EHRJ45D6SBM3
EHRJ45D6SBM3
    SWITCHCRAFT
    模块 耦合器 连接器 插孔,8p8c(RJ45) 至 插孔,8p8c(RJ45) Cat6 屏蔽
EHRJ45D6SBM3 数据手册
0.58 14.6 0.748 19.00 0.945 24.00 0.945 24.00 1.02 26.0 0.748 19.00 0.083 2.10 EHRJ45D6S SHOWN 1.18 30.0 0.93 23.6 0.13 3.3 MOUNTING FLANGE FINISH EHRJ45D6S EHRJ45D6SB EHRJ45D6S440 EHRJ45D6SB440 EHRJ45D6SM3 EHRJ45D6SBM3 NICKEL BLACK CHROME NICKEL BLACK CHROME NICKEL BLACK CHROME MOUNTING HOLE 0.138 [3.50] THRU-HOLE 0.138 [3.50] THRU-HOLE #4-40 THREAD #4-40 THREAD M3 X 0.5 THREAD M3 X 0.5 THREAD NOTES: 1. SHIPPED ASSEMBLED WITHOUT PANEL MOUNTING HARDWARE. ADD "PKG" SUFFIX TO INCLUDE MOUNTING SCREWS AND INDIVIDUAL PACKAGING. 2. MATERIALS: MOUNTING FLANGE - ZINC ALLOY, SEE TABLE FOR FINISH RJ45 BODY - THERMOPLASTIC, BLACK RJ45 SHIELD - COPPER ALLOY, NICKEL PLATED RJ45 CONTACTS - COPPER ALLOY, GOLD PLATED 3. SPECIFICATIONS: RJ45 CONNECTOR MEETS TIA/EIA-568 STANDARD. PHYSICAL CHARACTERISTICS INSERTION LIFE: 750 MATING CYCLES WITH FCC PLUG OPERATING TEMP: -10 C TO +60 C (14 F TO +140 F) ELECTRICAL INSULATION RESISTANCE: 500MOHM DIELECTRIC WITHSTANDING VOLTAGE: 1000V DC CURRENT RATING: 1.5 AMPS DC RESISTANCE: 0.1OHM CONTACT RESISTANCE: 20mOHM 4. THESE PRODUCTS ARE RoHS COMPLIANT. 0.138 [3.50] THRU 0.230 [5.84] x 82 (2) PLACES RECOMMENDED PANEL CUT-OUT REAR MOUNT ONLY 0.93 23.6 PART NUMBER RJ45 CONNECTOR MOUNTING FLANGE 1.22 31.0 1.00 25.4 0.945 24.00 CUSTOMER DRAWING MOUNTING HOLE (2) PLACES SEE TABLE THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES [mm] SIZE REV CREATED FOR PDR 18006 ECO NUMBER 6/21/19 DATE REVISIONS JGK BY - TWO PLACE DECIMALS 0.02 [0.5] - THREE PLACE DECIMALS 0.005 [0.13] 6/21/19 DO NOT SCALE DRAWING SolidWorks CAD File NAME TEMPER BY JGK SPEC No. SCALE 2:1 CHKD JGK 7/10/19 APVD TJK 7/10/19 METAL FLANGE, REAR MOUNT RJ45, CAT6 CONNECTOR, SHIELDED, RoHS B LBS/M MATERIAL SPEC No. FIRST USED ON * APVD MULT FINISH DATE DRAWN 0A WIDTH SHEET PART No. 1 OF EHRJ45D6S SERIES 1 REV 0A
EHRJ45D6SBM3 价格&库存
很抱歉,暂时无法提供与“EHRJ45D6SBM3”相匹配的价格&库存,您可以联系我们找货
EHRJ45D6SBM3
  • 1+245.143941+31.64324
EHRJ45D6SBM3
    • 1+254.77200
    • 200+101.66040
    • 500+98.26920
    • 1000+96.58440
