51ST30-01-3-02N
51ST30-01-3-02N
    GRAYHILLINC.
    旋转开关 28VDC 115VAC
51ST30-01-3-02N 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Single Deck Rotary Switches SERIES 50 SERIES 51 0.5" Diameter, 200mA, .698" Behind Panel FEATURES • Optional Complete Seal for PC Board Assembly and Cleaning • Small 1/2" Diameter • Choice of 22.5°, 30°, 36°, 45°, 60° and 90° Angles of Throw in inches (and millimeters) PC Mount Style .250±.015 (6,35±0,38) A .375±.015 (9,53±0,38) .125±.015 (3,18±0,38) .250±.015 (6,35±0,38) DIMENSION D POS. 1 OPTIONAL PANEL SEAL GASKET Ø.125 +.001- .002 (3,18 + 0,03 -0,05) 22.5° 30° 36° Angle of Throw Angle A 45° 112.5° 60° 120° 90° 135° 101.25° 105° 108° Dimension Series 50 D .500 ± .015 (12,70 ± 0,38) PC COMMON DETAIL All angles of throw, except 22.5° .171 ± .015 (4,34 ± 0,38) Ø .025 ± .002 (0,64 ± 0,05) Series 51 .562 ± .015 (14,27 ± 0,38) Dimension B Style T .576 ± .015 (14,63 ± 0,38) All Others All 22.5° .537 ± .015 (13,64 ± 0,38) .537 ± .015 (13,64 ± 0,38) SOLDER LUG TERMINAL DETAIL All angles of throw, except 22.5° .250±.015 (6,35±0,38) Dimension B .375±.015 (9,53±0,38) .064 ± .005 (1,63 ± 0,13) .020 ± .005 (0,51 ± 0,13) Dimension C .250±.015 (6,35±0,38) Front view same as PC Mount style. TERMINAL SEALANT IN STYLE T .065 ± .003 (1,65± 0,08) Solder Lug Style Ø.125 + .001 - .002 (3,18 + 0,03 - 0,05) TERMINAL SEALANT IN STYLE "T" .020 ± .005 (0,51 ± 0,13) .020 ± .003 (0,51 ± 0,08) Angle A COMMON Ø .025 ± .002 (0,64 ± 0,06) AND EXTEND TO SAME PLANE AS POSITION TERMINALS PC TERMINAL DETAIL All angles of throw, except 22.5° .125 ± .015 (3,18 ± 0,38) Dimension E .032 ± .004 (0,81 ± 0,10) 2 1 10 9 GRAYHILL Rotary Switches Grayhill part number and date code marked on label. Customer part number marked on request. Military part number marked when required. TERMINALS ARE .016 ± .003 (0,41 ± 0,08) SQ. 1/4-28 UNF-2A THREAD .093 ± .005 (2,36 ± 0,13) Angle of Throw .171 ± .015 (4,34 ± 0,38) .125 (3,18) REF. GRAYHILL .203 ± .003 (5,16 ± 0,08) ACROSS FLATS Side View 22.5° All others as shown at left DIMENSION "B" 2 1 10 9 DIMENSIONS • Up to 4 Poles on 1 Deck • Up to 16 Positions Per Switch • PC or Solder Lug Termination • Positive Shaft Grounding for EMI/RFI Shielding .065 ± .003 (1,65 ± 0,08) SOLDER LUG TERMINAL DETAIL 22.5° .064 ± .005 (1,63 ± 0,13) .016 ± .004 (0,41 ± 0,10) TERMINAL SEALANT IN STYLE "T" 1/4-28 UNF-2A THREAD Dimension 30°, 36°, 45°, 60°, 90° 22.5° B .658 ±.015 (16,71 ±0,38) .591±.020 (15,01±0,50) C .234 ±.015 (5,94 ±0,38) .200±.015 (5,08±0,38) E .153±.015 (3,89±0,38) .12±.015 (3,05±0,38) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .021 ± .004 (0,53 ± 0,10) .046 ± .004 (1,17 ± 0,10) 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Single Deck Rotary Switches CIRCUIT DIAGRAMS AND REAR VIEWS: Solder Lug and PC Mount Rear View SOLDER LUG COMMON TERMINAL (1 POLE) .382 ± .015 (9,70 ± 0,13) DIAMETER CIRCLE OF TERMINAL CENTERS .156 ± .015 (3,96 ± 0,13) 11.25˚ POS. 1 22.5˚ LOCATION OF COMMONS 2 POLES Circuit as Viewed From Shaft End PC MOUNT .500 ± .015 (12,7 ± 0,13) DIA. CIRCLE OF CENTERS 11.25˚ POS. 1 22.5˚ .156 ± .015 (3,96 ± 0,13) C2 8 6 9 POLE 1 POS. 1 POLE 1 FOUR POLES THREE POLES Dimension A, diameter circle of common centers, is .175 (4,45) for Solder Lug and .232 (5,89) for PC. 6 1 6 .175 ± .005 (4,45 ± 0,13) DIAMETER CIRCLE OF COMMON CENTERS 9 7 C2 6 5 1 C2 6 2 5 9 5 1 5 1 3 2 8 9 10 C2 1 C1 4 2 ONE POLE 36° Angle of Throw 2 3 TWO POLES 7 7 6 8 1 4 12 C1 7 5 11 C4 4 30° Angle of Throw FOUR POLES 6 5 8 C2 C1 4 2 3 10 C3 10 6 2 3 9 8 C1 3 1 4 7 6 LOCATION OF COMMONS 2 POLES 45˚ 11 3 12 TWO POLES 12 8 7 4 22.5˚ POS. 1 5 C3 4 11 C1 THREE POLES LOCATION OF COMMONS 2 POLES COMMON TERMINAL (1 POLE) .320 ± .015 (8,13 ± 0,38) DIAMETER CIRCLE OF TERMINAL CENTERS 10 10 1 45° Angle of Throw 2 3 TWO POLES ONE POLE COMMON TERMINAL (1 POLE) .320 ± .015 (8,13 ± 0,38) DIAMETER CIRCLE OF TERMINAL CENTERS 5 5 6 4 4 30˚ 1 3 POS. 1 LOCATION OF COMMONS 2 POLES 60˚ 6 C2 .125 ± .015 (3,18 ± 0,38) C1 3 1 2 2 ONE POLE TWO POLES 60° Angle of Throw COMMON TERMINAL (1 POLE) LOCATION OF COMMONS 2 POLES .320 ± .015 (8,13 ± 0,38) DIAMETER CIRCLE OF TERMINAL CENTERS 3 4 3 4 90° Angle of Throw C2 .125 ± .015 (3,18 ± 0,38) C1 2 45˚ 1 ONE POLE POS. 1 2 1 TWO POLES 90˚ Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Rotary Switches .125 ± .015 (3,18 ± 0,38) .125 ± .015 (3,18 ± 0,38) 9 C2 2 3 3 5 4 8 ONE POLE .320 ± .015 (8,13 ± 0,38) DIAMETER CIRCLE OF TERMINAL CENTERS 36˚ 11 7 COMMON TERMINAL (1 POLE) 18˚ POS. 1 2 6 22.5° Angle of Throw ONE POLE 12 4 15 16 1 7 7 LOCATION OF COMMONS 2 POLES DIM. A ± .005 (0,13) 10 14 8 3 5 4 8 POS. 1 1 12 13 11 10 9 2 7 5 30˚ 15 16 C1 8 .156 ± .005 (3,96 ± 0,13) 15˚ 14 LOCATION OF COMMONS TWO POLES 2 POLES COMMON TERMINAL (1 POLE) COMMON TERMINAL (1 POLE) .382 ± .005 (9,70 ± 0,13) DIAMETER CIRCLE OF TERMINAL CENTERS POS. 1 12 13 11 10 9 Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Single Deck Rotary Switches SPECIFICATIONS Military Qualification The dimensions for qualified switches are the same as those indicated in the drawings of standard switches. Switches with standard variations, such as shaft and bushing length, which do not affect switch performance, can be marked as qualified product. Contact Grayhill for complete information on variations. Electrical Ratings Life Expectancy: With the limiting criteria stated here, the Series 50 and 51 with non-shorting contacts will switch the following loads at atmospheric and reduced pressures for 25,000 cycles of operations. One cycle is 360° rotation clockwise and 360° return. Materials and Finishes Switch Base: Thermoset Detent Rotor: Nylon Shaft, Stop Blades, Stop Arm, Thrust washer, and Retaining Ring: Stainless steel Detent Balls: Steel, nickel‑plated Bushing: Zinc, tin‑zinc plated Detent and Contact Springs: Stainless steel Common Ring: Brass, gold‑plated over silver At 85°C, atmospheric pressure plate. 200 mA, 28 Vdc resistive Terminals: Brass, gold‑plated over silver plate 150 mA, 115 Vac resistive and nickel plate 30 mA, 28 Vdc inductive Rotor Contact: Precious metal alloy, gold‑plated 100 mA, 28 Vdc lamp load Panel Seal: Silicone rubber 75 mA, 220 Vac lamp load Shaft Seal: Fluorosilicone At 25°C, reduced pressure (70,000 feet) Mounting Nuts: Brass, tin-zinc plated Mounting Hardware: One mounting nut .089" thick by .375" 200 mA, 28 Vdc resistive across flats and one internal tooth lockwasher are 150 mA, 115 Vac resistive supplied with the switch. Maximum Mounting 75 mA, 220 Vac resistive Contact Resistance: 20 milliohms maximum, Torque: 15in-lbs (10 milliohms initially). Rotary Switches 36°, 45°, 60°, 90° (Series 50): The C and M style switches are qualified to MIL‑S‑3786/20. They include the following: Solder lug or PC terminals With or without panel seal Series 50 qualified switches may be ordered by the ‘M’ number or by the Grayhill part number. 30° (Series 51): The C and M style switches are qualified to MIL‑S‑3786/35. They include the following: Solder lug or PC terminals With or without panel seal Insulation Resistance: 1,000 Mohms Series 51 qualified switches may be ordered minimum between mutually insulated parts. by the ‘M’ number or by the Grayhill part Voltage Breakdown: 600 Vac minimum number. between mutually insulated parts at standard atmospheric pressure. Life Expectancy: Listed for the voltage source and make and break current levels. Contact Grayhill for more information if any of the following is true: the life limiting criteria are more critical than those listed; longer operation is required; a larger make and break current is required; the operating environment includes elevated temperatures or reduced pressures. Contact Carry Rating: Switch will carry 6 amperes continuously with a maximum contact temperature rise of 20°C. Additional Characteristics Contact Type and Forces: Shorting or non‑ shorting wiping contacts with over 80 grams of contact force. Shaft Flat Orientation: Flat opposite contacting position of pole number one (see circuit diagrams). Terminals: Switches have the full circle of terminals, regardless of number of active position. Stop Strength: 7.5 pound‑inches minimum Rotational Torque: 8–24 ounce‑inches, depending on the number of poles. Operating Temperature Range (Standard Style): -40 °C to +85 °C Operating Temperature Range (MILDTL-3786): -65 °C to +85 °C RECOMMENDED PANEL CUTOUT Ø0.380 1/8"Shaft Ø0.254 Ø0.280 "E" Style POS.1 POS.1 0.208 PROCESS SEALED–Style T Switch can be mounted on PC board with other components and subjected to wave soldering and conventional board cleaning techniques. No secondary wiring or soldering is necessary. "K" Style POS.1 0.350 0.240 1/4" SHAFT: Style K Bushing is o-ring sealed; epoxy potting seals the terminals and the rear of the switch. Designed for PC assembly, this sealing technique can also be applied to solder lug terminal switches. A bushing to panel seal can also be added to the process sealed versions. Military qualified versions are available, see ordering information. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois .250 ±.015 .219 ±.004 .250 +.001 -.002 .340 ±.005 .250 ±.015 .375 ±.015 3/8-32 UNEF-2A THREAD 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Single Deck Rotary Switches SUGGESTED ADJUSTABLE STOP SUBSTITUTION GUIDE Adj. Stop Fixed Stop Style Style Equivalent 50D 50A 50C 50CD 50CP 50CDP 50M 50CD* 50MP 50CDP* 50P 50DP 50S 50D* 50SP 50DP* Fixed Stop Style Adj. Stop Style Equivalent 51A 51C 51CP 51M 51MP 51P 51S 51SP 51D 51CD 51CDP 51CD* 51CDP* 51DP 51D* 51DP* ADJUSTABLE STOPS: Style D Adjustable stops permit the user to set and reset the number of positions per poles. Shown in the diagram, a plastic washer can be removed to reveal slots at the base of the bushing. Stop blades can be inserted into the appropriate slots to limit switch rotation. Positions per pole configuration can thus be changed to meet the needs of the application. Dimensions are the same as the fixed stop version, when plastic washer is in place. Most desirable for prototype work. Readily available from local distributor. *Form fit and function equivalents, but not watertight sealed to the panel. Stop Blade Slots Plastic Washer Stop Blades ACCESSORY: Non-Turn Washers In Inches (and millimeters) SHAFT AND PANEL SEAL: Styles S and M Shaft and panel seal switches are watertight to the panel. They are not totally process sealed like the Style “T”. Panel is sealed by a gasket at the base of the bushing. Shaft is sealed by an O-ring inside the bushing. After mounting, seals do not alter switch dimensions. See Style “S” (standard switches) and Style “M” (military switches) in the Choices and Limitations chart. SEAL Form, fit and function equivalent to standard shaft switches. The dimensions shown have evolved as the most popular for this type of switch. See Style “B” in the Choices and Limitations chart. Previous users may have ordered these switches by a non-descriptive part number containing a “Y”. Contact Grayhill, if in doubt about a cross-reference. .125±.015 (3,18±0,38) .032±.005 (0,81±0,13) "A" .050±.005 (1,27±0,13) METRIC SHAFT AND BUSHING: Style E 9,53 ±0,38 6,0±0,08 "A" 3,15 ±0,12 7,0 ±0,51 6,35 ±0,38) 4,0 ±0,03 Metric standard dimensions for the shaft and bushing are shown in the drawing. Other dimensions approximately the same as shown in dimensional drawing. Contact Grayhill for exact dimensions. See Style “E” in the Choices and Limitations chart. .025 ± .001 (0,64 ± 0,03) 90° ± 1° .250 ± .003 (6,35 ± 0,08) .015 (0,38) RADIUS MAX. .125 ± .005 (3,16 ± 0,13) .060 ± .001 (1,52 ± 0,25) Part No. 50J1066 Cut round hole for the bushing and for the non-turn tab. Washer fits the double D bushing flats. Washer is sold only when accompanied by an order for a like number of switches. Washer is 302 stainless steel. Dimensions are in millimeters 11,13 ± 0,13 DIA. 0,64 ± 0,05 90° ± 1° 5,08 ± 0,05 CL 1,57 ± 0,08 .015 (0,38) RADIUS MAX. 2,36 ± 0,13 Part No. 71J1103 Designed to fit the double flatted bushing of the metric dimensioned bushing, this non-turn washer permits a round hole for the bushing and the tab while still preventing switch rotation. Washer is only sold when accompanied by a like number of switches. Washer is 302 stainless steel. M7 x 0,75 Part No. 50J5140-4 Designed to fit the single flatted bushing of the "K" style switches, this non-turn washer prevents switch rotation when using a full round hole in the panel. Washer is only sold when accompanied by a like number of switches. Washer is 302 stainless steel. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Rotary Switches SCREWDRIVER SLOTTED SHAFT: Style B .400 ± .005 DIA. (10,16 ± 0,13) Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Single Deck Rotary Switches CHOICES AND LIMITATIONS: Series 50 A = Standard, 1/8" Shaft B = Screwdriver Slot Shaft C = Military, Without Panel Seal D = Adjustable Stop (Adj. Stop) P = PC Mount Terminals S = Shaft/Panel Seal (S/P Seal) T = Process Sealed E = Metric, 4mm Shaft K = 1/4" Shaft M = Military Standard Style Style Choices1 Series Std., 1/8" Shaft 1/4" Shaft Metric, 4mm Shaft Terminals A AT B BS BST BT D S ST K KS KST KT KB KBS KBST KT BP BPT BSP BSPT DP P PT SP SPT KP KPT KSP KSPT KBP KBSP KBSPT KBT E ES EST ET EB EBS EBST EBT Solder Lug 50 EP EPT ESP ESPT EBP EBSP KBSPT EBT Angle of Throw Number of Poles Number of Positions Per Pole Shorting or Non-Shorting Contacts Rotary Switches 36° 1 2 02 thru 10 02 thru 05 N or S N or S 45° 1 2 02 thru 08 02 thru 04 N N 60° 1 2 02 thru 06 02 or 03 N N 90° 1 02 thru 04 2 02 N N 36° 1 2 02 thru 10 02 thru 05 N or S N or S 45° 1 2 02 thru 08 02 thru 04 N N 60° 1 2 02 thru 06 02 or 03 N N 90° 1 02 thru 04 2 02 N N PC Mount Military Style Style Choices Series Std., 1/8" Shaft 1/4" Shaft Metric, 4mm Shaft Terminals C CB CBT CD CT M MB MBT MT KM KMB KMBT KMT EM EMB EMBT EMT Solder Lug 50 CBP CBPT CDP CP CPT MBP MBPT MP MPT KMBP KMBPT KMP KMPT EMBP EMBPT EMP EMPT Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois Angle of Throw Number of Poles Number of Positions Per Pole Shorting or Non-Shorting Contacts 36° 1 2 02 thru 10 02 thru 05 N or S N or S 45° 1 2 02 thru 08 02 thru 04 N N 60° 1 2 02 thru 06 02 or 03 N N 90° 1 02 thru 04 2 02 N N 36° 1 2 02 thru 10 02 thru 05 N or S N or S 45° 1 2 02 thru 08 02 thru 04 N N 60° 1 2 02 thru 06 02 or 03 N N 90° 1 02 thru 04 2 02 N N PC Mount 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Single Deck Rotary Switches CHOICES AND LIMITATIONS: Series 51 A = Standard, 1/8" Shaft B = Screwdriver Slot Shaft C = Military, Without Panel Seal D = Adjustable Stop (Adj. Stop) P = PC Mount Terminals S = Shaft/Panel Seal (S/P Seal) T = Process Sealed E = Metric, 4mm Shaft K = 1/4" Shaft M = Military Standard Style Style Choices1 Series Std., 1/8" Shaft 1/4" Shaft Metric, 4mm Shaft1 Terminals A B S BS 51 AT BT ST BST A AT B BS BST BT D S ST P PT BP BPT SP SPT BSP BSPT SEE BELOW K KS KST KT E ES EST ET Solder Lug SEE BELOW PC Mount SEE BELOW KP KPT KSP KSPT EP EPT ESP ESPT PC Mount 22.5° 30° 22.5° 30° Number of Poles Number of Positions Per Pole Shorting or Non-Shorting Contacts 1 2 02 thru 16 02 thru 08 N or S N or S 1 2 3 4 02 thru 12 02 thru 06 02 thru 04 02 or 03 N or S N or S N or S N or S 1 2 02 thru 16 02 thru 08 N or S N or S 1 2 3 4 02 thru 12 02 thru 06 02 thru 04 02 or 03 N or S N or S N or S N or S Military Style Style Choices Series Std., 1/8" Shaft 1/4" Shaft Metric, 4mm Shaft Terminals 51 1 C CB CBT CD CT M MB MBT MT KM KMB KMBT KMT EM EMB EMBT EMT CBP CBPT CDP CP CPT MBP MBPT MP MPT KMBP KMBPT KMP KMPT EMBP EMBPT EMP EMPT Angle of Throw Solder Lug 30° PC Mount 30° Number of Poles Number of Positions Per Pole Shorting or Non-Shorting Contacts 1 2 3 4 02 thru 12 02 thru 06 02 thru 04 02 or 03 N or S N or S N or S N or S 1 2 3 4 02 thru 12 02 thru 06 02 thru 04 02 or 03 N or S N or S N or S N or S Contact Grayhill if 1/4" or metric shaft required with a 22.5° angle of throw. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Rotary Switches BP BPT BSP BSPT DP P PT SP SPT Solder Lug SEE BELOW Angle of Throw Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Single Deck Rotary Switches ADDITIONAL FEATURES Economy keylock switch, isolated position, spring return, and coded switches are available in similar series. See Keylock and Special Function Rotary Switch sections. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. ORDERING INFORMATION: Series 50 Series: Series 50 (36°, 45°, 60°, or 90°) Style*: Letters from Choices Chart Angle of Throw: 36, 45, 60, or 90 Stop Arrangement: Needed only with 1 pole switches with maximum positions. Leave blank for continuous rotation; add F for fixed stop. Type of Contacts: N = Non-shorting, S = Shorting Positions Per Pole: 02 as a minimum to the maximum allowable for the angle of throw and the number of poles per the Choices Chart. Use Letters AJ in this location if adjustable stop switch is ordered. Poles per Deck: See chart Number of Decks: 01 only 50AT36–01–1–10N–F * All rotary switches that are required to have military designated markings and testing adhering to MIL-3786 are to be ordered by specifying the military part number identified on the appropriate slash sheet. Rotary Switches ORDERING INFORMATION: Series 51 Series: Series 51 (30°; 22.5°) Style*: Letters from Choices Chart Angle of Throw: Use 22 (for 22.5°), 30 Stop Arrangement: Needed only with 1 pole switches with maximum positions. Leave blank for continuous rotation; add F for fixed stop. Type of Contacts: N = Non-shorting, S = Shorting Positions Per Pole: 02 as a minimum to the maximum allowable for the angle of throw and the number of poles per the Choices Chart. Use Letters AJ in this location if adjustable stop switch is ordered. Poles per Deck: See chart Number of Decks: 01 only 51SPT30–01–1–12S–F * All rotary switches that are required to have military designated markings and testing adhering to MIL-3786 are to be ordered by specifying the military part number identified on the appropriate slash sheet. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Mechanical Encoders Series 51 Binary or Binary Complement Code Features • PC Mount, 30° Angle of Throw • 2 to 12 Positions • .562" Diameter, 200 mA • Shaft and Panel Seal • Adjustable Stop Versions Dimensions in Inches (and millimeters) .250 – .015 (6,35 – 0,38) .537 + .020 .030 (13,64 + 0,51 0,76) .125 + .015 .020 (3,18 + 0,38 0,51) .375 – .015 (9,53 – 0,38) .125 – .002 (3,18 – 0,05) .203 – .003 (5,16 – 0,08) COMMON POLE 2 COMMON POLE 3 1/4-28 UNF-2A THREAD .562 + .025 .015 (14,27 + 0,64 0,38) pC TerMinAl DeTAil .125– .015 (3,18 – 0,38) COMMON POLE 1 .382 (9,70) TERMINAL CIRCLE OF CENTERS pC CoMMon DeTAil .020 – .003 (0,51 – 0,08) .125– .015 (3,18 – 0,38) .062 – .004 (1,57 – 0,10) .020 – .003 (0,51 – 0,08) .025 – .002 (0,64 – 0,05) See circuit diagrams for omitted terminals. All switches are provided with PC mount terminals. Grayhill part number and date code marked on label. Customer part number marked on request. CIRCUIT DIAGRAMS Switch is viewed from the shaft end and shown in switch position number 1, which is decimal number zero and BCD number zero. Indicates Terminal is present.   Indicates Terminal is omitted.   Note: Connections must be made on PC board to generate code output. Switch position numbers do not correspond to the decimal input or binary output. See Truth Tables. BCD BCD Complement TIED TOGETHER ON PC BOARD 1 OUTPUT 4 OUTPUT 3 4 2 C1 ROTATING CONTACTS TIED TOGETHER ON PC BOARD 5 1 TIED TOGETHER ON PC BOARD 6 C2 8 OUTPUT 11 C3 10 COMMON TIED TOGETHER ON PC BOARD ROTATING CONTACTS 3 2 C1 5 1 11 8 8 OUTPUT 7 2 OUTPUT 8 C3 10 TIED TOGETHER ON PC BOARD TIED TOGETHER ON PC BOARD 6 C2 9 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 4 12 7 12 1 OUTPUT 4 OUTPUT 2 OUTPUT 9 TIED TOGETHER ON PC BOARD COMMON 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Optical and Mechanical Encoders CL SHAFT FLAT 6 5 .250 + .020 .015 (6,35 + 0,51 0,38) .232 (5,89) COMMON CIRCLE OF CENTERS 8 7 105¡ .035 (0,89) REF. GRAYHILL .093 – .005 (2,36 – 0,13) Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Mechanical Encoders Truth tables Binary Code Decimal Binary Code Decimal Complement Dec. Switch 2nd Output Terminal No. Pos'n.* Pin** 1 2 4 8 Dec. Switch 2nd Output Terminal No. Pos'n.* Pin** 1 2 4 8 0 1 2 3 4 5 6 7 8 9 10 11 1 2 3 4 5 6 7 8 9 10 11 12 4-5 5-6 6-7 7-8 8-9 9-10 10-11 11-12 12-1 1-2 2-3 3-4 0 1 2 3 4 5 6 7 8 9 10 11 1 2 3 4 5 6 7 8 9 10 11 12 12-1 1-2 2-3 3-4 4-5 5-6 6-7 7-8 8-9 9-10 10-11 11-12 Options Adjustable Stops Set and reset stops to limit rotation. All dimensions are the same as for fixed stop switches. Switches are shipped with the stop blades located to limit rotation to 11 switch positions. For continuous rotation, remove both blades. For limited rotation, remove the 2nd (clockwise) blade and move it to the hole located between the positions shown in the Truth Tables. Removal of a plastic washer provides access to the blades and slots. Adjustable stop versions are available in unsealed styles only. Shaft and Panel Seal Switches are available in sealed or unsealed styles. For sealed style, the panel is sealed by an o-ring at the base of the bushing. The shaft is sealed by an o-ring inside of bushing. After the switch is mounted, seals do not alter the dimensions of the unsealed style. Indicates contact made to common * The switch position number is the terminal location opposite the shaft flat; it is not the same as the decimal number. ** To limit an adjustable stop switch to the decimal number shown, insert the second pin in the hole lying between the 2 switch positions indicated. Specifications Optical and Mechanical Encoders Electrical Rating Rated: To make and break 125 mA 30 Vdc resistive load for 25,000 cycles of operation. Cycle: (1 cycle = 360° rotation and return) Test conditions are standard atmospheric pressure, 25°C and 68% relative humidity. Contact Resistance: 20 milliohms initially, 300 milliohms maximum after life Insulation Resistance: 50,000 megohms initially, 10,000 megohms after life Voltage Breakdown: 500 Vac between mutually insulated parts Materials and Finishes Bases: Thermoset plastic Detent Rotor: Nylon Shaft, Stop Blades, Stop Arm, Thrust Washer And Retaining Ring: Stainless steel Detent Balls: Steel, nickel-plated Bushing: Zinc, Tin-zinc-plated Detent Spring: Stainless steel Common Terminals and Rings: Brass, gold plate .00003" minimum over silver plate .0003" minimum Terminals: Brass with silver contact surface, gold-plated .00003" Rotor Contact: Berillium copper with silver contact surface Shaft And Panel Seal: Silicone rubber Mounting Hardware: One mounting nut, .089" thick by .375" across flats, and one internal tooth lockwasher are supplied with the switch. Additional Characteristics Contact Type: Wiping contacts Shaft Flat Orientation: Switch position is defined as that position that is opposite the shaft flat.The location of the contacts in relation to the shaft flat is shown on the circuit diagram. Terminals: Only the active position terminals, as shown in the circuit diagram are supplied with the switch. All common terminals are supplied. Stop Strength: 7.5 in-lbs minimum Rotational Torque: 8 to16 in-oz Bushing Mounting: Required for these switches Maximum Mounting Torque: 15 in-lbs. Ordering Information Type Of Maximum No. Switch Of Positions Unsealed BCD Output Sealed BCD Complement Unsealed Sealed Fixed Stop 7 8 9 10 11 12 513360-7 513360-8 513360-9 513360-10 513360-11 513360-12-F 513374-7 513374-8 513374-9 513374-10 513374-11 513374-12-F 513361-7 513361-8 513361-9 513361-10 513361-11 513361-12-F 513375-7 513375-8 513375-9 513375-10 513375-11 513375-12-F Continuous Rotation 12 513360-12-C 513374-12-C 513361-12-C 513375-12-C Adjustable Stop 12 513385 ——— 513384 ——— The -C suffix indicates continuous rotation. The -F suffix indicates a fixed stop between positions 1 and 12. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Adjustable Stop Rotary Switches Features • Quick Route to Rotary Switches • For Prototypes and Small Production Runs Series 50/51 Series 42/44 Series 56 Series 71 BEST AVAILABILITY The Problem Procurement lead time on rotary switches for prototypes and small production runs can be long. This is often a source of headache for design engineers and production control managers. Grayhill makes more than 300,000 combinations of rotary switch styles; number of decks, poles per deck, positions per pole, military qualified or commercial grade, etc. This wide variety makes it impractical for either distributors or manufacturers to stock completed switches. Consequently, even small quantities must be built to order. The Solution Grayhill Electronic Distributors can supply a wide variety of rotary switches with Adjustable Stops. This feature gives you a switch immediately with exactly the electrical properties you need. These Adjustable Stop switches have the basic mechanical characteristics of their fixed stop counterparts. To get the right number of positions per pole for your application, simply adjust the stop washers or stop pins. By stocking a few switches, the Distributor provides over 100,000 possible combinations of switches. This includes the popular styles, sizes, angles of throw, number of decks, poles per deck, positions per pole, and types of contacts. Availability of these switches through Distributors speeds prototype development time. There is no time lag in waiting for factory made samples. The Substitution Writing an equivalent part number is easy. To obtain an adjustable-stop equivalent to a fixedstop rotary switch you must substitute style letters and possibly series number. Then replace the positions-per-pole number in the fixed-stop number with the letters AJ. See the examples for the scheme. series, style and angle of throw as well as the adjustable stop rotary switch series, style and angle of throw. Then the letters AJ in the positions-per-pole location, gives you the part number of the equivalent. Suppliers Distributors can supply 1 and 2-deck adjustablestop switches from stock (one or two poles per deck). They can also quickly secure other variations from factory stock. Reduce prototype development time. Use Grayhill Adjustable Stop Rotary Switches for all of your prototype requirements. These electronic distributors also maintain a representative stock of Grayhill products. Local availability can often “save the day”, and simplify your paperwork. When adjustable equivalents apply, the rotary switch pages will indicate the substitutions. A chart will show the fixed stop rotary switch Fixed Stop Rotary Switch Adjustable Stop Equivalent Series Style Angle of Throw No. of Decks Poles/Deck Positions/Pole Type of Contacts N = Non-Shorting S = Shorting 42A36-01-1-07N www.grayhill.com Series Style Angle of Throw No. of Decks Poles/Deck Positions/Pole Type of Contacts N = Non-Shorting S = Shorting 42D36-01-1-AJN Bulletin 1221 Rev 04/14 Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Special Function Rotary Switches SERIES 09, 42, 44, 50, 51 Isolated Position FEATURES • Protected Switch Positions For Safety, Calibration, or Stand-by • Choice of Push- or Pull-To-Turn • 1/2" Diameter, 200 mA and 1" Diameter, 1 Amp Switch • 10,000 Cycles of Operation DESCRIPTION An isolated position is one which cannot be reached by the normal rotation. An additional action is required by the operator. It could be either Push-To-Turn, or Pull-To-Turn. After the switch is rotated to the isolated position, releasing the shaft locks the switch in that position. Push or pull again to rotate the switch again. Use isolated positions to protect a switch position from indiscriminate rotation. Such safety positions might include “calibrate”, “off” and/or “stand-by”. DIMENSIONS Series 09 Series 42 & 44 Series 50 & 51 DIM. A + .046 (1,17) –.020 (0,51) DIM. A .062 (1,57) Rotary Switches DIM. A DIM. A + .046 –.020 (+ 0,05 –0,51) SOLDER LUGS PC TERMINALS Dimension A 1 Deck 2 Decks 3 Decks 4 Decks 1.228 1.496 1.764 2.032 (31,19) (38,0) (44,81) (51,61) Dimension A Dimension A Solder Lug PC Style .893 ± .025 (22,68 ± 0,64) .897 ± .025 (22,78 ± 0,64) 1 Deck 2 Decks 3 Decks 4 Decks 1.371 1.717 2.063 2.409 (34,82) (43,61) (52,40) (61,19) Grayhill part number and date code marked on label. Customer number marked on request. EXTERNAL DIFFERENCES SPECIFICATIONS The isolated position mechanism increases the depth of the Series 50 and 51 by 0.217" (5,51 mm). All other dimensions remain unchanged. In Series 9, 42 and 44, it has the appearance of an additional deck section without terminals, located directly behind the detent system. Electrical Ratings Materials and Finishes The switching elements, and therefore ratings, are the same in an isolated position switch as in a conventional rotary switch. Mechanical life is also the same. Materials and finishes for the isolation mechanism are listed here. Series 50 and 51 Housing: Zinc casting, tin/zinc-plated Shaft: 303 stainless steel Stop Pin and Stop Post: 303 stainless steel Spring: Tinned music wire Series 09 Housing: Phenolic for style A; Diallyl, for M Shaft: 303 stainless steel, electro-polished Stop Pin and Stop Post: 303 stainless steel Spring: Tinned music wire Series 42 and 44 Housing: Diallyl per MIL-M-14 Shaft: 303 stainless steel Lock Plate: 302 stainless steel Lock Arm: 316 stainless steel Lock Post: Brass, tin/zinc-plated Compression Spring: Tinned music wire Additional Characteristics Shaft Movement or Vertical Travel: Series 09 .062 ± .020 (1,57 ± 0,51) Series 42 & 44 .070 ± .020 (1,78 ± 0,51) Series 50 & 51 .080 ± .020 (2,03 ± 0,51) Push or Pull Force Required: Series 09 1.75 ± .5 lbs Series 42 & 44 2 ± .5 lbs Series 50 & 51 2 ± .5 lbs Stops: Single pole per deck switches with the maximum number of positions are supplied with stops only on request: 12 positions in 30° throw, 10 in 36°, and 8 in 45°. Stop Strength: Approximately 7.5 pound-inches for the isolated position stop. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Special Function Rotary Switches CHOICES AND LIMITATIONS Standard Style Military Style** Style Description Angle Of Throw 09A 09M Solder Lug 42A 42S — — 42M — 42H 42HS Solder Lug Sealed 125° Temperature Rating 125° Temp Rating, Sealed Poles Per Deck Positions Per Pole 01 to 04 01 to 04 01 to 04 01 to 04 01 to 04 01 to 03 1 2 3 4 5 6 02 to 12 02 to 06 02 to 04 02 or 03 02 02 N or S N or S N or S N or S N or S N or S 01 to 04 01 to 04 1 2 02 to 10 02 to 05 N or S N or S 01 to 04 01 to 04 01 to 04 01 to 04 01 to 04 01 to 04 1 2 3 4 5 6 02 to 12 02 to 06 02 to 04 02 or 03 02 02 N or S N or S N or S N or S N or S N or S 45° 01 to 04 01 to 03 01 or 02 01 or 02 1 2 3 4 02 to 08 02 to 04 02 02 N or S N or S N or S N 36° 01 1 2 02 to 10 02 to 05 N or S N or S 30° 01 1 2 3 4 02 to 12 02 to 06 02 or 03 02 or 03 N or S N or S N or S N or S 30° 36° 30° 44A 44S — — 44M — 44H 44HS Solder Lug Sealed 125° Temperature Rating 125° Temp Rating, Sealed ----- 50C 50CP 50M* 50MP* Solder Lug PC Mount Solder Lug, Sealed Sealed, PC ----- 51C 51CP 51M* 51MP* Solder Lug PC Mount Solder Lug, Sealed PC Mount, Sealed Shorting Or Non-Shorting *(Pull-to-Turn only) **For specifics on military qualified products, see Standard Switch Pages. CONVENTIONAL NUMBERS Start by creating a conventional switch number in the manner which follows: Series & Style Angle of Throw Number of Decks 09A30-01-1-12N Type of Contacts Shorting = S Non-Shorting = N Positions Per Pole Poles Per Deck Note: No stop arrangement suffix is needed. See Describing Stops. DESCRIBING POSITIONS The Grayhill system for isolating positions lets you choose the positions to be isolated. Grayhill inserts isolation posts next to the positions to be isolated. Consider a continuous rotation switch of the Series 09A with a 30° angle of throw. The terminals are listed here from 1 through 12 with a space between each to indicate where isolation posts might be inserted. 12 1 2 3 4 5 6 7 8 9 10 11 12 Let's isolate position 1 and position 2 from all other positions and from each other. We indicate isolation posts as shown here: 12P1P2P3 4 5 6 7 8 9 10 11 12 To isolate just position 1, describe like this: 12P1P2 3 4 5 6 7 8 9 10 11 12 To isolate positions 1 and 2 from all other positions, but not from each other, do this: 12P1 2P3 4 5 6 7 8 9 10 11 12 ORDERING INFORMATION Indicate this as a SPECIAL switch to ensure that no error is made when the order is entered. Sample part number: SPECIAL 09A30-04-1-12N PULL 12P1P2P3 4 5 6 7 8 9 10 11 12 DESCRIBING STOPS When a 1-pole switch has less than the maximum number of positions, consider also the stop system. Following is the arrangement for a 6 position switch with the position 1 isolated. STOP 1P2 3 4 5 6 STOP The word “STOP” indicates the conventional switch stops, which limit rotation to positions 1 through 6. To isolate position 1 we insert only one isolation post–between terminals 1 and 2. The stop system already prevents rotation beyond terminal 1. In multi-pole switches, the stop system and isolation system described for the first pole, automatically affects the other poles. In the example above, isolating position #1 on the first pole isolates the first position (terminal #7) of the second pole. See Standard Switch Pages for a 2 pole circuit diagram for a 30° throw switch. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois This sample part number orders a Series 9 standard style, four deck, one pole per deck, twelve positions per pole rotary switch with nonshorting contacts and isolation posts between positions 12 and 1, between 1 and 2, and between 2 and 3. This lengthy order number is required to prevent any possible confusion in ordering the switch. When we receive your order, we will assign a special “short form” part number to facilitate future identification of this special switch. This number is sequentially assigned as the need arises, and is non-descriptive. A typical “short form” special part number might be 09YY12345. Contact Grayhill for price. Not available through Distributors. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Rotary Switches No. Of Decks Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Special Function Rotary Switches SERIES 08,09,42,44,50 Spring Return FEATURES • Hold-To-Test, Hold-To-Calibrate, And Other Momentary Applications • Choice of Configurations, Ratings, Styles and Circuitry • 10,000 Cycles of Operation DESCRIPTION A spring return rotary switch has 1 or more momentary positions. Maintaining contact at momentary positions requires rotational force. Releasing the force allows the mechanism to return the contact to a normal, or detent, position. DIMENSIONS Series 08 & 09 Series 50 Equivalent to Series 50 Standard Switches .500 ± .015 (12,7 ± 0,38) DIA. DIM. A + .046 (1,17) –.020 (0,51) DIM. B REF. STUD PROJECTION .320 ± .015 (8,13 ± 0,38) CIRCLE OF CENTERS COMMON No. of Decks .960 1.228 1.496 1.764 2.032 2.550 (24,38) (31,19) (38,0) (44,81) (51,61) (64,77) Dim B .062 .062 .062 .062 .062 .312 Series 42 & 44 DIM. A + .046 (1,17) –.020 (0,51) (1,57) (1,57) (1,57) (1,57) (1,57) (7,92) No. of Decks 1 2 3 For all other dimensions and specifications, see Standard Switch pages. Dim. A 1.025 (26,04) 1.371 (34,82) 1.717 (43,61) For all other dimensions and specifications, see Standard Switch pages. CONFIGURATIONS SELECTING A SWITCH OPTIONS This configuration indicates a counterclockwise force is required to hold the switch at position #1. “M” indicates a momentary position counterclockwise of “D” and "D", detented ones. Positions 1 2 3 M D D Releasing this force breaks contact with position #1 and returns the switch to #2. Normal rotary switch detent action occurs when the switch is rotated between position #2 and #3. 1. Select a Configuration: The total number of positions always includes the 2 basic positions. A (4) position switch of DDDDM configuration would have 3 detent positions counterclockwise of the momentary position. Watertight panel seal; Multi-pole switches that exceed the limits noted in the Selector Chart; Series 50 MD or DM configurations in Military styles; Series 08, 09, & 44 in MMMDM MM, and in MMDD MM, and in MMMMMD. Not available through Distributors All of the configurations (except MDM) list a basic 2 position arrangement which is shown in italics. Example: MDDDDD or DDDDDM. Several positions can be added during the switch construction at the factory; but, any configuration must always contain the 2 basic positions. 2. Select Series, Angle of Throw, and Style: See the Choices Chart. The basic switch description, series, and throw are as follows: 1 /2", 1/4 Amp, multi-deck 08 = 36° 09 = 30° 1", 1 Amp, multi-deck 42 = 36° 44 = 30° 1 /2", 200 mA, single deck 50 = 36° Electrical ratings are the same as those of the conventional switches with the exception of life. Life is limited to 10,000 cycles of operation (25,000 cycles for Series 50) due to the spring arrangement. Dimensions are the same as for conventional types except for the shaft flat orientation of the 3, 4, 5, and 6 pole, Series 09 and 44 in the DDDDDM configuration (see chart). 3. Select Poles & Positions Per Pole: If you do not find the poles and positions per pole you need in one series, try another or contact the factory. If the behind panel length is a problem, select a multi-pole type instead of a single deck. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois ORDERING INFORMATION Create the part number using this example. Stem number from chart (4 or 5 digits) Number of Decks Number of Poles/Deck 093103-2-045 Type of Contacts: S=Shorting N=Non-Shorting Number of Positions/Pole Exception: Numbers beginning with 5 are already complete part numbers. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Rotary Switches 1 2 3 4 5 6 Dim A For all other dimensions and specifications, see Standard Switch pages. 36° ± 3° Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Special Function Rotary Switches CHOICES AND LIMITATIONS Configuration Conventional Switch 08A36 Description Of Style Standard Spring Return Stem Number (See Ordering Info.) 08317 Poles Per Deck Positions Per Pole & Contact Type Location Of Unique Position, Detent or Momentary Term. Opp. Flat** 1 to 6 1 to 3 1 2 02 to 05 (N or S) 02 to 05 (N or S) M5 M 5, 10 5 5 1 to 6 1 to 3 1 or 2 1 1 1 2 3 4 5 or 6 02 to 06 (N or S) 02 to 06 (N or S) 02 to 04 (N or S) 02 or 03 (N or S) 02 (N or S) M6 M 6, 12 M 4, 8, 12 M 3, 6, 9, 12 M 2, 4, 6, 8, 10, 12 6 6 4 3 2 09A30 Standard 09310 42A36 Standard 42349 1 to 3 1 1 2 02 to 05 (N or S) 02 to 05 (N or S) M5 M 5, 10 5 5 42M36 Military 42352 1 to 3 1 1 2 02 to 05 (N or S) 02 to 05 (N or S) M5 M 5, 10 5 5 44A30 Standard 44346 1 to 3 1 1 2 02 to 06 (N or S) 02 to 06 (N or S) M6 M 6, 12 6 6 44M30 Military 44350 1 to 3 1 1 2 02 to 06 (N or S) 02 to 06 (N or S) M6 M 6, 12 6 6 08A36 Standard 08319 1 to 6 1 to 3 1 2 02 to 05 (N or S) 02 to 05 (N or S) M1 M 1, 6 1 1 1 2 3 4 5 or 6 02 to 06 (N or S) 02 to 06 (N or S) 02 to 04 (N or S) 02 or 03 (N or S 02 (N or S) M1 M 1, 7 M 1, 5, 9 M 1, 4, 7, 10 M 1, 3, 5, 7, 9, 11 1 1 1 1 1 DDDDDM 09A30 Standard 09312 1 to 6 1 to 3 1 or 2 1 1 09M30 Military 09356 1 to 3 1 1 1 2 3 02 to 06 (N or S) 02 to 06 (N or S) 02 to 04 (N or S) M1 M 1, 7 M 1, 5, 9 1 1 1 42A36 Standard 42350 1 to 3 1 1 2 02 to 05 (N or S) 02 to 05 (N or S) M1 M 1, 6 1 1 42M36 Military 42353 1 to 3 1 1 2 02 to 05 (N or S) 02 to 05 (N or S) M1 M 1, 6 1 1 44A30 Standard 44312 1 to 3 1 1 2 02 to 06 (N or S) 02 to 06 (N or S) M1 M 1, 7 1 1 44M30 Military 44351 1 to 3 1 1 2 02 to 06 (N or S) 02 to 06 (N or S) M1 M 1, 7 1 1 50A36 Std., Solder Lug 503265-1-03N* 1 1 03N D2 2 50P36 Std., PC Mount 503267-1-03N* 1 1 03N D2 2 8A36 Standard 08316 1 to 6 1 to 3 1 2 03 (N or S) 03 (N or S) D2 D 2, 7 2 2 9A30 Standard 09311 1 to 6 1 to 3 1 or 2 1 1 2 3 4 03 (N or S) 03 (N or S) 03 (N or S) 03 (N or S) D2 D 2, 8 D 2, 6, 10 D 2, 5, 8, 11 2 2 2 2 42A36 Standard 42348 1 to 3 1 1 2 03 (N or S) 03 (N or S) D2 D 2, 7 2 2 42M36 Military 42351 1 to 3 1 1 2 03 (N or S) 03 (N or S) D2 D 2, 7 2 2 44A30 Standard 44345 1 to 3 1 1 2 03 (N or S) 03 (N or S) D2 D 2, 8 2 2 44M30 Military 44349 1 to 3 1 1 2 03 (N or S) 03 (N or S) D2 D 2, 8 2 2 MDDDDD Rotary Switches MDM No. Of Decks *This is a complete (not stem) part number. **Terminal opposite shaft flat when switch is in its unique (detent or momentary) position. Available from your local Grayhill Distributor Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Rotary Switch Engineering Information Catalog Ratings Are catalog ratings misleading? In most cases, yes. Load and life ratings shown in most catalogs are usually invalid for most applications. This results from the complex interplay of such factors as environment, duty cycle, life limiting or failure criteria, actual load, etc. Circuit designers should be aware of these factors, and the effect they have on the useful life of the switch in their applications. The problem of switch rating arises from the wide variety of requirements placed on the switch. This includes various applications, and the sensitivity of the switch to a change in requirements. If we attempted to establish life ratings for all possible applications, we would have an almost infinite variety of ratings. To simplify the problem, switch manufacturers, switch users, and the military, have established certain references for ratings. These include loads, life requirements, environments, duty cycles, and failure criteria. These references are arbitrarily established. But, they allow you to compare different switch designs. They do not, however, match the actual requirements for most applications. The curves shown here are an example of some of the life load curves. These curves are life load characteristics of the Grayhill 42M and 44M switches. Note that the curves consider only two voltage sources and two types of loads. These voltages and loads are, however, considered as standards for testing procedures by the industry. Curve data is based on tests conducted at sea level, 25°C and 68% relative humidity. Cycle = 360° rotation and return. Cycling rate is 10 cycles per minute. Switch rating is for non-shorting contacts. CURRENT (AMPS) 7 6 5 VOLTAGE 115 VAC RESISTIVE 4 3 2 1 0 0 10 25 50 CYCLES x 1,000 CURRENT (AMPS) 1.7 1.5 VOLTAGE 30 VDC RESISTIVE 1.2 1.0 .75 INDUCTIVE (2.8 HENRIES) .50 .20 0 0 10 25 50 CYCLES x 1,000 www.grayhill.com These curves allow you to predict the expected life of the switch once you know the voltage, current and type of load. Also note that each cycle is approximately a 360° rotation and a return. For a ten position switch this would be a rotation from position 1 to position 10 and back to 1. This cycle runs approximately ten times a minute. Thus testing causes more electrical and mechanical wear than what the switch incurs in actual use. Summary The life and load ratings in this and other catalogs are probably not totally valid for your application. The bright side of the picture is that in most applications the switch will perform better than its ratings. This is because the standard industry test conditions are more stringent than those found in most applications. This difference can be very dramatic. For example, Grayhill’s 42A and 44A Series Rotary Switches, are rated at 1 ampere (115 Vac resistive). However, they will operate at 5 amperes in many applications. To see how some major factors influence switch performance, read on. USEFUL LIFE CRITERIA The “useful” life of a switch in your application depends on what you demand of it. This includes parameters such as contact resistance, insulation resistance, torque, detent feel, dielectric strength, and many other factors. For example, a contact resistance of 50 milliohms may be totally unusable in certain applications such as a range switch in a micro-ohm meter. In other applications a contact resistance of 5 ohms may be perfectly satisfactory. In establishing “useful” life for a switch in your application, you must first determine “failure criteria,” or “end of life” parameters. At what level of contact resistance, dielectric strength, etc., is the switch no longer acceptable for your application? Most switches are acceptable on all parameters when new. There is a gradual deterioration in performance with life. The rate of deterioration varies greatly with basic switch design. Often, circuit designers select a switch on the basis of its performance when new. This is a mistake. The performance of the switch after several years of equipment use is more significant. To estimate this, first determine the life limiting or failure criteria for your application. In most uses, important life-limiting (failure) criteria include the following parameters: Contact Resistance Insulation Resistance Dielectric Strength Actuating Force Contact Resistance This is the resistance of a pair of closed contacts. This resistance effectively appears in series with the load. Typical values are in the range of a few milliohms for new switches. These values usually increase during life. The rate of increase is greatly affected by the voltage, current, power factor, frequency, and environment of the load being switched. Typical industry standard “end of life” criteria for this parameter are: MIL-DTL-3786: MIL-S-6807: MIL-S-8805: MIL-S-83504: 20 milliohms (Rotary Switches) 20 milliohms (Snap Pushbuttons) 40 milliohms (Pushbuttons) 100 milliohms (DIP Switches) Contact resistance can be measured by a number of different methods. All of them are valid depending upon the switch application and the circuit. Grayhill uses the method in applicable military specifications. This method specifies an open circuit test voltage and a test current. The voltage drop across the closed contacts is measured. The contact resistance is determined by Ohm’s Law from the test current and the measure voltage drop. MIL-DTL-3786, MIL-S-6807 and MIL-S-8805 require a maximum open circuit test voltage of 2 Vdc; they require a test current of 100 milliamperes. MIL-S-83504 requires a maximum test voltage of 50 millivolts and a test current of 10 milliamperes. When a switch is rated to make and break 5 or more amperes, there is a difference. Contact resistance is determined by measuring the voltage drop while the switch is carrying the maximum rated current. The voltage drop that occurs across the contacts determines, in part, the contact temperature. If the temperature rise of the contacts is sufficient, it affects contact material. A chemical reaction will take place that can cause an insulating film to appear on the contacts. This film is present between the contacts during the next switching operation. This film formation can cause failure due to increasing contact resistance. For switching of very low voltages and currents, this resistance may be the failure criteria. Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Insulation Resistance This is the resistance between two normally insulated metal parts, such as a pair of terminals. It is measured at a specific high DC potential, usually 100 Vdc or 500 Vdc. Typical values for new switches are in the range of thousands of megohms. These values usually decrease during switch life. This is a result of build-up of surface contaminants. Typical industry standard “end of life” criteria for the parameter are: MIL-DTL-3786: MIL-S-6807: MIL-S-8805: MIL-S-83504: 1000 megohms (for plastic insulation) Not specified 2000 megohms 1000 megohms Another special test condition is commonly specified. It measures insulation resistance for switches in a high humidity atmosphere (90%-98% R.H.). In this condition, condensation of moisture commonly occurs on the surface of the insulating material. Some types of insulation will absorb varying amounts of moisture. This will normally lower the insulation resistance. Typical industry values for this condition are: MIL-DTL-3786: MIL-S-6807: MIL-S-8805: MIL-S-83504: 10 megohms (for plastic insulation) 3 megohms after drying 10 megohms (for plastic material) 10 megohms Dielectric Strength This is the ability of the insulation to withstand high voltage without breaking down. Typical values for new switches in this test are in excess of 1500 Vac RMS. During switch life, contaminants and wear products deposit on the surface of the insulation. This tends to reduce the dielectric withstanding voltage. In testing for this condition, a voltage considerably above rated voltage is applied. Then, the leakage current is measured at the end of life. Typical industry standard test voltages and maximum allowable leakage currents are as follows: MIL-DTL-3786: 1000 Vac and 1 mA maximum leakage MIL-S-6807: 600 Vac RMS after life 10 microamperes maximum leakage MIL-S-8805: 1000 or 1000 plus twice working voltage (AC) RMS and 1mA maximum leakage MIL-S-83504: 500 Vac and 1 mA maximum leakage UL Standard: 900 Vac without breakdown (UL Standard (dependent on test) Voltage breakdown is another method for www.grayhill.com describing the ability of the insulating material to withstand a high voltage. Voltage breakdown describes the point at which an arc is struck and maintained across the insulating surface with the voltage applied between the conducting members. ADDITIONAL LIFE FACTORS Effect of Loads On any switch, an arc is drawn while breaking a circuit. This causes electrical erosion of the contacts. This erosion normally increases contact resistance and generates wear products. These wear products contaminate insulating surfaces. This reduces dielectric strength and insulation resistance. The amount of this erosion is a function of current, voltage, power factor, frequency and speed of operation. The higher the current is, the hotter the arc and the greater the erosion. The higher the voltage is, the longer the arc duration and the greater the erosion. Inductance acts as an energy storage device. This returns its energy to the circuit when the circuit is broken. The amount of erosion in an inductive circuit is proportionate to the amount of inductance. Industry standard test inductance as described in MIL-I-81023 is 140 millihenries. Other test loads include 250 millihenries and 2.8 henries. Effect of Ambient Temperature Temperature extremes may affect switch performance and life. Very high temperatures may reduce the viscosity of lubricants. This allows them to flow out of bearing areas. This can hasten mechanical wear of shafts, detents, plungers, and cause early mechanical failure. Contact lubricants are sometimes used. Too little lubrication can result in a high rate of mechanical wear. Too much lubrication flowing from other bearing areas can adversely affect dielectric strength and insulation resistance. Through careful design and selection of lubricants most manufacturers attempt to minimize these affects. Nevertheless, continual operation in high ambient temperatures will shorten the life of a switch regardless of design. Extremely low ambient temperatures may also create problems. Low temperatures may cause an increase in the viscosity of the contact lubricant. Higher viscosity can delay or prevent the closing of contacts, causing high operating contact resistance. Under certain atmospheric conditions, ice may form on the contact surfaces. This also causes high and erratic contact resistance. Frequency can also affect erosion. The arcing ends when the voltage passes through zero. To a certain extent, the following is true. The higher the frequency, the sooner arcing ends, the lower the erosion. Neither of these conditions may materially reduce the life of the switch. However, it may cause unsatisfactory operation. If the voltage of the circuit is high enough, it can break down the insulating layer. Some current will flow through the high resistance contacts. A local heating action is created, which tends to correct the condition in a short period of time. The speed of operation affects the duration of the arc. Fast operation can extinguish the arc sooner. This reduces the erosion, unless the air within the switch is completely ionized. Switches with high contact pressures may minimize the low ambient temperature effect. This is particularly true if the application calls for switching signal level voltages and currents. Actuating Force Effects of Altitude Rotational torque is the actuating force required to turn a rotary switch through the various positions. The actual torque or force required depends on the design of the switch. It varies widely from one design to another. See appropriate MIL Specs or manufacturers literature for typical industry values for specific designs. When torque or force values are specified, it is customary to give a minimum and maximum value. During life, two offsetting factors may occur to change the initial value. Relaxation of spring members will tend to lower torque or force values. Wear or “galling” of mating surfaces, however, may tend to increase these values. Typical end of life specifications may require the switch to fall within the original range. Or, they may specify a maximum percentage change from original value. For example, “the rotational torque shall not change more than 50% from its initial value. In high altitudes, barometric pressure is lower. Low pressure reduces the dielectric strength of the air. The arc strikes at a lower voltage and remains longer. This increases contact erosion. Switches for use in high altitudes will therefore require derating in terms of loads and/or life. Effects of Duty Cycle Mechanical life testers cause accelerated life testing. Testers operate switches at a rate of approximately 10 cycles per minute. This rate is greatly in excess of normal manual operation in equipment. It constitutes a severe test of the switch. Lubricants do not have an opportunity to redistribute themselves over the bearing surfaces at this duty cycle. The contact heating caused by arcing does not have a chance to dissipate. Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Thus, the switch runs “hot”, increased mechanical wear and contact erosion result. Your application probably requires manual operation of the switch with an attendant low duty cycle. If so, you can usually expect much longer switch life than is shown by the accelerated life laboratory life tests. Conclusion Remember, load and life ratings are based on manufacturers’ selected references. They include accelerated life tests and an arbitrary set of application parameters and failure criteria. These parameters and criteria may not always fit your application. Then how do you know if a switch will give reliable performance in your application? How do you know if it will last the life of your equipment? Ask the switch manufacturer. Grayhill, and most other reputable manufacturers have compiled vast quantities of test data. We are in a position to give a good estimate of a switch’s performance in many nonstandard applications. You should provide the following data: Expected Life: Load: Operation: Application: Environment: Failure Criteria: in number of cycles voltage, current, power factor, and frequency manual or mechanical, duty cycle type of equipment altitude, ambient temperature range relative humidity, corrosive atmosphere, shock, vibration, etc. end of life contact resistance, dielectric strength, insulation resistance, etc. With this information, we can usually estimate if a given switch is suitable for your application. www.grayhill.com Soldering What causes failure in a new switch after it has been installed? The principle failure is high contact resistance caused by solder flux on the contact surfaces. To avoid this, be sure to follow good soldering practices. Use the proper solder with the proper flux core, maintain the proper soldering temperature, use the proper soldering iron tip for the work, and never use liquid flux when soldering a switch. initially and 10.0 ohm maximum dc resistance following environmental and mechanical tests. Many equipment manufacturers feel they are satisfying their needs with a measurement of .025 to 10 ohms for the expected life of the switch. Under most circumstances, standard non-sealed switches pass the larger value easily. The lower value (.025 ohms) requires special attention and parts for compliance over the life of the switch. Do not use solvent baths or washes with any unsealed electromechanical parts. Switches, unless they have been especially protected suffer badly. Solvents readily dissolve fluxes and carry them into the contact area of switches. A thin, hard flux coats the contact surface after the solvent evaporates. Additionally, solvents may dissolve and wash away lubricants in switches. Lubricant loss may prevent proper mechanical action. Switch Selection Exercise similar precautions when you mount a switch to a printed circuit board. Maintain proper solder temperatures and follow proper cleaning techniques. Avoid subjecting these switches to lengthy solder baths. The excessive heat can deform the plastics. RFI/EMI Shielding Some applications require shielding against Radio Frequency Interference and/or Electro-Magnetic Interference. Experts feel that the most effective way to achieve shielding is to provide a conductive bridge across the component mounting hole. They also generally agree that there is no good method for testing shielding. So, the equipment manufacturers themselves must identify and solve specific problems. Component manufacturers can generally assist in the solution of shielding problems. RFI/EMI testing is incorporated into MILDTL-3786 for rotary switches. Requirements are 1.0 ohm maximum dc resistance between the mounting bushing and operating shaft Whenever possible, use standard switches and contact configurations. Standards provide the greatest economy and the best delivery. When you need a deviation, it pays to consult with your suppliers as soon as possible. At the early stages of the design, there are many low cost options for achieving the results. At the late stages of design, some of the options may no longer be open. For example, size may be restricted. This might result in a more costly redesign. Typical standard rotary options are as follows: coded contacts, homing rotor effect, progressively shorting contacts, PC mountable terminals, rotary switch spring return positions, and push-to-turn or pull-to-turn mechanisms. Limited panel space may be solved by a concentric shaft rotary switch. It is two rotary switches, located one behind the other. There are other concentric shaft possibilities. A rotary switch can be combined with another component. These include a potentiometer, a pushbutton switch, and a mechanical element. The most cost effective design may be one of these concentric options. But, selection must be made at the outset of equipment design. Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. 1. SELECT A FACTOR FACTOR: Current Life Rating All switches are rated to make and break at least 100 milliamperes for 10,000 cycles of operation. Rating becomes a matter of interpretation. Carefully review the Engineering Information on the previous pages. Ratings which assure a different life are possible; contact Grayhill. 25,000 Cycles At Load (Amps) 10,000 Cycles At Load (Amps)   6,000 Cycles At Load (Amps, UL) 19 24 — — 15 1 — — Single Deck Switch Series Multi-Deck Switch Series 50/51 56 75 77 5000 08/09 42/44 43/54 53,57,59 71 .050 .200 — — .200 — — .100 — .050 — — 1 — — .250 .500 — 1,3,5* 1,3,5* — 1,3,5* 1,3,5* — — .250 .150, .250* — — — * Varies with angle of throw and style. FACTOR: Size Maximum Dimension In Inches (& Millimeters) 19 24 Single Deck Switch Series 50 51 56 75 77 5000 08 09 Multi-Deck Switch Series 42 44 53 57 59 71 Diameter, Behind Panel 2.280 1.015 .500 .561 .500 .298 1.015 .687 .750 1.015 1.170 1.350 1.190 1.190 .750 Length Behind Panel, 1 Deck .950 .580 .698 .698 .355 .500 .470 .960 .960 1.025 1.025 .916 .916 .916 .760 Behind Panel, Add'l Deck — — — — — — — — .268 .268 .346 .346 .329 .326 .326 .218 Diameter, Behind Panel (57,9) (25,8) (12,7) (14,2) (12,7) (7,6) Length Behind Panel, 1 Deck (24,1) (14,7) (17,7) (17,7) (9,0) (12,7) Behind Panel, Add'l Deck — — — — — — FACTOR: Circuitry Max. Positions 1 Deck (1Pole)* () (25,8) (17,4) (19,0) (25,8) (29,7) (34,3) (30,2) (30,2) (19,0) () (11,9) (24,4) (24,4) (26,0) (26,0) (23,3) (23,3) (23,3) (19,3) — — (6,8) (6,8) (8,8) (8,8) (8,4) (8,3) (8,3) (5,5) * If multi-deck switch is needed, contact Grayhill. Angle Of Throw Maximum Decks** Maximum Poles Per Deck*** Shorting Or Non-Shorting 15° 18° 22°30' 22°30' 12 12 12 1 12 10 8 2 N or S N or S N or S N or S Solder Solder Solder Both 53 59 57 51 12 12 12 12 12 11 30° 30° 30° 30° 30° 30° 12 12 12 1 1 1 6 6 6 4 4 1 N or S N or S N or S N or S N or S N Both Both Solder Both Both **** 71 9 44 51 56 19 10 10 10 10 10 10 10 10 36° 36° 36° 36° 36° 36° 36° 36° 12 12 12 1 1 1 1 1 2 2 2 2 2 2 1 1 N or S N or S N or S N N or S N or S N or S N or S Both Both Both PC Both Both Both Solder 8 71 42 75/77 50 56 24 5000 8 8 8 6 6 6 4 4 4 45° 45° 45° 60° 60° 60° 90° 90° 90° 12 12 1 6 12 1 12 6 1 4 4 2 3 3 2 2 2 2 N or S N or S N N N N N N N Both Solder Both Both Solder Both Solder Both Both 9 44 50 9 44 50 44 9 50 24 20 16 16 * Maximum positions per pole depends on number of poles per deck. www.grayhill.com ** Based on 1 pole per deck. Number of decks is also limited by the total number of poles. Solder Lug Or PC Series Number *** Limited by total number of poles per switch. ****Choice of Faston or Solder Lug terminals. Bulletin 1220 Rev 04/14 Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Rotary Switch Standard Options • Custom Switches With No Tooling Required • Easily Ordered Specials 1. Dummy Terminal Used as tie point, it is not an active switch position. Can be located at any specified position outside of active switch terminals. Priced as active position. Example, a three position switch with 2 dummy terminals would be priced as a five position switch. .072 +.000 –.002 (1,83 –0,05) .034 ± .003 (0,86 ± 0,07) .045 .047 (1,19) (1,14) .096 ± .001 (2,44 ± 0,03) 2. Enlarged Wire Holes .032 ± .001 (0,81 ± 0,03) R (2) 5. Notched Terminals Used in place of the conventional solder lug terminals. 6. External Shorting Links .068 ± .005 (1,73 ± 0,13) .045 (1,14) .062 ± .003 (1,57 ± 0,08) DIAMETER Series 08A, 09A, 42H, 42M, 44H, and 44M: Lug terminals for several wires; standard in Series 08M, 09M, 53, 57, and 59 switches. 3. High Density Wiring Terminal .096 ± .001 (2,44 ± 0,03) .0635 + .002 –.001 (1,61 + 0,05 – 0,02) DIAMETER The gold-plated terminal features a slot to accept wires in addition to the conventional wire hole. 4. Taper Tab Terminals External shorting links, as shown in the drawing, can be used in place of conventional solder lug terminals in the Series 5000, 24, 42 or 43 rotary switches. Shorted terminals can also be accomplished internally in the Series 71 rotary switches. Solder lug terminals can be intermixed on the same deck. 7. Non-Standard, Non-Turn Devices Switches without tabs Series 08, 09, 42 and 44: There is no additional charge for a front support plate without a nonturn tab. .095 (2,41) .280 (7,11) 45° .079 (2,01) Used in place of conventional solder lug terminals. Taper tab terminals are gold plated. Switch Series# 1 Options For Styles A and S 2 3 4 5 6 7 Non-turn tab of non-standard projection Series 08: All tabs located at .260 inch radius from centerline of switch. The following projections (inches) are available: .121; .094; .045; .032 Series 44: From Centerline Projection .375" (9,53 mm) .062" (1,57 mm) .531" (13,49 mm) .121" or .049" (3,07 or 1,24 mm) 8. RFI Grounding A silver-plated shaft and wave washer improve DC grounding of shaft to mounting bushing, thus minimizing possible radio frequency interference. Example: static and dynamic DC resistance after 25,000 cycle life test is maximum 100 milliohms. For concentric shaft switches, discuss grounding with factory. Special handling charges apply to small lots. 9. Electrostatic, Electromagnetic Shielding A metallic shield can be added between decks. Grounding of the shield provides additional RFV /EMI protection, Size and shape of the shield depends on the equipment configuration and the amount of protection required Price is dependant onthe number and type of shields required. 10. Unidirectional Rotation The detenting system permits rotation in only one direction. Usable only with continuous rotation switches. Specify direction of rotation. Applicable to 30° and 36° throw switches only. 8 9 Options For All Styles 10 11 12 13 14 15 16 08 x x x x x x 09 x x x x x x 24 x x x x x x 42 x x* x x x x x x x x x x 43 x x x x x x* x x x 44 x x* x x x x x x x x x 50/51 x x 56 x x 53/57/59 x 54 x x x x x* x x x x x 71 x* x x 5000 x x x x x x * See description below for limitations. www.grayhill.com Patent Pending ©2013 Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. 11. Intermixing of Shorting and NonShorting Contacts In some switches, non-shorting and shorting contacts can be intermixed between decks. A 2-deck switch, for example could have shorting contacts on deck 1 and non-shorting contacts on deck 2. In a few switches, non-shorting and shorting contacts can also be intermixed between poles. A 2-pole per deck switch, for example, could have non-shorting on pole #1, and shorting on pole #2. Series 08 and 09: An 09M30 or 08M36 rotary switch can have shorting and non-shorting contacts intermixed between decks. Shorting and non-shorting contacts can be intermixed between poles as well as decks in styles A, S, P, and SP. Example: an 08P36, 1-pole, 10 position switch with terminals on one side of the switch would be priced as a 2 deck, five position, one pole per deck switch. 13. Homing Rotor (Bridging and Shorting Deck) and Progressively Shorting Deck A homing rotor (bridging and shorting) switch deck connects all terminals to the common except the terminal in the selected switch position. For example, in position 1, terminals 2 thru 12 are CIRCUIT DIAGRAM Series 50, 51, and 56: Non-shorting and shorting contacts can be intermixed between poles. Priced the same as standard switches. The type of contacts on each pole must be precisely indicated. 12. PC Mount Switches With Terminals From One Side of Switch Series 71 PC mount switch has all terminals on one side. Series 08P, 09P, and 42P with non-shorting contacts are also available with terminals limited to one side. Contact Grayhill for a special part number. This is accomplished by using 2 decks per pole and placing the rotating contacts 180° out of phase on each deck. The first deck picks up the first half of the positions; the second deck picks up the last half of the positions. Common terminals are tied together by the PC board circuitry. A total of 12 decks (6 usable poles) is the maximum per switch. Switches with the maximum number of positions (12 for 30°, or 10 for 36°) will have continuous rotation. Rotation can be limited to less than the maximum positions. For example, an 8 position Series 8P36 switch with terminals on one side, would pick up 5 positions on the first deck and 3 positions on the second deck. Price is the same as standard switches with comparable number of decks and positions. www.grayhill.com C 12 HOMING ROTOR DECK 1 2 11 Series 42, 43, 44, and 54, in 30° or 36°: Non-shorting and shorting contacts can be intermixed between poles or decks. Series 71: Non-shorting and shorting contacts can be intermixed between poles in fixed stop switches only. decks are used in combination with conventional decks, it is important to remember that the stop system limits the rotation of both types of decks. For example, when a homing rotor deck Is used in combination with a 6-position conventional deck, the homing rotor is likewise limited to six positions. O-RINGS 10 3 9 4 5 8 6 7 connected to the common, and terminal 1 is open. In position 2, terminal 3 thru 12 and 1 are connected to the common, and terminal 2 is open. A homing rotor deck will function for 25,000 mechanical cycles of operation. The progressively shorting switch deck connects consecutive switch positions to the common. For example, in position 1, terminal 1 is connected to the common; in position 2, terminals 1 and 2 are connected to the common; in position CIRCUIT DIAGRAM C PROGRESSIVELY SHORTING DECK 1 2 14. Shaft and Panel Seal on Concentric Shaft Switches The following diagram shows the location of the O-rings required to seal the shafts to the bushings. When the concentric shaft switches are sealed in this manner, the .125 inch diameter shaft is supplied full round. Bushing-to-panel sealing is accomplished by the panel seal kit. 15. Fixed Stop, Add-A-Pot Switches The rotary switch section of the Add-A-Pot rotary switches can be built with a fixed mechanism rather than the standard adjustable stop mechanism. The front end of a switch of this type is similar to the Series 43A or Series 54A style concentric rotary switches. The total number of decks is limited to three. The Series 43 is limited to 1 pole per deck. Series 54 to 2 poles per deck. 3 4 5 6 3, terminals 1,2, and 3 are connected to the common. A progressively shorting deck is limited to a maximum of 6 positions. A progressively shorting deck will function for 25,000 mechanical cycles of operation. 16. Series 54 Concentric Shaft Switch in 45°, 60°, and 90° Throws The Series 54A switch is available with these angles of throw in Section A of the concentric rotary switch. Section B is available in 30° angle of throw only. Section A is limited to 1 to 3 decks, non-shorting contacts, and 1 or 2 poles per deck. Homing Rotor or Progressively Shorting decks can be ordered as a deck of a 44A or 44M style switch, or their sealed equivalents. Order up to 11 conventional decks and 1 special circuitry deck. For a good detent feel, the switch is limited to a total of 12 poles plus the homing rotor or progressively shorting deck. Example: 6 2-pole decks and a homing rotor. When these special Bulletin 1222 Rev 04/14
51ST30-01-3-02N 价格&库存
很抱歉,暂时无法提供与“51ST30-01-3-02N”相匹配的价格&库存,您可以联系我们找货
51ST30-01-3-02N
