Harsh Environment Connectivity Solutions
Square Pushbutton Switches, BXR
Series
Economical momentary, non-illuminated
switches feature "Adjusto-Clip" snap-lock
mounting and selection of switching. Bezel trims
mounting and enclosed construction protects
against dust, dirt, and physical damage. Color
pushbuttons have concave face for positive
"feel".
MOUNTING
Front mount in .620 inch (15.75 mm) minimum square hole. Solder lug/quick-connect
terminals accept AMP FASTON® 110 terminals. "Adjusto-Clip" permits mounting in panels
from .047 inch (1.19 mm) to .281 inch (7.14 mm) thick.
® FASTON is a registered trademark of AMP INC.
SPECIFICATIONS
Housing: Molded plastic, charcoal gray only.
Pushbutton: Molded plastic; red, black and white standard.
"Adjusto-Clip" Mounting Frame: Copper alloy, plated.
Contact Springs: Copper alloy, plated.
Contacts: Integral, copper alloy, plated. 1-A, 1-C, 2-C
Switching: 250 mA, 30 W max., AC, non-inductive load.
Terminals: Copper alloy, silver-plated.
PART NUMBERS
Pushbutton Color/Part Number
Black
White
Solder Lug/Quick-Connect Terminals
BXR011
BXR021
BXR051
BXR013
BXR023
BXR053
BXR016
BXR026
BXR056
Red
Circuits
1-A
1-C
2-C
"ADJUSTO-CLIP" MOUNTING POSITIONS
Position Number
1*
2
3
4
5
Panel Thickness Inch (mm)
Minimum
Maximum
.047 (1.2)
.094 (2.4)
.094 (2.4)
.141 (3.6)
.141 (3.6)
.188 (4.8)
.188 (4.8)
.234 (6.0)
.234 (6.0)
.281 (7.1)
* "Adjusto-Clips" normally installed in this position unless
otherwise specified.
很抱歉,暂时无法提供与“BXR011”相匹配的价格&库存,您可以联系我们找货
