19001-04UL
19001-04UL
    GRAYHILLINC.
19001-04UL 数据手册
Single Deck Rotary Switches SERIES 19 2” Diameter, 15 Amp FEATURES • UL Recognized • Rugged Construction • Choice of Termination DIMENSIONS In inches (and millimeters) Solder Lug Terminals BUSHING KEYWAY .066 – .003 WIDE (1,68 – 0,08) .036 – .005 DEEP (0,91 – 0,13) HEX MTG NUT 9/16 – .010 (14,29 – 0,25) ACROSS FLATS 3/32 – .010 (2,38 – 0,25) THICK ‘Faston’ Terminals Non-Turn Washer Detail All dimensions not shown are the same as the Solder Lug Terminals. 3/8-32 UNEF-2A THREAD .344 – .010 (8,74 – 0,25) 1.687 – .030 2.00 .88 (22,4) (42,85 (50,8) – 0,76) DIA. .250 – .005 (6,35 – 0,13) DIA. .500 – .020 (12,7 – 0,51) .375 – .020 (9,53 – 0,51) 1.687 2.28 .88 ± .030 (57,91) (22,4) (42,85 DIA. ± 0,76) DIA. .219 ± .005 (5,56 ± 0,15) .025 ± .002 (0,64 ± 0,05) .500 ± .005 (12,7 ± 1,27) .060 ± .010 (1,52 ± 0,25) FOR AMP .250 SERIES OR EQUIVALENT WIRE HOLE .080" (2,03) SOLDER TERMINALS WIRE HOLE .125 (3,18) .187 ± .003 (4,75 ± 0,08) .093 + .015/ – .000 (2,36 + 0,38/ – 0,00) Grayhill part number and date code marked on label. Customer part number marked on request. SPECIFICATIONS Electrical Rating Rated: UL Recognition: File Number E35289 15 Amps, 120 Vac, non-inductive load. One Amp, 120 Vdc, non-inductive load. Additional Grayhill Rating: 7.5 Amps, 220 Vac, non-inductive load. This rating is based on the following criteria: Overload—50 operations at 125% rated ac load and 150% rated DC load. Endurance—6000 operations at rated load with 900 Vac dielectric strength before and after test. Temperature Rise—Not to exceed 30°C when carrying rated ac load after endurance test. Contacts will carry 20 Amps at 115 volts AC with 30°C maximum temperature rise. Contact Resistance: (Measured at 2 Vdc and approximately 100 mA) for new switch approximately 10 milliohms. Insulation Resistance: Approximately 100,000 Mohms. Between mutually insulated parts. Voltage Breakdown: Approximately 2500 Vac between mutually insulated parts. Mounting Nut: Brass, tin/zinc-plated or stainless steel. Detent Mechanism: Brass, silver-plated “Faston” Terminal: Brass, silver-plated Solder Terminal: Brass, silver-plated Mounting Hardware: One mounting nut 9/16" across flats, 3/32" thick and one non-turn washer (see detail) are supplied with each switch. Additional Characteristics Single Pole, Single Deck: 2 to 11 positions plus common 30° Indexing. Contacts: Non-shorting type Stops: A rivet provides the fixed stop on all switches. Minimum number of positions is 2, and maximum is 11. Terminal 12, the common, is isolated from rotation. Rotational Torque: 12 to 36 ounchinches on average for new switches. Contact Force: Approximately 12 ounces Shaft Flat Orientation: Opposite point of contact (see circuit diagram). Circuit Diagram viewed from shaft end with switch in position #1 8 Materials and Finishes Rotor Contact: Silver alloy Stator Contact: Silver alloy Shaft: 303 Stainless steel Stop Rivet: Steel, tin/zinc-plated Mounting Bushing: Brass, tin/zinc-plated Base and Drive Hub: Heat resistant, electrical grade phenolic. 9 10 7 11 5 1 12 (COMMON) 6 4 3 ACCESSORIES Screw Terminal Adapter Spring loaded, plug-in adapters for ‘Faston’ Terminals provide excellent mechanical fit and electrical contact. Adapter material is brass tin-plated. The terminal adapters are available with a 6-32 thread (-1) or 8-32 thread (-2). A 1/4" panhead screw is provided as part of the adapter. Part No. SC906-1 .........6-32 Thread Part No. SC906-2 .........8-32 Thread Non-Turn Washer Brass, tin/zinc-plated washer, detailed above may be purchased as a separate item. Part No. 19C1014. Ordering Information Part Numbers: Designate as follows, using the 2 digits after the dash to indicate the number of positions. For Faston Terminal: Use 19101-02UL through 19101-11UL For Solder Terminal: Use 19001-02UL through 19001-11UL Specials: Not available through Distributors. For special shafts, bushings, etc. contact Grayhill. OF BUSHING KEYWAY 2 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Rotary Switches .950 – .060 (24,13 – 1,52) .625 ± .010 (15,88 ± 0,25) DIA.
19001-04UL 价格&库存
很抱歉,暂时无法提供与“19001-04UL”相匹配的价格&库存,您可以联系我们找货
19001-04UL
  • 3+549.01917
  • 6+538.78474
  • 12+528.68090
库存:1
