GLUEPRO 300
GLUEPRO 300
    STEINEL
    STEINEL - GLUEPRO 300 - HOT-MELT GLUE APPLICATOR, 230V, 11.7MM
GLUEPRO 300 数据手册
Hot-melt glue applicator GluePRO 300 Case EAN 4007841 052683 Quickstart Temperature High adhesive performance Glue sticks CE EMC Function description The new benchmark. The rugged GluePRO 300 with non-slip grip handle is comfortable to hold and has what it takes to become one of your favourite tools. This hot melt glue applicator is the key to convenient, reliable and tireless gluing work without compromising on anything. Practical stroke adjustment makes it possible to set the quantity of glue per stroke for any specific application. Warm-up time is approximately three minutes. Temperature: 190°C. Includes practical case. Technical specifications Output, heat-up phase 300 W Stroke adjustment Yes Average power consumption 90 W Idle mode No Temperature 190 – 190 °C Dimensions (L x W x H) 283 x 83 x 212 mm Melt temperature 190 – 190 °C Nozzle can be changed Yes Temperature accuracy +/- 3 °C Mains power supply 220 – 230 V / 50 – 60 Hz Warm-up time 3 min Model Case Delivery rate 25 gr/min PU1, net weight 0,580 kg Max. stick diameter 11.7 mm Manufacturer's Warranty 1 year Function, hanger Yes PU1, EAN 4007841052683 Soft grip Yes https://www.steinel.de Subject to technical modifications 11.2019 Page 1 from 1
GLUEPRO 300 价格&库存
很抱歉,暂时无法提供与“GLUEPRO 300”相匹配的价格&库存,您可以联系我们找货
