201Y10L
201Y10L
    NICOMATIC
201Y10L 数据手册
A B C D TECHNICALS FEATURES ±0.10 3 Last LF contact G Pitch=2 A First LF contact D ±0.10 (3.2) ±0.05 CUT A-A 0.5 L : Latches fitted Leave blank : no Latches The strain relief straps are only sold separately. They are not delivered mount on connectors. (2.7) (A) (2.7) C 4 Radiation resistance No humidity absorption Oxygen free SIGNAL CONTACTS for PCB: Male :  Contact area  Contact tail Copper alloy / Ni + Au 1µ Copper alloy / Ni + Au flash 0.1µ FIXING HARDWARE :  Latch (optional) Beryllium alloy / Ni 3µ ELECTRICAL for LF Contacts Signal contacts reference mark number B ±0.10  All contacts     Working voltage (sea level) Proof voltage Contact resistance (initially) Insulation resistance 3 3 A max. @ 25°C 2.2 A max. @ 85°C Tested at 800 V DC Tested at 1200 V DC max. 10 mΩ 1000 MΩ min 1 B C D E F G 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 6.7 8.7 10.7 12.7 14.7 16.7 18.7 20.7 22.7 24.7 26.7 28.7 30.7 32.7 34.7 36.7 38.7 40.7 42.7 44.7 46.7 48.7 50.7 52.7 7.4 9.4 11.4 13.4 15.4 17.4 19.4 21.4 23.4 25.4 27.4 29.4 31.4 33.4 35.4 37.4 39.4 41.4 43.4 45.4 47.4 49.4 51.4 53.4 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 4 6 MECHANICAL for LF Contacts 8  Mechanical operations 500 cycles min. up to 2500. 10  Contact insertion and withdrawal force 2 N max. / 0.2 N min. 12 ENVIRONMENTAL 14  Temperature range From -60°C to +260°C 16  Vibration severity 0.75mm, 10 g RMS 6 hours long random with superimposed sinusoid. No intermittencies 18 measured when using an H.S.L.I. 20 (High Speed Logic Interrupt) detector with a trip threshold of 2 ns. Recommended PCB layout: 22 2  Shock severity 100g for 6 ms nn x 0.65 min.  Solvent resistance HcFc 141 bMGX (ATOCHEM) solvent Pitch=2 24  Salt spray test 96 hrs 26  Humidity test 56 days @ 90% humidity 28 30 Pitch=2 4 x 0.9 min. 32 (2.35) (A) (2.35) 34 36 B 38 Marking as referenced in the CMM catalogue pages 12 & 13 40 E.M. D.Z. 2 04/03/09 H.L. 42 Drawn Checked Approved Iss Date 44 www.nicomatic.com Item : 46 Connector CMM200 male straight Mail : nicomatic@nicomatic.fr Tools recommended 1 on PCB, nn LF contacts 48 Latch Separation tool Tel : +33 (0)4.50.36.13.85 P/N C14790 50 Strain relief straps P/N 13218 Folder : X:\Méthodes\Plans clients\Plans clients 2D\08 - CMM200\Connecteurs mâles\201Y\201Ynn(L)_cl This document and drawings, sketches, and schematic drawings are the property of the NICOMATIC company. and no parts thereof may be reproduced and used without the written consent of the owner. Law dated 11.03.1902 D ±0.05 0.5 ±0.05 (8) 0.5 == 0.2 2 A 4.8 = = LF contact number nn 3 04 06 08 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 INSULATOR : Special PPS (Polyphenylene Sulfide Fiberglass filled thermoplastic) UL 94-V0 Note : PPS characteristics are recognized for space applications A CONNECTOR SERIE 200 MALE Length without Latches in mm MATERIAL    5.5 4 Pitch=2 5.6 Catalogue Reference : 201Ynn(L) General tolerance ±0.2 A4 Scale 2:1 Page 1/1
201Y10L 价格&库存
很抱歉,暂时无法提供与“201Y10L”相匹配的价格&库存,您可以联系我们找货
201Y10L
