HL 2020 E EURO
HL 2020 E EURO
    STEINEL
    STEINEL - HL 2020 E EURO - Hot Air Gun, 630 °C Max Temperature, 2.2 kW, 230 V, EU Plug
HL 2020 E EURO 数据手册
Hot air tool HL 2020 E Folding box EAN 4007841 008192 CE VDE Function description The master class. Electronically controlled hot air tool HL 2020 E with LCD. Professional technology for shaping tiles, de-soldering circuit boards, welding plastics, drying repair filler, shrinking cable sleeves, soldering pipes and a whole lot more. Adjustable by joystick from 80°C to 630°C in 10°C steps. Residual heat indicator to prevent burns. Technical specifications Output 2200 W Residual heat indicator Yes Temperature 80 – 630 °C Function, hanger Yes Airflow rate 150 – 500 l/min Restart protection No Motor, type Brush motor Thermal cut-out Yes Temperature setting in 10°C steps by joystick Thermostat Yes Temperature display LCD display Cord length 2.2 m Temperature measurement range 0-300°C, adjustment in 10°C steps Dimensions (L x W x H) 253 x 86 x 200 mm Temperature scan via Sensor Mains power supply 220 – 230 V / 50 – 60 Hz Optimum distance from workpiece 15 cm Model Folding box Work-area marking with LED light beam PU1, net weight 0,880 kg Emission level adjustable (0.85 / 0.90 / 0.95) Manufacturer's Warranty 3 years Heating element Ceramic heating element PU1, EAN 4007841008192 https://www.steinel.de Subject to technical modifications 11.2019 Page 1 from 2 Hot air tool HL 2020 E Folding box EAN 4007841 008192 Accessories EAN 4007841 014919 Temperature scanner HL Scan EAN 4007841 078218 Fine dust filter HL 1920 E - HG 2320 E EAN 4007841 009625 HL Light EAN 4007841 010317 Paint Scraper Set EAN 4007841 074210 ABS plastic welding rod EAN 4007841 073411 PP plastic welding rod EAN 4007841 071219 HDPE plastic welding rod EAN 4007841 073114 PVC plastic welding rod EAN 4007841 006648 Crimp connectors - Ø 1.5 - 2.5 mm EAN 4007841 072766 Shrink tubing III - ? 4,0 – 12,0 mm EAN 4007841 006662 Crimp connectors - Ø 0.1 - 6.0 mm EAN 4007841 071318 Shrink tubing I - ? 1,6 – 4,8 mm EAN 4007841 006655 Crimp connectors - Ø 0.5 - 1.5 mm EAN 4007841 070717 Reduction nozzle 14 mm EAN 4007841 074715 Wide-slit nozzle EAN 4007841 012311 Feed roller EAN 4007841 071417 Shrink tubing II - ? 4,8 – 9,5 mm EAN 4007841 070212 Surface nozzle 75 mm EAN 4007841 075811 Shrink tubing kit EAN 4007841 070915 Welding nozzle EAN 4007841 070113 Surface nozzle 50 mm EAN 4007841 070311 Window nozzle 50 mm EAN 4007841 070519 Reflector nozzle EAN 4007841 070410 Window nozzle 75 mm EAN 4007841 074616 Soldering reflector nozzle 10 mm EAN 4007841 034566 HL Tool Stand EAN 4007841 070618 Reduction nozzle 9 mm https://www.steinel.de Subject to technical modifications 11.2019 Page 2 from 2
HL 2020 E EURO 价格&库存
很抱歉,暂时无法提供与“HL 2020 E EURO”相匹配的价格&库存,您可以联系我们找货
