04J-AS-T02
04J-AS-T02
    GRAYHILLINC.
    04J-AS-T02
04J-AS-T02 数据手册
D Joysticks SERIES 04J Joystick with Center Pushbutton FEATURES • Sealed against contamination when properly mounted (IP67) Ø.925 ±.002 ID .56 ±.03 • TwoOF styles available: O-RING GROOVE behind-panel mount or front-panel mount • RoHS compliant • Short behind panel 4X .030 TERMINAL THICKNESS 5X .079 TERMINAL .093 CENTER TERMINAL DESCRIPTION Series 04J is a single Y pole, 4-way toggle switch with a pushbutton in the center position. 4-way contact is made in the opposite direction of travel. EPOXY REAR SEAL 3 DIMENSIONS in inches (and millimeters) .775 ±.005 BEHIND PANEL MOUNTTO FLAT 2 Y .56 ±.03 4X .030 5X .079 TERMINAL TERMINAL THICKNESS .093 CENTER TERMINAL Y Ø.700 REF BUTTON RECOMMENDED PANEL CUTOUT EPOXY REAR SEAL Ø.080 CENTER TERMINAL .114 .210 2X .141 CENTER TO CENTER .674 .674 FRONT PANEL MOUNT 2X .141 CENTER TO CENTER .015 COMMON THICKNESS .223 TO OF TERMINAL 2X .283 CENTER TO CENTER 2X .283 CENTER TO CENTER .051 ±.001 .659 O-RING GROOVE [ 16,73 ] DEPTH .410 .601 [ 15,25 ] Ø.700 [ 17,78 ] 4X .055 TERMINAL 4 1 Ø.700 REF BUTTON .055 COMMON TERMINAL Ø.080 CENTER 3 C TERMINAL 2 5 .775 ±.005 TO FLAT .114 .210 45.0° .015 [ 0,38 ] .055 [ 1,4 ] 2X .283 [ 7,19 ] [ 10,41 ] 4X .055 [ 1,4 ] .705 [ 17,91 ] RECOMMENDED PANEL CUTOUT Ø1.000 [ 25,4 ] .096 +.002/-.003 O-RING GROOVE WIDTH ELECTRIC & MECHANICAL RATINGS Rating: 2 amp resistive; 0.5 amp inductive at 28VDC or 115VAC Contact Resistance: .05 ohms (max) Operating Temperature: -55°C to +85°C Operational Life: 100,000 cycles (min) Pushbutton Travel: .020 minimum overall Pushbutton Operating Force: 5 lbs. (max) Insulation Resistance: 10,000M ohms ORDERING INFORMATION .160 Available from your local Grayhill Distributor. For prices and discounts, contact a local sales office, an authorized local distributor or Grayhill. O-RING GROOVE DETAIL .079 [ 2,01 ] .350 [ 8,89 ] SECTION Y-Y 3/4-32 UNF 2A THREADS Ø1.063 Vibration: per MIL-DTL-9419F, Method 3.5.9 Toggle Lever Travel: 15° from center (max) Toggle Operating Force: 16 oz + 6 oz initial Toggle Pivot & Stop Strength: 25 lbs. (max) Mechanical Shock: per MIL-STD-810, procedure I, method 516.4 Immersion: per MIL-PRF-8805 Moisture Resistance: per MIL-DTL-9419 .125 Grayhill Series Number Version: B = behind panel; A = front panel Connection: P = PCB mount; S = solder lugs MOUNTING NUT Ø.625 [ 15,88 ] .223 [ 5,66 ] 4X .030 [ 0,76 ] MATERIALS & FINISHES Switch Body & Concave Cap: Thermoplastic (black, cone-shaped cap is gray) Bushing: Aluminum alloy (black chrome) Contact Terminals: 1/2 hard brass (gold over silver over nickel plating) Spanner Nut: Stainless steel (black chrome) O-Ring: 50 durometer fluorosilicone CIRCUITRY POS 4 C POS. 3 POS. 1 04J-BP-T 0 1 Current: 1 = high; 2 = low Keycap SCALE 1.000 Color: 0 = black; 1 = gray Keycap Shape: T = stadium cap; C = cone-shaped cap Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois POS. 5 (PSHBTN MODE) POS. 2 *Contact made opposite the direction of travel 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com C 5 1 Ø.925 ±.002 ID OF O-RING GROOVE Ø1.176 ±.005 Joysticks FF. Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. 4
04J-AS-T02 价格&库存
很抱歉,暂时无法提供与“04J-AS-T02”相匹配的价格&库存,您可以联系我们找货
04J-AS-T02
