202S10
202S10
    NICOMATIC
    2 ROWS FEMALE CRIMP 24-28 AWG 10 PIN
202S10 数据手册
A B C D TECHNICALS FEATURES MATERIAL 7.50 ±0.10 4 First LF contact D F (3.10) E Last LF contact G A INSULATOR : Special PPS (Polyphenylene Sulfide Fiberglass filled thermoplastic) UL 94-V0    4 Radiation resistance No humidity absorption Oxygen free CUT A-A 1.60 5.50 ±0.10 Pitch=2 Note : PPS characteristics are recognized for space applications A (2.50) Pitch=2 A (2.50) CRIMPING SIGNAL CONTACTS : Female :  Body  Socket body Copper alloy / Ni + Au 0.2µ Beryllium copper / Ni + Au 1.25µ ELECTRICAL for LF Contacts 3 LF contact number nn CONNECTOR SERIE 200 FEMALE A C D E F All contacts     Working voltage (sea level) Proof voltage Contact resistance (initially) Insulation resistance 3 A max. @ 25°C 2.2 A max. @ 85°C Tested at 800 V DC Tested at 1200 V DC max. 10 mΩ 1000 MΩ min     G Mechanical operations Contact insertion and withdrawal force Contact retention in insulator Contact replacement in insulator 500 cycles min. up to 2500 2 N max. / 0.2 N min. 10 N min. 3 cycles 2 1 04 2 7 1 2 3 4 C ENVIRONMENTAL 06 4 9 1 3 4 6 08 6 11 1 4 5 8  Temperature range From -60°C to +260°C  Vibration severity 0.75mm, 10 g RMS 6 hours long random 10 8 13 1 5 6 10 with superimposed sinusoid. No intermittencies 12 10 15 1 6 7 12 measured when using an H.S.L.I. LF contact 14 12 17 1 7 8 14 (High Speed Logic Interrupt) detector with a to crimp or to solder trip threshold of 2 ns. 16 14 19 1 8 9 16 Conductor 0.7  Shock severity 100g for 6 ms "S" AWG24-28 18 16 21 1 9 10 18  Solvent resistance HcFc 141 bMGX (ATOCHEM) solvent scale : 5 : 1 Jacket 20 18 23 1 10 11 20  Salt spray test 96 hrs  Humidity test 56 days @ 90% Humidity 22 20 25 1 11 12 22 24 22 27 1 12 13 24 26 24 29 1 13 14 26 AWG 24-28 28 26 31 1 14 15 28 3D view 30 28 33 1 15 16 30 2 scale: 2:1 32 30 35 1 16 17 32 1.1 max. 34 32 37 1 17 18 34 Crimping following cable instruction ICLF 01 36 34 39 1 18 19 36 Marking as referenced in the CMM catalogue pages 12 & 13 38 36 41 1 19 20 38 E.M. D.Z. 2 23/03/09 H.L. Tools recommended 40 38 43 1 20 21 40 42 40 45 1 21 22 42 LF contacts insertion & withdrawal tool P/N C12935 Drawn Checked Approved Date Iss www.nicomatic.com 44 42 47 1 22 23 44 Recommended hand crimp tool P/N MH800 Item : Connector CMM200 female to crimp or to solder Mail : nicomatic@nicomatic.fr 46 44 49 1 23 24 46 Recommended positionner K 1692 P/N C12929 AWG 24-28, nn LF contacts Tel : +33 (0)4.50.36.13.85 48 46 51 1 24 25 48 AWG24 crimp tool setting Position 7 50 48 53 1 25 26 50 AWG26 & AWG28 crimp tool setting Position 6 Folder : X:\Méthodes\Plans clients\Plans clients 2D\08 - CMM200\Connecteurs femelles\202S\202Snn_cl This document and drawings, sketches, and schematic drawings are the property of Scale Page General the NICOMATIC company. and no parts thereof may be reproduced and used without Catalogue 2:1 1/1 Reference : tolerance the written consent of the owner. Law dated 11.03.1902 202Snn D 3 MECHANICAL for LF Contacts Signal contacts reference mark number Length in mm  ±0.2 A4 2 1
202S10 价格&库存
很抱歉,暂时无法提供与“202S10”相匹配的价格&库存,您可以联系我们找货
