68A115Q-L9N-06C
68A115Q-L9N-06C
    GRAYHILLINC.
    ENCODER FINGERTIP KNOB, 3.3V, 3"
68A115Q-L9N-06C 数据手册
Hall Effect SERIES 68A Hall Effect Encoder FEATURES • Quadrature output - (push / pull type) • Debris resistant hall effect sensor technology • Over 1 million rotational cycles • Optional integrated pushbutton • Low power consumption • Reverse voltage protection • Choice of cable lengths and termination • Available in 5Vdc and 3.3Vdc • High torque version available APPLICATIONS • Medical Equipment • Test & Measurement • Audio / Visual • Agriculture & Construction Vehicles DIMENSIONS in inches (and millimeters) Hall Effect .161 ± .002 [ 4,09 ± 0,05 ] Ø .380 ± .003 [ 9,65 ± 0,07 ] .057 ± .002 [ 1,45 ± 0,05 ] Suggested Mounting Panel Cutout TERMINATION OPTIONS M AT I N G C O N N E C T O R AMP P/N 7-215079-6 .050” Connector Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois PIN 1 .050” Stripped Cable .050” Pin Header 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Hall-Effect SCHEMATICS, WAVEFORM, AND TRUTH TABLE FIG. 1 - 68A ELECTRICAL CONNECTION DIAGRAM PIN # Hall Effect Sensor Microcontroller PB 6 VDD 5 OUT A 4 OUT B 3 PB1 2 PB2 1 GND *Customized electrical outputs are available. Contact Grayhill for additional details. SPECIFICATIONS Electrical Specifications Operating Voltage: Minimum 3.0 V, maximum 3.6 V (3.3V Style); minimum 4.5 V, maximum 5.5 V (5V Style) Absolute Maximum Voltage* on VDD pin: -4.0 V min., +4.0 V max (3.3V style); -6.5 V min., +6.5 V max (5V style) Avg Supply Current for 3.3V Style: Typical: 1.2 mA, Maximum: 2.0 mA (at 3.30 V) Peak Supply Current for 3.3V Style: 12 mA (at 3.30 V) Avg Supply Current for 5V Style: Typical: 1.8 mA, Maximum: 3.0mA (at 5.00 V) Peak Supply Current for 5.0V Style: 12 mA (at 5.00 V) Output Low Voltage: 0.6V maximum for IOL = 3mA, VDD = 3.3V and for IOL = 3mA, VDD = 5.0V Output High Voltage: 2.6V minimum for IOH = -1.5mA, VDD = 3.3V, 4.3V minimum for IOH = -2mA, VDD = 5.0V Power-Up Time: A & B outputs valid 120 ms (max) after VDD reaches 3.0 V (3.3 V Style) or 4.5 V (5V Style). Hall Effect Soldering Recommendation Hand solder only per IPC J-STD-001 Mechanical Specifications Mechanical Life: 1,000,000 cycles of operation. 1 cycle is a rotation through all positions and a full return Average Rotational Torque: Low Detent = 2.0±1.4 in-oz initially High = 3.5±1.4 in-oz initially 40% of initial value after 1 million cycles Non-Detented: 1.5 in-oz maximum Maximum rotational speed: 100 rpm Mounting Torque: 15in-lbs. maximum Shaft Pushout / Pulloutut Force: 45 lbs. / 45 lbs. minimum Terminal Strength: 15 lbs. minimum. Cable or Header pullout force, MIL-STD-202, Method 211A, Test Condition A Solderability: 95% free of pin holes & voids, MILSTD-202, Method 208 Environmental Specifications Operating Temperature: -40°C to 85°C, IEC 68-21, Test Aa and IEC 68-2-2, Test Aa Storage Temperature: -55°C to 85°C, IEC 68-2-1, Method Aa and IEC 68-2-2, Method Ba Humidity: 96 hours @ 90-95% humidity @ 40°C, MIL-STD-202, Method 103B Mechanical Vibration: Harmonic motion with amplitude of 15g within a varied frequency of 10 to 2000 Hz for 12 hours, MILSTD-202, Method 204, Test Condition B Mechanical Shock: Test 1: 100g for 6 ms half-sine wave with a velocity change of 12.3 ft/s. Test 2: 100g for 6 ms sawtooth wave with a velocity change of 9.7 ft/s, MIL-STD-202, Method 213, Test Condition C and I Seal: IP67, Meets IEC 60529 Pushbutton Electrical and Mechanical Specifications Electrical Ratings: 6.0 V max, 10 mA, Resistive Absolute Maximum Voltage* on Pins 2 & 3: 6.0 V Contact Resistance:
68A115Q-L9N-06C 价格&库存
很抱歉,暂时无法提供与“68A115Q-L9N-06C”相匹配的价格&库存,您可以联系我们找货
