67C18-8-M-025C
67C18-8-M-025C
    GRAYHILLINC.
    Joystick; With P/B and Encoder; 18 Deg 20Pos; 8 Direction; 2.5 In Cable W/Connec
67C18-8-M-025C 数据手册
Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Joysticks SERIES 67C Hall Effect Joystick with Integrated Pushbutton & Optical Encoder FEATURES • Proportional joystick, pushbutton & optical encoder functions from a single shaft • Analog joystick outputs are proportional to angle of shaft deflection • Long life, high reliability • Choices of cable length and termination • Customized solutions available APPLICATIONS • Global positioning / Driver information systems • Entertainment equipment • Medical equipment controls • Radio control belly boxes • Robotics • Aerospace • Avionics • Security camera controls DIMENSIONS in inches Joysticks 87654321 MATING CONNECTOR AMP P/N 188275-8 OR EQUIVALENT JOYSTICK OUTPUT WAVEFORM Y+ X- CODE REPEATS EVERY 4 POSITIONS 20 POSITIONS PER REVOLUTION X+ Y- OUTPUT SHOWN IS TYPCIAL FOR VDD = 5.00V AND NOT NECESSARILY TO SCALE BEHAVIOR IS SHOWN FOR X-AXIS AS EXAMPLE BEHAVIOR OF Y-AXIS IS SAME AS X-AXIS Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Specifications are subject to change. Please refer to the current datasheet on www.grayhill.com for the most current published specifications for this product. Joysticks SPECIFICATIONS General Electrical Specifications Operating Voltage on Pin 6 (VDD): 5.0 ± 0.25V Absolute Maximum Voltage* on Pin 6 (VDD): -0.3 V min, 6.5 V max. Operating Current: 8 mA typ., 12 mA, max. Joystick Electrical and Mechanical Ratings Sensing Method: Hall effect, proportional to angle of deflection Output Voltage (Pins 7 & 8): Analog (Ratiometric to Operating Voltage) Output at Center Position: 50% VDD Output at Full Travel: 10% VDD (for X-, Y- directions) 90% VDD (for X+, Y+ directions) Output Tolerance: ± 2% VDD (at Center and at Full Travel) Output Current: 200 µA, max. Angle of Throw: 6.5° + 2° / -1° in main directions; 9.0° ± 0.1° in diagonals Life: 500,000 actuations in each of the four main directions Pushbutton Electrical and Mechanical Ratings Joysticks Rating: 10 mA at 5 Vdc resistive Absolute Maximum Voltage* on Pins 2 & 3: 6.0 V Contact Resistance: less than 10 ohms Life: 1 million actuations minimum Contact Bounce: < 4 mS make,
67C18-8-M-025C 价格&库存
很抱歉,暂时无法提供与“67C18-8-M-025C”相匹配的价格&库存,您可以联系我们找货
