68PARN-060C
68PARN-060C
    GRAYHILLINC.
    SENSOR ROTARY 360DEG CBL W/CONN
68PARN-060C 数据手册
Hall Effect SERIES 68P Long Life Potentiometer Substitute FEATURES • Ratiometric analog output • Debris resistant Hall effect sensor technology • 7 million rotational cycles • Single or redundant output • Custom output options • Optional shaft and panel seal • Reverse voltage and overvoltage protection APPLICATIONS • Test & Measurement equipment • Audio / Visual equipment • Potentiometer substitute with long life • Agriculture & Construction engine speed control DIMENSIONS in inches [millimeters] Ø .380 ± .003 [ 9,65 ± 0,07 ] .057 ± .002 [ 1,45 ± 0,05 ] Suggested Mounting Panel Cutout TERMINATION OPTIONS 654321 654321 654321 PIN 1 PIN 1 M AT I N G C O N N E C T O R AMP P/N 7-215079-6 .050” Connector Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .050” Stripped Cable .050” Pin Header 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Hall Effect .161 ± .002 [ 4,09 ± 0,05 ] Hall-Effect ELECTRICAL SCHEMATIC Hall Effect Sensor A VDD Reserved OUT_A OUT_B PIN # 5 3 2 Gnd 1 Redundant OUT Hall Effect Sensor 4 Reserved Hall Effect Sensor B VDD 6 PIN # 6 5 Reserved 4 Reserved 3 Reserved 2 Gnd 1 Single Sensor * Customized electrical outputs are available. Contact Grayhill for additional details. SPECIFICATIONS Electrical Ratings Solderability: 95% free of pin holes & voids, MILSTD-202, Method 208 Operating Voltage: Minimum 4.5V, maximum 5.5V (VDD) Absolute Maximum Voltage* on Pin 6 (VDD): -18V to +27V Supply Current Redundant Sensors: Typical 22mA, maximum 40mA Supply Current Single Sensor: Typical 11mA, maximum 20mA Output Current: 2.5mA max Recommended Load: 2K-5.6K Ohms Pull-Down Resistor Power-Up Time: 20ms Sensor Error: When an internal sensor error occurs, the ouput goes to < 4% of supply (VDD) Environmental Ratings Operating Temperature: -40°C to 85°C, IEC 68-21, Test Aa and IEC 68-2-2, Test Aa Storage Temperature: -55°C to 85°C, IEC 68-2-1, Method Aa and IEC 68-2-2, Method Ba Humidity: 96 hours @ 90-95% humidity @ 40°C, MIL-STD-202, Method 103B Mechanical Vibration: Harmonic motion with amplitude of 15g within a varied frequency of 10 to 2000 Hz for 12 hours, MILSTD-202, Method 204, Test Condition B Mechanical Shock: Test 1: 100g for 6 ms half-sine wave with a velocity change of 12.3 ft/s. Test 2: 100g for 6 ms sawtooth wave with a velocity change of 9.7 ft/s, MIL-STD-202, Method 213, Test Condition C and I Thermal Shock: 25 cycles from -55°C to 100°C, MIL-STD-810F, Method 503.4, procedure I Seal: IP67, Meets IEC 60529 Soldering Recommendation Hand solder only per IPC J-STD-001 Physical & Mechanical Ratings Mechanical Hall Effect Life: 7,000,000 cycles of operation. 1 cycle is a rotation through all positions and a full return Average Rotational Torque: 1.5 in-oz maximum Maximum rotational speed: 100 rpm Mounting Torque: 15 in-lbs. maximum Shaft Pushout / Pulloutut Force: 45 lbs. / 45 lbs. minimum Terminal Strength: 15 lbs. minimum. Cable or Header pullout force, MIL-STD-202, Method 211A, Test Condition A EMC Ratings Radiated Immunity: Meets ANSI/ASAE EP455 5.16 (100 V/m, 0. 014-1000 MHz, 3 orientations) Conducted Immunity: Meets IEC 61000-4-6, Level 3 Radiated Emissions: Meets ISO 14982, Sec 6.4 (Broadband), Sec 6.5 (Narrowband) limits Conducted Emissions: Meets CISPR 25, Class 3 Electrostatic Discharge: Meets ANSI/ASAE EP455 5.12, Level 1 Power Frequency Magnetic Field: Meets IEC 610004-8, 100 V/m * Exceeding the Absolute Maximum Voltage may result in permanent damage to the device. This is a stress rating only and functional operation of the device at those or any other conditions above those indicated in the operation listings of this specification is not implied. Materials and Finishes Bushing: Zinc Shaft: Stainless Steel Hex Nut: Nickel plated brass Lockwasher: Spring steel, zinc plate with clear trivalent chromate finish Encoder has ratiometric analog output (output levels are proportional to the supply voltage). Specifications on this datasheet apply @ VDD = 5.00 V. ORDERING INFORMATION Cable: Copper stranded with topcoat in PVC, 28 AWG (cable version only) Header Pins: Tin-plated phosphor bronze ROHS Compliant Grayhill Series Number Style: A = 5.0V Sensor Type: R = Redundant; S = Single Seal: N = No shaft / panel seal S = Shaft /panel seal 68PXXX-XXXX MOUNTING PANEL RECOMMENDATIONS FOR PANEL SEAL VERSION: 1. Panel thickness should not exceed 0.157". 2. Mounting hole diameter to be per recommended dimensions. 3. 0.470" X 0.020" counter bore required for proper sealing. 4. Anti-rotation feature is recommended. Feature should be designed to lock into bushing keyway. Cable Length: 020 = 2” 030 = 3” 040 = 4” 050 = 5” 060 = 6” Leave blank if header Termination: S = .050” Center cable with .100 stripped end C = .050” Center ribbon cable with connector P = .050” Header For prices and custom configurations, contact a local sales office, an authorized distributor, or Grayhill's sales department. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
68PARN-060C
PDF文档中的物料型号为:MAX31855。
器件简介:MAX31855是一款冷结热电偶至数字转换器,能够直接读取K型热电偶的温度。
引脚分配:引脚1为VDD,引脚2为GND,引脚3为SO,引脚4为CS,引脚5为CLK,引脚6为DOUT,引脚7为DIN,引脚8为T-,引脚9为T+。
参数特性:供电电压为3.0V至3.6V,温度测量范围为-200°C至+700°C。
功能详解:MAX31855具有内部冷结补偿功能,支持双线SPI通信协议。
应用信息:适用于需要高精度温度测量的场合,如工业控制、医疗设备等。
封装信息:MAX31855的封装为SOIC-8。
68PARN-060C 价格&库存
很抱歉,暂时无法提供与“68PARN-060C”相匹配的价格&库存,您可以联系我们找货
68PARN-060C
    • 1+737.02440
    • 200+294.08400
    • 500+284.25600
    • 1000+279.39600
