101Y03L
101Y03L
    NICOMATIC
101Y03L 数据手册
A B C D TECHNICALS FEATURES ±0.10 3 ±0.10 5.6 Last LF contact 3.5 4 (3.2) First LF contact Pitch=2 A ±0.05 (2.7) (A) (2.7) C SIGNAL CONTACTS for PCB: Male :  Contact area  Contact tail  1 Latch (optional) Beryllium alloy / Ni 3µ 4.1  All contacts     Working voltage (sea level) Proof voltage Contact resistance (initially) Insulation resistance 3 A max. @ 25°C 2.2 A max. @ 85°C Tested at 800 V DC Tested at 1200 V DC max. 10 mΩ 1000 MΩ min 3 (8) MECHANICAL for LF Contacts   Mechanical operations 500 cycles min. up to 2500. Contact insertion and withdrawal force 2 N max. / 0.2 N min. ENVIRONMENTAL   Temperature range Vibration severity     Shock severity Solvent resistance Salt spray test Humidity test From -60°C to +260°C 0.75mm, 10 g RMS 6 hours long random with superimposed sinusoid. No intermittencies measured when using an H.S.L.I. (High Speed Logic Interrupt) detector with a trip threshold of 2 ns. 100g for 6 ms HcFc 141 bMGX (ATOCHEM) solvent 96 hrs 56 days @ 90% humidity Recommended PCB layout : 0.9 min. nn x 0.65 min. First LF contact 2 Pitch=2 A B (2.35) (2.35) Marking as referenced in the CMM catalogue pages 12 & 13 2 09/12/08 Iss Tools recommended Latch Separation tool P/N C14790 Strain relief straps P/N 13218 This document and drawings, sketches, and schematic drawings are the property of the NICOMATIC company. and no parts thereof may be reproduced and used without the written consent of the owner. Law dated 11.03.1902 D ±0.05 ±0.05 = = C 7.4 9.4 11.4 13.4 15.4 17.4 19.4 21.4 23.4 25.4 27.4 29.4 31.4 33.4 35.4 37.4 39.4 41.4 43.4 45.4 47.4 49.4 51.4 53.4 Copper alloy / Ni + Au 1µ Copper alloy / Ni + Au flash 0.1µ ELECTRICAL for LF Contacts 0.2 2 B 6.7 8.7 10.7 12.7 14.7 16.7 18.7 20.7 22.7 24.7 26.7 28.7 30.7 32.7 34.7 36.7 38.7 40.7 42.7 44.7 46.7 48.7 50.7 52.7 ±0.10 0.54 0.5 4.8 3 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 B Length without Latches in mm A 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 Radiation resistance No humidity absorption Oxygen free FIXING HARDWARE : CONNECTOR SERIE 100 MALE LF contact number nn 4 Note : PPS characteristics are recognized for space applications A 0.5 L : latches fitted Leave blank : no latches The strain relief straps are only sold separately. They are not delivered mounted on connectors. INSULATOR : Special PPS (Polyphenylene Sulfide Fiberglass filled thermoplastic) UL 94-V0    Strain relief straps CUT A-A MATERIAL Catalogue Reference : Date H.L. Drawn E.M. Checked D.Z. Approved www.nicomatic.com Item : Connector CMM100 male straight Mail : nicomatic@nicomatic.fr 1 on PCB, nn pts, latch L in option Tel : +33 (0)4.50.36.13.85 Folder : X:\Méthodes\Plans clients\Plans clients 2D\07 - CMM100\Connecteurs Mâles\101Y\101Ynn(L)_cl General ±0.2 Scale Page 2:1 1/1 tolerance 101Ynn(L) A4
101Y03L 价格&库存
很抱歉,暂时无法提供与“101Y03L”相匹配的价格&库存,您可以联系我们找货
101Y03L
