HG2320 E 110V
HG2320 E 110V
    STEINEL
    STEINEL - HG2320 E 110V - HOT AIR TOOL, 80 TO 650 DEG C
HG2320 E 110V 数据手册
Hot air tool HG 2320 E Folding box EAN 4007841 007386 CE Function description Precision digital control. Electronically controlled HG 2320 E hot air tool. 2300 W, digital temperature setting by joystick from 80 – 650 °C, temperature indicated in 10 °C steps on LCD display. Airflow regulation in 2 stages of 150 and 500 l/min. Technical specifications Output 2300 W Restart protection Yes Temperature 80 – 650 °C Thermal cut-out Yes Airflow rate 150 – 500 l/min Thermostat Yes Motor, type Brush motor Cord length 3m Temperature setting in 10°C steps by joystick Dimensions (L x W x H) 253 x 87 x 200 mm Temperature display LCD display Mains power supply 230 V / 50 – 60 Hz Heating element Ceramic heating element Model Folding box Loc function Yes PU1, net weight 1,024 kg Residual heat indicator Yes Manufacturer's Warranty 1 year Function, hanger Yes PU1, EAN 4007841007386 https://www.steinel.de Subject to technical modifications 11.2019 Page 1 from 2 Hot air tool HG 2320 E Folding box EAN 4007841 007386 Accessories EAN 4007841 074616 Soldering reflector nozzle 10 mm EAN 4007841 034566 HL Tool Stand EAN 4007841 010294 Sieve reflector nozzle 50 x 35 mmT421T399:T827 EAN 4007841 009571 Reduction nozzle 6 mm EAN 4007841 075569 12-piece hot-air accessory kit EAN 4007841 070618 Reduction nozzle 9 mm EAN 4007841 073114 PVC plastic welding rod EAN 4007841 006648 Crimp connectors - Ø 1.5 - 2.5 mm EAN 4007841 072766 Shrink tubing III - ? 4,0 – 12,0 mm EAN 4007841 006662 Crimp connectors - Ø 0.1 - 6.0 mm EAN 4007841 071318 Shrink tubing I - ? 1,6 – 4,8 mm EAN 4007841 006655 Crimp connectors - Ø 0.5 - 1.5 mm EAN 4007841 070717 Reduction nozzle 14 mm EAN 4007841 006785 Pressure roller 40mm - Silicone EAN 4007841 074210 ABS plastic welding rod EAN 4007841 009601 Flexible hot air tool stand with suction pad foot EAN 4007841 071417 Shrink tubing II - ? 4,8 – 9,5 mm EAN 4007841 070212 Surface nozzle 75 mm EAN 4007841 075811 Shrink tubing kit EAN 4007841 010317 Paint Scraper Set EAN 4007841 070915 Welding nozzle EAN 4007841 009625 HL Light EAN 4007841 070113 Surface nozzle 50 mm EAN 4007841 070311 Window nozzle 50 mm EAN 4007841 014919 Temperature scanner HL Scan EAN 4007841 070519 Reflector nozzle EAN 4007841 009595 Flexible hot air tool stand with magnetic foot EAN 4007841 034122 Pressure roller 40mm - Teflon EAN 4007841 073411 PP plastic welding rod EAN 4007841 070410 Window nozzle 75 mm EAN 4007841 071219 HDPE plastic welding rod EAN 4007841 093211 Pressure roller 50mm - Rubber EAN 4007841 074715 Wide-slit nozzle EAN 4007841 078218 Fine dust filter HL 1920 E - HG 2320 E EAN 4007841 053963 Hot Air Tool Guard Cage HL 1820 S - HG 2320 E https://www.steinel.de Subject to technical modifications 11.2019 Page 2 from 2
HG2320 E 110V 价格&库存
很抱歉,暂时无法提供与“HG2320 E 110V”相匹配的价格&库存,您可以联系我们找货
