BXR026
BXR026
    SWITCHCRAFT
    SW-6P_17.526X17.526MM_TM
    SWITCH PUSH DPDT 0.25A 115V
BXR026 数据手册
Harsh Environment Connectivity Solutions Square Pushbutton Switches, BXR Series Economical momentary, non-illuminated switches feature "Adjusto-Clip" snap-lock mounting and selection of switching. Bezel trims mounting and enclosed construction protects against dust, dirt, and physical damage. Color pushbuttons have concave face for positive "feel". MOUNTING Front mount in .620 inch (15.75 mm) minimum square hole. Solder lug/quick-connect terminals accept AMP FASTON® 110 terminals. "Adjusto-Clip" permits mounting in panels from .047 inch (1.19 mm) to .281 inch (7.14 mm) thick. ® FASTON is a registered trademark of AMP INC. SPECIFICATIONS Housing: Molded plastic, charcoal gray only. Pushbutton: Molded plastic; red, black and white standard. "Adjusto-Clip" Mounting Frame: Copper alloy, plated. Contact Springs: Copper alloy, plated. Contacts: Integral, copper alloy, plated. 1-A, 1-C, 2-C Switching: 250 mA, 30 W max., AC, non-inductive load. Terminals: Copper alloy, silver-plated. PART NUMBERS Pushbutton Color/Part Number Black White Solder Lug/Quick-Connect Terminals BXR011 BXR021 BXR051 BXR013 BXR023 BXR053 BXR016 BXR026 BXR056 Red Circuits 1-A 1-C 2-C "ADJUSTO-CLIP" MOUNTING POSITIONS Position Number 1* 2 3 4 5 Panel Thickness Inch (mm) Minimum Maximum .047 (1.2) .094 (2.4) .094 (2.4) .141 (3.6) .141 (3.6) .188 (4.8) .188 (4.8) .234 (6.0) .234 (6.0) .281 (7.1) * "Adjusto-Clips" normally installed in this position unless otherwise specified.
BXR026 价格&库存
很抱歉,暂时无法提供与“BXR026”相匹配的价格&库存,您可以联系我们找货
