67B-JA-3C-S-03C
67B-JA-3C-S-03C
    GRAYHILLINC.
    SWITCH JOYSTICK FLATTED HALL
67B-JA-3C-S-03C 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Joysticks SERIES 67B Hall Effect Joystick FEATURES • Proportional output joystick, pushbutton, & momentary rotary select in one device • Shaft and panel seal to IP67 • Rugged and compact: 1.25 inch diameter • Long operational life • RoHS compliant • i²c output (see www.grayhill.com for User Manual) APPLICATIONS • Medical imaging - X-ray, CT scanner, MRI patient tables • Military vehicles - display navigation • Handheld remote control devices • Material handling equipment and crane operations Actual Size DIMENSIONS in inches [millimeters] with sealing boot SHOWN WITH GRAYHILL P/N 677702 KNOB SOLD SEPARATELY RECOMMENDED PANEL CUTOUT SEE DETAIL B PANEL THICKNESS SHOULD NOT EXCEED .075" IN AREA OF Ø.900 FOR SEALED VERSIONS .550 [ 13,97 TYP. Ø1.250 [ 31,75 ] 4x THREADED MOUNTING HOLES #4-40 UNC .250 [6,35] ] Ø.900 [ 22,86 ] Ø.115 [ 2,92 ] +.000 / -.010 [+0,00 / -0,25] 4 PLACES .140 [ 3,56 ] SHAFT FLAT .870 [ 22,1 ] SHAFT Ø.160 [ 4,06 ] ±.002 [0,05] .550 [ 13,97 TYP. Joysticks .843 [ 21,41 SHOWN WITH .025x45° CHAMFER ON Ø.900 ] Ø.990 [ 25,15 ] REF. ] DETAIL B SCALE 3.000 1.120 [ 28,45 REF. ] .583 [ 14,81 REF. ] .020 [0,51]x45° CHAMFER SHAFT TRAVEL 20° ANY DIRECTION (ALL-WAY GATER) .982 [ 24,94 ] ±.015 [0,38] MOUNTING SURFACE .686 [ 17,42 ] ±.015 [0,38] .200 [ 5,08 ] SHAFT FLAT .746 [ 18,95 ] ±.015 [0,38] .296 [ 7,52 ] SHAFT PIVOT POINT .660 [ 16,76 ] ±.015 [0,38] CABLE LENGTH ±.200 [5,08] CONNECTOR IS MOLEX, P/N 14-56-2084 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Joysticks DIMENSIONS in inches [millimeters] without sealing boot SEE DETAIL C .140 SHAFT FLAT Ø1.250 .550 TYP. 4x THREADED MOUNTING HOLES #4-40 UNC .250 .843 SHAFT Ø.160 ±.002 DETAIL C SCALE 3.000 .870 PIN HEADER VERSION .020x45° CHAMFER SHAFT TRAVEL 20° ANY DIRECTION (ALL-WAY GATER) 1.032 ±.015 .200 SHAFT FLAT .736 ±.015 MOUNTING SURFACE .302 ±.050 .696 ±.015 .246 SHAFT PIVOT POINT .610 ±.015 CABLE LENGTH ±.200 CONNECTOR IS MOLEX, P/N 14-56-2084 BLOCK DIAGRAM VDD 67B JOYSTICK VDD Effect I2C Slave Sensor PB (OPTION) 3 POS MOM SW (OPTION) µC SDA INTn PBn A1 SCL 1 2 3 4 5 6 7 8 1 2 3 4 5 6 7 8 SDA SCL A1 INTn PBn SIDE OF PRINTED CIRCUIT BOARD PROTRUSION INDICATES +Y DIRECTION FOR JOYSTICK OUTPUT I2C Master µC +Y (0,50) SELECT I2C ADDRESS JUMPER OUT = 42H JUMPER IN = 40H CCW CW (-50,0) -X 50 -3°±2° SHAFT FLAT OPPOSITE PCB PROTRUSION (0,1) * PULL-UP RESISTORS REQUIRED JOYSTICK OUTPUT WAVEFORM +Y JOYSTICK OUTPUT JOYSTICK OPERATIONAL LIMITS 10K* Rp* Rp* 10K* Hall -20° HOST CPU (-1,0) SLEEP ZONE +X (1,0) (50,0) (0,-1) JOYSTICK OUTPUT ALONG X OR Y AXIS Joysticks BLOCK DIAGRAM & JOYSTICK OUTPUT WAVEFORM (0,-50) 0 3°±2° 20° -Y NOT TO SCALE DEGREES SHAFT TRAVEL, ° NOT TO SCALE -50 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Joysticks SPECIFICATIONS Electrical Ratings Supply Voltage (VVD): 3.3V ± .0.3V High Level Input Voltage (VIH, Min): 0.7*VDD on SCL & SDA / 0.25*VDD+0.8 on Al Low Level Input Voltage (VIL, Max): 0.3*VDD on SCL & SDA / 0.15*VDD on Al Current Draw In Active Mode (IDDI): 3mA Maximum @ VDD = 3.3V (J & P options only) Current Draw In Sleep Mode (IDD2): 100uA Maximum @ VDD = 3.3V (J & P options only) Current Draw in Active Mode (IDD3): 4mA Maximum @ VDD = 3.3V (R option has active mode only) Typical Operating Current: 4.0 mA at Vcc = 3.3V, T = 25°C Maximum Operating Current: 7.0 mA over 3.0 < Vcc < 3.6V, -40°C < T < 85°C Maximum Current Sunk By Any I/O Pin: 25mA Leakage Current: ±5 nA Typ., ±125 nA Max Low Level Output Voltage (VOL): 0.6V On INTn & SDA @ IOL = 6mA, @ VDD = 3.3V Measurement Frequency (Active Mode): 50 Samples/Sec Response Time, Active Mode (T1): 20ms* Response Time, Sleep Mode (T2): 80ms* Output @ Maximum Joystick Deflection (XMax, YMax): 50 Units Output With Joystick Shaft Released (Center Position): (0,0) Nominal Startup Time (TP, W): 300ms Vibration: Random, Meets MIL-STD-810G, Method 514.6, Procedure I Mechanical Shock: Meets per MIL-STD 202, Method 213B Test Condition A Transit Drop: Meets per MIL-ST-810G, Method 516.6, Procedure II Impact Strength: 227 grams, dropped from 40cm, 3 times Materials and Finishes Housing: Thermoplastic Backplate: Thermoplastic Lockwashers: 304 Stainless Steel Hex Nuts: 303 Stainless Steel Shim Washers: 304 Stainless Steel Shaft: 303 Stainless Steel Cable Assembly: 26 AWG Stranded Copper Conductors Connector Body: Thermoplastic Terminals: Phosphor Bronze O-Rings: Fluorosilicone Sealing Boot: Silicone Rubber Molded over Thermoplastic Insert Environmental Ratings Operating Low Temperature: -40°C, Tested per IEC 68-2-14, Test Na Storage High Temperature: +100°C, Tested per IEC 68-2-2, Method Ba Storage Low Temperature: -55°C, Tested per IEC 68-2-1, Method Aa Humidity: Meets MIL-STD 202, Method 103B Humidity, 85/85: 500 hours tested per MIL-STD 202, Method 103B Solar Radiation: Tested per MIL-STD 810G, Method 505.5, Procedure II Chemical Resistance: Meets ISO 16750-5 Dielectric: Meets MIL-STD 202G, Method 301 Insulation Resistance: Tested per MIL-STD 202G, Method 302 EMC Ratings Radiated Immunity: Meets IEC 61000-4-3, 10 V/m,80 MHz-1000 MHz Conducted Immunity: Meets IEC 61000-4-6, 10 V RMS, 150 KHz to 80 MHz Radiated Emissions: Meets ANSI C63.4, Class B Conducted Emissions: Meets EN 55022, Class B Electrostatic Discharge: Meets IEC 61000-4-2, 8 kV contact/15 kV air discharge Power Frequency Magnetic Field: Meets IEC 61000-4-8, 30 A/m Seal: IP67, Meets IEC 60529 (sealed version only) Altitude: Tested per MIL-STD 202, Method 105C Thermal Shock: Meets MIL-STD 202, Method 107G Operating High Temperature: +85°C, Tested per IEC 68-2-14, Test Na *Response time is the time from joystick movement to when new X,Y position data is available. **One cycle is defined as a complete revolution of the shaft around the fixed perimeter, or one actuation in each of the 4 main directions, with return to center between each actuation. ORDERING INFORMATION Grayhill Series Number Available Functions: J = Joystick Only, P = Joystick + Pushbutton, R = Joystick + Pushbuttons + Momentary Turn Joystick Shaft Limiting: 2 = 2-Way 20° Either Direction, 4 = 4-Way 20° in 4 Main Directions, A = All-Way 20° in Any Direction 67B - PA- 3C - S - 03C Termination: C = Cable with Connector, P = Pin Header Cable Length: 02 = 2.0 inches through 06 = 6.0 inches. 1 inch increments. Leave blank if pinned. Example: 67B-PA-3C-S-P Seal Option: S = With Sealing Boot, U = Without Sealing Boot Interface: C = I2C Voltage: 3 = 3.3V Pictured with knob, p/n: 677702 For prices and custom configurations, contact a local sales office, an authorized distributor, or Grayhill's sales department. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Joysticks Physical & Mechanical Ratings Terminal Strength: 10 lbs. Minimum, Tested per MIL-STD-202, Method 211A Push-Out Force: 60 lbs. Minimum Pull-Out Force: 60 lbs. Minimum Shaft Side-Load: 45 lbs. Minimum Mounting Torque: 3-5 in-lbs recommended, 8 in-lbs. Maximum Joystick Actuation Force: 300g Peak ± 25% Joystick Life: 1 million cycles minimum** Pushbutton Life: 1 million actuations, minimum Rotational Life: 1 million turns, minimum in each direction
67B-JA-3C-S-03C 价格&库存
很抱歉,暂时无法提供与“67B-JA-3C-S-03C”相匹配的价格&库存,您可以联系我们找货
