62HB7FX
62HB7FX
    SWITCHCRAFT
62HB7FX 数据手册
Sign In Search About Products Applications Resources Contact Home > Industrial Products > Connectors > DIN > DIN Panel Mount 3 to 8 pin DIN connectors which mount to PC boards. Plugs connect at right-angle to mounting surface. Shielded version has metal flange surrounding face of insert to provide through-grounding between plug and receptacle and to potential panel/chassis for common grounding. Male version features interlocking flanges for side-by-side row mounting. Questions? Contact Switchcraft Customer Support at 1-773-792-2700 Product 57GB3FX 57GB5FX Description DIN Panel Mount Connector, 3 contacts at 180° Downloads: Specification Sheet DIN Panel Mount Connector, 5 contacts at 180° Associated Products: 57HB3FX 57HB5FX DIN Panel Mount Connector, Female receptacle with ground contact, 5 contacts at 210°, flared solder terminals DIN Panel Mount Connector, Female receptacle with ground contact, 3 contacts at 180°, flared solder terminals Mini DIN Dual Right Angle 57NC5FX 60GB4FX 60HA4FX DIN Panel Mount Connector, 5 contacts at 180°, PC terminals Receptacles, DMD Series DIN Panel Mount Connector, 4 contacts at 210° DIN Panel Mount Connector, Female receptacle with ground contact, 4 contacts at 210° Locking DIN Cable Mount 60NC4FX 61GB5FX 61GB6FX 61HA5FX 61NC5FX 62GB7FX 62GB8FX DIN Panel Mount Connector, 4 contacts at 210°, PC terminals DIN Panel Mount Connector, 5 contacts at 240° DIN Panel Mount Connector, 6 contacts at 240° DIN Panel Mount Connector, Female receptacle with ground contact, 5 contacts at 240° DIN Panel Mount Connector, 5 contacts at 240°, PC terminals DIN Panel Mount Connector, 7 contacts at 270° DIN Panel Mount Connector, 8 contacts at 270° DIN Cable Mount 62HB7FX 62HB8FX 62NC7FX 62NC8FX DIN Panel Mount Connector, Female receptacle with ground contact,7 contacts at 270°, flared solder terminals DIN Panel Mount Connector, Female receptacle with ground contact, 8 contacts at 270°, flared solder terminals DIN Panel Mount Connector, 7 contacts at 270°, PC terminals DIN Panel Mount Connector, 8 contacts at 270°, PC terminals Switchcraft : 773-792-2700 Conxall : 630-834-7504 Home Support Contact Us Login
62HB7FX 价格&库存
很抱歉,暂时无法提供与“62HB7FX”相匹配的价格&库存,您可以联系我们找货
