STUDIOPATCH
STUDIOPATCH SERIES
SERIES AUDIO
AUDIO PATCHBAYS
PATCHBAYS
NPB | 563C
5555 N ELSTON AVE | CHICAGO, IL 60630 | P: 773.792.2700 | F: 773.792.2129 | WWW.SWITCHCRAFT.COM
STUDIOPATCH
STUDIOPATCH SERIES
SERIES AUDIO
AUDIO PATCHBAYS
PATCHBAYS
NPB | 563C
GROUNDING
SWITCHES
Up = sleeves
vertically strapped
Down = sleeves
isolated
EZ NORM JACK
Change the signal
flow of each
channel from
(F) Full to (H) Half to
(N) Non-Normalled
with the twist of a
standard
screwdriver
StudioPatch® Series Audio Patchbays utilize Switchcraft’s EZ Norm
technology, allowing signal flow to be changed from the front of the
patchbay using a standard screwdriver.
Every StudioPatch® Series patchbay also comes with easy access
programmable grounds, making it possible to customize the ground
setting of each channel to either vertically strapped or isolated with
the flip of a switch.
DB25 I/O connections wired to the TASCAM DTRS pinout allow for
direct connection to today’s most popular audio interfaces and
outboard gear, creating greater flexibility in your studio.
StudioPatch® Series audio patchbays - featuring front-of-rack access
programmable normalling and easy access programmable grounds!
Other available accessories: DB25 Breakout Cables,
MULT Connectors and TT Patchcords
PLEASE VISIT WWW.SWITCHCRAFT.COM FOR THE MOST UP-TO-DATE PRODUCT SPECIFICATIONS.
MADE IN USA
STUDIOPATCH
STUDIOPATCH SERIES
SERIES AUDIO
AUDIO PATCHBAYS
PATCHBAYS
NPB | 563C
STUDIOPATCH® SERIES AUDIO PATCHBAY OPTIONS
StudioPatch® 9625 Patchbay
The 9625 is called out around the world as the patchbay of choice for professional
recording studios, broadcast facilities and mobile production units. It features
48 channels (96 TT/bantam jacks), DB25 I/O, front-of-rack access programmable
normalling and easy access programmable grounds all in 1RU!
Part Number: 9625
StudioPatch® 6425 Patchbay
The 6425 is ideal for fixed installation in studios where less patching is required
than a standard 48 channel patchbay. It features 32 channels (64 TT/bantam
jacks), DB25 I/O, front-of-rack access programmable normalling and easy access
Part Number: 6425
StudioPatch® 1625 TT Patch Module
The 1625 is a modular, eight channel patchbay perfect for desktop or mobile
applications where limited patching is required, or for building a full size
patchbay over time as your studio grows. The 1625RACK, a 1.5RU rack tray can
accommodate up to five 1625 patch modules.
Part Number: 1625
*1625RACK sold separately.
MADE IN USA
很抱歉,暂时无法提供与“1625”相匹配的价格&库存,您可以联系我们找货
