38BT-4-H-2-N
38BT-4-H-2-N
    GRAYHILLINC.
    SMD
    SWITCH PUSH SPST-NO 1A 120V
38BT-4-H-2-N 数据手册
Butt Contact Pushbutton Switches SERIES 38BT and 38BH Sub-Miniature Horizontal PC Mount Features • Drop-In Replacement for Industry Standard • Sealed Plunger Option • Printed Circuit Board Mount • SPST and SPDT, Momentary Contact DIMENSIONS in inches (and millimeters) 38BT .215 (5,46) .125 (3,18) CL .249 (6,32) .162 (4,11) .320 (8,13) .025 (0,64) .130 (3,30) CL PC Mounting .043 (1,09) DIA. TYP. .200 (5,08) Pushbutton Switches .100 (2,54) DIA. SPST .030 (0,76) TYP. 38BH .200 (5,08) C L DIM. "A" .249 (6.32) .200 (5,08) .125 (3,18) .180 (4,57) .165 (4,19) DIA. .015 (0,38) TYP. .200 (5,08) .162 (4.11) C L .030 (0.76) TYP. .200 (5.08) .020 (0,51) TYP. .030 (0,76) TYP. PC Mounting .320 (8.13) .025 (0.64) .200 (5.08) .130 (3.30) .180 .125 .100 (4.57) (3.18) (2.54) DIA. DIA. 1 .030 (0.76) TYP. .200 (5.08) .165 (4.19) .015 (0.38) TYP. SPDT .200 (5,08) 2 .020 (0.51) TYP. .043 (1.09) DIA. TYP. .100 (2.54) TYP. 3 TERMINAL IDENTIFICATION .200 (5.08) .200 (5.08) Unless otherwise indicated, tolerances are ± .010 (0,25) SPECIFICATIONS Materials and Finishes Rating Criteria Operating Life: 80,000 make-and-break cycles at full load Contact Rating (resistive load): Gold Contacts: 0.4 VA maximum at 20 Vac or Vdc maximum Silver Contacts: 1.0 Amp maximum at 120 Vac or 28 Vdc Contact Resistance: Below 20 milliohms typical initial at 2-4 Vdc, 100 mA Insulation Resistance: 1000 megaohms min. Voltage Breakdown: 1000 Vrms minimum at sea level Operating Temperature: -30°C. to +85°C. Solderability: Per MIL-STD-202F, Method 208D, or EIA RS-186E Method 9 (1 hour steam aging) CIRCUITRY ORDERING INFORMATION SPST–N.O. SPSt n.O. N.C. TERM. 1 COMM TERM. 2 N.O. TERM. 3 SPDT–N.O. Base and Cover: Thermoplastic (UL 94V-0) Plunger: Thermoplastic (UL 94V-0), (S versions include an internal o-ring seal) Terminals: Copper alloy, gold or silver plate (as specified) over nickel plate Spring: Plated Music Wire Contact System: Copper alloy, gold or silver plate (as specified) over nickel plate Switch Support: Brass, tin-plated 38BX-4-H-3-N Series: 38BT = SPST, Momentary, Thru Hole Series: 38BH = SPDT, Momentary, Thru Hole Dimension A: 0 = 0.020" 4 = 0.215" Seal: S = O-Ring Seal, N = No Seal Contact Material: 1 = Solder Dip over Gold 2 = Solder Dip over Silver 3 = Gold - RoHS Compliant 4 = Silver - RoHS Compliant Orientation: H = Horizontal to PCB Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
38BT-4-H-2-N
1. 物料型号:38Bt和38BH系列,分别代表SPST(单极单掷)和SPDT(单极双掷)按钮开关。 2. 器件简介:这些开关是行业标准的插入式替代品,提供密封柱塞选项,PCB安装,以及水平方向的配置。 3. 引脚分配:文档中提供了详细的尺寸和引脚布局,例如38Bt的CL(触点寿命)为0.200英寸,38BH的CL为0.162英寸。 4. 参数特性:包括操作寿命(80,000次全负载开合周期),材料和表面处理,接触系统,以及弹簧材料等。 5. 功能详解:开关支持SPST和SPDT配置,具有不同的接触材料选项,如金接触和银接触,以及不同的环境适应性。 6. 应用信息:开关适用于需要高可靠性和长寿命的应用场合。 7. 封装信息:提供了详细的尺寸信息,包括安装孔径、柱塞直径等,以及密封选项和方向。
38BT-4-H-2-N 价格&库存
很抱歉,暂时无法提供与“38BT-4-H-2-N”相匹配的价格&库存,您可以联系我们找货
