Snap Action Joysticks
SERIES 04JT
Joystick with Tactile Feel
FEATURES
• Dynamically sealed against contamination to IP67
when properly mounted
• Available in front panel mount
• RoHS compliant
• High life (250,000 Operational Cycles)
• Short behind panel length (0.689")
DESCRIPTION
Series 04JT is a single pole, 4-way toggle switch with a tactile feel.
4-way contact is made in the opposite direction of travel.
DIMENSIONS in inches (and millimeters)
Joysticks
ELECTRIC & MECHANICAL RATINGS
Lower Level Rating: 10mA @ 5V resistive
Contact Resistance: 50m ohms (max)
Operating Temperature: -55°C to +85°C
Operational Life: 250,000 cycles
Insulation Resistance: 10,000M ohms
Toggle Lever Travel: 12° from center (max)
Toggle Operating Force: 16 oz + 6 oz initial
Toggle Pivot & Stop Strength: 25 lbs. (max)
Mechanical Shock: per MIL-STD-810,
ORDERING INFORMATION
Available from your local Grayhill
Distributor.
For prices and discounts, contact
a local sales office, an authorized
local distributor or Grayhill.
procedure I, method 516.4
Immersion: per MIL-PRF-8805, sealed to IP67
Moisture Resistance: per MIL-DTL-9419
Vibration: per MIL-DTL-9419G, Method 4.7.11
Terminal Strength: Over 30 lbs. for 1 minute,
per MIL-DTL-9419G, Paragraph 4.7.6
Altitude: Up to 60,000 ft per MIL-DTL-9419G,
Paragraph 4.7.16
Solderability: per MIL-DTL-9419G, Paragraph
4.7.19
Grayhill Series Number
Version:
A = front panel
Connection:
P =PCB mount
04JT-AP-T 0 2
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois
Cap: Thermoplastic (black, cone-shaped cap
is gray)
Bushing: Aluminum alloy (black chrome finish)
Contact Terminals: 1/2 hard brass (gold over
silver over nickel plating)
Hex Nut: Aluminum alloy (black chrome finish)
O-Ring: 50 durometer fluorosilicone
CIRCUITRY
POS 4
C
POS. 3
Current: 2 = low*
Keycap Color: 0 = black; 1 = gray
Keycap Shape:
T = stadium
* Low Level signal is defined as a very small electrical load (i.e., 10 milliamps at 5 volts)
MATERIALS & FINISHES
POS. 1
POS. 2
* Contact made opposite direction of travel
60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
很抱歉,暂时无法提供与“04JT-AP-T02”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2027.465091+260.06316
- 5+1768.283285+226.81788
- 10+1666.9249610+213.81664
- 25+1541.5422825+197.73379
- 50+1452.7834850+186.34869
