GLUEPRO 400
GLUEPRO 400
    STEINEL
    STEINEL - GLUEPRO 400 - HOT-MELT GLUE APPLICATOR, 11.7MM, LCD
GLUEPRO 400 数据手册
Hot-melt glue applicator GluePRO 400 LCD Case EAN 4007841 052690 Quickstart Degree-accurate temperature setting High adhesive performance Glue sticks CE EMC Function description Professional gluing to the accuracy of a degree. Virtually any hot-melt adhesive can be used. Including acrylates demanding a high temperature or low-temperature Low Melt adhesives. The GluePRO 400 LCD is the ergonomic hot-melt glue applicator for professional use in industry and the trades, producing optimum results with the capability of setting the temperature to an accuracy of one degree. With a display for monitoring temperature to the accuracy of one degree (40-230°C). Heats up in under two minutes. Technical specifications Output, heat-up phase 400 W Soft grip Yes Average power consumption 110 W Stroke adjustment Yes Temperature 40 – 230 °C Idle mode Yes Temperature display LCD display Dimensions (L x W x H) 282 x 82 x 212 mm Melt temperature 40 – 230 °C Nozzle can be changed Yes Temperature accuracy +/- 2 °C Mains power supply 220 – 230 V / 50 – 60 Hz Warm-up time 2 min Model Case Delivery rate 30 gr/min PU1, net weight 0,600 kg Max. stick diameter 11.7 mm Manufacturer's Warranty 1 year Function, hanger Yes PU1, EAN 4007841052690 https://www.steinel.de Subject to technical modifications 11.2019 Page 1 from 2 Hot-melt glue applicator GluePRO 400 LCD Case EAN 4007841 052690 Accessories EAN 4007841 052737 Long nozzle, Ø 3.0 mm EAN 4007841 052744 Long nozzle, angled, Ø 3.0 mm EAN 4007841 052928 Long nozzle, Ø 1.5 mm EAN 4007841 052935 Long nozzle, Ø 4.5 mm EAN 4007841 052416 Acrylate glue sticks Ø 11 mm EAN 4007841 052430 Fast glue sticks Ø 11 mm EAN 4007841 052423 Flex glue sticks Ø 11 mm EAN 4007841 052409 Low Melt glue sticks Ø 11 mm EAN 4007841 050092 General-purpose glue sticks Ø 11 mm https://www.steinel.de Subject to technical modifications 11.2019 Page 2 from 2
GLUEPRO 400 价格&库存
很抱歉,暂时无法提供与“GLUEPRO 400”相匹配的价格&库存,您可以联系我们找货
