34BWDP31B4M7QT
34BWDP31B4M7QT
    GRAYHILLINC.
    插件
    钮子开关 双刀双掷 5万次 直插 5A 28V -30℃~+85℃
34BWDP31B4M7QT 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Series 34B: Sealed Miniature Toggle Switches Series 34B Sealed Miniature Toggle Switches FEATURES • Save Space and Weight • SPDT, DPDT, and 3PDT Circuitry • Choice of Actuators, Bushings and Terminations • Sealed per IP67 Toggle Switches Models in inches (and millimeters) SPDT Model No. Switching Position WSP1 ON NONE ON WSP2 ON NONE (ON) WSP3 ON OFF ON WSP4 (ON) OFF (ON) WSP5 ON OFF (ON) OPEN 2-1 Term. Comm. 2-3 ()=MOMENTARY Ø.220 Ø5.60 .250 (6.35) 3 .504 (12.8) Ø.107 (Ø2.72) .268 (6.8) .297 (7.54) 02COMM. SCHEMATIC DPDT Ø.220 (Ø5.60) Model No. Switching Position WDP1 ON NONE ON WDP2 ON NONE (ON) WDP3 ON OFF ON WDP4 (ON) OFF (ON) WDP5 ON OFF (ON) OPEN 2-1 5-4 2-3 5-6 SCHEMATIC .457 (11.6) W3P1 ON NONE ON W3P2 ON NONE (ON) W3P3 ON OFF ON W3P4 (ON) OFF (ON) OFF (ON) OPEN 2-1 5-4 ON .663 (16.85) .297 (7.54) 1 05COMM. 3 4 .185 (4.7) 6 3 5 2 4 1 .190 (4.83) EPOXY SEAL .250 (6.35) .250 (6.35) .030 (0.76) .500 (12.7) Ø.107 (Ø2.72) .650 (16.5) ()=MOMENTARY 02COMM. .050 (1.27) .250 (6.35) .030 (0.76) Ø.107 (Ø2.72) Ø.220 (Ø5.60) Switching Position 2-3 5-6 EPOXY SEAL 6 Model No. W3P5 .185 (4.7) .504 (12.8) 3PDT Term. Comm. 1 05COMM. 3 4 1 .663 (16.85) .250 (6.35) ()=MOMENTARY 02COMM. 2 .030 (0.76) 3 1 Term. Comm. .050 (1.27) .250 (6.35) .297 (7.54) .722 (18.35) .050 (1.27) 9 6 3 8 5 2 7 4 1 .185 .190 (4.7) (4.83) EPOXY SEAL 08COMM. 6 7 9 SCHEMATIC Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Series 34B: Sealed Miniature Toggle Switches ACTUATOr OPTIONS in inches (and millimeters) 1 2 Ø.115 (Ø2.92) Std Ø.107 (Ø2.72) .496 (12.60) SUBTRACT .079 (2.00) FOR BUSHING OPTION B1 BUSHING OPTIONS DIP Switches Toggle Switches .299 (7.60) SUBTRACT .083 (2.10) FOR BUSHING OPTION B1 in inches (and millimeters) B1 b4 Std .250 (6.35) .350 (8.90) 1/4-40 UNS Termination options M1 in inches (and millimeters) .078 (1.98) Solder Lug .156 (3.96) .106 (2.70) Ø.220 (Ø5.60) .050 (1.27) Ø.107 (Ø2.72) .663 (16.85) EPOXY SEAL .125 (3.18) .200 (5.08) .500 (12.7) .663 (16.85) DPDT .106 (2.70) Ø.220 (Ø5.60) .200 (5.08) Ø.107 (Ø2.72) .050 (1.26) Ø.073 (Ø1.85) P.C. MOUNTING .030 (0.76) .297 (7.54) .500 (12.7) .050 (1.26) .200 (5.08) .185 .185 (4.70) (4.70) EPOXY SEAL .125 (3.18) .050 (1.26) .500 (12.7) 3 .050 (1.27) .297 (7.54) SPDT .504 (12.8) 2 THK. .030 (0.76) .185 (4.70) .030 (0.76) .185 (4.70) 1 .050 (1.26) .220 (5.60) .189 P.C. Mount (4.80) (Std) THK. .030 (0.76) Right Angle P.C. Mount, Horizontal Actuation .504 (12.8) EPOXY SEAL .080 (2.03) .047 (1.19) M6 M2 EPOXY SEAL 4 5 6 1 2 3 .500 (12.7) Ø.073 (Ø1.85) .050 (1.26) P.C. MOUNTING Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com .150 (3.81) .200 (5.08) Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Series 34B: Sealed Miniature Toggle Switches Termination options in inches (and millimeters) .720 (16.85) .504 (12.8) Ø.220 (Ø5.60) EPOXY SEAL Ø.107 (Ø2.72) .106 (2.70) .125 (3.18) 1 2 3 .050 (1.26) .200 (5.08) Toggle Switches .500 (12.7) .150 (3.81) 2 .030 (0.76) 1 2 1 3 .150 (3.81) .200 (5.08) .663 (16.85) Ø.107 (Ø2.72) Ø.073 (Ø1.85) .200 (5.08) P.C. MOUNTING .500 (12.7) Ø.220 (Ø5.60) .150 (3.81) 3 .050 (1.26) EPOXY SEAL .190 (4.83) .050 (1.26) .106 (2.70) 6 .125 (3.18) .297 (7.54) 4 5 .150 (3.81) .500 (12.7) 3 5 2 4 1 .030 (0.76) Ø.073 (Ø1.85) .200 (5.08) .190 (4.83) 6 P.C. MOUNTING .050 (1.26) .200 (5.08) .500 (12.7) .457 (11.6) .150 (3.81) EPOXY SEAL .720 (18.30) Ø.107 (Ø2.72) .650 (12.8) Ø.220 (Ø5.60) .125 (3.18) .500 (12.7) .297 (7.54) 7 8 Ø.107 (Ø2.72) SPDT .230 (5.84) .320 (8.13) 2 7 4 1 .297 (7.54) 2 Ø.073 (Ø1.85) .200 (5.08) V2 .460 (11,68) V3 .630 (16,00) .190 (4.83) .150 (3.81) P.C. MOUNTING .125 (3.18) .185 (4.70) .620 (15.75) 3 .020 (0.51) .185 (4.70) .565 (14.35) .200 (5.08) OPTION DIM."A" CODE 1 .125 (3.18) 8 5 .150 (3.81) DIM. "A" .048 (1.22) 3 .048 (1.22) .565 (14.35) Vertical Bracket P.C. Mount 9 6 9 .050 (1.27) .190 (4.83) V2-V3 6 .125 (3.18) .297 (7.54) 3PDT 5 .050 (1.26) .106 (2.70) .504 (12.8) DPDT 4 Ø.073 (Ø1.85) EPOXY SEAL .663 (16.85) Ø.107 (Ø2.72) Ø.220 (Ø5.60) .504 (12.8) 9 .050 (1.26) Right Angle P.C. Mount, Vertical Actuation SPDT 8 P.C. MOUNTING .565 (14.35) .200 (5.08) M7 7 .185 (4.70) .565 (14.35) .297 (7.54) .050 (1.26) 3PDT .185 (4.70) .030 (0.76) .030 (0.76) .620 (15.75) .073 DIA. (Ø1.85) P.C. MOUNTING Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Series 34B: Sealed Miniature Toggle Switches Termination options Ø.107 (Ø2.72) in inches (and millimeters) .230 (5.84) .125 (3.18) DIM. "A" DPDT .297 (7.54) .320 (8.13) Ø.107 (Ø2.72) .125 (3.18) 5 6 .030 (0.76) .020 (0.51) .185 (4.70) V3 .630 (16,00) Ø.073 (Ø1.85) P.C. MOUNTING Ø.073 (Ø1.85) DIM. "A" .185 (4.70) OPTION DIM."A" CODE 4 .125 (3.18) .620 (15.75) .190 (4.83) .230 (5.84) .297 (7.54) .320 (8.13) .460 (11,68) .620 (15.75) 3PDT .048 (1.22) V2 5 .020 (0.51) .185 (4.70) 6 .030 (0.76) V2 .460 (11,68) V3 .630 (16,00) .620 (15.75) .190 (4.83) P.C. MOUNTING .620 (15.75) Specifications Ratings Contact Rating: Q option - 5A with resistive load @ 125VAC or 28 VDC; 2A with resistive load @ 250 VAC. R option-0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 50,000 make-and-break cycles at full load Contact Resistance: 10 milliohms max. initial @ 2-4 VDC, 100 mA Insulation Resistance: 1,000 megaohms min Dielectic Strength: 1,500 V RMS @ sea level Operating Temperature: -30°C to 85°C MATERIALS Case and Bushings: Glass-filled nylon 6/6, flame retardant, heat stabilized (UL94V-0) Frame: Spring steel Actuator: Brass, chrome plated. Internal Oring seal standard with all actuators. Switch Support: Brass, tin-plated Actuator Pivot & Mounting Bracket: Nylon Actuator Pivot Retainer: Stainless Steel Terminal and Contacts: Copper alloy with plated over nickel or silver plate Terminal Seal: Epoxy Ordering Information Series 34B Sealed Miniature Toggle Switches Model: SPDT: WSP1, WSP2, WSP3, WSP4, WSP5 DPDT: WDP1, WDP2, WDP3, WDP4, WDP5 3PDT: W3P1, W3P2, W3P3, W3P4, W3P5 (See Model options.) Actuator: 1, 2 (See Actuator options) Bushing Option: B1, B4 (See Bushing options.) 34BWSP12B4M2RT RoHS Compliant Contact: R = Copper alloy, gold plate over nickel plate, Q = Copper alloy, gold plate over silver plate Termination Options: M1, M2, M6, M7, V2, V3 (See Termination options.) Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Hardware In inches (and millimeters) nut locking ring ( ) ( ) ( ) ( ) ( ) lock washer ( ) ( ) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DIP Switches Toggle Switches 4 .048 (1.22) .185 (4.70) OPTION DIM."A" CODE
34BWDP31B4M7QT 价格&库存
很抱歉,暂时无法提供与“34BWDP31B4M7QT”相匹配的价格&库存,您可以联系我们找货
34BWDP31B4M7QT
  • 25+41.13359
  • 60+40.35977
  • 100+38.08666
库存:485
