15CL8MX
15CL8MX
    SWITCHCRAFT
15CL8MX 数据手册
Sign In Search Home About Us Products Applications Resources Contact Us Home > Industrial Products > Connectors > DIN > Locking DIN Cable Mount Male plug with ground key-rib. Unique 30° turn lockring securely fastens two halves of connector. Mates with lock flange female connectors and receptacles. Insert screw holds insert assembly in shell and also retains lockring on shell. Flexible black strain relief with 7/32" diameter cable entry. Heavy duty clamp. Questions? Contact Switchcraft Customer Support at 1-773-792-2700 Downloads: Produc t Desc ription 05CL3MX DIN Cable Mount Connector, Male plug with ground key-rib, 3 pins at 180° 05CL5MX DIN Cable Mount Connector, Male plug with ground key-rib, 5 pins at 180° 06EL5FX DIN Cable Mount Connector, female plug with ground contact, 5 contacts at 180° 09CL4MX DIN Cable Mount Connector, Male plug with ground key-rib, 4 pins at 210° 12CL5MX DIN Cable Mount Connector, Male plug with ground key-rib, 5 pins at 240° 13EL5FX DIN Connector Receptacle, female plug with ground contact, 5 contacts at 240° 15CL7MX DIN Cable Mount Connector, Male plug with ground key-rib, 7 pins at 270° 15CL8MX DIN Cable Mount Connector, Male plug with ground key-rib, 8 pins at 270° Specification Sheet Associated Products: DIN Right Angle PC Mount Receptacles DIN Panel Mount 5555 N Elston Avenue Chicago, IL 60630 USA 773-792-2700 Home Support Contact Us Login
15CL8MX 价格&库存
很抱歉,暂时无法提供与“15CL8MX”相匹配的价格&库存,您可以联系我们找货
