94HBB10T
94HBB10T
    GRAYHILLINC.
    DIP
    SWITCH ROTARY DIP BCD 100MA 50V
94HBB10T 数据手册
Rotary DIP Switches SERIES 94H FEATURES • Sealed Construction; No Tape Seal Required • Surface Mount or Thru-Hole Style • Tube or Tape and Reel Packaging • Octal, BCD, and Hexadecimal Code • In Standard or Complement • Standard and Right Angle Mount • Flush or Extended Actuators • Gold-Plated Contacts Binary Coded DIP Switches DIMENSIONS ACTUATOR STYLES In inches (and millimeters) Tolerances are ± .010 inches unless specified otherwise. 2 4 5 6 2 3 .140 DIA. ( ∅ 3,56) 0.410 [10.41] 1 6 2 4 5 3 2 0 1 2 7 0 1 7 6 6 .225 (5,72) 5 5 PC board layout as viewed from the top of the switch CORNER CLOSEST TO PIN #1 4 0 3 1 4 C 1 .270 (6,86) OR .170 (4,32) OR .090 (2,29) .200 (5,08) SEE ORDERING INFORMATION .140 DIA. ( ∅ 3,56) .100 ± .005 TYP. (2,54 ± 0,13) 2 C 8 .380 (9,65) .146 (3,71) 45 45 XXXX 0.240 [6.10] 0.050 [1.27] .040 ± .005 (1,02 ± 0,13) Standard Thru-Hole .190 (4,83) 2 PLACES 23 2 1 2 3 9 0.325 [8.25] REF. 0 7 8 EXTENDED ACTUATOR TYPES 0.100 [2.54] TYP. 0.385 [9.78] 3 Figure 2 "F" style rotor 6 0.315 [8.00] .390 (9,91) 89 All actuation types are available in octal (8), binary coded decimal (10), or hexadecimal (16) codes; with either standard or complement output. Standard code outputs have natural color rotors; complements in a contrasting color. .025 (0,64) 0.250 [6.35] 4 67 7 5 23 Figure 1 Surface Mount J-Lead 4 Hex–16 position "A" style rotor Solder pad layout as viewed from the top of the switch .225 (5,72) .500 (12,7) 01 0 0.280 EF 1 0.070 TYP 89 01 7 8 67 CD C AB 4 C CD .380 (9,65) 2 AB 0.100 TYP BCD–10 position 9 0 1 PIN #1 7 8 6 0.560 .190 (4,83) 2 PLACES Octal–8 position EF 4 5 3 .390 (9,91) 4 5 3 .020 +.004/-.002 (0,51 + 0,10/0,05) .100 ± .005 (2,54 ± 0,13) TYP. 0 1 .060 (1,52) TYP. 6 7 Surface Mount Gullwing .270 (6,86) OR .170 (4,32) OR .090 (2,29) .282 (7,16) SEE ORDERING INFORMATION Figure 3 TERMINALS ARE .020 +.004/-.002 (0,51 +0,10/0,05) WIDE BY .012 ±.002 (0,31 ±0,05) THICK .038 DIA. HOLE SIZE RECOMMENDED .300 (7,62) TYP. B-21 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Rotary DIP Switches DIMENSIONS TAPE AND REEL PACKAGING: Series 94H In inches (and millimeters) Right Angle Thru-Hole Meets requirements of EIA 481-2. .430 (10,92) .210 (5,33) 13 INCH DIAMETER REEL .282 (7,16) 2 3 7 2 3 7 2 3 6 0 1 .100 ± .005 (2,54 ± 0,13) 0 6 ORDERING INFORMATION: Series 94H Series Actuator Style: A = Flush, Figure 1 B = .270, Figure 3 (see page B-21) C = .170, Figure 3 (see page B-21) E = .090, Figure 3 (see page B-21) F = Flush, Figure 2 Code: B = Standard, C = Complementary 16mm 6 7 5 6 7 5 4 6 7 2 3 5 0 1 2 3 4 5 0 1 4 SERIES 94 High Temperature Knobs: For Shaft Extensions 2 3 * 27 Pieces per tube for surface mount and thru-hole, 24 pieces per tube for right angle switches. 0 1 Packaging:R = Tape and Reel, (Surface Mount Only) Blank = Tube* Terminal Style: RA = Right Angle, Thru-Hole J = J-Lead W = Surface Mount Blank = Thru-Hole Number of Positions: 08 = Octal, 8 Position 10 = BCD, 10 Position 16 = Hex, 16 Position 2 3 94HAB10WR 4 0 1 6 7 PIN #1 CHAMFER DIRECTION OF FEED 24mm Each reel contains the following number of switches with a 15.35 inch (390 mm) minimum leader and a 6.30 inch (160 mm) minimum trailer. 94HA style 94HB style 94HC style 94HE style 94HF style 750 150 200 300 750 sw/reel sw/reel sw/reel sw/reel sw/reel .190 (4,83) .370 (9,40) 1 Slotted knobs show switch markings. Contact Grayhill for other knob material/ marking color combinations and geometrics. 2 3 4 .040 (1,02) .370 (9,40) A .210 (5,33) 5 .040 (1,02) B * Use only with Actuator Type B or C ORDERING INFORMATION: Series 94 High Temperature Knobs* Knob Style and Height Knob Color Arrow Color Part Number 1A 5A 1B 1B 2B 3B 4B 1B 4B 5B Gray Gray Black Gray Gray Gray Gray Natural Black Gray N/A Black N/A N/A White Black Black N/A White Black 947706-001 947706-005 947705-001 947705-012 947705-004 947705-017 947705-018 947705-009 947705-010 947705-019 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. *Ordered as a separate item. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com B-22 DIP Switches 1 5 7 6 CONDUCTIVE PLASTIC EMBOSSED TAPE 7 4 5 6 .100 ± .005 (2,54 ± 0,13) TYP. 4 5 4 5 PC board layout as viewed from the top of the switch .156 (3,96) PIN #1 8 C 2 1 C 4 0 4 TERMINALS ARE .020 ±.002 (0,51±0,05) WIDE BY .012 ±.002 (0,31 ±0,05) THICK 1 .145 (3,68) 0 1 2 3 .190 .400 (4,83) (10,16) Rotary DIP Switches SERIES 94R Economical, Binary Coded In inches (and millimeters) .213 (5,41) .480 .443 (12,19) (11,25) .286 (7,26) .200 (5,08) .689 (17,50) .433 (11,00) 1.123 (28,52) .044 (1,12) DIA. 1 C 4 8 C 2 PC board layout as viewed from the top of the switch Pin #1 .179 (4,55) .059 (1,50) .058 (1,47) DIA. .199 (5,05) .235 (5,97) Unless otherwise indicated, tolerances are ± .010 (0,25) CODE & TRUTH TABLES: SPECIFICATIONS: Series 94H and 94R Electrical Ratings Environmental Ratings Make-and-break Current Rating: 30 mA at 30 Vdc for 10,000 cycles of operation. Carrying Current Rating: 100 mA at 50 Vdc Contact Resistance: 50 mohms maximum initially (measured at 10 mA, 50 mVdc). 150 mohms maximum after life. Insulation Resistance:(measured at 100 Vdc across open switch contacts) Initial: 5000 Mohms minimum. After Life: 1000 Mohms minimum. Dielectric Strength: (measured across open switch contacts) Initial: 500 Vac RMS minimum. After Life: 250 Vac RMS Operating Temperature Range: -40° to +85°C. Storage Temperature Range: -40° to +85°C. Moisture Resistance: 240 hours with temperature cycling and polarization. Passes insulation resistance and dielectric strength per MIL-STD-202F, Method 106 following exposure. Mechanical Ratings Mechanical Life: 10,000 cycles of operation. One cycle is a rotation through all positions and a complete return through all positions. Mechanical Shock: 1000g's, 0.5 mS, half sine per MIL-STD-202F, Method 213, Test Condition E. Vibration Resistance: 10-2000 Hz at 15G or 0.060" double amplitude per MIL-STD-202F, Method 204, Test Condition B. Operational Torque: 2 to 6 inch-ounces initially and 1.2 inch-ounces minimum after life. B-23 Materials and Finishes Rotor and Switch Body: Plastic (UL94V-O) Contact Material: Copper alloy plated. 30 microinches minimum gold over 50 microinches minimum nickel. Shorting Member: Copper alloy plated. 30 microinches minimum gold over 50 microinches minimum nickel. Terminals: Copper alloy plated. 100 microinches minimum 90/10 tin lead solder over 50 microinches minimum nickel. Internal O-ring: Rubber BUNA-N Soldering Information Soldering Temperature: 250° C for 10 seconds maximum. Cleaning: Acceptable solutions include 1-1-1 Trichlorenthane, Freon (TF, TE, or TMS), Isopropyl Alcohol and detergent (140°F maximum). Solutions which are not recommended include Acetone, Methylene Chloride, and Freon TMC. Series 94H and 94R Standard Output SWITCH POSITION DIP Switches DIMENSIONS FEATURES • 10,000 Cycles of Operation • Gold-Plated Contacts • Sealed Contact System • Right Angle Mount • Octal, BCD & Hexadecimal Codes • Standard or Complement CODE OUTPUT CODE OUTPUT 1 2 4 8 1 2 4 8 Complement Output 0 1 2 3 4 5 6 7 8 9 A B C D E F Dot indicates terminal to common connection. All switches are continuous rotation. Octal and Octal Complement outputs are 0 thru 7 positions. BCD and BCD Complement outputs are 0 thru 9 positions. Hexadecimal and Hexadecimal Complement outputs are 0 thru F positions. Standard codes have natural color rotors; complements have rotors in a contrasting color. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Rotary DIP Switches DIP Switches ORDERING INFORMATION: Series 94R Continuous Rotation Versions Code No. of Positions Standard Code Part Number Complement Part Number 8 10 16 94RB08C 94RB10C 94RB16C 94RC08C 94RC10C 94RC16C No. of Positions Standard Code Part Number Complement Part Number 16 94RB16F 94RC16F Octal BCD Hexadecimal Rotational Stop Versions* Code Hexadecimal * Consult Grayhill for 8 or 10 position Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com B-24
94HBB10T 价格&库存
很抱歉,暂时无法提供与“94HBB10T”相匹配的价格&库存,您可以联系我们找货
