48ASSP1S1M1QBT
48ASSP1S1M1QBT
    GRAYHILLINC.
    滑动开关 单刀双掷 直插
48ASSP1S1M1QBT 数据手册
Series 48A: Slide Switches SERIES 48A Slide Switches FEATURES • Save Space and Weight • SPDT and DPDT Circuitry • Choice of Actuations and Terminations MODELS in inches (and millimeters) SPDT TRAVEL .085 (2.16) SWITCH POSITION MODEL NO. SSP1 SSP2 SSP3 ON ON ON 2-1 TERM. COMM. NONE NONE OFF OPEN ON (ON) ON 2-3 .770 (19.56) ()=MOMENTARY SDP1 SDP3 TERM. COMM. TRAVEL .085 (2.16) SWITCH POSITION ON NONE ON OFF OPEN 2-3,5-6 ON ON 2-1,5-4 .770 (19.56) ()=MOMENTARY 1 2 .152 (3.86) .155 (3.94) .250 (6.35) 3 4 6 .500 (12.70) .080 (2.03) .030 (0.76) .450 (11.43) .185 (4.70) .152 (3.86) .250 (6.35) 6 3 5 2 4 1 .500 (12.70) .080 (2.03) .155 (3.94) .190 (4.83) SCHEMATIC Slide Switches in inches (and millimeters) Std S3 S2 .152 SQ. (3.86) .200 (5.08) EPOXY SEAL .200 (5.08) .690 (17.53) .240 (6.10) 05COMM. ACTUATOR OPTIONS S1 3 3 1 02COMM. .260 (6.60) .690 (17.53) .240 (6.10) DPDT MODEL NO. .030 (0.76) .185 (4.70) 1 02COMM. SCHEMATIC EPOXY SEAL .200 (5.08) .152 SQ. (3.86) .285 (7.24) .152 SQ. (3.86) .370 (9.40) S4 .152 SQ. (3.86) .140 (3.56) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Series 48A: Slide Switches ACTUATOR OPTIONS S5 in inches (and millimeters) For DPDT Only S6 S7 .152 SQ. (3.86) .152 SQ. (3.86) T1 For DPDT Only .152 SQ. (3.86) .152 (3.86) .325 (8.26) .485 (12.32) TERMINATION OPTIONS M1 .310 (7.88) DIP Switches .051 (1.30) .200 (5.08) in inches (and millimeters) Solder Lug .156 (3.96) .078 (1.98) M2 M3 P.C. Mount (Std) P.C. Mount, Quick Connect EPOXY SEAL .189 (4.80) .189 (4.80) .250 (6.36) .047 (1.19) .250 (6.35) .080 (2.03) THK. .030 (0.76) THK. .030 (0.76) M6 Right Angle P.C. Mount, Horizontal Actuation .152 .186 (4.72) .125 (3.86) (3.18) .050 (1.27) .500 (12.70) .260 (6.60) 1 .030 (0.76) .185 (4.70) SPDT .046 (1.17) .106 (2.69) 3 .014 (0.36) 4 5 6 1 2 3 .106 (2.69) .450 (11.43) 1 DPDT .185 (4.70) 4 .050 (1.27) .500 (9.53) .150 (3.81) M7 Right Angle P.C. Mount, Vertical Actuation .186 EPOXY SEAL .014 (0.36) .050 (1.27) SPDT 1 2 .520 (13.21) Ø.073 (Ø1.85) 2 .500 (12.70) .400 (10.16) .046 (1.17) .030 (0.76) .150 (3.81) 1 3 .014 (0.36) .400 (10.16) .150 (3.81) 3 .106 2.69 .152 (3.86) .500 (12.70) .520 (13.21) .260 (6.60) (4.72) Ø.073 (Ø1.85) .150 (3.81) .175 (4.45) .175 (4.45) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Slide Switches .030 (0.76) .046 (1.17) .520 (13.21) .185 (4.70) .500 (12.70) EPOXY SEAL .185 (4.70) Ø.073 (Ø1.85) .375 (9.53) .520 (13.21) .375 (9.53) .186 (4.72) .152 (3.86) .125 (3.18) .050 (1.27) 2 .062 (1.57) .030 (0.76) THK. Series 48A: Slide Switches TERMINATION OPTIONS in inches (and millimeters) EPOXY SEAL .186 (4.72) DPDT .190 (4.83) .450 (6.60) .106 (2.69) 2 .150 (3.81) Ø.073 (Ø1.85) 3 .500 (12.70) 1 .152 (3.86) .150 (4.83) V2 4 .014 (0.36) .500 (12.70) Vertical Bracket P.C. Mount .152 (3.86) 5 6 .030 (0.76) .152 (3.86) .314 (8.00) .125 (3.18) 2 .186 (4.72) 3 .014 (0.36) .181 (4.60) .175 (4.45) .125 (3.18) 1 SPDT .106 .175 (2.69) (4.45) .150 (3.81) .350 (8.90) .046 (1.17) .500 (12.70) .046 (1.17) .620 (15.75) .030 (0.76) .185 (4.70) .185 (4.70) Ø.073 (Ø1.85) .620 (15.75) .152 (3.86) .152 (3.86) .492 (12.50) .314 (8.00) .400 (10.16) .125 (3.18) 4 5 6 .014 (0.36) DPDT .046 (1.17) .125 (3.18) Ø.073 (Ø1.85) .190 (4.83) .620 (15.75) SPECIFICATIONS Slide Switches RATINGS Contact Rating: Q option - 5A with resistive load @ 125 VAC or 28 VDC; 2A with resistive load @ 250 VAC. R option - 0.4 VA max @ 20 Vmax (AC or DC) Electrical Life: 30,000 cycles at full load .620 (15.75) .030 (0.76) .185 (4.70) .184 (4.67) .186 (4.72) .185 (4.70) Contact Resistance: 10 milliohms max. initial @ 2-4 VDC, 100 mA Insulation Resistance:1,000 megaohms min Dielectic Strength: 1,000 V RMS @sea level Operating Temperature: -30°C to 85°C MATERIALS Case: Diallyl phthalate (DAP) (UL94V-0) Housing: Stainless steel Slide Handle: Nylon Terminal/Contacts: Copper alloy with gold over silver plate. Terminal Seal: Epoxy ORDERING INFORMATION Series 48A Slide Switches Model: SPDT: SSP1, SSP2, SSP3 DPDT: SDP1, SDP3 Actuator Options: S1, S2, S3, S4, S5, S6, S7, T1 (See Actuator options.) 48ASSP1S2M6RBT RoHS Compliant Mounting Options: A = Mounting Tabs, B= No Mounitng Tabs Contacts: R = Copper alloy, gold plate over nickel plate, Q = Copper alloy, silver plate Termination Options: M1, M2, M3, M6, M7, V2 (See Termination options.) Available from your local Grayhill Component Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
48ASSP1S1M1QBT 价格&库存
很抱歉,暂时无法提供与“48ASSP1S1M1QBT”相匹配的价格&库存,您可以联系我们找货
48ASSP1S1M1QBT
