05001-04N
05001-04N
    GRAYHILLINC.
    旋转开关 28VDC 115VAC
05001-04N 数据手册
Single Deck Rotary Switches SERIES 5000 1" Diameter, 1 Amp, . 470" Behind Panel FEATURES • High Quality at a Low Price • High Contact Force Provides Stable Electrical and Mechanical Operation • Proven Reliability in Thousands of Applications DIMENSIONS In inches (and millimeters) Circuit Diagram .490 ± .020 (12,45 ± 0,51) .312 ± .020 (7,93 ± 0,51) (Switch is viewed from shaft end.) Note: Common Terminal is located above Base Terminal 10. .250 ± .020 (6,35 ± 0.51) .250 ± .020 (6,35 ± 0.51) TERMINAL 9 IN LINE WITH KEYWAY .250 + .001/ – .002 (6,35 + 0,03/ – 0,05) DIA. .823 ± .015 (20,9 ± 0,38) Rotary Switches BUSHING KEYWAY .066 ± .002 (1,68 ± 0,05) WIDE .036 ± .005 (0,91 ± 0,13) DEEP FROM THE .375 (9,53) DIAMETER .564 ± .020 (14,33 ± 0,51) 7 8 9 6 .823 ± .020 (20,90 ± 0,51) DIA. 1.015 ± .015 COMMON (25,78 ± 0,38) DIA. 36° ± 5° 5 10 4 .219 ± .005 (5,56 ± 0,13) C1 1 3 3/8-32UNEF-2A THREAD CL OF BUSHING KEYWAY 2 ONE POLE Grayhill part number and date code marked on label. Customer part number marked on request. SPECIFICATIONS STANDARD OPTIONS Electrical Rating Rated: To make and break the following loads: 1 amp at 115 Vac resistive; 0.5 amp at 220 Vac resistive; 1/4 amp, 115 Vac inductive; 1/50 amp, 115 Vdc inductive, 1/10 amp, 6 to 28 Vdc inductive; 1/10 amp, 115 Vdc resistive; 1 amp, 6 to 28 Vdc resistive; to carry 10 amps continuously. Contact Resistance: 10 milliohms initial. After 25,000 cycles of operation 20 milliohms maximum. Insulation Resistance: 50,000 Mohms minimum initially Voltage Breakdown: 1,000 Vac (500 Vac, or better after most environmental tests). Life Expectancy: 100,000 mechanical cycles of operation normally. NOTE: Actual life is determined by a number of factors, including electrical loading, rate of rotation, and environment, as well as maximum contact resistance, minimum insulation resistance, and minimum voltage breakdown required at the end of life. Materials and Finishes Switch Base: Melamine per MIL-M-14 (ASTMD-5948) Cover, Stop Washers, Bushing: Brass, tin/ zinc-plated Mounting Nut: Brass, tin/zinc-plated or stainless steel Rotary 16 Retaining Rings, Stop Arms, and Thrust Washers: Stainless steel Shaft: Stainless steel Terminals (except common): Brass, tin plated Rotor Contact: Phosphor bronze, silver-plated .0003" minimum Stator (Base) Contact: Brass, silver-plated .0003" minimum Common Plate: Brass, silver-plated .0003" minimum Rotor Mounting Plate: Nylon fabric-based laminated Phenolic per MIL-T-1 5047. Additional Characteristics Stop Strength: 12 in-lbs Rotational Torque: 12 in-ozs. Contacts: Shorting or non-shorting wiping contacts with over 500 grams contact force. Shaft Flat Orientation: Opposite point of contact (See circuit diagram.) Environmental: These switches have passed the following environmental testing: Altitude and temperature; 100 hour salt spray; Vibration 10 to 500 cps; Shock 30-G; Humidity; Fungus. Detent: A formed spring operating against a formed wave washer. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Special Terminals Not available through distributors. ORDERING INFORMATION The Series 5000 switches are single deck, one pole switches of two to 10 positions. Ten position switches have continuous rotation. Ten position fixed stop switches are available by special order. The part number is 05001-XX with the number of positions required (02,03, etc.) listed in place of the XX. Complete part number by adding N for non-shorting contacts or S for shorting contacts. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
05001-04N
物料型号为 Grayhill 的 SERIES 5000,具体型号为 05001-XX,其中 XX 代表所需位置数(如02,03等)。
若需要非短路接触点,则在型号后加 N;若需要短路接触点,则加 S。
器件简介:这是一款直径为1英寸、额定电流为1安培的高品质、低成本的旋转开关,适用于多种应用场景。
引脚分配:开关的公共端位于基座端的上方,具体的引脚分配和电路图在文档中有详细描述。
参数特性:电气额定值为1安培,115Vac电阻性负载;接触电阻初始值为10毫欧姆,操作25,000次后最大为20毫欧姆;绝缘电阻至少为50,000兆欧姆;电压击穿为1,000Vac。
功能详解:开关具有高接触力,提供稳定的电气和机械操作,经过多种环境测试,具有很高的可靠性。
应用信息:适用于数千种应用,具体应用场景未在文档中详细说明。
封装信息:开关基座材料为三聚氰胺,符合MIL-M-14 (ASTMD-5948);盖子、定位垫圈、衬套为镀锡/锌黄铜;安装螺母为镀锡/锌黄铜或不锈钢;保持环、定位臂和推力垫圈为不锈钢;轴为不锈钢;端子(公共端除外)为镀锡黄铜;转子接触为至少镀银0.0003英寸的磷青铜;定子(基座)接触为至少镀银0.0003英寸的黄铜;公共板为至少镀银0.0003英寸的黄铜;转子安装板为尼龙织物基覆层酚醛树脂,符合MIL-T-15047。
以上信息摘自提供的PDF文档。
05001-04N 价格&库存
很抱歉,暂时无法提供与“05001-04N”相匹配的价格&库存,您可以联系我们找货
