62AG11-L0-P
62AG11-L0-P
    GRAYHILLINC.
    OPT ENCODER, 32 POS W/O PB & HDR
62AG11-L0-P 数据手册
Optical Encoders Series 62AG Price Competitive Solution FEATURES • • • • • • • • • Over 1 million rotational cycles 2-bit gray code output Quadrature coding Available in 16 detent positions 4 inch cable/connector assembly RoHS compliant Optional integrated pushbutton Patented light pipe technology Cost competitive with mechanical encoders at higher volumes APPLICATIONS • Automotive - audio systems - navigation systems • Medical - patient monitoring systems • Test & Measurement - analyzers - oscilloscopes • Audio & Video - consumer electronics - professional editing equipment DIMENSIONS in inches (and millimeters) Optical and Mechanical Encoders Unless otherwise specified, standard tolerances are: Linear ± .025 Diameter ± .010 Angle ± 2.0 0 .152 ±.002 [3,86 ] .066 ±.002 [1,68 ] .500 [12,7] .580 [14,73] Ø.249 ±.002 [ 6,32 ] SHAFT [.687] .219 ±.004 [ 5,56 ] .250 [6,35] .312 [ 7,92 ] [ 17,45 ] 3/8-32 UNEF-2A THREAD THREADS TO BE WITHIN .030 [0,76] OF SHOULDER NOTE: GRAYHILL ALLOWS MULTIPLE ORIENTATIONS FOR THE GRAYHILL TEXT ON THE BACKPLATE. CONNECTOR IS AMP P/N 7-215083-6 OR EQUIVALENT .532 ±.015 [ 13,51 ] .512 [ 13 ] 4.00±.200 [101,6] Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical Encoders WAVEFORM AND TRUTH TABLE POWER (+5.0 V) OUTPUT A 6 OUTPUT B 4 PUSHBUTTON 3 PUSHBUTTON 2 GROUND *EXTERNAL 10k HIGH OUTPUT A LOW 5 POSITION OUTPUT B #2 HIGH OUTPUT B LOW #3 #4 POS. POS. POS. POS. POS. POS. #1 #2 #3 #4 #5 #6 1 OUTPUT A #1 INDICATES LOGIC HIGH; BLANK INDICATES LOGIC LOW. CODE REPEATS EVERY FOUR POSITIONS. *CLOCKWISE SHAFT ROTATION PULL-UP RESISTORS REQUIRED FOR OPERATION SPECIFICATIONS Environmental Specifications Rotary Electrical and Mechanical Specifications Operating Voltage: 5.00±0.25 Vdc Supply Current: 30 mA maximum at 5 Vdc. Logic Output Characteristics: Logic high shall be no less than 3.0 VdcLogic low shall be no greater than 1.0 Vdc Minimum sink current: 0.5 mA for 5 Vdc. (Preliminary) Power Consumtpion: 150 mW maximum for 5 Vdc Output: Open Collector Phototransistor Optical Rise Time: 30ms maximum. Optical Fall Time: 30ms maximum. Average Rotational Torque: Low = 2.0±1.4 in-oz initially. High = 3.5±1.4 in-oz initially. 50% of initial value after 1 million cycles. Mechanical Life: 1,000,000 cycles of operation. 1 cycle is a rotation through all positions and a full return. Mounting Torque: 15in-lbs. maximum Shaft Pushout Force: 45 lbs. minimum Terminal Strength: 15 lbs. Cable pull out force minimum Solderability: 95% free of pin holes and voids Maximum rotational speed: 100 rpm. Pushbutton Electrical and Mechanical Specifications Rating: 10 mA @ 5 Vdc Contact Resistance:
62AG11-L0-P 价格&库存
很抱歉,暂时无法提供与“62AG11-L0-P”相匹配的价格&库存,您可以联系我们找货
