High Temperature DC Power Jacks & Plugs
NPB 637
New high temperature jacks and plugs from Switchcraft utilize a specially engineered, high RTI thermoplastic
capable of withstanding higher temperatures and current than our standard power jacks. This is ideal for
applications with a high ambient temperature and is better able to withstand the high temperatures introduced
by soldering than typical power jacks and plugs.
They are made in the USA using the same high quality components and procedures as our other power jacks
and plugs and are fully mateable with either high temperature or standard jacks and plugs from Switchcraft.
5555 N ELSTON AVE, CHICAGO, IL 60630 - 773.792.2700 - SALES@SWITCHCRAFT.COM
NPB 637
VISIT WWW.SWITCHCRAFT.COM FOR THE MOST UP-TO-DATE PRODUCT SPECIFICATIONS
NPB 637
SPECIFICATIONS
ELECTRICAL:
Voltage Rating:
Current Rating:
Insulation Resistance:
Contact Resistance:
Dielectric Withstanding:
MATERIAL (JACKS):
Bushing:
Terminals:
Hardware:
Electrical Insulator:
Contacts:
MATERIAL (PLUGS):
Plug Sleeve and Pin:
Lock Ring:
Lock Ring Thread Size:
Finger Insulator:
Insulating Washers:
Terminals:
Handle:
Handle Thread Size:
24V DC resistive
See current carry table on pg. 2
1,000 MΩ min.
0.01Ω max. (initial)
0.02Ω max. (after humidity/ durability)
0.10Ω max. (after salt spray)
500 VAC max.
Copper Alloy, nickel plated
Copper Alloy, silver plated
P2439 nickel plated copper alloy hex nut
P2441 nickel plated steel flat washer
High RTI Thermoplastic, Phenolic
Nickel-plated copper alloy.
5/16 - 32 UNEF 2B.
Phenolic
Copper alloy, electro-tinned.
5/16 - 24 UNF 2B.
MECHANICAL/ ENVIRONMENTAL:
Life:
5,000 insertion/withdrawal cycles min
Operating Forces:
3 pound maximum insertion
4 ounce minimum withdrawal
Temperature Limits:
-40°C to 105°C (-40°F to 221°F)
很抱歉,暂时无法提供与“722AH.”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+44.70732
- 10+42.80892
