at VCC = 4.75 Vdc with 10 kΩ PULL-UP RESISTOR Logic Low: VOL = 1.0 Vdc MAX at VCC = 5.25 Vdc with 10 kΩ PULL-UP RESISTOR Output: Open Collector Phototransistor Optical Rise Time: 30ms maximum Optical Fall Time: 30ms maximum Mechanical Life: 1,000,000 cycles of operation. 1 cycle is a rotation through all positions and a full return Mounting Torque: 15in-lbs. maximum Shaft Pushout Force: 45 lbs. minimum Terminal Strength: 15 lbs. cable pull out force minimum Solderability: 95% free of pin holes & voids Pushbutton Electrical and Mechanical Specifications Rating: 30 mA @ 5 Vdc Contact Resistance:
62SG11-M0-040C 价格&库存
很抱歉,暂时无法提供与“62SG11-M0-040C”相匹配的价格&库存,您可以联系我们找货
62SG11-M0-040C
  • 1+389.537121+48.84871
62SG11-M0-040C
    • 1+137.375891+17.22720
    • 3+135.694103+17.01630
    • 10+133.8352710+16.78320
    • 20+132.7730920+16.65000
    • 40+130.8257540+16.40580
