MAY 2011 - non contractual document – NICOMATIC reserves the right to discontinue the production or to change the specifications of any part of this data sheet without prior notice - ©
NICOMATIC SA (HEADQUARTERS)
173, rue des Fougères - ZI Les Bracots
F-74890 Bons-en-Chablais
Téléphone: +33 4 50 36 13 85 – Fax: +33 4 50 36 11 33
NICOMATIC is certified
ISO9001:2008 / EN9100:2003
C12000
SMD
TEST TERMINAL
The PCB industry has moved irresistibly towards surface mounted components technology. The components are
mounted on the circuit board without piercing it. NICOMATIC SMD test terminals are supplied on reeled tapes
specifically designed for distribution by a Pick & Place machine like any other SMD component.
The C12000 test terminal is used to test zones on PCBs, separately or by comparison with another.
C12000 are designed to attach a large range of probes, test probes, oscilloscope probes at key points...
ADVANTAGES
Saves time on mounting by avoiding:
- PCB piercing
- Hole plating
- Manual insertion and soldering of traditional test pins
No specific test probe needed
Can be used as zero resistance
No special compartment needed on auto-placing machines
FEATURES
MATERIAL
Copper alloy, RoHS compliant
PLATING
Tin plating over nickel and copper
composition: Cu 2μ + Ni 1 to 2μ + Sn 3 to 5μ
(pure tin bright with nickel under layer)
Also available in gold: Cu 2μ + Ni 1 to 2μ + Gold flash
ORDERING INFORMATION
Packaging in reel:
2 000 components: P/N C12000B
8 500 components: P/N C12000B-8500
2 000 components*: P/N C12000BG
(Top cover tape and embossed carrier)
*gold version
NICOMATIC INDIA
NICOMATIC CHINA
NICOMATIC NORTH AMERICA
NICOMATIC SOUTH AMERICA
th
Av.Brigadeiro Faria Lima,
165 Veterans Way,
6A XEDA Jimei Industrial Park #21, 5 Floor, SK Vista, Rustam Bagh,
2.639 – 10a Jardim Paulistano
Unit 200
Xiqing Economic & Dvpt Area Old Airport Rd, Behind Manipal Hospital
Bangalore - 560017 - INDIA
01452-000 Sao Paulo – SP - BRAZIL
Tianjin – CHINA
Warminster, PA 18974 - USA
Phone: +91-80-30468361
Phone : (55) 11 3815-4411
Phone: (215) 444-9580
Phone: (86) 22 238 88 050
Fax: +91-80-30758990
Fax: (55) 11 3814-6133
Fax: (86) 22 238 88 060
Fax: (215) 444-9581
e-mail: india@nicomatic.com
e-mail: sales@nicomatic.net e-mail: carlos.guimaraes@nicomatic.com.br
e-mail: sales@nicomatic.cn
www.nicomatic.com
