56SD36-01-1-AJN
56SD36-01-1-AJN
    GRAYHILLINC.
    插件
    旋转开关 扁平型 焊片 非短路200mA
56SD36-01-1-AJN 数据手册
Single Deck Rotary Switches Series 56 0.5" Diameter, 200mA, .355" Behind Panel Features • Requires Minimum Distance Behind the Panel • Adjustable Stop Types Provide Prototypes Immediately • Industrial Quality, Economically Priced • RoHS Compliant DIMENSIONS In inches (and millimeters) PC Mount Style A .500 Ø ± .015 (12,70 ± 0,25) POS. 1 .250 ± .015 (6,35 ± 0,38) .375 ± .015 (9,53 ± 0,38) .377 ± .020 (9,58 ± 0,51) .250 ± .015 (6,35 ± 0,38) Ø .125 ± .002 (3,18 ± 0,06) GRAYHILL 2 1 10 9 .203 ± .003 (5,16 ± 0,08) ACROSS BUSHING FLATS PC TERMINAL DETAIL .110 ± .015 (2,79 ± 0,38) .016 ± .004 (0,4 ± 0,10) .110 ± .015 (2,79 ± 0,38) .016 ± .004 SQ. (0,4 ± 0,10) .046 ± .004 (1,2 ± 0,10) FOR REAR VIEWS, SEE FOLLOWING PAGE. PC COMMON 1/4-28 UNF-2A THREAD .094 ± .010 (2,39 ± 0,25) Angle of Throw 30° 36° Rotary Switches .110 ± .015 (2,79 ± 0,38) Ø .025 ± .002 (0,64 ± 0,05) Angle A 105° 108° Grayhill part number and date code marked on label. Customer part number marked on request. Solder Lug Style SOLDER LUG TERMINAL DETAIL A .500 Ø ± .015 (12,70 ± 0,38) POS. 1 .250 ± .015 (6,35 ± 0,38) .375 ± .015 (9,53 ± 0,38) 30° 36° Ø .125 ± .002 (3,18 ± 0,06) FOR REAR VIEWS, SEE FOLLOWING PAGE. .016 ± .004 (0,41 ± 0,10) .020 ± .004 (0,51 ± 0,10) .046 ± .004 (1,17 ± 0,10) SOLDER LUG COMMON 1/4-28 UNF-2A THREAD Angle A 105° 108° .063 ± .005 (1,60 ± 0,13) .125 ± .015 (3,18 ± 0,38) .250 ± .015 (6,35 ± 0,38) .094 ± .010 (2,39 ± 0,25) Angle of Throw .480 ± .020 (12,19 ± 0,51) GRAYHILL 2 1 10 9 .203 ± .003 (5,16 ± 0,08) ACROSS BUSHING FLATS .125 ± .015 (3,18 ± 0,38) Ø .062 ± .002 (1,58 ± 0,51) Grayhill part number and date code marked on label. Customer part number marked on request. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Rotary 11 Single Deck Rotary Switches Circuit Diagrams and Rear Views: PC Mountable AND Solder Lug Terminals Circuit as Viewed From Shaft End Rear View .366 ± .015 (9,30 ± 0,38) DIA. CIRCLE OF CENTERS .366 ± .015 (9,30 ± 0,38) DIA. CIRCLE OF CENTERS .190 ± .015 (4,83 ± 0,38) DIA. CIRCLE OF CENTERS 15° (PC MOUNT AND POS. 1 SOLDER LUG) 30° TYP. COMMON LOCATION FOR 2 POLE SWITCH 15° POS. 1 30° TYP. 8 .190 ± .015 (4,83 ± 0,38) DIA. CIRCLE OF CENTERS (PC MOUNT AND SOLDER LUG) 8 9 7 COMMON LOCATION FOR 1 POLE SWITCH 10 6 5 4 12 1 8 1 C1 5 DIMENSION A DIA. CIRCLE OF CENTERS 18° POS. 1 8 7 COMMON LOCATION FOR 2 POLE SWITCH COMMON LOCATION FOR 1 POLE SWITCH PC Mount Solder Lug Dimension Terminals Terminals A .184 ± .015 .126 ± .015 (4,67 ± 0,38) (3,20 ± 0,38) 5 1 3 CURRENT - MILLIAMPS Rotary Switches Chart shown for non-shorting (break before make) contacts, resistive load. 300 ONE POLE 100 0 0 10 20 30 CYCLES x 1000 115 Vac 0r 30 Vdc One cycle is 360° rotation clockwise and 360° return. The data for the curve was measured at sea level, 25°C and 68% relative humidity with the life limiting criteria which follows. Contact Resistance: 100 milliohms maximum, (15 milliohms initially). Insulation Resistance: 10,000 Mohms minimum between mutually insulated parts (50,000 Mohms initially). Voltage Breakdown: 600 Vac minimum between mutually insulated parts at standard atmospheric pressure. Life Expectancy: As determined from the loadlife curve for the current to be switched. Contact GRAYHILL for more information if any of the following is true: the life limiting criteria are more critical than those listed; longer operation is required; a larger make and break current is required; the operating environment includes elevated temperatures or Rotary 12 reduced pressures. Contact Carry Rating: Switch will carry 6 amperes continuously with a maximum contact temperature rise of 20°C. Additional Characteristics 200 Contact Type and Forces: Shorting or nonshorting wiping contacts with over 25 grams of contact force. Shaft Flat Orientation: Flat opposite contacting position of pole number one (see circuit diagrams). Terminals: Switches have the full circle of terminals, regardless of number of active positions. Stop Strength: 7.5 lb-in. minimum Rotational Torque: 3.5 to 9 oz-in. (21-53 mN-m), depending on the number of poles. Bushing Mounting: Required for switches with stops, and recommended for switches without stops. Meets MIL-S-3786 for: High and medium shock; Vibration (10 to 2,000 Hz); Thermal shock (-65° to 85 ° C); Salt spray; Explosion; Stop strength (7.5 in-lbs. minimum (.85 N-m); Terminal strength; Sealed styles withstand water pressure of 15 PSI minimum (103 KPa) without leakage. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 2 11 12 C4 1 C1 4 3 8 7 10 SPECIFICATIONS Electrical Ratings 9 6 4 36° TYP. 10 2 FOUR POLES TWO POLES .340 ± .015 (8,64 ± 0,38) DIA. CIRCLE OF CENTERS 9 C2 6 30° Angle of Throw 2 4 3 ONE POLE C3 7 2 3 11 6 5 12 10 7 11 C2 9 6 9 10 C2 1 C1 5 4 3 36° Angle of Throw 2 TWO POLES Materials and Finishes Housing: Zinc die cast, tin zinc plated Mounting Nut: Brass, tin zinc plated Lockwasher: Spring steel, zinc plated Panel Seal: Silicone rubber Shaft and Stop Arm: Zinc die cast Retaining Ring: 302 Stainless steel, passivated Shaft Seal: Silicone rubber Stop Pins: 303 Stainless steel, passivated Detent Rotor: Molded thermoplastic Detent Spring: Tinned music wire Detent Balls: Steel, nickel-plated Contact Spring: Stainless steel, passivated Rotor Contact: Non-shorting: Brass, silver over nickel plate Shorting: Zinc, silver over nickel over copper plate Common Ring: Brass, gold over silver over nickel plate Terminals: Brass, gold over silver over nickel plate 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Single Deck Rotary Switches SHAFT AND PANEL SEAL: Style S Panel is sealed by a flat rubber seal washer at the base of bushing. Shaft is sealed by an Oring inside the bushing. After the switch is mounted, seals do not alter the dimensions of the unsealed style. SEAL Shaft and Panel Seal SCREWDRIVER SLOTTED SHAFT: Option .125 ± .015 (3,18 ± 0,38) .050 ± .005 (1,27 ± 0,13) .032 ± .005 (0,81 ± 0,13) A Series 56 rotary switches are available with a screwdriver slotted shaft with dimensions as shown. Available in the styles, angles of throw and pole/ positions combinations shown in the choice and limitations chart. Screwdriver Slotted Shaft ADJUSTABLE STOP SWITCHES Adjustable Stop desired to limit the shaft rotation. All dimensions are identical to the fixed stop switch counterpart. ACCESSORY: Non-Turn Washer In Inches (and millimeters) ADJUSTABLE STOP PINS ADJUSTABLE STOP PINS REMOVABLE STICKER FOR ADJUSTMENT OF STOPS REMOVABLE SEAL WASHER FOR ADJUSTMENT OF STOPS .400 ± .005 DIA. (10,16 ± 0,13) .025 ± .001 (0,64 ± 0,03) 90° ± 1° .250 ± .003 (6,35 ± 0,08) .060 ± .001 (1,52 ± 0,25) SUGGESTED ADJUSTABLE STOP SUBSTITUTION GUIDE Fixed Stop Style 56A 56S 56P 56SP Adjustable Stop Style Equivalent Fixed Stop Style 56D 56SD 56DP 56SDP Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 56B 56BS 56BP 56BSP Adjustable Stop Style Equivalent 56BD 56BSD 56BDP 56BSDP .015 (0,38) RADIUS MAX. .125 ± .005 (3,16 ± 0,13) Part No. 50J1066 Cut round hole for the bushing and for the non-turn tab. Washer fits the double D bushing flats. Washer is sold only when accompanied by an order for a like number of switches. Washer is 302 stainless steel. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Rotary 13 Rotary Switches Two stop pins and an adhesive backed sticker or seal washer are provided. Sticker is temporarily removed to locate stop pins as Single Deck Rotary Switches CHOICES AND LIMITATIONS: Series 56 A = Standard, 1/8" Shaft B = Screwdriver Slot Shaft D = Adjustable Stop (Adj. Stop) Style Designation 1 Solder Lug Terminals A X S X P = PC Mount Terminals S = Shaft/Panel Seal (S/P Seal) FEATURES PC Mount Shaft/Panel Seal Terminals X SP X X SD X Angle Of Throw Number Of Poles Number Of Positions Per Pole Shorting Or Non-Shorting Contacts 30° 1 2 4 02 thru 12 02 thru 06 02 or 03 N or S N or S N or S 36° 1 2 02 thru 10 02 thru 05 N or S N or S B X P D Screwdriver Adjustable Slotted Shaft Stops1 Equivalent BS BP X BSP X DP X SDP X X X BD X BSD X BDP X BSDP Adjustable stop versions allow selection of 2 positions to the maximum number of positions per pole. STANDARD OPTIONS Available from your local Grayhill Distributor For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Not available thru Distributors when Intermixing of shorting and non-shorting contacts. Contact Grayhill. ORDERING INFORMATION Series Style: Letters from Choices Chart Angle of Throw: 30 or 36° 56A36–01–1–10N–F Rotary Switches Stop Arrangement: The suffix C or F must be added to a one pole per deck switch with the maximum number of positions to indicate continuous rotation (C) or fixed stops (F) between position 1 and the last position. Type of Contacts: N = Non-shorting, S = Shorting Positions Per Pole: 02 as a minimum to the maximum allowable for the angle of throw and number of poles per the Choices Chart. Use the letters AJ in this location if adjustable stop switch is to be ordered. Poles per Deck: Limited by angle of throw. See chart Number of Decks: 01 only Rotary 14 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
56SD36-01-1-AJN 价格&库存
很抱歉,暂时无法提供与“56SD36-01-1-AJN”相匹配的价格&库存,您可以联系我们找货
56SD36-01-1-AJN
    • 1+200.97720
    • 30+191.25720
    56SD36-01-1-AJN
    • 1+128.86135
    • 10+118.94894
    • 30+116.96646
    • 100+111.01901
