67C08-8-M-040C
67C08-8-M-040C
    GRAYHILLINC.
    PROPORTIONAL JOYSTICK WITH PUSHB
67C08-8-M-040C 数据手册
Joysticks SERIES 67C Hall Effect Joystick with Integrated Pushbutton & Optical Encoder FEATURES • Proportional joystick, pushbutton & optical encoder functions from a single shaft • Analog joystick outputs are proportional to angle of shaft deflection • Long life, high reliability • Choices of cable length and termination • Customized solutions available APPLICATIONS • Global positioning / Driver information systems • Entertainment equipment • Medical equipment controls • Radio control belly boxes • Robotics • Aerospace • Avionics • Security camera controls DIMENSIONS in inches Joysticks 87654321 MATING CONNECTOR AMP P/N 188275-8 OR EQUIVALENT JOYSTICK OUTPUT WAVEFORM Y+ X- CODE REPEATS EVERY 4 POSITIONS 20 POSITIONS PER REVOLUTION X+ Y- OUTPUT SHOWN IS TYPCIAL FOR VDD = 5.00V AND NOT NECESSARILY TO SCALE BEHAVIOR IS SHOWN FOR X-AXIS AS EXAMPLE BEHAVIOR OF Y-AXIS IS SAME AS X-AXIS Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Joysticks SPECIFICATIONS General Electrical Specifications Operating Voltage on Pin 6 (VDD): 5.0 ± 0.25V Absolute Maximum Voltage* on Pin 6 (VDD): -0.3 V min, 6.5 V max. Operating Current: 8 mA typ., 12 mA, max. Joystick Electrical and Mechanical Ratings Sensing Method: Hall effect, proportional to angle of deflection Output Voltage (Pins 7 & 8): Analog (Ratiometric to Operating Voltage) Output at Center Position: 50% VDD Output at Full Travel: 10% VDD (for X-, Y- directions) 90% VDD (for X+, Y+ directions) Output Tolerance: ± 2% VDD (at Center and at Full Travel) Output Current: 200 µA, max. Angle of Throw: 6.5° + 2° / -1° in main directions; 9.0° ± 0.1° in diagonals Life: 500,000 actuations in each of the four main directions Pushbutton Electrical and Mechanical Ratings Joysticks Rating: 10 mA at 5 Vdc resistive Absolute Maximum Voltage* on Pins 2 & 3: 6.0 V Contact Resistance: less than 10 ohms Life: 1 million actuations minimum Contact Bounce: < 4 mS make,
67C08-8-M-040C 价格&库存
很抱歉,暂时无法提供与“67C08-8-M-040C”相匹配的价格&库存,您可以联系我们找货
