1Y20141101
1Y20141101
    NICOMATIC
    Custom
1Y20141101 数据手册
C.CS.1000 / GB C C R O I M P N N E F L E X C T O R ® S CRIMPFLEX® connectors Technical data .................................................3 CRIMPFLEX ® CONNECTORS Description.......................................................4 CRIMPFLEX ® CRIMPING Typical contact application ..............................5 Female contact with low insertion force..........6 Female contact with high insertion force ........7 Female contact “Hi-Flex”.................................8 FEMALE CONTACTS Typical male pin application ............................9 0.635 mm (.025ʼʼ) square male contact ........10 0.635 mm (.025ʼʼ) reverse square male contact ...11 Short square male pin...................................12 MALE PINS Solder tabs environment ...............................13 Standard short male solder tab.....................14 Standard male solder tab..............................15 Retention short male solder tab....................16 Retention male solder tab .............................17 Double retention male solder tab..................18 Long male solder tab ....................................19 MALE SOLDER TABS Manual press.................................................28 Pneumatic press ...........................................29 CRIMPFLEX ® MACHINES Technical data................................................30 Part numbering .............................................31 JUMPER CABLES Technical data................................................32 Part numbering ..............................................33 FFC CARD CABLE Technical data................................................34 Standard headers..........................................34 Walled headers ............................................ 35 Standard and low profile sockets ..................36 Straight & Right Angle Headers ................... 37 HEADERS AND SOCKETS INDEX ...............................................................38 NOTES ..........................................................39-40 OTHER NICOMATIC PRODUCTS Technical data ..........................................20-21 Accessories : polarization keys.....................21 Housing OFxx series.....................................22 Housing 4Fxx series......................................22 Housing 2Exx series .....................................23 Housing 4Exx series .....................................23 Housing 1Exx series .....................................24 Housing 7F10xx series..................................24 Housing OLxx series .....................................25 Housing OMxx series ....................................25 Housing OPxx series.....................................26 Housing ODxx series ....................................26 Housing 1Lxx series ......................................27 Housing 1Pxx series......................................27 CRIMPFLEX ® HOUSINGS 1 2 CRIMPFLEX® connectors S RoH nt plia com TECHNICAL DATA MATERIAL ✓ ■ Phosphor bronze MALE SOLDER TAB PLATING ■ The standard connector is tin plated (thickness : Ni 2µ + Sn 5µ) MALE PINS AND FEMALE CONTACTS PLATING ■ The standard connector is tin plated (thickness : Ni 2µ + Sn 5µ) ■ Selective gold plating in mating area (thickness : Ni 2µ + Au 0.15µ) ■ Other thickness plating available CERTIFICATIONS ■ UL : E 125469 (Component - Connectors For Use In Data, Signal, Control And Power Applications) MECHANICAL SPECIFICATIONS ■ Crimp strength to laminated cable : ➡ 15 N min. (3.3 Ibs) perpendicular to the tracks (breaking-up of the conductor) ➡ 50 N min. (11.2 Ibs) parallel to the tracks (breaking-up of the conductor) ELECTRICAL SPECIFICATIONS ■ ■ ■ ■ ■ ■ ■ Contact resistance Contact resistance after environmental tests Insulation resistance Withstanding voltage Capacitance between two contacts DC current rating per contact AC current rating per contact 5 m ⍀ max. 6 m ⍀ max. 5.105 M ⍀ at 500 V 1 100 V RMS 4 pF max. 3 A Continuous 5 A Continuous THERMAL SPECIFICATIONS ■ Connectors operating temperature -55°C to +150°C 3 CRIMPFLEX® crimping CRIMPFLEX® system patented by NICOMATIC DESCRIPTION Developed and patented by NICOMATIC, the CRIMPFLEX® connection system complies with the most rigorous electrical and mechanical requirements. The crimping of the contacts is obtained by piercing the conductor in 6 points. This ensures excellent mechanical retention by 2 points and electrical contact by 4 points with the lowest possible contact resistance. CRIMPING ENVIRONMENT Copper conductors, silver or carbon ink printed conductors, EL lamps. ■ All types of flexible circuits whose thickness ranges from 75 µ to 350 µ (0.003 ʼʼ to 0.014ʼʼ). For other dimensions, contact NICOMATIC. ■ Can pierce all kinds of supports : polyester, FR4, polyimide, PTFE, etc. ■ ADVANTAGES ■ ■ ■ ■ ■ ■ ■ 4 Use of contacts in reel at final pitch of 2.54 mm (0.100ʼʼ).and 1.27mm(0.050'') Mass termination of all contacts in one press stroke which saves time and allows more accuracy. Crimp is easily inspected. The housing is assembled after crimping. The width of the circuit is not limited by the width of the housing. The housing can be removed. The broadest range of connector solutions in the industry. Female contacts TYPICAL CONTACT APPLICATION Straight single row standard header (refer to page 34) Straight single row walled header (refer to page 35) Straight double row standard header (refer to page 34) Straight double row walled header (refer to page 35) The length of the pin on mating side must range from 4.5 mm to 7 mm. 1L xx OL xx OM xx 1L-10-2Z1-XX-1 or 1L-10-1Z1-XX-1 (straight version) compatible with industry standard headers compatible with industry standard headers OD xx or OP xx 1P xx 5 Female contacts LOW INSERTION FORCE REF. 11506 Number of mating cycles = 500 Number of mating cycles = 50 2,54 pitch 1,5 min. Contact zone : after cutting Length on support : ■ Au = 1.5 N max (5.5 oz) ■ Sn = 3 N max (11 oz) CUTTING 6 Contact lay out REF. 11506-12 11506-32 PLATING Tin plated Selective gold plated REEL 35 000 contacts 35 000 contacts OTHER PLATINGS ON REQUEST 6 Dimensions in mm Female contacts HIGH INSERTION FORCE REF. 10025 Contact zone : after cutting length on support : ■ Increased retention for high vibration applications. ■ Recommended for a small amount of contacts (2 to 10 contacts). CUTTING 2,54 pitch 1,5 min. 6 Contact lay out Dimensions in mm REF. 10025-12 10025-32 PLATING Tin plated Selective gold plated REEL 35 000 contacts 35 000 contacts OTHER PLATINGS ON REQUEST 7 Female contacts HI-FLEX REF. 14106 Contact zone : 3,2 after cutting length on support : ■ The Hi-Flex female contact is designed to offer a stable insertion force and low contact resistance over a larger number of mating cycles. ■ More resistant to damage by bent or angled pins, primarily on test devices. CUTTING 2,54 pitch 1,5 min. 1,25 6 Contact lay out REF. 14106-12 14106-32 PLATING Tin plated Selective gold plated REEL 35 000 contacts 35 000 contacts OTHER PLATINGS ON REQUEST 8 Dimensions in mm Male pins TYPICAL MALE PINS APPLICATION OF xx + Female contacts + + Female Header OF xx + 12410 OM xx + Female contacts OR OL xx + Female contacts + 1L xx + 12410 or 13756 OF xx + Female contacts + 13595 Female Header 9 Male pins 0.635 MM (.025’’) SQUARE MALE REF. 12410 length support : 6 ■ The square male contact will mate with female connectors designed to accept a 0.635 mm (.025ʼʼ) pin header. 2,59 19,3 after cutting 24,5 0,8 1,7 16,5 1,3 0,635 1,5 min. 6,3 2,54 pitch 6 1 Contact lay out 1,1 1,6 CUTTING REF. 12410-12 12410-32 PLATING Tin plated Selective gold plated REEL 35 000 contacts 35 000 contacts OTHER PLATINGS ON REQUEST 10 Dimensions in mm Male pins 0.635 MM (.025’’) REVERSE SQUARE MALE REF. 13756 ■ The square male contact will mate with most female connectors designed to accept a 0.635 mm (.025ʼʼ) pin header. ■ This contact is available by special order only. 19,3 after cutting 0,8 2,59 24,5 length support : 6 1,7 Male pin difference with REF. 12410 (see page 13) is the reverse clip 1,3 16,5 3.6 0,635 1,5 min. 6,3 2,54 pitch 6 1,1 Contact lay out 1 1,6 CUTTING Dimensions in mm REF. 13756-12 13756-32 PLATING Tin plated Selective gold plated REEL 35 000 contacts 35 000 contacts OTHER PLATINGS ON REQUEST 11 Male pins SHORT SQUARE MALE PIN REF. 13595 ■ This square male pin allows for the cost effective mating to a female connector or header for use with 0.025ʼʼ square pins without the use of a housing. 15,3 12,4 after cutting length on support : 6 1,7 5 0,635 1,5 min. 2,6 2,54 pitch 1,1 CUTTING 6 Contact lay out REF. 13595-12 PLATING Tin plated 35 000 contacts OTHER PLATINGS ON REQUEST 12 REEL Dimensions in mm Male solder tabs SOLDER TABS ENVIRONMENT I.C. socket, wipe contacts with single or double point Directly soldered onto printed circuit, hole dia. 0.8mm 13 Male solder tabs STANDARD SHORT MALE SOLDER TAB REF. 10141 10 3,7 7,6 after cutting Length on support : 3,4 ■ Widely used in applications with restricted crimped areas requiring male solder tabs. ■ To solder or to fit into I.C. sockets or wipe contacts. CUTTING 1,5 min. 2,54 pitch 3,44 3, Contact lay out REF. 10141-12 PLATING Tin plated 35 000 contacts OTHER PLATINGS ON REQUEST 14 REEL Dimensions in mm Male solder tabs STANDARD MALE SOLDER TAB REF. 10241 3,7 10,4 after cutting length on support : ■ Widely used in most applications on flexible supports requiring male solder tabs. To solder or to fit into I.C. sockets or wipe contacts. CUTTING 2,54 pitch 1,5 min. 6 Contact lay out Dimensions in mm REF. 10241-12 PLATING Tin plated REEL 35 000 contacts OTHER PLATINGS ON REQUEST 15 Male solder tabs RETENTION SHORT MALE SOLDER TAB REF. 10067 3,7 7,6 after cutting length on support :3,4 ■ The crimped section is shorter to comply with high density packaging requirements. ■ For use in tight fitting applications. CUTTING 1,5 min. 2,54 pitch 3,44 3, Contact lay out REF. 10067-12 PLATING Tin plated 35 000 contacts OTHER PLATINGS ON REQUEST 16 REEL Dimensions in mm Male solder tabs RETENTION MALE SOLDER TAB REF. 10167 3,7 after cutting length on support : ■ The curved shape ensures firm holding of the contacts in the printed circuit and provides retention during wave-soldering. CUTTING 2,54 pitch 1,5 min. 6 Contact lay out Dimensions in mm REF. 10167-12 PLATING Tin plated REEL 35 000 contacts OTHER PLATINGS ON REQUEST 17 Male solder tabs DOUBLE RETENTION MALE SOLDER TAB REF. 12887 ■ Each pin is formed in an opposite direction to give excellent retention during soldering. 0,6 0,8 2,59 0,65 0,6 10 3,7 0,4 15,3 10,2 after cutting length on support : 6 1,7 CUTTING 1,5 min. 4,6 2,54 pitch 6 Contact lay out REF. 12887-12 PLATING Tin plated 35 000 contacts OTHER PLATINGS ON REQUEST 18 REEL Dimensions in mm Male solder tabs LONG MALE SOLDER TAB REF. 11612 12,6 after cutting length on support : 6 ■ The long solder tab allows connection in screw terminal blocks. ■ Used for connections to EL lamps. CUTTING 1,5 min. 1 2,6 1,1 2,54 pitch 6 Contact lay out Dimensions in mm REF. 11612-12 PLATING Tin plated REEL 35 000 contacts OTHER PLATINGS ON REQUEST 19 20 CRIMPFLEX® housings TECHNICAL DATA S RoH iant pl m o c MATERIAL ✓ ■ Thermoplastic w/glass fiber ■ Classified UL 94V-0 CERTIFICATIONS ■ UL : E 125469 (Component - Connectors For Use In Data, Signal, Control And Power Applications) THERMAL SPECIFICATIONS ■ Operating temperature - 55° C to + 150° C ACCESSORIES POLARIZATION KEYS REF. PHK-10 (BLACK) OR PHK-101 (WHITE) ■ Keys to plug into the housings to ensure polarization. ■ Can be used with the NICOMATIC PCB Connector female range. (refer to page 34) ■ Available in black or in white colour Dimensions in mm Information : All female housings are end to end stackable. OF xx and 7F10 xx housings are side to side and end to end stackable. 21 CRIMPFLEX® housings HOUSING SERIES OF xx ■ Removable connection with all types of 0.635 mm (.025ʼʼ) square or round pin headers. ■ Housings are side to side and end to end stackable. ■ Standard single housing for use with all female contacts or long male pins. Mates with headers (tin or gold plated) ref. 12-17-111-xx-1 ref. 12-17-141-xx-1 (refer to page 34) POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NO NO 1 NUMBER OF WAYS XX Dimensions in mm 02 ➞ 25 (on request : 26 ➞ 51) HOUSING SERIES 4F xx ■ This housing allows connection of a double row flexcable jumper onto a 2 rows, 0.635 mm (.025ʼʼ) square or round pin header. ■ Housings are end to end stackable. Mates with headers (tin or gold plated) ref. 16-17-111-xx-1 ref. 16-17-141-xx-1 (refer to page 34) 22 POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NUMBER OF WAYS XX NO NO 2 04 ➞ 50 Dimensions in mm CRIMPFLEX® housings HOUSING SERIES 2E xx ■ This housing is used with walled pin headers 1Y (refer to page 35). ■ It allows polarization and locking. Mates with walled headers ref. 1Y-10-111-xx-1 ref. 1Y-10-141-xx-1 (refer to page 35) Dimensions in mm POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NUMBER OF WAYS XX YES YES 1 02 ➞ 25 HOUSING SERIES 4E xx ■ This housing is used with double row walled headers (refer to page 35). ■ It allows polarization and locking. Mates with walled headers ref. 1Y-20-111-xx-1 ref. 1Y-20-141-xx-1 (refer to page 35) Dimensions in mm POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NUMBER OF WAYS XX YES YES 2 04 ➞ 50 23 CRIMPFLEX® housings HOUSING SERIES 1E xx ■ This housing is designed to mate to industry standard walled connectors. ■ It allows polarization and locking. POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NUMBER OF WAYS XX YES YES 1 02 ➞ 25 Dimensions in mm HOUSING SERIES 7F10 xx ■ The low height of this housing allows right angle connection in high density packaging. ■ Housings are side to side and end to end stackable. 24 POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NUMBER OF WAYS XX NO NO 1 02 ➞ 25 Dimensions in mm CRIMPFLEX® housings HOUSING SERIES OL xx ■ Industry standard locking system that allows easy mating and unmating to a walled pin header. ■ Optional : alternate part available on request to allow for latch to be oriented in either direction. Mates with Male headers ref. 1L-10-111-xx-1 ref. 1L-10-141-xx-1 (refer to page 37) 1,27 3,3 3,2 2,54 2,5 For ref. OL02 and OL03, only one guide Dimensions in mm POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NUMBER OF WAYS XX YES YES 1 02 ➞ 25 HOUSING SERIES OM xx ■ Industry standard locking system that allows for easy mating and unmating to a walled pin header. ■ The location of the latch is different from housing series OL in order to ensure a total compatibility with the different versions available on the market. ■ Optional : alternate part available on request to allow for latch to be oriented in either direction. Mates with Male headers ref. 1L-10-111-xx-1 ref. 1L-10-141-xx-1 (refer to page 37) 1,27 3,3 3,2 2,54 2,5 For ref. OM02 and OM03 : only one guide Dimensions in mm POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NUMBER OF WAYS XX YES YES 1 02 ➞ 25 25 CRIMPFLEX® housings HOUSING SERIES OP xx 3,3 3,2 ■ Industry standard polarization feature. ■ Optional : contacts can be inserted on the guide side and on the opposite side to the guide, from 4 to 25 ways. 2,5 For ref. OP03, only one guide POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NUMBER OF WAYS XX YES NO 1 02 ➞ 25 Dimensions in mm HOUSING SERIES OD xx 2 3,2 ■ Industry standard polarization feature. ■ Optional : contacts can be inserted on the opposite side to the latch, from 4 to 25 ways. 1,2 2,5 26 POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NUMBER OF WAYS XX YES YES 1 03 ➞ 25 Dimensions in mm CRIMPFLEX® housings HOUSING SERIES 1L xx ■ This housing allows industry standard polarization. ■ It allows the locking of OM/OL xx female references (refer to page 25). ■ Use with all square male pins. (N-1) x 2,54 22,9 (N) x 2,54 2,6 1 4,6 1,6 9,9 7° 6,4 Dimensions in mm 1,8 POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NUMBER OF WAYS XX YES YES 1 02 ➞ 25 HOUSING SERIES 1P xx ■ This housing allows the locking of OP xx industry standard polarized housing (refer to page 26). ■ This housing is available by special order only. Pas 2,54 2,3 (N -1) x 2,54 2,3 (N) x 2,54 1 4,6 2,6 9,9 22,9 1 4,6 Dimensions in mm POLARIZATION LOCKING SYSTEM NUMBER OF ROWS NUMBER OF WAYS XX YES NO 1 02 ➞ 25 27 CRIMPFLEX® presses Other documents : product data sheet & CrimpFlex® Crimping Guidelines Typical MANUAL PRESS REF. 10025-MO Substrate Conductor GENERAL DATA ■ ■ ■ ■ Dimensions without reel (L x w x h) : 79 x 40 x 54 cm. Dimensions with reel (L x w x h) : 99 x 40 x 61 cm. Net weight : 27 kg, Gross weight : 38 kg. Approximate capacity : 7 cycles / minute. OPERATION ■ The contacts are moved forward from stop to stop by hand via the side loader. ■ The graduated positions correspond to the number of contacts to crimp (1 to 25 points). ■ The crimping is operated manually via the upper lever. TOOLING ■ This machine is delivered with 2 different toolings for solder tabs, male and female contacts. The change of tooling is simple and quick. ■ 10025-MO (male & female tooling) - 10025-MO-F (female tooling) - 10025-MO-M (male tooling) ■ Manual Press ref. 10025-SP is especially made for square male contacts 12410 and 13756. TOOLING PART NUMBERS 10025-MOM MALE 10141 – 10241 – 10067 – 10167 – 12887 10025-MOF FEMALE 10025 – 11506 – 11612 – 13595 – 14106 SQUARE MALE 12410 – 13756 PRESS 10025-MO 10025-SP 28 CRIMPFLEX® presses Other documents : product data sheet & CrimpFlex® Crimping Guidelines PNEUMATIC PRESS REF. 10500-SA(P) GENERAL DATA ■ ■ ■ ■ ■ ■ ■ Dimensions without reel (L x w x h) : 83 x 44 x 61 cm. Dimensions with reel (L x w x h) : 103 x 44 x 61 cm. Packaging dimensions (L x w x h) : 84 x 40 x 57 cm. Net weight : 57 kg, Gross weight : 85 kg. Air pressure of 6 bars : dry air recommended, gauge G1/4. No electrical requirement. Approximate capacity : 30 cycles / minute. OPERATION ■ From 1 to 36 contacts are crimped at one time. The number of contacts to be crimped is determined by turning a dial on the front of the machine. ■ This machine is also equipped with a downcounter which allows to pre-select a precise number of operations and stops automatically once it is back to zero. ■ The press is operated by foot pedal. TOOLING ■ The machine can be delivered with three different tooling : one for male solder tabs, one for female contacts and one for square male pins. ■ The change of tooling is simple and quick. PRESS 10500-SA 10500-SAP TOOLING PART NUMBERS MALE 10141 – 10241 – 10067 – 10167 – 12887 FEMALE 10025 – 11506 – 11612 – 13595 – 14106 SQUARE MALE 12410 – 13756 MALE 10141 – 10241 – 10067 – 10167 – 12887 FEMALE 10025 – 11506 – 11612 – 13595 – 14106 29 S RoH nt ia l p com Jumper Cables ✓ TECHNICAL DATA ■ The flat cables used for NICOMATIC flexcable jumpers equipped with CRIMPFLEX® connectors, are made of two flat copper conductor laminated between two layers of polyester / adhesive insulation. DIMENSIONS ■ Bare copper conductors, section 1.57mm (width) x 0.076mm (thickness). ■ Pitch : 2.54 mm. ■ Number of conductors : 2 to 36*. ■ Insulators thickness : 0.1 mm. * Higher number of conductors are available by special request ELECTRICAL SPECIFICATIONS ■ ■ ■ ■ Operating voltage Withstand voltage AC current rating per conductor Resistance 300 V RMS 1100 V RMS 3A 160 ⍀ /Km CERTIFICATES ■ UL E 235596 / UL E 232912 / UL E 203388 (Appliance Wiring Material - Component) THERMAL SPECIFICATIONS - 55° C to + 105° C VW-1 ■ CABLE ■ UL Flame rating MECHANICAL SPECIFICATIONS 0 = once 25 mm = 10 million cycles ■ Flex life JUMPER CABLE CODES FOR PART NUMBERING SYSTEM ON PAGE 31 HOUSINGS TABLE CONTACTS TABLE CODE F1 F2 F3 F4 F5 F6 M1 M3 PART NUMBER 10025-12 10025-32 11506-12 11506-32 14106-12 14106-32 13595-12 12410-12 CODE M4 S1 S2 S3 S4 S5 S6 PART NUMBER 12410-32 10241-12 10141-12 10167-12 10067-12 12887-12 11612-12 CODE V PART NUMBER N OF xx D PART NUMBER H 1L xx CODE OM xx 2 7 2E xx 7F10 xx L OTHERS ALSO POSSIBLE P OL xx OP xx For Flex to discrete wire connection, please consult us. 30 1 OD xx 1E xx OTHERS ALSO POSSIBLE Jumper Cables Part Numbering System Using the CRIMPFLEX ® Connector System LEFT END 254 PW 14 E 0305 RIGHT END S1( BC )(WK)F2 L( BC )(WK)(R) Connector Style 254 – 2.54 mm ■ Pitch PW – Standard White Polyester (Tin Plating Standard) S1 – Standard Solder Tab, P/N 10241-12 S5 – Double Retention Solder Tab, P/N 12887-12 SOLDERTAB ■ ■ Style ■ FEMALE ■ Number of Conductors ■ ■ Conductor Size (Bare) E – 0.076 mm x 1.57 mm ■ Length in mm (Measured from End to End) ■ ■ ■ *F1X – High Insertion Force Female Contact, P/N 10025-12 *F2X – High Insertion Force Female Contact, Selective gold plating, P/N 10025-32 *F3X – Low Insertion Force Female Contact, P/N 11506-12 *F5X – Hi Flex Female Contact, P/N 14106-12 MALE PIN ■ ■ ■ *M1 –Short Square Male Pin, P/N 13595-12 *M3X– Long Square Male Pin, P/N 12410-12 *M4X– Long Square Male Pin, Selective gold plating, P/N 12410-32 *housing style must be specified, see below Options : B (-90° bending), C (+90° bending), K (polyimide insulator), R (crimping on the opposite side to the left), W (polyester insulator) B : Bending to the crimping direction HOUSING - X ■ H – Standard Housing, P/N OF-XX ■ L – Latching Housing, P/N OL-XX ■ 4 – Dual Row Housing, P/N 4F-XX ■ D – Detent Style Housing, P/N OD-XX ■ 7 – Low Profile Housing, P/N 7F10-XX ■ V – Latching Receptacle Housing, P/N 1L-XX — Other Options are Available, Please Contact the Factory or see page 30 — C : Bending to the opposite side 31 S RoH iant pl com FFC Card Cable ✓ TECHNICAL DATA 0.5 mm 1.00 mm 1.25 mm 1.27 mm 2.54 mm (N+1) 0.50 (N+1) (N+1) 1.25 (N+1) 1.27 (N+1) 2.54 Cable Thickness 0.22 0.25 0.25 0.25 0.25 Conductor Width 0.28 0.66 0.80 0.80 1.57 Conductor Thickness 0.035 0.076 0.076 0.076 0.076 Exposed Length 4 5 (4 for P8) 5 (4 for P8) 5 (4 for P8) 5 (4 for P8) Stiffener Length 6 (2 for P8) 10 (2 for P8) 10 (2 for P8) 10 (2 for P8) 10 (2 for P8) 0.30 0.30 0.30 0.30 0.30 Polyester Polyester Polyester Polyester Polyester 90 V 90 V 300 V 300 V 300 V -55°C to105°C -55°C to105°C -55°C to105°C -55°C to105°C -55°C to105°C VW-1 VW-1 VW-1 VW-1 VW-1 5,000 V 5,000 V 5,000 V 5,000 V 5,000 V 5,000 MΩ 5,000 MΩ 5,000 MΩ 5,000 MΩ 5,000 MΩ Pitch Cable Width Mating Thickness (P3, P5) Insulation Voltage Temperature UL Flame Rating Dielectric Strength Insulation Resistance • All dimensions in mm • ■ Style P3 Shown 32 FFC Card Cable Part Numbering System LEFT END 100 050 100 125 127 254 – – – – – 0.50 1.00 1.25 1.27 2.54 ■ Pitch P3 mm mm mm mm mm ■ Style 14 D 0305 - RIGHT END 5 10 5 10 ■ Exposed length in mm ■ Stiffener length in mm ■ Length in mm (Measured from End to End) P3 P5 Conductor Size (Tinned) P7 P7 A – 0.076 mm x 1.57 mm C– 0.076 mm x 0.80 mm D– 0.076 mm x 0.66 mm P8 K – 0.035 mm x 0.28 mm Pitch (mm) 2.54 1.25/1.27 1.00 0.50 ■ Number of Conductors ■ Style P3, P5 ■ Style P7, P8 — Other Options are Available, Please Contact the Factory — 33 Headers and Sockets STANDARD TECHNICAL DATA ■ 0.635 mm (.025ʼʼ) square pin header PLATING ■ Ni 2µ + Sn 5µ or gold plated ■ 2.54 mm (.100ʼʼ) pitch and multiple INSULATOR ■ Glass filled plastic UL 94V-0 ■ Number of ways on request MECHANICAL ENDURANCE INSERTION FORCE ■ Au = 500 ■ Sn = 50 ■ 1.5 max. ■ 3N max. ELECTRICAL SPECIFICATIONS ■ Contact resistance ■ AC current rating per contact ■ Min. withstanding voltage ■ Min. insulation resistance 20 m ⍀ 3A 500V eff. 1000M ⍀ THERMAL SPECIFICATIONS ■ Operating temperature -40°C to +150°C STRAIGHT SINGLE AND DOUBLE ROW Dimensions in mm REF. PLATING 12-17-141-XX-1 Tin plated NUMBER OF CONTACTS XX Gold plated 16-17-141-XX-1 Tin plated 02 ≤ XX ≤ 40 Gold plated 04 ≤ XX ≤ 80 12-17-111-XX-1 16-17-111-XX-1 02 ≤ XX ≤ 40 04 ≤ XX ≤ 80 RIGHT ANGLE SINGLE AND DOUBLE ROW Dimensions in mm REF. PLATING 12-21-241-XX-1 Tin plated NUMBER OF CONTACTS XX Gold plated 16-52-241-XX-1 Tin plated 02 ≤ XX ≤ 40 Gold plated 04 ≤ XX ≤ 80 04 ≤ XX ≤ 80 12-21-211-XX-1 16-52-211-XX-1 34 02 ≤ XX ≤ 40 Headers and Sockets WALLED HEADERS STRAIGHT SINGLE AND DOUBLE ROW Dimensions in mm REF. PLATING NUMBER OF CONTACTS XX 1Y-10-141-XX-1 Tin plated Gold plated 1Y-20-141-XX-1 Tin plated 02 ≤ XX ≤ 20 Gold plated 04 ≤ XX ≤ 40 1Y-10-111-XX-1 1Y-20-111-XX-1 02 ≤ XX ≤ 20 04 ≤ XX ≤ 40 RIGHT ANGLE SINGLE AND DOUBLE ROW Dimensions in mm REF. PLATING 1Y-10-241-XX-1 Tin plated NUMBER OF CONTACTS XX Gold plated 1Y-20-241-XX-1 Tin plated 02 ≤ XX ≤ 20 Gold plated 04 ≤ XX ≤ 40 1Y-10-211-XX-1 1Y-20-211-XX-1 02 ≤ XX ≤ 20 04 ≤ XX ≤ 40 35 Headers and Sockets ■ Strongs tails : the contact is firmly retained in the PCB holes thus allowing the solder to ascend. STANDARD AND LOW PROFILE SINGLE AND DOUBLE ROW Dimensions in mm REF. PLATING 8Y-10-131-XX-1 Tin plated NUMBER OF CONTACTS XX Selective gold plated 8Y-20-131-XX-1 Tin plated 02 ≤ XX ≤ 40 Selective gold plated 04 ≤ XX ≤ 80 8Y-10-111-XX-1 8Y-20-111-XX-1 02 ≤ XX ≤ 40 04 ≤ XX ≤ 80 DOUBLE ROW DUAL ENTRY ou 7 Dimensions in mm REF. 3Y-20-311-XX-1 PLATING Tin plated 3Y-20-331-XX-1 Selective gold plated 36 5.08 or 7.62 NUMBER OF CONTACTS XX PITCH 04 ≤ XX ≤ 80 7.62 04 ≤ XX ≤ 80 7.62 Male Headers STRAIGHT HEADER 1L-10-1Z1-XX-1 ■ It allows the locking of OL xx, OM xx and OP xx housings (refer to page 25 and 26). 3 2,3 (N-1) x 2,54 2,3 9,9 11,2 7° Dimensions in mm 1,6 4,6 6,4 REF. PLATING NUMBER OF CONTACTS XX 1L-10-141-XX-1 gold plated 02 ≤ XX ≤ 25 1L-10-111-XX-1 tin plated 02 ≤ XX ≤ 25 RIGHT ANGLE HEADER 1L-10-2Z1-XX-1 ■ It allows the locking of OL xx, OM xx and OP xx housings (refer to page 25 and 26). 3 7° 4,6 6,4 Dimensions in mm 1,6 11 9,9 11,2 2,3 (N-1) x 2,54 2,3 REF. PLATING NUMBER OF CONTACTS XX 1L-10-241-XX-1 gold plated 02 ≤ XX ≤ 25 1L-10-211-XX-1 tin plated 02 ≤ XX ≤ 25 37 Index Numerical search Part numbers 11506 10025 14106 12410 13756 13595 10141 10241 10067 10167 12887 11612 OF 4F 2E 4E 1E 7F10 OL OM OP OD 1L 1P 10025 - MO 10500 - SA 1L-10-1Z1-XX-1 1L-10-2Z1-XX-1 38 Page 6 7 8 10 11 12 14 15 16 17 18 19 22 22 23 23 24 24 25 25 26 26 27 27 28 29 37 37 Alphabetical search Part numbers 10025 10025-MO 10067 10141 10167 10241 10500-SA 11506 11612 12410 12887 13595 13756 14106 1E 1L 1L-10-1Z1-XX-1 1L-10-2Z1-XX-1 1P 2E 4E 4F 7F10 OD OF OL OM OP Page 7 28 16 14 17 15 29 6 19 10 18 12 11 8 24 27 37 37 27 23 23 22 24 26 22 25 25 26 Notes 39 Notes 40 A world of interconnect and switching solutions YEARS OF EXPERTISE IN THE CONNECTOR INDUSTRY AT YOUR DISPOSAL From its origin in 1976 as a micro screw machining manufacturer, NICOMATIC has taken advanage of its precision know-how to specialize in the development, design and manufacture of electronic connectors and metal dome switching technology for membrane switches and mobile phones. Activity sector : Electronic Passive Components Specialties : Connectors and metal domes. Our production capabilities include everything from low volume high technology products to mass production of precision components for the consumer markets. CMM MICRO-CONNECTORS 2 mm pitch connectors CMM series 100/200/220/320/340 (signal, high power, coax, connected shieldings, backpotting shapes…) Special contact series HF/HP 30 and 22 High frequency coax contacts High power contacts CONNECTORS FOR PRINTED CIRCUIT BOARDS Headers and Sockets SMD test points Discrete wire to flat cable connection Pins, shunts and eyelets SWITCH’AIR® DOMES AND ARRAYS OF DOMES Four-legged non-stick domes and round domes Semi-automatic and automatic dome placement machines (up to 5 000 domes per hour) UltraThin LEDs & adhesive spacers for membrane switches SPECIFIC DEVELOPMENTS All parts requiring screw machining, cutting, moulding, and assembly know-how. JAN 2016 Reference catalogue : C.CS.1000/GB NICOMATIC maintains a policy of ongoing development and improvement. It therefore reserves the right to change design, dimensions and specifications without notice. All information stated inside this catalogue is not contractual and subject to change. Copyright 2007 by NICOMATIC (All Rights Reserved). NICOMATIC - FRANCE Headquarters : NICOMATIC SA 173, rue des Fougères - Zone Industrielle les Bracots - F-74890 BONS-EN-CHABLAIS Tel. (33) (0)4 50 36 13 85 - Fax (33) (0)4 50 36 11 33 http://www.nicomatic.com - Email : nicomatic@nicomatic.fr NICOMATIC - SUBSIDIARIES NICOMATIC HONG-KONG CHINA - TAIWAN - HONG-KONG 38-44, D’Aguillon Street Ho Lee Commercial Building 5 th Floor Central HONG-KONG Tel. (886) 42201-6456 Fax (886) 42202-6456 Email : viragetw@tcts.seed.net.tw NICOMATIC KOREA 9F Saehan Venture World. 113-15 Siheung Dong, Kumchun-Ku SEOUL Tel. (82) 2 804 3206 Fax (82) 2 806 3206 Email : nicoree@unitel.co.kr NICOMATIC SOUTH AMERICA Rua Hungria, 574 cj. 51 Jd. Europa 01455-000 SÃO PAULO - SP Tel : (55) 11 3815-4411 Fax : (55) 11 3814-6133 Email : nicomatic@nicomatic.com.br NICOMATIC NORTH AMERICA USA - CANADA - MEXICO 165 Veterans Way, Unit 200 WARMINSTER, PA 18974 USA Tel. (1) 215 444-9580 Fax (1) 215 444-9581 Email : sales@nicomatic.net For more information about the NICOMATIC distribution network, please visit our web site http://www.nicomatic.com NICOMATIC FRANCE IS CERTIFIED 9001:2000
1Y20141101 价格&库存
很抱歉,暂时无法提供与“1Y20141101”相匹配的价格&库存,您可以联系我们找货
1Y20141101
