12GM6M
12GM6M
    SWITCHCRAFT
12GM6M 数据手册
Welcome to Switchcraft! Consistently Excellent since 1946! Last updated: 2/22/07 Previous Page | Return to Index | Next Page 5555 N. Elston Ave. Chicago, IL 60630 Phone: 773.792.2700 Fax: 773.792.2129 DIN PLUGS 1. STRAIGHT CORD PLUG with 30° lock ring 2. STRAIGHT CORD PLUG with Shielded Barrel click here to download a schematic drawing (you will need to have Adobe Acrobat installed on your system to do this) STRAIGHT CORD PLUG with 30° lock ring Type 05CL5M - typical: Male plug with ground key-rib. Unique 30° turn lockring securely fastens two halves of connector. Mates with lock flange female connectors and receptacles. Insert screw holds insert assembly in shell and also retains lockring on shell. Flexible black strain relief with 7/32" diameter cable entry. Heavy duty clamp. ORDERING INFORMATION Part Number Description Pin Arrangement 05CL3M 3 pins at 180° 2 05CL5M 5 pins at 180° 5 09CL4M 4 pins at 210° 3 12CL5M 5 pins at 240° 4 ¤15CL7M 7 pins at 270° 7 http://www.switchcraft.com/ (1 of 2)08/03/2007 02:25:22 • Welcome to Switchcraft! Consistently Excellent since 1946! ¤15CL8M 8 pins at 270° 8 STRAIGHT CORD PLUG with Shielded Barrel Type 15GM7M - typical: Male cord plug with shielded barrel and insulated snaplock plastic body. Two piece metal barrel surrounds pin insert to form an electrical shield. The entire insert assembly is held together by snapping the insulated plastic shell over the assembly. The barrel's special metal tab locks the shell in place. Standard color of plastic shell is gray. All-purpose cable clamp. ORDERING INFORMATION Part Number Description Pin Arrangement 05GM3M 3 pins at 180°, Gray body and strain relief. 2 05GM5M 5 pins at 180°, Gray body and strain relief 5 ¤09GM4M 4 pins at 210°, Gray body and strain relief 3 12GM5M 5 pins at 240°, Gray body and strain relief 4 ¤12GM6M 6 pins at 240°, Gray body and strain relief 6 15GM7M 7 pins at 270°, Gray body and strain relief 7 15GM8M 8 pins at 270°, Gray body and strain relief 8 ¤20GM8M 8 pins at 262°, Gray body and strain relief 10 ¤ Available on special order only; contact Switchcraft for price and delivery. SPECIFYING NOTE: Use letter "JL" in place of "GM" to order same part number with black housing. Previous Page | Return to Index | Next Page To search a category please click on the corresponding icon: | Connectors | Jacks and Plugs | | Patch Panels, Patch Kits & Jackfields | Cable Assemblies and Patch Cords | Switches | All products shown are covered by Switchcraft's limited lifetime warranty. | Switchcraft home | About Us | Products | What's New | Search | Contact Us http://www.switchcraft.com/ (2 of 2)08/03/2007 02:25:22 •
12GM6M 价格&库存
很抱歉,暂时无法提供与“12GM6M”相匹配的价格&库存,您可以联系我们找货
