321Y048F42H
321Y048F42H
    NICOMATIC
321Y048F42H 数据手册
Pitch=2 E G Last LF contact J ±0.10 (3.8) A B C D 6.1 First LF contact D F H A Pitch=2 TECHNICALS FEATURES MATERIAL ±0.10 = = CUT A-A 7.7 4 INSULATOR : Special PPS (Polyphenylene Sulfide Fibreglass filled thermoplastic) UL 94-V0    4 Radiation resistance No humidity absorption Oxygen free 3 (4.5) (A) 1 D E F G H J 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 64 66 68 70 72 74 76 78 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 61 63 65 67 69 71 73 75 77 79 81 83 85 87 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 61 63 65 67 69 71 73 75 77 79 81 83 85 87 89 91 93 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 64 66 68 70 72 74 76 78 80 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 49 51 53 55 57 59 61 63 65 67 69 71 73 75 77 79 81 6 9 12 15 18 21 24 27 30 33 36 39 42 45 48 51 54 57 60 63 66 69 72 75 78 81 84 87 90 93 96 99 102 105 108 111 114 117 120 0.54 M2 ±0.05   All contacts     Working voltage (sea level) Proof voltage Contact resistance (initially) Insulation resistance 3 3 A max. @ 25°C 2.2 A max. @ 85°C Tested at 800 V DC Tested at 1200 V DC max. 10 mΩ 1000 MΩ min MECHANICAL for LF Contacts (3)   B ±0.10 Recommended PCB layout : 0.65 min. Pitch=2 Pitch=2 Mechanical operations Contact insertion and withdrawal force (4.5) Pitch=2 (A) B 500 cycles min. up to 2500. 2 N max. / 0.2 N min. per contact ENVIRONMENTAL (3) C nnn x Jackscrew : Stainless steel ELECTRICAL for LF Contacts M2 This document and drawings, sketches, and schematic drawings are the property of the NICOMATIC company. and no parts thereof may be reproduced and used without the written consent of the owner. Law dated 11.03.1902 D Hex.4 4 C 0.5 B Copper alloy / Ni + Au 1µ Copper alloy / Ni + Au flash 0.1µ FIXING HARDWARE : First LF contact   Temperature range Vibration severity     Shock severity Solvent resistance Salt spray test Humidity test = = 2 A Fixing Hardware F42H 1.6 LF contacts reference m ark num ber Length in m m SIGNAL CONTACTS for PCB: Male :  Contact area  Contact tail 4.5 nnn LF contact number 3 006 009 012 015 018 021 024 027 030 033 036 039 042 045 048 051 054 057 060 063 066 069 072 075 078 081 084 087 090 093 096 099 102 105 108 111 114 117 120 Distance betw een the axies in m m ±0.10 ±0.05 B CONNECTOR SERIES 320 MALE (4.5) Connector support face Pitch=2 Note : PPS characteristics are recognized for space applications A 2x 2.2 From -60°C to +260°C 0.75mm, 10 g RMS 6 hours long random with superimposed sinusoid. No intermittencies measured when using an H.S.L.I. (High Speed Logic Interrupt) detector with a trip threshold of 2 ns. 100g for 6 ms HcFc 141 bMGX (ATOCHEM) solvent 96 hrs 56 days @ 90% humidity 2 3D view scale: 1.5:1 min. (4.5) Marking as referenced in the CMM catalogue pages 12 & 13 2 04/11/08 www.nicomatic.com Mail : nicomatic@nicomatic.fr Tel : +33 (0)4.50.36.13.85 Iss Date G.C. Drawn E.M. Checked D.Z. Approved Item : Connector CMM320 male straight on PCB, nnn pts, F42H 1 Folder : X:\Méthodes\Plans clients\Plans clients 2D\24 - CMM320\Connecteur Mâles\321Y\321YnnnF42H_cl Catalogue Reference : 321YnnnF42H General tolerance ±0.2 A4 Scale 1:1 Page 1/1
321Y048F42H 价格&库存
很抱歉,暂时无法提供与“321Y048F42H”相匹配的价格&库存,您可以联系我们找货
