46-270 RED
46-270 RED
    GRAYHILLINC.
46-270 RED 数据手册
Wiping Contact Pushbutton Switches SERIES 46 SPST and DPDT, 1/4 Amp FEATURES • Long Wipe Contact Assures High Reliability • 250,000 Cycles of Operation DIMENSIONS In Inches (and millimeters) Single Pole/Double Throw Double Pole/Double Throw 46-101* (BBM) 46-110* (MBB) 46-102* (BBM) 46-111* (MBB) Pushbutton Switches .187 ± .010 (4,75 ± 0,25) 1/4-32 UNEF-2A THREAD 1.327 (33,7) REF. HEX MOUNTING NUT .375 (9,53) ACROSS FLATS .109 (2,77) THICK .703 (17,86) MAX. .375 ± .010 (9,53 ± 0,25) DIA. .187 ± .010 (4,75 ± 0,25) .125 ±.005 (3,18 ± 0,13) DIA. A 46-200* (BBM) 46-201* (MBB) .375 ± .010 (9,53 ± 0,25) DIA. SNAP ON BUTTON CAP .391 (9,93) REF. SNAP ON BUTTON CAP C .391 (9,93) REF. 1/4-32 UNEF-2A THREAD A HEX MOUNTING NUT .375 (9,53) ACROSS FLATS .109 (2,77) THICK 1,56 (39,6) REF. A = .250 ± .005 (6,35 ± 0,13) B A = .250 ± .005 (6,35 ± 0,13) B = .734 (18,64) REF. C = .187 ± .010 (4,75 ± 0,38) LABEL* LABEL* .187 ± .015 (4.75 ± 0,38) .437 ± .010 (11,10 ± 0,25) DIA. NC LABEL* *PART NUMBER AND E.I.A. DATE CODE LABEL .187 ± .015 (4,75 ± 0,38) .625 ± .015 (15,88 ± 0,38) NO *PART NUMBER AND E.I.A. DATE CODE LABEL C Rating at 115 Vac Resistive 1 Rating at Operations at Rated 220 Vac Load Resistive 1 /4 Amp /8 Amp Action Momentary 250,000 Total Travel .180 (4,57) Min. *Complete Part Number Button or Cap Color 46-101 46-101 46-102 46-102 46-110 46-110 46-111 46-111 RED BLK RED BLK RED BLK RED BLK Red Black Red Black Red Black Red Black Bottoming Force (oz.) Mtg. Hole 17 ± 5 NC C NO *PART NUMBER AND E.I.A. DATE CODE LABEL Rating at 115 Vac Resistive 1 /4 Amp 17/64" (6,75) Rating at 220 Vac Resistive 1 /8 Amp NO C NC .453 ± .015 (11,51 ± 0,38) Operations at Rated Load 250,000 *Complete Part Number Cap Color 46-200 46-200 46-201 46-201 RED BLK RED BLK Red Black Red Black Action Total Travel Bottoming Force (oz.) Mtg. Hole Momentary .180 (4,57) Min. 35 ± 9 17/64" (6,75) CIRCUITRY N.C. C1 N.C. C. N.C. N.O. N.O. N.C. N.O. SPDT - BBM C. N.O. N.C. C. SPDT MBB N.C. C2 N.O. DPDT BBM Pushbutton 54 N.O. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois C. DPDT MBB 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Wiping Contact Pushbutton Switches SERIES 46 SPST and DPDT, 1/4 Amp FEATURES • Bushing and Button Seal • Environmentally Sealed DIMENSIONS In Inches (and millimeters) Sealed Bushing and Button Single Pole/Double Throw 46-150* (BBM) 46-151* (MBB) .375 ± .010 (9,53 ± 0,25) DIA. .391 (9,93) REF. O A HEX MOUNTING NUT .375 (9,5) ACROSS FLATS .109 (2,8) THICK A = .250 ± .005 (6,35 ± 0,13) B = .770 ± .015 LABEL* (19,56 ± 0,38) C = .187 ± .010 (4,75 ± 0,25) B Terminals are marked as shown in bottom view of SPDT switch on previous page. *PART NUMBER AND E.I.A. DATE CODE LABEL .187 ± .015 (4,75 ± 0,38) Rating at 220 Vac Resistive 1 1.62 (41,15) REF. Operations at Rated Load /8 Amp 100,000 *Complete Part Number Cap Color 46-150 46-150 46-151 46-151 RED BLK RED BLK Red Black Red Black SNAP ON BUTTON CAP C 1/4-32 UNEF-2A THREAD O HEX MOUNTING NUT .312 (7,92) ACROSS FLATS .062 (1,57) THICK A = .250 ± .005 (6,35 ± 0,13) B = .770 ± .015 LABEL* (19,56 ± 0,38) C = .187 ± .010 (4,75 ± 0,25) B Terminals are marked as shown in bottom view of DPDT switch on previous page. .187 ± .015 (4,75 ± 0,38) .450 (11,43) MAX. ACROSS FLATS OF HEX .505 (12,83) REF. ACROSS CORNERS O = O RING /4 Amp .391 (9,93) REF. 1/4-32 UNEF-2A THREAD 1.62 (41,15) REF. 1 .375 ± .010 (9,53 ± 0,25) DIA. SNAP ON BUTTON CAP C A Rating at 115 Vac Resistive 46-270* (BBM) 46-271* (MBB) Pushbutton Switches Sealed Bushing and Button Double Pole/Double Throw O = O RING Rating at 115 Vac Resistive 1 /4 Amp .580 (14,73) MAX. ACROSS FLATS OF HEX .650 (16,51) REF. ACROSS CORNERS *PART NUMBER AND E.I.A. DATE CODE LABEL Rating at 220 Vac Resistive 1 /8 Amp Operations at Rated Load 100,000 *Complete Part Number Cap Color 46-270 46-270 46-271 46-271 RED BLK RED BLK Red Black Red Black Action Total Travel Bottoming Force (oz.) Mtg. Hole Action Total Travel Bottoming Force (oz.) Mtg. Hole Momentary .180 (4,57) Min. 24 ± 4 17/64" (6,75) Momentary .180 (4,57) Min. 48 ± 4 17/64" (6,75) CIRCUITRY N.C. C1 N.C. C. N.C. N.O. N.O. N.C. N.O. N.C. SPDT MBB N.C. C2 N.O. DPDT BBM Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois C. N.O. C. SPDT - BBM N.O. C. DPDT MBB 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Pushbutton 55 Wiping Contact Pushbutton Switches DIMENSIONS In Inches (and millimeters) Environmentally Sealed Double Pole/Double Throw .375 ± .010 (9,53 ± 0,25) DIA. 46-260* (BBM) .390 ± .010 (9,90 ± 0,25) SNAP ON BUTTON CAP C O-RING SEALED D .641 ± .005 (16,28 ± 0,13) 3/8-32 UNEF-2A THREAD TO .060 (15,24) MAX. FROM SHOULDER .281 ± .010 (7,14 ± 0,25) R O .812 ± .005 (20,62 ± 0,13) DIAMETER HEX MOUNTING NUT .562 (14,2) ACROSS FLATS .094 (2,40) THICK A = 1.14 (29,0) MAX. B = 22.00 (558,8) MAX. C = .187 ± .010 (4,75 ± 0,25) D = .125 ± .005 (3,18 ± 0,13) A Y G BR BL Pushbutton Switches SWITCH AND WIRE LEADS ENCAPSULATED B Operations at Rated Load *Complete Part Number Cap Color 250,000 46-260 RED 46-260 BLK Red Black Action Total Travel Bottoming Force (oz.) Mtg. Hole Momentary .180 (4,57) Min. Approx. 45 25/64" (9,92) Rating at 115 Vac Resistive 1 /4 Amp .250 ± .010 (6,35 ± 0,25) CIRCUITRY 1 /8 Amp ACCESSORY Decorative Mounting Nut Part No. 30C1023-1 Fits .250" (6,35) Bushing For dimensions, materials and finishes, see page E-36. N.C. C1 N.O. N.C. ORDERING INFORMATION C2 Description N.O. DPDT BBM SPECIFICATIONS Rating Criteria Contact Resistance: Less than 25 milliohms at the switch initially. Less than 4 milliohms/inch of wire. Voltage Breakdown: 1,000 Vac between mutually insulated parts Insulation Resistance: 1,000 megohms minimum O-Ring Seal: Nitrile per MIL-P-5516, class B Seal Adapter and Hex Nut (46-260): Brass, zinc trivalent chromate-plated Wire Leads (46-260): Per MIL-W-16878 type E. #26 AWG, insulated teflon, copper stranded wire Operating Features Materials and Finishes Cover, Bushing, Mounting Nut: Brass, tin zinc Shorting Bar: Phosphor bronze, silver-plated. Terminals: Phosphor bronze, silver contact surface. Terminal ends are tin/silver Base or Potting Shell: Phenolic per MlL-M14, type CFG Spring: Tinned music wire Button Cap: Polyethylene Button: Polyphenylene sulfide (PPS) for 46200 and 46-201. Polycarbonate for all other unsealed versions. Aluminum for all sealed versions. Pushbutton 56 Rating at 220 Vac Resistive Break-Before-Make: Rest position to N.C. break .020" (0,51) minimum. Rest position to N.O. Make .140" (3,35) maximum. Make-Before-Break: Rest position to N.O. make .065" ± .015 (1,65 ± 0,38). Rest position to N.C. break .130" ± .015 (3,30 ± 0,38). Operating Temperature: -40°C to +85°C SPDT, BBM, Red Button SPDT, BBM, Black Button SPDT, BBM, Red Cap SPDT, BBM, Black Cap SPDT, MBB, Red Button SPDT, MBB, Black Button SPDT, MBB, Red Cap SPDT, MBB, Black Cap SPDT, BBM, Red Cap SPDT, BBM, Black Cap SPDT, MBB, Red Cap SPDT, MBB, Black Cap DPDT, BBM, Red Cap DPDT, BBM, Black Cap DPDT, MBB, Red Cap DPDT, MBB, Black Cap DPDT, BBM, Red Cap DPDT, BBM, Black Cap DPDT, MBB, Red Cap DPDT, MBB, Black Cap DPDT, BBM, Sealed, Red DPDT, BBM, Sealed, Black Decorative mountings, see pages E-24 to E-26. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 46-101 46-101 46-102 46-102 46-110 46-110 46-111 46-111 46-150 46-150 46-151 46-151 46-200 46-200 46-201 46-201 46-270 46-270 46-271 46-271 46-260 46-260 RED BLK RED BLK RED BLK RED BLK RED BLK RED BLK RED BLK RED BLK RED BLK RED BLK RED BLK ACCESSORY STANDARD OPTIONS Epoxy sealed terminals and wire leads, see page E-34 and E-35. Part No. Decorative Nut 30C1023-1 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
46-270 RED 价格&库存
很抱歉,暂时无法提供与“46-270 RED”相匹配的价格&库存,您可以联系我们找货
46-270 RED
