110073503
110073503
    STEINEL
    热风枪 120V 120°F ~ 1200°F(49°C ~ 649°C) 1600W 黑色,银色
110073503 数据手册
Product data sheet HG 2320 ESD Electrostatic Discharge Heat Gun Technical Specifications Voltage: Power: Amps: 120 VAC / 60 Hz 1600 watts 13.3 Surface Conductivity: Airflow Rate: Stages: 104 ohms 4-13 cfm. (continuously variable) 2 (continuously variable) Power Cord: Motor: Heating Element: Industrial grade rubber, length: 6 ft Brush motor Cereamic heating element Motor Lifetime: Accessories: Temperature: Net Weight: Dimensions: (L x W x D) 1000 hours Use of standard accessories 120-1200 °F 2.19 lbs 9.96“ x 3.41“ x 7.87“ Single Sell Pack: Dimensions: 10.20“ x 3.54“ x 9.33“ Weight: 2.60 lbs Features: Higher durability (+20%), optimized weight balance, LCD-Display, 4 settings programmable, heat build-up warning, hanging ring, easily replaceable power cord, residual heat indicator, optional temperature scanner and fine dist filter UPC Code Product No. 1 year 0 18139 73503 8 110073503 Warranty: 9051 Lyndale Ave. South | Bloomington, MN 55420 STEINEL America, Inc. v. 12.19
110073503 价格&库存
很抱歉,暂时无法提供与“110073503”相匹配的价格&库存,您可以联系我们找货
